[MOAB-dev] commit/MOAB: 7 new changesets
commits-noreply at bitbucket.org
Wed Jul 9 10:54:32 CDT 2014
7 new commits in MOAB:
https://bitbucket.org/fathomteam/moab/commits/513fc2d8aa64/
Changeset: 513fc2d8aa64
Branch: None
User: nray
Date: 2014-07-09 17:54:12
Summary: Added the HalfFacetRep class and one test code.
Affected #: 7 files
diff --git a/MeshFiles/unittest/Makefile.am b/MeshFiles/unittest/Makefile.am
index bc4f522..2bd2a8a 100644
--- a/MeshFiles/unittest/Makefile.am
+++ b/MeshFiles/unittest/Makefile.am
@@ -34,5 +34,6 @@ EXTRA_DIST = 125hex.g \
BedCrop2.h5m \
mpas_p8.h5m \
Homme_2pt.h5m \
- surfrandomtris-4part.h5m
+ surfrandomtris-4part.h5m \
+ hexes_mixed.vtk
diff --git a/MeshFiles/unittest/hexes_mixed.vtk b/MeshFiles/unittest/hexes_mixed.vtk
new file mode 100755
index 0000000..8ee5c11
--- /dev/null
+++ b/MeshFiles/unittest/hexes_mixed.vtk
@@ -0,0 +1,45 @@
+# vtk DataFile Version 3.0
+This file was written using writevtk_unstr.m
+ASCII
+DATASET UNSTRUCTURED_GRID
+POINTS 18 double
+0 -1 0
+0 1 0
+1 -1 0
+1 1 0
+-1 1 0
+-1 -1 0
+0 -1 1
+0 1 1
+1 -1 1
+1 1 1
+-1 1 1
+-1 -1 1
+0 -1 -1
+0 1 -1
+1 -1 -1
+1 1 -1
+-1 1 -1
+-1 -1 -1
+CELLS 9 59
+2 0 1
+4 0 1 7 6
+4 0 2 3 1
+4 0 12 13 1
+4 0 1 4 5
+8 0 2 3 1 6 8 9 7
+8 5 0 1 4 11 6 7 10
+8 12 14 15 13 0 2 3 1
+8 17 12 13 16 5 0 1 4
+CELL_TYPES 9
+3
+9
+9
+9
+9
+12
+12
+12
+12
This diff is so big that we needed to truncate the remainder.
https://bitbucket.org/fathomteam/moab/commits/c700d35c2415/
Changeset: c700d35c2415
Branch: None
User: nray
Summary: Added interface to AHF functionalities through the get_adjacencies
functions.
Affected #: 10 files
diff --git a/configure.ac b/configure.ac
index 890f70d..b0905cf 100644
--- a/configure.ac
+++ b/configure.ac
@@ -657,6 +657,13 @@ MB_OPTIONAL_TOOL([mbdepth], [yes])
MB_OPTIONAL_TOOL([refiner], [no])
MB_OPTIONAL_TOOL([h5mtools], [yes])
MB_OPTIONAL_TOOL([mbcslam], [no])
+MB_OPTIONAL_TOOL([ahf], [no])
+if test "xyes" = "x$ENABLE_ahf"; then
+ AM_CPPFLAGS="$AM_CPPFLAGS -DUSE_AHF"
+fi
if test "xyes" = "x$ENABLE_refiner"; then
if test "xyes" != "x$WITH_MPI"; then
@@ -1333,3 +1340,27 @@ if test "x$WARN_PARALLEL_HDF5_NO_COMPLEX" = "xyes"; then
fi
+# AHF OPTIONS
+#AC_ARG_ENABLE([ahf],
+#[AC_HELP_STRING([--enable-ahf],[use the half facet representation])],
+#[ case "${enableval}" in
+# yes) ahf1=true ;;
+# no) ahf1=false ;;
+# *) AC_MSG_ERROR([bad value]) ;;
+#esac],[ahf1=false])
+ #ENABLE_AHF=$enableval],[ENABLE_AHF=no] )
+#if test "x$ENABLE_AHF" = "xyes"; then
+# AM_CPPFLAGS="$AM_CPPFLAGS -DUSE_AHF"
+#fi
+#AM_CONDITIONAL([ENABLE_AHF],[test x$ahf1 = xtrue])
+#AC_SUBST(ENABLE_AHF)
+#test "xyes" != "x$WITH_AHF" || AM_CPPFLAGS="$AM_CPPFLAGS -DUSE_AHF"
+#AM_CONDITIONAL(USE_AHF, [test "xno" != "x$WITH_AHF"])
diff --git a/src/Core.cpp b/src/Core.cpp
index 0bd882f..3641fd5 100644
--- a/src/Core.cpp
+++ b/src/Core.cpp
@@ -56,6 +56,10 @@
#include <errno.h>
#include <string.h>
+#ifdef USE_AHF
+#include "moab/HalfFacetRep.hpp"
+#endif
#ifdef USE_MPI
/* Leave ParallelComm.hpp before mpi.h or MPICH2 will fail
* because its C++ headers do not like SEEK_* macros.
@@ -272,6 +276,12 @@ ErrorCode Core::initialize()
geom_dimension_tag();
globalId_tag();
+#ifdef USE_AHF
+ ahfRep = new HalfFacetRep(this);
+ if (!ahfRep)
+ return MB_MEMORY_ALLOCATION_FAILED;
+#endif
return MB_SUCCESS;
@@ -322,6 +332,11 @@ void Core::deinitialize()
if (mpiFinalize)
MPI_Finalize();
#endif
+#ifdef USE_AHF
+ delete ahfRep;
+ ahfRep = 0;
+#endif
ErrorCode Core::query_interface_type( const std::type_info& type, void*& ptr )
@@ -1338,6 +1353,80 @@ ErrorCode get_adjacencies_union( Core* gMB,
return result;
+#ifdef USE_AHF
+template <typename ITER> static inline
+ErrorCode get_adjacencies_intersection_ahf(Core *mb,
+ ITER begin, ITER end,
+ const int to_dimension,
+ std::vector<EntityHandle>& adj_entities )
+ const size_t SORT_THRESHOLD = 200;
+ std::vector<EntityHandle> temp_vec;
+ std::vector<EntityHandle>::iterator adj_it, w_it;
+ ErrorCode result = MB_SUCCESS;
+ if (begin == end) {
+ adj_entities.clear(); // intersection
+ return MB_SUCCESS;
+ // First iteration is a special case if input list is empty.
+ // Rather than returning nothing (intersecting with empty
+ // input list), we begin with the adjacencies for the first entity.
+ if (adj_entities.empty()) {
+ EntityType type = TYPE_FROM_HANDLE(*begin);
+ if(to_dimension == 0 && type != MBPOLYHEDRON)
+ result = mb->get_connectivity(&(*begin), 1, adj_entities);
+ else
+ result = mb->a_half_facet_rep()->get_adjacencies(*begin, to_dimension, adj_entities);
+ if (MB_SUCCESS != result)
+ return result;
+ ++begin;
+ for (ITER from_it = begin; from_it != end; from_it++)
+ // running results kept in adj_entities; clear temp_vec, which is working space
+ temp_vec.clear();
+ // get the next set of adjacencies
+ EntityType type = TYPE_FROM_HANDLE(*from_it);
+ result = mb->get_connectivity(&(*from_it), 1, temp_vec);
+ else
+ result = mb->a_half_facet_rep()->get_adjacencies(*from_it, to_dimension, temp_vec);
+ return result;
+ // otherwise intersect with the current set of results
+ w_it = adj_it = adj_entities.begin();
+ if (temp_vec.size()*adj_entities.size() < SORT_THRESHOLD) {
+ for (; adj_it != adj_entities.end(); ++adj_it)
+ if (std::find(temp_vec.begin(), temp_vec.end(), *adj_it) != temp_vec.end())
+ { *w_it = *adj_it; ++w_it; }
+ else {
+ std::sort( temp_vec.begin(), temp_vec.end() );
+ if (std::binary_search(temp_vec.begin(), temp_vec.end(), *adj_it))
+ adj_entities.erase( w_it, adj_entities.end() );
+ // we're intersecting, so if there are no more results, we're done
+ break;
+#endif
ErrorCode get_adjacencies_intersection( Core* mb,
@@ -1445,37 +1534,116 @@ ErrorCode Core::get_adjacencies( const EntityHandle *from_entities,
const bool create_if_missing,
std::vector<EntityHandle> &adj_entities,
- const int operation_type )
+ const int operation_type
+#ifdef USE_AHF
+ , const bool use_ahf)
+#else
+#endif
- if (operation_type == Interface::INTERSECT)
- return get_adjacencies_intersection( this, from_entities, from_entities+num_entities,
- to_dimension, create_if_missing, adj_entities );
- else if (operation_type != Interface::UNION)
- return MB_FAILURE;
- // do union
- ErrorCode result;
- std::vector<EntityHandle> tmp_storage;
- const EntityHandle* conn;
- int len;
- for (int i = 0; i < num_entities; ++i) {
- if(to_dimension == 0 && TYPE_FROM_HANDLE(from_entities[0]) != MBPOLYHEDRON) {
- result = get_connectivity(from_entities[i], conn, len, false, &tmp_storage);
- adj_entities.insert( adj_entities.end(), conn, conn+len );
- if (MB_SUCCESS != result)
- return result;
+#ifdef USE_AHF
+ bool can_handle = true;
+ int source_dim = this->dimension_from_handle(from_entities[0]);
+ if ((source_dim > to_dimension) && (to_dimension != 0))
+ std::cout<<"Currently Not Supported by MOAB_AHF: Down Adjacencies"<<std::endl;
+ std::cout<<"Reverting to MOAB adjacency functionality"<<std::endl;
+ can_handle = false;
- else {
- result = aEntityFactory->get_adjacencies(from_entities[i], to_dimension,
- create_if_missing, adj_entities);
- return result;
+ else if (((source_dim == 0) && (to_dimension == 2))||((source_dim == 0) && (to_dimension == 3)))
+ std::cout<<"Currently Not Supported by MOAB_AHF: Vertex to face/cell"<<std::endl;
+ else if (TYPE_FROM_HANDLE(from_entities[0]) == MBPOLYHEDRON)
+ std::cout<<"Currently Not Supported by MOAB_AHF: Polyhedron Meshes"<<std::endl;
+ else if (create_if_missing)
