[MOAB-dev] commit/MOAB: danwu: Adding example to simulate MOAB's enhanced error handling in parallel. All of the errors are contrived, used for simulation purpose only.
    commits-noreply at bitbucket.org
    Wed Jul  9 15:04:48 CDT 2014
1 new commit in MOAB:
https://bitbucket.org/fathomteam/moab/commits/6917d60bfb59/
Changeset:   6917d60bfb59
Branch:      danwu/error_handling_enhancement
User:        danwu
Date:        2014-07-09 22:04:17
Summary:     Adding example to simulate MOAB's enhanced error handling in parallel. All of the errors are contrived, used for simulation purpose only.
Affected #:  2 files
diff --git a/examples/ErrorHandlingSimulation.cpp b/examples/ErrorHandlingSimulation.cpp
new file mode 100644
index 0000000..ffdc831
--- /dev/null
+++ b/examples/ErrorHandlingSimulation.cpp
@@ -0,0 +1,100 @@
+/** @example ErrorHandlingSimulation.cpp
+ * Description: This example simulates MOAB's enhanced error handling in parallel. \n
+ * All of the errors are contrived, used for simulation purpose only. \n
+ * <b>To run</b>: mpiexec -np 4 ./ErrorHandlingSimulation <test_case_num(1 to 4)> \n
+#include "moab/ErrorHandler.hpp"
+#ifdef USE_MPI
+#include "moab_mpi.h"
+#endif
+#include <iostream>
+#include <stdlib.h>
+using namespace moab;
+using namespace std;
+// Functions that create and handle contrived errors
+// Call hierarchy: A calls B, and B calls C
+ErrorCode FunctionC(int test_case_num, int rank)
+  switch (test_case_num) {
+    case 1:
+      // Simulate a global fatal error MB_NOT_IMPLEMENTED on all processors
+      // Note, it is printed by root processor 0 only
+      SET_GLB_ERR(MB_NOT_IMPLEMENTED, "A contrived global error MB_NOT_IMPLEMENTED");
+      break;
+    case 2:
+      // Simulate a per-processor relevant error MB_INDEX_OUT_OF_RANGE on all processors
+      // Note, it is printed by all processors
+      SET_ERR_STR(MB_INDEX_OUT_OF_RANGE, "A contrived error MB_INDEX_OUT_OF_RANGE on processor " << rank);
+      break;
+    case 3:
+      // Simulate a per-processor relevant error MB_TYPE_OUT_OF_RANGE on all processors except root
+      // Note, it is printed by all non-root processors
+      if (0 != rank)
+        SET_ERR_STR(MB_TYPE_OUT_OF_RANGE, "A contrived error MB_TYPE_OUT_OF_RANGE on processor " << rank);
+      break;
+    case 4:
+      // Simulate a per-processor relevant error MB_INDEX_OUT_OF_RANGE on processor 1
+      // Note, it is printed by processor 1 only
+      if (1 == rank)
+        SET_ERR(MB_INDEX_OUT_OF_RANGE, "A contrived error MB_INDEX_OUT_OF_RANGE on processor 1");
+      // Simulate a per-processor relevant error MB_TYPE_OUT_OF_RANGE on processor 3
+      // Note, it is printed by processor 3 only
+      if (3 == rank)
+        SET_ERR(MB_TYPE_OUT_OF_RANGE, "A contrived error MB_TYPE_OUT_OF_RANGE on processor 3");
+      break;
+    default:
+      break;
+  return MB_SUCCESS;
+ErrorCode FunctionB(int test_case_num, int rank)
+  ErrorCode err_code = FunctionC(test_case_num, rank);CHK_ERR(err_code);
+ErrorCode FunctionA(int test_case_num, int rank)
+  ErrorCode err_code = FunctionB(test_case_num, rank);CHK_ERR(err_code);
+int main(int argc, char** argv)
+  if (argc < 2) {
+    cout << "Usage: " << argv[0] << " <test_case_num(1 to 4)>" << endl;
+    return 0;
+#ifdef USE_MPI
+  MPI_Init(&argc, &argv);
+#endif
+  MBErrorHandler_Init();
+  int test_case_num = atoi(argv[1]);
+  int rank = 0;
+#ifdef USE_MPI
+  MPI_Comm_rank(MPI_COMM_WORLD, &rank);
+#endif
+  ErrorCode rval = FunctionA(test_case_num, rank);CHK_ERR(rval);
+  MBErrorHandler_Finalize();
+#ifdef USE_MPI
+  MPI_Finalize();
+#endif
+  return 0;
diff --git a/examples/makefile b/examples/makefile
index 787c8d3..c4dd9e7 100644
--- a/examples/makefile
+++ b/examples/makefile
@@ -11,8 +11,9 @@ EXAMPLES = HelloMOAB GetEntities SetsNTags LoadPartial structuredmesh Structured
 PAREXAMPLES = HelloParMOAB ReduceExchangeTags LloydRelaxation CrystalRouterExample
 EXOIIEXAMPLES = TestExodusII
 F90EXAMPLES = DirectAccessNoHolesF90 PushParMeshIntoMoabF90
+ERROREXAMPLES = ErrorHandlingSimulation
-default: ${EXAMPLES} ${PAREXAMPLES} ${EXOIIEXAMPLES} ${F90EXAMPLES}
+default: ${EXAMPLES} ${PAREXAMPLES} ${EXOIIEXAMPLES} ${F90EXAMPLES} ${ERROREXAMPLES}
 HelloMOAB: HelloMOAB.o ${MOAB_LIBDIR}/libMOAB.la
 	${MOAB_CXX} -o $@ $< ${MOAB_LIBS_LINK}
@@ -70,9 +71,12 @@ VisTags: VisTags.o ${MOAB_LIBDIR}/libMOAB.la
 ReadWriteTest: ReadWriteTest.o ${MOAB_LIBDIR}/libMOAB.la
+ErrorHandlingSimulation: ErrorHandlingSimulation.o ${MOAB_LIBDIR}/libMOAB.la
+	${MOAB_CXX} -o $@ $< ${MOAB_LIBS_LINK}
 clean:
-	rm -rf *.o *.mod *.h5m ${EXAMPLES} ${PAREXAMPLES} ${EXOIIEXAMPLES} ${F90EXAMPLES}
+	rm -rf *.o *.mod *.h5m ${EXAMPLES} ${PAREXAMPLES} ${EXOIIEXAMPLES} ${F90EXAMPLES} ${ERROREXAMPLES}
 .cpp.o:
 	${MOAB_CXX} ${CXXFLAGS} ${MOAB_CXXFLAGS} ${MOAB_CPPFLAGS} ${MOAB_INCLUDES} -DMESH_DIR=\"${MESH_DIR}\" -c $<
Repository URL: https://bitbucket.org/fathomteam/moab/
This is a commit notification from bitbucket.org. You are receiving
this because you have the service enabled, addressing the recipient of
this email.
