[MOAB-dev] commit/MOAB: danwu: Applied new error handling code to a few places in Core.cpp and ReadParallel.cpp, to test serial or parallel read of climate .nc files (with errors returned) later.
commits-noreply at bitbucket.org commits-noreply at bitbucket.org
Fri Jul 11 15:42:28 CDT 2014
1 new commit in MOAB:
https://bitbucket.org/fathomteam/moab/commits/796093d0ea75/
Changeset:   796093d0ea75
Branch:      danwu/error_handling_enhancement
User:        danwu
Date:        2014-07-11 22:20:01
Summary:     Applied new error handling code to a few places in Core.cpp and ReadParallel.cpp, to test serial or parallel read of climate .nc files (with errors returned) later.
Affected #:  4 files
diff --git a/src/Core.cpp b/src/Core.cpp
index 0bd882f..01b5b9b 100644
--- a/src/Core.cpp
+++ b/src/Core.cpp
@@ -483,6 +483,7 @@ ErrorCode Core::load_file( const char* file_name,
       rval = ReadParallel(this,pcomm).load_file( file_name, file_set, opts, &sl );
     else
       rval = ReadParallel(this,pcomm).load_file( file_name, file_set, opts );
+    CHK_ERR(rval);
 #else
     mError->set_last_error( "PARALLEL option not valid, this instance"
                             " compiled for serial execution.\n" );
@@ -494,6 +495,7 @@ ErrorCode Core::load_file( const char* file_name,
       rval = serial_load_file( file_name, file_set, opts, &sl );
     else
       rval = serial_load_file( file_name, file_set, opts );
+    CHK_ERR(rval);
   if (MB_SUCCESS == rval && !opts.all_seen()) {
@@ -544,8 +546,9 @@ ErrorCode Core::serial_load_file( const char* file_name,
   status = stat(file_name, &stat_data);
 #endif
   if (status) {
-    mError->set_last_error( "%s: %s", file_name, strerror(errno) );
-    return MB_FILE_DOES_NOT_EXIST;
+    //mError->set_last_error( "%s: %s", file_name, strerror(errno) );
+    //return MB_FILE_DOES_NOT_EXIST;
+    SET_GLB_ERR_STR(MB_FILE_DOES_NOT_EXIST, file_name << ": " << strerror(errno));
 #if defined(WIN32) || defined(WIN64) || defined(MSC_VER)
   else if (_S_IFDIR(stat_data.st_mode)) {
@@ -608,6 +611,7 @@ ErrorCode Core::serial_load_file( const char* file_name,
   if (MB_SUCCESS != rval) {
     clean_up_failed_read( initial_ents, initial_tags );
+    SET_ERR(rval, "Failed to load file after trying all possible readers");
   else if (file_set) {
     Range new_ents;
diff --git a/src/Makefile.am b/src/Makefile.am
index f55d82c..bc3a8de 100644
--- a/src/Makefile.am
+++ b/src/Makefile.am
@@ -19,6 +19,7 @@ BUILT_SOURCES = MBCN_protos.h
 # Some variables
 AM_CPPFLAGS += -DIS_BUILDING_MB \
+               -DLOCDIR=src/ \
                -I. \
                -I$(srcdir)/io \
                -I$(srcdir)/io/mhdf/include \
diff --git a/src/parallel/Makefile.am b/src/parallel/Makefile.am
index b80b85e..5a39552 100644
--- a/src/parallel/Makefile.am
+++ b/src/parallel/Makefile.am
@@ -5,7 +5,7 @@ AUTOMAKE_OPTIONS = foreign
 noinst_LTLIBRARIES = libMOABpar.la
 # Some variables
-AM_CPPFLAGS += -DIS_BUILDING_MB -DSRCDIR=$(srcdir) \
+AM_CPPFLAGS += -DIS_BUILDING_MB -DSRCDIR=$(srcdir) -DLOCDIR=src/parallel/ \
                -I$(srcdir)/.. -I.. -I$(srcdir)/../io \
                -I$(srcdir)/../io/mhdf/include
diff --git a/src/parallel/ReadParallel.cpp b/src/parallel/ReadParallel.cpp
index fe4ed55..06faf6d 100644
--- a/src/parallel/ReadParallel.cpp
+++ b/src/parallel/ReadParallel.cpp
@@ -235,6 +235,7 @@ ErrorCode ReadParallel::load_file(const char **file_names,
                    reader_rank, cputime,
                    resolve_dim, shared_dim,
                    ghost_dim, bridge_dim, num_layers, addl_ents);
+  CHK_ERR(result);
   if (parallel_mode == POPT_BCAST_DELETE && !is_reader)
     opts.mark_all_seen();
@@ -519,11 +520,12 @@ ErrorCode ReadParallel::load_file(const char **file_names,
     if (MB_SUCCESS != tmp_result) {
       result = tmp_result;
       if (myPcomm->proc_config().proc_size() != 1) {
-        std::ostringstream ostr;
-        ostr << "Failed in step " << ParallelActionsNames[*vit] << std::endl;
-        std::string tmp_str;
-        if (MB_SUCCESS == mbImpl->get_last_error(tmp_str)) ostr << tmp_str << std::endl;
-        RR(ostr.str());
+        //std::ostringstream ostr;
+        //ostr << "Failed in step " << ParallelActionsNames[*vit] << std::endl;
+        //std::string tmp_str;
+        //if (MB_SUCCESS == mbImpl->get_last_error(tmp_str)) ostr << tmp_str << std::endl;
+        //RR(ostr.str());
+        SET_ERR_STR(result, "Failed in step " << ParallelActionsNames[*vit]);
       break;
Repository URL: https://bitbucket.org/fathomteam/moab/
This is a commit notification from bitbucket.org. You are receiving
this because you have the service enabled, addressing the recipient of
this email.