+ std::cout<<"Currently Not Supporteded by MOAB_AHF: create_if_missing capability "<<std::endl;
- std::sort( adj_entities.begin(), adj_entities.end() );
- adj_entities.erase( std::unique( adj_entities.begin(), adj_entities.end() ), adj_entities.end() );
- return MB_SUCCESS;
+ if ((use_ahf) && (can_handle))
+ if (operation_type == Interface::INTERSECT)
+ return get_adjacencies_intersection_ahf(this, from_entities, from_entities+num_entities,
+ to_dimension, adj_entities );
+ else if (operation_type != Interface::UNION)
+ return MB_FAILURE;
+ // do union
+ ErrorCode result;
+ std::vector<EntityHandle> tmp_storage;
+ const EntityHandle* conn;
+ int len;
+ for (int i = 0; i < num_entities; ++i) {
+ if(to_dimension == 0 && TYPE_FROM_HANDLE(from_entities[0]) != MBPOLYHEDRON) {
+ result = get_connectivity(from_entities[i], conn, len, false, &tmp_storage);
+ adj_entities.insert( adj_entities.end(), conn, conn+len );
+ return result;
+ else {
+ result = ahfRep->get_adjacencies(from_entities[i], to_dimension, adj_entities);
+ return result;
+ std::sort( adj_entities.begin(), adj_entities.end() );
+ adj_entities.erase( std::unique( adj_entities.begin(), adj_entities.end() ), adj_entities.end() );
+ else
+#endif
+ return get_adjacencies_intersection( this, from_entities, from_entities+num_entities,
+ to_dimension, create_if_missing, adj_entities );
+ // do union
+ ErrorCode result;
+ int len;
+ return result;
+ else {
+ result = aEntityFactory->get_adjacencies(from_entities[i], to_dimension,
+ create_if_missing, adj_entities);
+ return result;
+ //return MB_SUCCESS;
+#ifdef USE_AHF
+#endif
+return MB_SUCCESS;
diff --git a/src/HalfFacetRep.cpp b/src/HalfFacetRep.cpp
index 95efb7e..f3818a6 100755
--- a/src/HalfFacetRep.cpp
+++ b/src/HalfFacetRep.cpp
@@ -17,21 +17,32 @@
#pragma warning (disable : 4786)
#endif
#include <iostream>
#include <assert.h>
-#include <time.h>
#include <vector>
-#include <queue>
-#include <stack>
#include "moab/Core.hpp"
#include "moab/Range.hpp"
#include "moab/CN.hpp"
-#include "moab/HalfFacetRep.hpp"
namespace moab {
const int MAXSIZE = 500;
+ HalfFacetRep::HalfFacetRep(Core *impl)
+ assert(NULL != impl);
+ mb = impl;
+ mInitAHFmaps = false;
+ HalfFacetRep::~HalfFacetRep()
+ ErrorCode result;
+ result = deinitialize();
+ //if (MB_SUCCESS != result) return result;
MESHTYPE HalfFacetRep::get_mesh_type(int nverts, int nedges, int nfaces, int ncells)
MESHTYPE mesh_type;
@@ -58,7 +69,9 @@ namespace moab {
* initialize *
- ErrorCode HalfFacetRep::initialize(){
+ ErrorCode HalfFacetRep::initialize()
+ mInitAHFmaps = true;
ErrorCode error;
@@ -436,36 +449,100 @@ namespace moab {
* User interface for adjacency functions *
- ErrorCode HalfFacetRep::get_upward_incidences(EntityHandle ent, int out_dim, std::vector<EntityHandle> &adjents, bool local_id, std::vector<int> * lids)
+ ErrorCode HalfFacetRep::get_adjacencies(const EntityHandle source_entity,
+ const unsigned int target_dimension,
+ std::vector<EntityHandle> &target_entities)
+ ErrorCode error;
+ unsigned int source_dimension = mb->dimension_from_handle(source_entity);
+ if (mInitAHFmaps == false)
+ error = initialize();
+ if (MB_SUCCESS != error) return error;
+ if ((source_dimension == 0) && (target_dimension == 1))
+ error = get_up_adjacencies_1d(source_entity, target_entities);
+ else if ((source_dimension == 1) && (target_dimension == 2))
+ error = get_up_adjacencies_2d(source_entity, target_entities);
+ else if ((source_dimension == 1) && (target_dimension == 3))
+ error = get_up_adjacencies_edg_3d(source_entity, target_entities);
+ else if ((source_dimension == 2) && (target_dimension ==3))
+ error = get_up_adjacencies_face_3d(source_entity, target_entities);
+ else if (source_dimension == target_dimension)
+ if (target_dimension == 1)
+ error = get_neighbor_adjacencies_1d(source_entity, target_entities);
+ else if (target_dimension == 2)
+ error = get_neighbor_adjacencies_2d(source_entity, target_entities);
+ else if (target_dimension == 3)
+ error = get_neighbor_adjacencies_3d(source_entity, target_entities);
+ ErrorCode HalfFacetRep::get_up_adjacencies(EntityHandle ent,
+ int out_dim,
+ std::vector<EntityHandle> &adjents,
+ bool local_id,
+ std::vector<int> * lids)
ErrorCode error;
int in_dim = mb->dimension_from_handle(ent);
if ((in_dim == 0) && (out_dim == 1))
- error = get_upward_incidences_1d(ent, adjents, local_id, lids);
+ error = get_up_adjacencies_1d(ent, adjents, local_id, lids);
else if ((in_dim == 1) && (out_dim == 2))
- error = get_upward_incidences_2d(ent, adjents, local_id, lids);
+ error = get_up_adjacencies_2d(ent, adjents, local_id, lids);
else if ((in_dim == 1) && (out_dim == 3))
- error = get_upward_incidences_edg_3d(ent, adjents, local_id, lids);
+ error = get_up_adjacencies_edg_3d(ent, adjents, local_id, lids);
else if ((in_dim == 2) && (out_dim ==3))
- error = get_upward_incidences_face_3d(ent, adjents, local_id, lids);
+ error = get_up_adjacencies_face_3d(ent, adjents, local_id, lids);
return MB_SUCCESS;
- ErrorCode HalfFacetRep::get_neighbor_adjacencies(EntityHandle ent, std::vector<EntityHandle> &adjents)
+ ErrorCode HalfFacetRep::get_neighbor_adjacencies(EntityHandle ent,
+ std::vector<EntityHandle> &adjents)
ErrorCode error;
@@ -619,8 +696,11 @@ namespace moab {
return MB_SUCCESS;
- ErrorCode HalfFacetRep::get_upward_incidences_1d( EntityHandle vid, std::vector< EntityHandle > &adjents, bool local_id, std::vector<int> * lvids){
- ErrorCode error;
+ ErrorCode HalfFacetRep::get_up_adjacencies_1d( EntityHandle vid,
+ std::vector< EntityHandle > &adjents,
+ bool local_id,
+ std::vector<int> * lvids){
+ ErrorCode error;
EntityHandle start_eid, eid, sibeid[2];
int start_lid, lid, siblid[2];
@@ -655,7 +735,8 @@ namespace moab {
return MB_SUCCESS;
- ErrorCode HalfFacetRep::get_neighbor_adjacencies_1d( EntityHandle eid, std::vector<EntityHandle> &adjents){
+ ErrorCode HalfFacetRep::get_neighbor_adjacencies_1d( EntityHandle eid,
+ std::vector<EntityHandle> &adjents){
ErrorCode error;
@@ -912,9 +993,65 @@ namespace moab {
return MB_SUCCESS;
+ /* ErrorCode HalfFacetRep::get_up_adjacencies_2d(EntityHandle vid, std::vector<EntityHandle> &adjents)
+ ErrorCode error;
+ EntityHandle fid; int lid;
+ error = mb->tag_get_data(v2he_fid, &vid, 1, &fid);
+ error = mb->tag_get_data(v2he_leid, &vid, 1, &lid);
+ if (fid != 0)
+ adjents.push_back(fid);
+ EntityHandle queue_fid[MAXSIZE], trackfaces[MAXSIZE];
+ int queue_lid[MAXSIZE];
+ for (int i = 0; i< MAXSIZE; i++)
+ queue_fid[i] = 0;
+ queue_lid[i] = 0;
+ trackfaces[i] = 0;
+ int qsize = 0, tcount = -1;
+ int num_qvals = 0;
+ error = gather_halfedges(vid, fid, lid, queue_fid, queue_lid, &qsize, trackfaces, &tcount);
+ while (num_qvals < *qsize)
+ EntityHandle curfid = queue_fid[num_qvals];
+ int curlid = queue_lid[num_qvals];
+ num_qvals += 1;
+ EntityHandle he2_fid; int he2_lid;
+ error = another_halfedge(vid, curfid, curlid, &he2_fid, &he2_lid);
+ bool found_ent = find_match_in_array(he2_fid, trackfaces, tcount[0]);
+ if (found_ent)
+ continue;
+ tcount[0] += 1;
+ trackfaces[tcount[0]] = he2_fid;
+ error = get_up_adjacencies_2d(he2_fid, he2_lid, queue_fid, queue_lid, qsize, trackfaces, tcount);
+ adjents.push_back(he2_fid);
- ErrorCode HalfFacetRep::get_upward_incidences_2d( EntityHandle eid, std::vector<EntityHandle> &adjents, bool local_id, std::vector<int> * leids)
+ ErrorCode HalfFacetRep::get_up_adjacencies_2d( EntityHandle eid,
+ bool local_id,
+ std::vector<int> * leids)
// Given an explicit edge eid, find the incident faces.
@@ -928,7 +1065,7 @@ namespace moab {
// Step 2: If there is a corresponding half-edge, collect all sibling half-edges and store the incident faces.
if (found)
- error = get_upward_incidences_2d(he_fid, he_lid, true, adjents, local_id, leids);
+ error = get_up_adjacencies_2d(he_fid, he_lid, true, adjents, local_id, leids);
@@ -936,7 +1073,12 @@ namespace moab {
- ErrorCode HalfFacetRep::get_upward_incidences_2d( EntityHandle fid, int leid, bool add_inent, std::vector<EntityHandle> &fids, bool local_id, std::vector<int> * leids)
+ ErrorCode HalfFacetRep::get_up_adjacencies_2d( EntityHandle fid,
+ int leid,
+ bool add_inent,
+ std::vector<EntityHandle> &fids,
+ bool local_id,
// Given an implicit half-edge <fid, leid>, find the incident half-edges.
ErrorCode error;
@@ -982,7 +1124,13 @@ namespace moab {
- ErrorCode HalfFacetRep::get_upward_incidences_2d(EntityHandle fid, int lid, EntityHandle *queue_fid, int *queue_lid, int *qsize, EntityHandle *trackfaces, int *tcount)
+ ErrorCode HalfFacetRep::get_up_adjacencies_2d(EntityHandle fid,
+ int lid,
+ EntityHandle *queue_fid,
+ int *queue_lid,
+ int *qsize,
+ EntityHandle *trackfaces,
+ int *tcount)
ErrorCode error;
@@ -1035,7 +1183,9 @@ namespace moab {
- bool HalfFacetRep::find_matching_halfedge( EntityHandle eid, EntityHandle *hefid, int *helid){
+ bool HalfFacetRep::find_matching_halfedge( EntityHandle eid,
+ EntityHandle *hefid,
+ int *helid){
ErrorCode error;
std::vector<EntityHandle> conn(2);
error = mb->get_connectivity(&eid, 1, conn);
@@ -1071,7 +1221,14 @@ namespace moab {
return found;
- ErrorCode HalfFacetRep::gather_halfedges( EntityHandle vid, EntityHandle he_fid, int he_lid, EntityHandle *queue_fid, int *queue_lid, int *qsize, EntityHandle *trackfaces, int *tcount)
+ ErrorCode HalfFacetRep::gather_halfedges( EntityHandle vid,
+ EntityHandle he_fid,
+ int he_lid,
+ int *queue_lid,
+ int *qsize,
+ int *tcount)
ErrorCode error;
EntityHandle he2_fid = 0; int he2_lid = 0;
@@ -1086,16 +1243,20 @@ namespace moab {
tcount[0] += 1;
trackfaces[tcount[0]] = he_fid;
- error = get_upward_incidences_2d(he_fid, he_lid, queue_fid, queue_lid, qsize, trackfaces, tcount);
+ error = get_up_adjacencies_2d(he_fid, he_lid, queue_fid, queue_lid, qsize, trackfaces, tcount);
- error = get_upward_incidences_2d(he2_fid, he2_lid, queue_fid, queue_lid, qsize, trackfaces, tcount);
return MB_SUCCESS;
- ErrorCode HalfFacetRep::another_halfedge( EntityHandle vid, EntityHandle he_fid, int he_lid, EntityHandle *he2_fid, int *he2_lid)
+ ErrorCode HalfFacetRep::another_halfedge( EntityHandle vid,
+ int he_lid,
+ EntityHandle *he2_fid,
+ int *he2_lid)
ErrorCode error;
int nepf;
@@ -1121,7 +1282,14 @@ namespace moab {
- bool HalfFacetRep::collect_and_compare(std::vector<EntityHandle> &edg_vert, EntityHandle *queue_fid, int *queue_lid, int *qsize, EntityHandle *trackfaces, int *tcount, EntityHandle *he_fid, int *he_lid)
+ bool HalfFacetRep::collect_and_compare(std::vector<EntityHandle> &edg_vert,
+ int *queue_lid,
+ int *qsize,
+ int *tcount,
+ EntityHandle *he_fid,
+ int *he_lid)
ErrorCode error;
int nepf = local_maps_2d(*_faces.begin());
@@ -1162,7 +1330,7 @@ namespace moab {
error = another_halfedge(edg_vert[0], curfid, curlid, &he2_fid, &he2_lid);
counter += 1;
@@ -1174,14 +1342,15 @@ namespace moab {
- ErrorCode HalfFacetRep::get_neighbor_adjacencies_2d( EntityHandle fid, std::vector<EntityHandle> &adjents)
+ ErrorCode HalfFacetRep::get_neighbor_adjacencies_2d( EntityHandle fid,
ErrorCode error;
if (fid != 0){
int nepf = local_maps_2d(fid);
for (int lid = 0; lid < nepf; ++lid){
- error = get_upward_incidences_2d(fid, lid, false, adjents);
+ error = get_up_adjacencies_2d(fid, lid, false, adjents);
@@ -1212,7 +1381,7 @@ namespace moab {
int id = nepf*(*f-firstF)+l;
if (!trackF[id])
- error = get_upward_incidences_2d(*f,l, false, adj_fids, true, &adj_lids);
+ error = get_up_adjacencies_2d(*f,l, false, adj_fids, true, &adj_lids);
total_edges -= adj_fids.size();
@@ -1530,7 +1699,10 @@ namespace moab {
- ErrorCode HalfFacetRep::get_upward_incidences_edg_3d( EntityHandle eid, std::vector<EntityHandle> &adjents, bool local_id, std::vector<int> * leids)
+ ErrorCode HalfFacetRep::get_up_adjacencies_edg_3d( EntityHandle eid,
+ bool local_id,
ErrorCode error;
@@ -1542,7 +1714,7 @@ namespace moab {
//Find all incident cells
if (found)
- error =get_upward_incidences_edg_3d(cid, leid, adjents, local_id, leids);
+ error =get_up_adjacencies_edg_3d(cid, leid, adjents, local_id, leids);
@@ -1550,7 +1722,11 @@ namespace moab {
- ErrorCode HalfFacetRep::get_upward_incidences_edg_3d( EntityHandle cid, int leid, std::vector<EntityHandle> &adjents, bool local_id, std::vector<int> * leids)
+ ErrorCode HalfFacetRep::get_up_adjacencies_edg_3d( EntityHandle cid,
+ int leid,
+ bool local_id,
ErrorCode error;
@@ -1648,7 +1824,10 @@ namespace moab {
- ErrorCode HalfFacetRep::get_upward_incidences_face_3d( EntityHandle fid, std::vector<EntityHandle> &adjents, bool local_id, std::vector<int> * lfids)
+ ErrorCode HalfFacetRep::get_up_adjacencies_face_3d( EntityHandle fid,
+ bool local_id,
+ std::vector<int> * lfids)
ErrorCode error;
@@ -1657,14 +1836,18 @@ namespace moab {
bool found = find_matching_halfface(fid, &cid, &lid);
if (found){
- error = get_upward_incidences_face_3d(cid, lid, adjents, local_id, lfids);
+ error = get_up_adjacencies_face_3d(cid, lid, adjents, local_id, lfids);
return MB_SUCCESS;
- ErrorCode HalfFacetRep::get_upward_incidences_face_3d( EntityHandle cid, int lfid, std::vector<EntityHandle> &adjents, bool local_id, std::vector<int> * lfids)
+ ErrorCode HalfFacetRep::get_up_adjacencies_face_3d( EntityHandle cid,
+ int lfid,
+ bool local_id,
ErrorCode error;
@@ -1701,7 +1884,9 @@ namespace moab {
return MB_SUCCESS;
- bool HalfFacetRep::find_matching_implicit_edge_in_cell( EntityHandle eid, EntityHandle *cid, int *leid)
+ bool HalfFacetRep::find_matching_implicit_edge_in_cell( EntityHandle eid,
+ EntityHandle *cid,
+ int *leid)
ErrorCode error;
diff --git a/src/Makefile.am b/src/Makefile.am
index e2bf713..6fac039 100644
--- a/src/Makefile.am
+++ b/src/Makefile.am
@@ -226,6 +226,12 @@ if HAVE_CGM
AM_CPPFLAGS += @CGM_CPPFLAGS@ -DCGM @MOAB_CGM_DEFINES@
endif
+# if ENABLE_ahf
+ # libMOAB_la_SOURCES += HalfFacetRep.cpp
+ # nobase_libMOAB_la_include_HEADERS += moab/HalfFacetRep.hpp
+# AM_CPPFLAGS += -DUSE_AHF
+# endif
MBCN_protos.h: MBCN.h $(top_srcdir)/itaps/mkprotos.sh
$(AM_V_GEN)$(top_srcdir)/itaps/mkprotos.sh MBCN MOAB $< $@ MOAB_FCDefs.h
diff --git a/src/moab/Core.hpp b/src/moab/Core.hpp
index aa7d9da..941129a 100644
--- a/src/moab/Core.hpp
+++ b/src/moab/Core.hpp
@@ -35,6 +35,10 @@ class EntitySequence;
class FileOptions;
class SetIterator;
+#ifdef USE_AHF
+class HalfFacetRep;
+#endif
#ifdef XPCOM_MB
#define MBCORE_CID \
@@ -311,12 +315,18 @@ public:
get_adjacencies( from_entities, MB_1D_ENTITY, adjacencies );
\endcode */
- virtual ErrorCode get_adjacencies(const EntityHandle *from_entities,
- const int num_entities,
- const int to_dimension,
- const bool create_if_missing,
- std::vector<EntityHandle>& adj_entities,
- const int operation_type = Interface::INTERSECT);
+ virtual ErrorCode get_adjacencies(const EntityHandle *from_entities,
+ const int num_entities,
+ const bool create_if_missing,
+ std::vector<EntityHandle>& adj_entities,
+ const int operation_type = Interface::INTERSECT
+ #ifdef USE_AHF
+ , const bool use_ahf = false);
+ #else
+ #endif
@@ -1126,7 +1136,12 @@ public:
//! return the a_entity_factory pointer
AEntityFactory *a_entity_factory() { return aEntityFactory; }
const AEntityFactory *a_entity_factory() const { return aEntityFactory; }
+#ifdef USE_AHF
+ HalfFacetRep *a_half_facet_rep() { return ahfRep; }
+ const HalfFacetRep *a_half_facet_rep() const {return ahfRep; }
+#endif
//! return set of registered IO tools
ReaderWriterSet* reader_writer_set() { return readerWriterSet; }
@@ -1347,6 +1362,10 @@ private:
//! list of iterators
std::vector<SetIterator*> setIterators;
+#ifdef USE_AHF
+ HalfFacetRep *ahfRep;
+#endif
diff --git a/src/moab/HalfFacetRep.hpp b/src/moab/HalfFacetRep.hpp
index eca5e91..3d1069a 100755
--- a/src/moab/HalfFacetRep.hpp
+++ b/src/moab/HalfFacetRep.hpp
@@ -52,14 +52,15 @@ namespace moab {
VOLUME_MIXED //Volume mesh with embedded curves and surfaces
+ class Core;
class HalfFacetRep{
public:
- HalfFacetRep(Interface *impl) : mb(impl) {}
+ HalfFacetRep(Core *impl);
- ~HalfFacetRep() {}
+ ~HalfFacetRep();
// User interface functions
@@ -74,6 +75,12 @@ namespace moab {
//! Prints the tag values.
ErrorCode print_tags();
+ ErrorCode get_adjacencies(const EntityHandle source_entity,
+ std::vector<EntityHandle> &target_entities);
//! Get the upward incidences associated with an entity.
/** Given an entity of dimension <em>d</em>, gather all the incident <em>D(>d)</em> dimensional entities.
* Parameters:
@@ -84,7 +91,11 @@ namespace moab {
* \param lids Vector in which the local id's are returned.
- ErrorCode get_upward_incidences(EntityHandle ent, int out_dim, std::vector<EntityHandle> &adjents, bool local_id = false, std::vector<int> * lids = NULL );
+ ErrorCode get_up_adjacencies(EntityHandle ent,
+ int out_dim,
+ bool local_id = false,
+ std::vector<int> * lids = NULL );
//! Get the same-dimensional entities connected with an entity.
/** Given an entity of dimension <em>d</em>, gather all the entities connected via <em>d-1</em> dimensional entities.
@@ -94,7 +105,8 @@ namespace moab {
* \param adjents Vector in which the neighbor entities are returned.
- ErrorCode get_neighbor_adjacencies(EntityHandle ent, std::vector<EntityHandle> &adjents);
+ ErrorCode get_neighbor_adjacencies(EntityHandle ent,
+ std::vector<EntityHandle> &adjents);
// 1D Maps and queries
@@ -127,7 +139,10 @@ namespace moab {
* \param lvids Vector returning the local vertex id's
- ErrorCode get_upward_incidences_1d(EntityHandle vid, std::vector<EntityHandle> &adjents, bool local_id = false, std::vector<int> * lvids = NULL);
+ ErrorCode get_up_adjacencies_1d(EntityHandle vid,
+ std::vector<int> * lvids = NULL);
//! Given an edge, finds vertex-connected neighbor edges
/** Given an edge, it gathers all the incident edges of each vertex of the edge.
@@ -136,7 +151,8 @@ namespace moab {
* \param adjents Vector returning neighbor edges
- ErrorCode get_neighbor_adjacencies_1d(EntityHandle eid, std::vector<EntityHandle> &adjents);
+ ErrorCode get_neighbor_adjacencies_1d(EntityHandle eid,
// 2D Maps and queries
@@ -161,6 +177,9 @@ namespace moab {
ErrorCode determine_incident_halfedges(Range &faces);
+ /* ErrorCode get_up_adjacencies_2d(EntityHandle vid,
+ std::vector<EntityHandle> &adjents);*/
//! Given an edge, finds the faces incident on it.
/** Given an edge, it first finds a matching half-edge corresponding to eid, and then
* collects all the incident half-edges/faces via the sibhes map.
@@ -171,7 +190,10 @@ namespace moab {
* \param leids Vector returning local edge ids
- ErrorCode get_upward_incidences_2d(EntityHandle eid, std::vector<EntityHandle> &adjents, bool local_id = false, std::vector<int> * leids = NULL);
+ ErrorCode get_up_adjacencies_2d(EntityHandle eid,
+ std::vector<int> * leids = NULL);
//! Given a half-edge <fid, leid>, finds the faces incident on it.
@@ -184,7 +206,12 @@ namespace moab {
- ErrorCode get_upward_incidences_2d(EntityHandle fid, int leid, bool add_inent, std::vector<EntityHandle> &adjents, bool local_id = false, std::vector<int> * leids = NULL);
+ ErrorCode get_up_adjacencies_2d(EntityHandle fid,
+ int leid,
+ bool add_inent,
//! Given an edge, finds edge-connected neighbor face
/** Given an face, it gathers all the neighbor faces of each local edge of the face.
@@ -193,7 +220,8 @@ namespace moab {
* \param adjents Vector returning neighbor faces
- ErrorCode get_neighbor_adjacencies_2d(EntityHandle fid, std::vector<EntityHandle> &adjents);
+ ErrorCode get_neighbor_adjacencies_2d(EntityHandle fid,
//! Given a range of faces, finds the total number of edges.
@@ -229,7 +257,8 @@ namespace moab {
* \param isborder: A dense tag over all vertices of size 1. Value is true for a border vertex, otherwise is false.
- ErrorCode determine_border_vertices( Range &cells, Tag isborder);
+ ErrorCode determine_border_vertices( Range &cells,
+ Tag isborder);
//! Given an edge, finds the cells incident on it.
/** Given an edge, it first finds a matching local edge in a cell corresponding to eid, and then
@@ -241,7 +270,10 @@ namespace moab {
- ErrorCode get_upward_incidences_edg_3d(EntityHandle eid, std::vector<EntityHandle> &adjents, bool local_id = false, std::vector<int> * leids = NULL);
+ ErrorCode get_up_adjacencies_edg_3d(EntityHandle eid,
//! Given a local edge <cid, leid>, finds the cells incident on it.
/** Given a local edge, it gathers all the incident cells via the sibhfs map.
@@ -253,7 +285,10 @@ namespace moab {
- ErrorCode get_upward_incidences_edg_3d(EntityHandle cid, int leid, std::vector<EntityHandle> &adjents, bool local_id = false, std::vector<int> * leids = NULL);
+ ErrorCode get_up_adjacencies_edg_3d(EntityHandle cid,
+ int leid, std::vector<EntityHandle> &adjents,
//! Given an face, finds the cells incident on it.
/** Given an face, it first finds a matching half-face in a cell corresponding to face, and then
@@ -265,7 +300,10 @@ namespace moab {
* \param leids Vector returning local face ids
- ErrorCode get_upward_incidences_face_3d(EntityHandle fid, std::vector<EntityHandle> &adjents, bool local_id = false, std::vector<int> * lfids = NULL);
+ ErrorCode get_up_adjacencies_face_3d(EntityHandle fid,
+ std::vector<int> * lfids = NULL);
//! Given a local face <cid, lfid>, finds the cells incident on it.
/** Given a local face, it gathers all the incident cells via the sibhfs map.
@@ -277,7 +315,11 @@ namespace moab {
* \param lfids Vector returning local face ids
- ErrorCode get_upward_incidences_face_3d(EntityHandle cid, int lfid, std::vector<EntityHandle> &adjents, bool local_id = false, std::vector<int> * lfids = NULL);
+ ErrorCode get_up_adjacencies_face_3d(EntityHandle cid,
+ int lfid,
//! Given a cell, finds face-connected neighbor cells
/** Given a cell, it gathers all the neighbor cells of each local face of the cell.
@@ -286,12 +328,17 @@ namespace moab {
* \param adjents Vector returning neighbor cells
- ErrorCode get_neighbor_adjacencies_3d(EntityHandle cid, std::vector<EntityHandle> &adjents);
+ ErrorCode get_neighbor_adjacencies_3d(EntityHandle cid,
protected:
- Interface * mb;
+ Core * mb;
+ HalfFacetRep();
+ bool mInitAHFmaps;
enum {
MAX_VERTICES = 8,
@@ -351,14 +398,23 @@ namespace moab {
* queue of half-edges, if they do not already exist in the queue. This function is used to increment the
* search space for finding a matching half-edge.
* Parameters:
- * \param <EntityHandle he_fid, int he_lid> The query half-edge
- * \param queue_fid, queue_lid, qsize Array of faces and local edge ids. qsize is the current size of the queue_fid.
+ * \param he_fid EntityHandle of query half-edge
+ * \param he_lid Local id of query half-edge
+ * \param queue_fid
+ * \param queue_lid
+ * \param qsize Array of faces and local edge ids. qsize is the current size of the queue_fid.
* \param trackfaces Array containing faces. If fid of an incident half-edge doesn't belong to trackfaces,
* the half-edge is added to the queue.
* \param tcount Current size of trackfaces
- ErrorCode get_upward_incidences_2d(EntityHandle he_fid, int he_lid, EntityHandle *queue_fid, int *queue_lid, int *qsize, EntityHandle *trackfaces, int *tcount);
+ ErrorCode get_up_adjacencies_2d(EntityHandle he_fid,
+ int he_lid,
+ int *queue_lid,
+ int *qsize,
+ int *tcount);
//! Given an edge, finds a matching half-edge in the surface.
/** Given an edge eid, it first collects few half-edges belonging to one-ring neighborhood of
@@ -369,7 +425,9 @@ namespace moab {
* \param hefid, helid: Returns the matching half-edge corresponding to the query edge.
- bool find_matching_halfedge( EntityHandle eid, EntityHandle *hefid, int *helid);
+ bool find_matching_halfedge( EntityHandle eid,
+ int *helid);
//! Gather half-edges to a queue of half-edges.
/** Given a vertex vid, and a half-edge <he_fid,he_lid>, add another half-edge in the same face sharing the vertex
@@ -381,7 +439,14 @@ namespace moab {
* \param trackfaces, tcount
- ErrorCode gather_halfedges( EntityHandle vid, EntityHandle he_fid, int he_lid, EntityHandle *queue_fid, int *queue_lid, int *qsize, EntityHandle *trackfaces, int *tcount);
+ ErrorCode gather_halfedges( EntityHandle vid,
+ int he_lid,
+ int *queue_lid,
+ int *qsize,
+ int *tcount);
//! Obtains another half-edge belonging to the same face as the input half-edge
/** It uses the local maps to find another half-edge that is either incident or outgoing depending
@@ -392,7 +457,11 @@ namespace moab {
* \param <EntityHandle he2_fid, int he2_lid>: Returns another half-edge in the same he_fid sharing vid.
- ErrorCode another_halfedge( EntityHandle vid, EntityHandle he_fid, int he_lid, EntityHandle *he2_fid, int *he2_lid);
+ ErrorCode another_halfedge( EntityHandle vid,
+ int he_lid,
+ int *he2_lid);
//! Collect and compare to find a matching half-edge with the given edge connectivity.
/** Given edge connectivity, compare to an input list of half-edges to find a matching half-edge
@@ -404,7 +473,14 @@ namespace moab {
* \param <EntityHandle he_fid, int he_lid>: Returns matching half-edge
- bool collect_and_compare(std::vector<EntityHandle> &edg_vert, EntityHandle *queue_fid, int *queue_lid, int *qsize, EntityHandle *trackfaces, int *tcount, EntityHandle *he_fid, int *he_lid);
+ bool collect_and_compare(std::vector<EntityHandle> &edg_vert,
+ int *queue_lid,
+ int *qsize,
+ int *tcount,
+ int *he_lid);
//! The local maps for 3D entities.
@@ -469,7 +545,9 @@ namespace moab {
* \param leid Returns the local id of the edge corresponding to the input edge w.r.t the incident cell.
- bool find_matching_implicit_edge_in_cell( EntityHandle eid, EntityHandle *cid, int *leid);
+ bool find_matching_implicit_edge_in_cell( EntityHandle eid,
+ int *leid);
//! Given a face, finds a matching local face in an incident cell.
/** Find a local face with the same connectivity as the input face, belonging to an incident cell.
@@ -479,9 +557,15 @@ namespace moab {
* \param lfid Returns the local id of the face corresponding to the input face w.r.t the incident cell.
- bool find_matching_halfface(EntityHandle fid, EntityHandle *cid, int *leid);
+ bool find_matching_halfface(EntityHandle fid,
+ int *leid);
- bool find_match_in_array(EntityHandle ent, EntityHandle *ent_list, int count, bool get_index = false, int *index = NULL);
+ bool find_match_in_array(EntityHandle ent,
+ EntityHandle *ent_list,
+ int count,
+ bool get_index = false,
+ int *index = NULL);
diff --git a/src/moab/Interface.hpp b/src/moab/Interface.hpp
index 09f4219..bfd5fb0 100644
--- a/src/moab/Interface.hpp
+++ b/src/moab/Interface.hpp
@@ -624,7 +624,12 @@ public:
- const int operation_type = Interface::INTERSECT) = 0;
+ #ifdef USE_AHF
+ , const bool use_ahf = false) = 0;
+ #else
+ ) = 0;
+ #endif
//! Get the adjacencies associated with a vector of entities to entities of a specfied dimension.
/** Identical to vector-based get_adjacencies function, except results are returned in a
diff --git a/test/Makefile.am b/test/Makefile.am
index fe7edb6..34432d0 100644
--- a/test/Makefile.am
+++ b/test/Makefile.am
@@ -61,6 +61,10 @@ if HDF5_FILE
lloyd_smoother_test
endif
+if ENABLE_ahf
+ TESTS += ahf_mbintf_test
+endif
# merge_test \ # input files no longer exist?
# test_tag_server \ # fails
@@ -154,6 +158,11 @@ lloyd_smoother_test_SOURCES = lloyd_smoother_test.cpp
ahf_test_SOURCES = test_ahf_moab.cpp
+if ENABLE_ahf
+ahf_mbintf_test_SOURCES = test_ahf_mb_interface.cpp
+endif
if PARALLEL
moab_test_CPPFLAGS += -I$(top_srcdir)/src/parallel
kd_tree_test_CPPFLAGS += -I$(top_srcdir)/src/parallel
diff --git a/test/test_ahf_mb_interface.cpp b/test/test_ahf_mb_interface.cpp
index 0000000..9bf76ef
--- /dev/null
+++ b/test/test_ahf_mb_interface.cpp
@@ -0,0 +1,174 @@
+/*This function tests the AHF datastructures on CST meshes*/
+#include <iostream>
+#include <vector>
+#include <algorithm>
+#include "moab/Core.hpp"
+#include "moab/Range.hpp"
+#include "moab/MeshTopoUtil.hpp"
+#include "TestUtil.hpp"
+using namespace moab;
+#ifdef MESHDIR
+static const char example[] = STRINGIFY(MESHDIR) "/hexes_mixed.vtk";
+#else
+static const char example[] = "/hexes_mixed.vtk";
+#endif
+void ahf_mbintf_test()
+ Core moab;
+ Interface* mbImpl = &moab;
+ MeshTopoUtil mtu(mbImpl);
+ ErrorCode error = mbImpl->load_file(example);
+ CHECK_ERR(error);
+ /*Create ranges for handles of explicit elements of the mixed mesh*/
+ Range verts, edges, faces, cells;
+ error = mbImpl->get_entities_by_dimension( 0, 0, verts);
+ error = mbImpl->get_entities_by_dimension( 0, 1, edges);
+ error = mbImpl->get_entities_by_dimension( 0, 2, faces);
+ error = mbImpl->get_entities_by_dimension( 0, 3, cells);
+ //Perform queries
+ std::vector<EntityHandle> adjents;
+ Range mbents, ahfents;
+ //1D Queries //
+ //IQ1: For every vertex, obtain incident edges
+ for (Range::iterator i = verts.begin(); i != verts.end(); ++i) {
+ adjents.clear();
+ error = mbImpl->get_adjacencies( &*i, 1, 1, false, adjents, Interface::INTERSECT, true);
+ CHECK_ERR(error);
+ mbents.clear();
+ error = mbImpl->get_adjacencies( &*i, 1, 1, false, mbents );
+ CHECK_ERR(error);
+ CHECK_EQUAL(adjents.size(),mbents.size());
+ std::sort(adjents.begin(), adjents.end());
+ std::copy(adjents.begin(), adjents.end(), range_inserter(ahfents));
+ mbents = subtract(mbents, ahfents);
+ CHECK(!mbents.size());
+ //NQ1: For every edge, obtain neighbor edges
+ for (Range::iterator i = edges.begin(); i != edges.end(); ++i) {
+ adjents.clear();
+ CHECK_ERR(error);
+ mbents.clear();
+ error = mtu.get_bridge_adjacencies( *i, 0, 1, mbents);
+ CHECK_ERR(error);
+ CHECK_EQUAL(adjents.size(), mbents.size());
+ // 2D Queries
+ //IQ2: For every edge, obtain incident faces
+ adjents.clear();
+ error = mbImpl->get_adjacencies( &*i, 1, 2, false, adjents, Interface::INTERSECT, true);
+ CHECK_ERR(error);
+ mbents.clear();
+ error = mbImpl->get_adjacencies( &*i, 1, 2, false, mbents);
+ CHECK_ERR(error);
+ //NQ2: For every face, obtain neighbor faces
+ for (Range::iterator i = faces.begin(); i != faces.end(); ++i) {
+ adjents.clear();
+ CHECK_ERR(error);
+ mbents.clear();
+ error = mtu.get_bridge_adjacencies( *i, 1, 2, mbents);
+ CHECK_ERR(error);
+ // 3D Queries
+ // IQ 31: For every edge, obtain incident cells
+ adjents.clear();
+ error = mbImpl->get_adjacencies( &*i, 1, 3, false, adjents, Interface::INTERSECT, true);
+ CHECK_ERR(error);
+ mbents.clear();
+ error = mbImpl->get_adjacencies(&*i, 1, 3, false, mbents);
+ CHECK_ERR(error);
+ //IQ32: For every face, obtain incident cells
+ adjents.clear();
+ CHECK_ERR(error);
+ mbents.clear();
+ CHECK_ERR(error);
+ //NQ3: For every cell, obtain neighbor cells
+ for (Range::iterator i = cells.begin(); i != cells.end(); ++i) {
+ adjents.clear();
+ CHECK_ERR(error);
+ mbents.clear();
+ error = mtu.get_bridge_adjacencies( *i, 2, 3, mbents);
+ CHECK_ERR(error);
+int main(int argc, char *argv[])
+ int result = 0;
+ argv[0] = argv[argc - argc]; // Followed read_mpas_nc.cpp test for removing warnings in serial mode about unused variables.
+ result += RUN_TEST(ahf_mbintf_test);
+ return result;
diff --git a/test/test_ahf_moab.cpp b/test/test_ahf_moab.cpp
index ff97fb1..93bd947 100755
--- a/test/test_ahf_moab.cpp
+++ b/test/test_ahf_moab.cpp
@@ -34,7 +34,7 @@ void ahf_test()
// Create an ahf instance
- HalfFacetRep ahf(mbImpl);
+ HalfFacetRep ahf(&moab);
// Call the initialize function which creates the maps for each dimension
ahf.initialize();
@@ -47,7 +47,7 @@ void ahf_test()
adjents.clear();
- error = ahf.get_upward_incidences( *i, 1, adjents);
+ error = ahf.get_up_adjacencies( *i, 1, adjents);
CHECK_ERR(error);
mbents.clear();
@@ -82,7 +82,7 @@ void ahf_test()
adjents.clear();
- error = ahf.get_upward_incidences( *i, 2, adjents);
+ error = ahf.get_up_adjacencies( *i, 2, adjents);
CHECK_ERR(error);
mbents.clear();
@@ -117,7 +117,7 @@ void ahf_test()
adjents.clear();
- error = ahf.get_upward_incidences( *i, 3, adjents);
+ error = ahf.get_up_adjacencies( *i, 3, adjents);
CHECK_ERR(error);
mbents.clear();
@@ -134,7 +134,7 @@ void ahf_test()
adjents.clear();
CHECK_ERR(error);
mbents.clear();
@@ -165,7 +165,7 @@ void ahf_test()
- ahf.deinitialize();
+ //ahf.deinitialize();
https://bitbucket.org/fathomteam/moab/commits/c3d8b5a1eab3/
Changeset: c3d8b5a1eab3
Branch: None
User: nray
Summary: Removed tag_iterate from sibling half-facet maps. Changed input to
test_ahf_moab to read in meshfile from command line. Added a test code
for timing and memory requirements.
Affected #: 9 files
index 3641fd5..692495b 100644
--- a/src/Core.cpp
+++ b/src/Core.cpp
@@ -1540,6 +1540,12 @@ ErrorCode Core::get_adjacencies( const EntityHandle *from_entities,
#else
#endif
+/*ErrorCode Core::get_adjacencies( const EntityHandle *from_entities,
+ std::vector<EntityHandle> &adj_entities,
+ const int operation_type)*/
#ifdef USE_AHF
@@ -1558,6 +1564,12 @@ ErrorCode Core::get_adjacencies( const EntityHandle *from_entities,
can_handle = false;
+ else if (to_dimension == 4)
+ std::cout<<"Currently Not Supported by MOAB_AHF: meshsets"<<std::endl;
@@ -1571,7 +1583,9 @@ ErrorCode Core::get_adjacencies( const EntityHandle *from_entities,
can_handle = false;
+ //if (can_handle)
index f3818a6..449a48a 100755
@@ -27,7 +27,7 @@
namespace moab {
- const int MAXSIZE = 500;
+ const int MAXSIZE = 150;
@@ -573,15 +573,6 @@ namespace moab {
ErrorCode error;
- EntityHandle start_edge = *edges.begin();
- int count, *sibhvs_lvid_ptr; EntityHandle *sibhvs_eid_ptr;
- error = mb->tag_iterate(sibhvs_eid, edges.begin(), edges.end(), count, (void*&)sibhvs_eid_ptr);
- if (MB_SUCCESS != error) return error;
- assert(count == (int) edges.size());
- error = mb->tag_iterate(sibhvs_lvid, edges.begin(), edges.end(), count, (void*&)sibhvs_lvid_ptr);
//Step 1: Create an index list storing the starting position for each vertex
int nv = _verts.size();
int *is_index = new int[nv+1];
@@ -595,8 +586,10 @@ namespace moab {
error = mb->get_connectivity(&*eid, 1, conn);
- is_index[conn[0]-*_verts.begin()+1] += 1;
- is_index[conn[1]-*_verts.begin()+1] += 1;
+ int index = _verts.index(conn[0]);
+ is_index[index+1] += 1;
+ index = _verts.index(conn[1]);
is_index[0] = 0;
@@ -615,7 +608,7 @@ namespace moab {
for (int j = 0; j< 2; j++)
- int v = conn[j] - *_verts.begin();
+ int v = _verts.index(conn[j]);
v2hv_map_eid[is_index[v]] = *eid;
v2hv_map_lvid[is_index[v]] = j;
is_index[v] += 1;
@@ -633,26 +626,59 @@ namespace moab {
+ EntityHandle sibeid[2];
+ int siblvid[2];
+ error = mb->tag_get_data(sibhvs_eid, &*eid, 1, sibeid);
+ error = mb->tag_get_data(sibhvs_lvid, &*eid, 1, siblvid);
for (int k =0; k<2; k++)
- if (sibhvs_eid_ptr[2*(*eid-start_edge)+k] != 0)
+ if (sibeid[k] != 0)
continue;
- int v = conn[k] - *_verts.begin();
+ int v = _verts.index(conn[k]);
int last = is_index[v+1] - 1;
if (last > is_index[v])
EntityHandle prev_eid = v2hv_map_eid[last];
int prev_lvid = v2hv_map_lvid[last];
+ EntityHandle seteid[2];
+ int setlvid[2];
+ error = mb->tag_get_data(sibhvs_eid, &prev_eid, 1, seteid);
+ error = mb->tag_get_data(sibhvs_lvid, &prev_eid, 1, setlvid);
for (int i=is_index[v]; i<=last; i++)
EntityHandle cur_eid = v2hv_map_eid[i];
int cur_lvid = v2hv_map_lvid[i];
- sibhvs_eid_ptr[2*(prev_eid-start_edge) + prev_lvid] = cur_eid;
- sibhvs_lvid_ptr[2*(prev_eid-start_edge) + prev_lvid] = cur_lvid;
+ seteid[prev_lvid] = cur_eid;
+ setlvid[prev_lvid] = cur_lvid;
+ error = mb->tag_set_data(sibhvs_eid, &prev_eid, 1, seteid);
+ error = mb->tag_set_data(sibhvs_lvid, &prev_eid, 1, setlvid);
prev_eid = cur_eid;
prev_lvid = cur_lvid;
@@ -663,6 +689,7 @@ namespace moab {
delete [] is_index;
delete [] v2hv_map_eid;
delete [] v2hv_map_lvid;
return MB_SUCCESS;
@@ -797,7 +824,7 @@ namespace moab {
int nepf;
if (type == MBTRI) nepf = 3;
else if (type ==MBQUAD) nepf = 4;
return nepf;
@@ -807,16 +834,13 @@ namespace moab {
// next: Local ids of next edges
// prev: Local ids of prev edges
- if (nepf == 3)
- next[0] = 1; next[1] = 2; next[2] = 0;
- prev[0] = 2; prev[1] = 0; prev[2] = 1;
- else if (nepf == 4)
- next[0] = 1; next[1] = 2; next[2] = 3; next[3] = 0;
- prev[0] = 3; prev[1] = 0; prev[2] = 1; prev[3] = 2;
+ for (int k=0; k<nepf-1; k++)
+ next[k]=k+1;
+ prev[k+1]=k;
+ next[nepf-1]=0;
+ prev[0] = nepf-1;
return MB_SUCCESS;
@@ -826,15 +850,6 @@ namespace moab {
ErrorCode error;
EntityHandle start_face = *faces.begin();
- // Create pointers to the tags for direct access to memory
- int count, *sibhes_leid_ptr; EntityHandle *sibhes_fid_ptr;
- error = mb->tag_iterate(sibhes_fid, faces.begin(), faces.end(), count, (void*&)sibhes_fid_ptr);
- assert(count == (int) faces.size());
- error = mb->tag_iterate(sibhes_leid, faces.begin(), faces.end(), count, (void*&)sibhes_leid_ptr);
int nepf = local_maps_2d(start_face);
int * next = new int[nepf];
int * prev = new int[nepf];
@@ -847,6 +862,7 @@ namespace moab {
for (int i =0; i<nv+1; i++)
is_index[i] = 0;
+ int index;
std::vector<EntityHandle> conn(nepf);
for (Range::iterator fid = faces.begin(); fid != faces.end(); ++fid)
@@ -856,7 +872,8 @@ namespace moab {
for (int i = 0; i<nepf; i++)
- is_index[conn[i]-*_verts.begin()+1] += 1;
+ index = _verts.index(conn[i]);
is_index[0] = 0;
@@ -877,7 +894,7 @@ namespace moab {
for (int j = 0; j< nepf; j++)
v2nv[is_index[v]] = conn[next[j]];
v2he_map_fid[is_index[v]] = *fid;
v2he_map_leid[is_index[v]] = j;
@@ -889,6 +906,7 @@ namespace moab {
is_index[i+1] = is_index[i];
is_index[0] = 0;
//Step 3: Fill up sibling half-verts map
@@ -896,13 +914,22 @@ namespace moab {
error = mb->get_connectivity(&*fid, 1, conn);
+ EntityHandle *sibfid = new EntityHandle[nepf];
+ int *sibleid = new int[nepf];
+ error = mb->tag_get_data(sibhes_fid, &*fid, 1, sibfid);
+ error = mb->tag_get_data(sibhes_leid, &*fid, 1, sibleid);
for (int k =0; k<nepf; k++)
- if (sibhes_fid_ptr[nepf*(*fid-start_face)+k] != 0)
+ if (sibfid[k] != 0)
continue;
- int vn = conn[next[k]] - *_verts.begin();
+ int vn = _verts.index(conn[next[k]]);
EntityHandle first_fid = *fid;
int first_leid = k;
@@ -910,38 +937,87 @@ namespace moab {
EntityHandle prev_fid = *fid;
int prev_leid = k;
- for (int index = is_index[vn]; index <= is_index[vn+1]-1; index++)
+ EntityHandle *setfid = new EntityHandle[nepf];
+ int *setleid = new int[nepf];
+ for (index = is_index[vn]; index <= is_index[vn+1]-1; index++)
if (v2nv[index] == conn[k])
EntityHandle cur_fid = v2he_map_fid[index];
int cur_leid = v2he_map_leid[index];
- sibhes_fid_ptr[nepf*(prev_fid-start_face)+prev_leid] = cur_fid;
- sibhes_leid_ptr[nepf*(prev_fid-start_face)+prev_leid] = cur_leid;
+ error = mb->tag_get_data(sibhes_fid, &prev_fid, 1, setfid);
+ error = mb->tag_get_data(sibhes_leid, &prev_fid, 1, setleid);
+ setfid[prev_leid] = cur_fid;
+ setleid[prev_leid] = cur_leid;
+ error = mb->tag_set_data(sibhes_fid, &prev_fid, 1, setfid);
+ error = mb->tag_set_data(sibhes_leid, &prev_fid, 1, setleid);
prev_fid = cur_fid;
prev_leid = cur_leid;
- for (int index = is_index[v]; index <= is_index[v+1]-1; index++)
+ for (index = is_index[v]; index <= is_index[v+1]-1; index++)
if ((v2nv[index] == conn[next[k]])&&(v2he_map_fid[index] != *fid))
prev_fid = cur_fid;
if (prev_fid != first_fid){
- sibhes_fid_ptr[nepf*(prev_fid-start_face) + prev_leid] = first_fid;
- sibhes_leid_ptr[nepf*(prev_fid-start_face) + prev_leid] = first_leid;
+ setfid[prev_leid] = first_fid;
+ setleid[prev_leid] = first_leid;
+ delete [] setfid;
+ delete [] setleid;
+ delete [] sibfid;
+ delete [] sibleid;
delete [] next;
@@ -1311,7 +1387,7 @@ namespace moab {
error = mb->get_connectivity(&curfid, 1, conn);
- int id = next[curlid];
+ int id = next[curlid];
if (((conn[curlid]==edg_vert[0])&&(conn[id]==edg_vert[1]))||((conn[curlid]==edg_vert[1])&&(conn[id]==edg_vert[0]))){
*he_fid = curfid;
*he_lid = curlid;
@@ -1336,7 +1412,7 @@ namespace moab {
counter += 1;
- delete [] next;
+ delete [] next;
delete [] prev;
return found;
@@ -1417,7 +1493,7 @@ namespace moab {
- HalfFacetRep::LocalMaps3D HalfFacetRep::lConnMap3D[4] =
+ const HalfFacetRep::LocalMaps3D HalfFacetRep::lConnMap3D[4] =
// Tet
{4, 6, 4, {3,3,3,3}, {{0,1,3},{1,2,3},{2,0,3},{0,2,1}}, {3,3,3,3}, {{0,2,3},{0,1,3},{1,2,3},{0,1,2}}, {{0,1},{1,2},{2,0},{0,3},{1,3},{2,3}}, {{3,0},{3,1},{3,2},{0,2},{0,1},{1,2}}, {{0,4,3},{1,5,4},{2,3,5},{2,1,0}}, {{-1,0,2,3},{0,-1,1,4},{2,1,-1,5},{3,4,5,-1}}},
@@ -1439,16 +1515,6 @@ namespace moab {
ErrorCode error;
EntityHandle start_cell = *cells.begin();
- int count, *sibhfs_lfid_ptr;
- EntityHandle *sibhfs_cid_ptr;
- error = mb->tag_iterate(sibhfs_cid, cells.begin(), cells.end(), count, (void*&)sibhfs_cid_ptr);
- assert(count == (int) cells.size());
- error = mb->tag_iterate(sibhfs_lfid, cells.begin(), cells.end(), count, (void*&)sibhfs_lfid_ptr);
int index = get_index_from_type(start_cell);
int nvpc = lConnMap3D[index].num_verts_in_cell;
int nfpc = lConnMap3D[index].num_faces_in_cell;
@@ -1459,6 +1525,7 @@ namespace moab {
is_index[i] = 0;
+ int vindex;
std::vector<EntityHandle> conn(nvpc);
for (Range::iterator cid = cells.begin(); cid != cells.end(); ++cid)
@@ -1476,7 +1543,8 @@ namespace moab {
if (v <= conn[id])
v = conn[id];
- is_index[v-*_verts.begin()+1] += 1;
+ vindex = _verts.index(v);
+ is_index[vindex+1] += 1;
is_index[0] = 0;
@@ -1518,7 +1586,7 @@ namespace moab {
error = local_maps_2d(nvF, next, prev);
- int v = vmax - *_verts.begin();
+ int v = _verts.index(vmax);
v2oe_v1[is_index[v]] = vs[next[lv]];
v2oe_v2[is_index[v]] = vs[prev[lv]];
v2hf_map_cid[is_index[v]] = *cid;
@@ -1542,9 +1610,18 @@ namespace moab {
error = mb->get_connectivity(&*cid, 1, conn);
+ EntityHandle *sibcid = new EntityHandle[nfpc];
+ int *siblfid = new int[nfpc];
+ error = mb->tag_get_data(sibhfs_cid, &*cid, 1, sibcid);
+ error = mb->tag_get_data(sibhfs_lfid, &*cid, 1, siblfid);
for (int i =0; i<nfpc; i++)
- if (sibhfs_cid_ptr[nfpc*(*cid-start_cell)+i] != 0)
+ if (sibcid[i] != 0)
continue;
@@ -1568,31 +1645,60 @@ namespace moab {
EntityHandle v1 = vs[prev[lv]];
EntityHandle v2 = vs[next[lv]];
+ EntityHandle *setcid = new EntityHandle[nfpc];
+ int *setlfid = new int[nfpc];
for (int ind = is_index[v]; ind <= is_index[v+1]-1; ind++)
if ((v2oe_v1[ind] == v1)&&(v2oe_v2[ind] == v2))
+ // Map to opposite hf
EntityHandle cur_cid = v2hf_map_cid[ind];
int cur_lfid = v2hf_map_lfid[ind];
- sibhfs_cid_ptr[nfpc*(*cid-start_cell)+i] = cur_cid;
- sibhfs_lfid_ptr[nfpc*(*cid-start_cell)+i] = cur_lfid;
+ error = mb->tag_get_data(sibhfs_cid, &*cid, 1, setcid);
+ error = mb->tag_get_data(sibhfs_lfid, &*cid, 1, setlfid);
+ setcid[i] = cur_cid;
+ setlfid[i] = cur_lfid;
+ error = mb->tag_set_data(sibhfs_cid, &*cid, 1, setcid);
+ error = mb->tag_set_data(sibhfs_lfid, &*cid, 1, setlfid);
+ //Map opposite hf to current cell
+ error = mb->tag_get_data(sibhfs_cid, &cur_cid, 1, setcid);
+ error = mb->tag_get_data(sibhfs_lfid, &cur_cid, 1, setlfid);
- sibhfs_cid_ptr[nfpc*(cur_cid-start_cell)+cur_lfid] = *cid;
- sibhfs_lfid_ptr[nfpc*(cur_cid-start_cell)+cur_lfid] = i;
+ setcid[cur_lfid] = *cid;
+ setlfid[cur_lfid] = i;
+ error = mb->tag_set_data(sibhfs_cid, &cur_cid, 1, setcid);
+ error = mb->tag_set_data(sibhfs_lfid, &cur_cid, 1, setlfid);
delete [] next;
delete [] prev;
delete [] vs;
+ delete [] setcid;
+ delete [] setlfid;
+ delete sibcid;
+ delete siblfid;
@@ -2115,10 +2221,8 @@ namespace moab {
bool HalfFacetRep::find_match_in_array(EntityHandle ent, EntityHandle *ent_list, int count, bool get_index, int *index)
bool found = false;
- // std::cout<<"count = "<<count<<std::endl;
for (int i = 0; i<= count; i++)
- // std::cout<<"For i = "<<i<<": ent-ent_list[i] = "<<(int)(ent-ent_list[i])<<std::endl;
if (!((int)(ent - ent_list[i])))
found = true;
index 941129a..20aafdc 100644
@@ -328,6 +328,16 @@ public:
#endif
+ /*virtual ErrorCode get_adjacencies(const EntityHandle *from_entities,
+ const int operation_type = Interface::INTERSECT);*/
index 3d1069a..344dbd1 100755
@@ -533,7 +533,7 @@ namespace moab {
int lookup_leids[MAX_VERTICES][MAX_VERTICES];
- static LocalMaps3D lConnMap3D[4];
+ static const LocalMaps3D lConnMap3D[4];
int get_index_from_type(EntityHandle cid);
index bfd5fb0..57252e9 100644
@@ -630,6 +630,12 @@ public:
#else
) = 0;
#endif
+ const int operation_type = Interface::INTERSECT) = 0; */
index 34432d0..1354e3c 100644
@@ -61,9 +61,9 @@ if HDF5_FILE
lloyd_smoother_test
endif
-if ENABLE_ahf
- TESTS += ahf_mbintf_test
-endif
+# if ENABLE_ahf
+# TESTS += ahf_mbintf_test
+# endif
@@ -158,9 +158,9 @@ lloyd_smoother_test_SOURCES = lloyd_smoother_test.cpp
-if ENABLE_ahf
-ahf_mbintf_test_SOURCES = test_ahf_mb_interface.cpp
-endif
+# if ENABLE_ahf
+# ahf_mbintf_test_SOURCES = test_ahf_mb_interface.cpp
+# endif
if PARALLEL
diff --git a/test/perf/Makefile.am b/test/perf/Makefile.am
index f946f94..32e2a57 100644
--- a/test/perf/Makefile.am
+++ b/test/perf/Makefile.am
@@ -7,13 +7,14 @@ AM_CPPFLAGS += -I$(top_srcdir)/src \
LDADD = $(top_builddir)/src/libMOAB.la
-check_PROGRAMS = perf seqperf adj_time perftool
+check_PROGRAMS = perf seqperf adj_time perftool ahf_mem_time
noinst_PROGRAMS =
perf_SOURCES = perf.cpp
seqperf_SOURCES = seqperf.cpp
adj_time_SOURCES = adj_time.cpp
perftool_SOURCES = perftool.cpp
+ahf_mem_time_SOURCES = test_ahf_mem_time.cpp
if ENABLE_imesh
LDADD += $(top_builddir)/itaps/imesh/libiMesh.la
diff --git a/test/perf/test_ahf_mem_time.cpp b/test/perf/test_ahf_mem_time.cpp
index 0000000..9c72ae7
--- /dev/null
+++ b/test/perf/test_ahf_mem_time.cpp
@@ -0,0 +1,281 @@
+#include <assert.h>
+#include <time.h>
+#include <vector>
+#include <sys/time.h>
+#ifdef MESHDIR
+std::string TestDir(STRINGIFY(MESHDIR));
+#else
+std::string TestDir(".");
+#endif
+std::string filename;
+double wtime() {
+ double y = -1;
+ struct timeval cur_time;
+ gettimeofday(&cur_time, NULL);
+ y = (double)(cur_time.tv_sec) + (double)(cur_time.tv_usec)*1.e-6;
+ return (y);
+int main(int argc, char **argv)
+ // Read the input mesh
+ filename = TestDir + "/hexes_mixed.vtk";
+ if (argc==1)
+ std::cout<<"Using default input file:"<<filename<<std::endl;
+ else if (argc==2)
+ filename = argv[1];
+ else {
+ std::cerr << "Usage: " << argv[0] << " [filename]" << std::endl;
+ return 1;
+ ErrorCode error;
+ Core moab;
+ error = mbImpl->load_file( filename.c_str());
+ if (MB_SUCCESS != error) {
+ std::cerr << filename <<": failed to load file." << std::endl;
+ return error;
+ //Create ranges for handles of explicit elements of the mixed mesh
+ int nverts = verts.size();
+ int nedges = edges.size();
+ int nfaces = faces.size();
+ int ncells = cells.size();
+ std::cout<<"nverts = "<<nverts<<", nedges = "<<nedges<<", nfaces = "<<nfaces<<", ncells = "<<ncells<<std::endl;
+ //Storage Costs before calling ahf functionalities
+ unsigned long sTotS, sTAS, sES, sAES, sAS, sAAS, sTS, sATS;
+ sTotS = sTAS = sES = sAES = sAS = sAAS = sTS = sATS = 0;
+ mbImpl->estimated_memory_use(NULL, 0, &sTotS, &sTAS, &sES, &sAES, &sAS, &sAAS, NULL, 0, &sTS, &sATS);
+ std::cout<<std::endl;
+ std::cout<<"Total storage = "<<sTotS<<std::endl;
+ std::cout<<"Total amortized storage = "<<sTAS<<std::endl;
+ std::cout<<"Entity storage = "<<sES<<std::endl;
+ std::cout<<"Amortized entity storage = "<<sAES<<std::endl;
+ std::cout<<"Adjacency storage = "<<sAS<<std::endl;
+ std::cout<<"Amortized adjacency storage = "<<sAAS<<std::endl;
+ std::cout<<"Tag storage = "<<sTS<<std::endl;
+ std::cout<<"Amortized tag storage = "<<sATS<<std::endl;
+ double time_start, time_elapsed, time_avg;
+ // Create an ahf instance
+ // Call the initialize function which creates the maps for each dimension
+ time_start = wtime();
+ ahf.initialize();
+ time_elapsed = wtime() - time_start;
+ std::cout << "Time taken to construct the MDS = "<<time_elapsed<<" secs"<<std::endl;
+ //Storage Costs after calling ahf initialize
+ unsigned long TotS, TAS, ES, AES, AS, AAS, TS, ATS;
+ TotS = TAS = ES = AES = AS = AAS = TS = ATS = 0;
+ mbImpl->estimated_memory_use(NULL, 0, &TotS, &TAS, &ES, &AES, &AS, &AAS, NULL, 0, &TS, &ATS);
+ std::cout<<"Total storage = "<<TotS<<std::endl;
+ std::cout<<"Total amortized storage = "<<TAS<<std::endl;
+ std::cout<<"Entity storage = "<<ES<<std::endl;
+ std::cout<<"Amortized entity storage = "<<AES<<std::endl;
+ std::cout<<"Adjacency storage = "<<AS<<std::endl;
+ std::cout<<"Amortized adjacency storage = "<<AAS<<std::endl;
+ std::cout<<"Tag storage = "<<TS<<std::endl;
+ std::cout<<"Amortized tag storage = "<<ATS<<std::endl;
+ //Perform queries
+ std::vector<int> lids;
+ Range mbents;
+ //1D Queries //
+ std::cout<<"1D QUERIES"<<std::endl;
+ adjents.clear();
+ time_avg = (wtime()-time_start)/(double)verts.size();
+ std::cout<<"MOAB_AHF: Average time taken to compute incident edges to a vertex = "<< time_avg<<" secs" <<std::endl;
+ error = mbImpl->get_adjacencies( &*verts.begin(), 1, 1, false, mbents );
+ mbents.clear();
+ std::cout<<"MOAB: Average time taken to compute incident edges to a vertex = "<< time_avg<<" secs" <<std::endl;
+ adjents.clear();
+ error = ahf.get_neighbor_adjacencies( *i, adjents);
+ time_avg = (wtime()-time_start)/(double)edges.size();
+ std::cout<<"MOAB_AHF: Average time taken to compute neighbor edges of an edge = "<<time_avg<<" secs" << std::endl;
+ error = mtu.get_bridge_adjacencies( *edges.begin(), 0, 1, mbents);
+ mbents.clear();
+ std::cout<<"MOAB: Average time taken to compute neighbor edges of an edge = "<<time_avg<<" secs" << std::endl;
+ // 2D Queries
+ //IQ21: For every edge, obtain incident faces
+ std::cout<<"2D QUERIES"<<std::endl;
+ adjents.clear();
+ std::cout<<"MOAB_AHF: Average time taken to compute incident faces on an edge = "<<time_avg<<" secs" <<std::endl;
+ error = mbImpl->get_adjacencies( &*edges.begin(), 1, 2, false, mbents);
+ mbents.clear();
+ std::cout<<"MOAB: Average time taken to compute incident faces on an edge = "<<time_avg<<" secs" <<std::endl;
+ adjents.clear();
+ time_avg = (wtime()-time_start)/(double)faces.size();
+ std::cout<<"MOAB_AHF: Average time taken to compute neighbor faces of a face = "<< time_avg<<" secs" <<std::endl;
+ error = mtu.get_bridge_adjacencies( *faces.begin(), 1, 2, mbents);
+ mbents.clear();
+ std::cout<<"MOAB: Average time taken to compute neighbor faces of a face = "<< time_avg<<" secs" <<std::endl;
+ // 3D Queries
+ std::cout<<"3D QUERIES"<<std::endl;
+ adjents.clear();
+ std::cout<<"MOAB_AHF: Average time taken to compute incident cells on an edge = "<<time_avg <<" secs"<<std::endl;
+ error = mbImpl->get_adjacencies(&*edges.begin(), 1, 3, false, mbents);
+ mbents.clear();
+ std::cout<<"MOAB: Average time taken to compute incident cells on an edge = "<<time_avg <<" secs"<<std::endl;
+ adjents.clear();
+ std::cout<<"MOAB_AHF: Average time taken to compute incident cells on a face = "<<time_avg <<" secs"<<std::endl;
+ error = mbImpl->get_adjacencies(&*faces.begin(), 1, 3, false, mbents);
+ mbents.clear();
+ std::cout<<"MOAB: Average time taken to compute incident cells on a face = "<<time_avg <<" secs"<<std::endl;
+ adjents.clear();
+ time_avg = (wtime()-time_start)/(double)cells.size();
+ std::cout<<"MOAB_AHF: Average time taken to compute neighbor cells of a cell = "<< time_avg <<" secs" << std::endl;
+ error = mtu.get_bridge_adjacencies( *cells.begin(), 2, 3, mbents);
+ mbents.clear();
+ std::cout<<"MOAB: Average time taken to compute neighbor cells of a cell = "<< time_avg <<" secs" << std::endl;
+ ahf.deinitialize();
+ //Storage Costs after calling ahf deinitialize
+ unsigned long eTotS, eTAS, eES, eAES, eAS, eAAS, eTS, eATS;
+ eTotS = eTAS = eES = eAES = eAS = eAAS = eTS = eATS = 0;
+ mbImpl->estimated_memory_use(NULL, 0, &eTotS, &eTAS, &eES, &eAES, &eAS, &eAAS, NULL, 0, &eTS, &eATS);
+ std::cout<<"Total storage = "<<eTotS<<std::endl;
+ std::cout<<"Total amortized storage = "<<eTAS<<std::endl;
+ std::cout<<"Entity storage = "<<eES<<std::endl;
+ std::cout<<"Amortized entity storage = "<<eAES<<std::endl;
+ std::cout<<"Adjacency storage = "<<eAS<<std::endl;
+ std::cout<<"Amortized adjacency storage = "<<eAAS<<std::endl;
+ std::cout<<"Tag storage = "<<eTS<<std::endl;
+ std::cout<<"Amortized tag storage = "<<eATS<<std::endl;
+ return 0;
index 93bd947..e415186 100755
@@ -11,172 +11,203 @@
#ifdef MESHDIR
-static const char example[] = STRINGIFY(MESHDIR) "/hexes_mixed.vtk";
#else
-static const char example[] = "/hexes_mixed.vtk";
#endif
-void ahf_test()
- Core moab;
- Interface* mbImpl = &moab;
- MeshTopoUtil mtu(mbImpl);
- ErrorCode error = mbImpl->load_file(example);
- CHECK_ERR(error);
- /*Create ranges for handles of explicit elements of the mixed mesh*/
- Range verts, edges, faces, cells;
- error = mbImpl->get_entities_by_dimension( 0, 0, verts);
- error = mbImpl->get_entities_by_dimension( 0, 1, edges);
- error = mbImpl->get_entities_by_dimension( 0, 2, faces);
- error = mbImpl->get_entities_by_dimension( 0, 3, cells);
- // Create an ahf instance
- HalfFacetRep ahf(&moab);
- // Call the initialize function which creates the maps for each dimension
- ahf.initialize();
- //Perform queries
- std::vector<EntityHandle> adjents;
- Range mbents, ahfents;
- //1D Queries //
- //IQ1: For every vertex, obtain incident edges
- for (Range::iterator i = verts.begin(); i != verts.end(); ++i) {
- adjents.clear();
- error = ahf.get_up_adjacencies( *i, 1, adjents);
- CHECK_ERR(error);
- mbents.clear();
- error = mbImpl->get_adjacencies( &*i, 1, 1, false, mbents );
- CHECK_ERR(error);
- CHECK_EQUAL(adjents.size(),mbents.size());
- std::sort(adjents.begin(), adjents.end());
- std::copy(adjents.begin(), adjents.end(), range_inserter(ahfents));
- mbents = subtract(mbents, ahfents);
- CHECK(!mbents.size());
- //NQ1: For every edge, obtain neighbor edges
- for (Range::iterator i = edges.begin(); i != edges.end(); ++i) {
- adjents.clear();
- error = ahf.get_neighbor_adjacencies( *i, adjents);
- CHECK_ERR(error);
- mbents.clear();
- error = mtu.get_bridge_adjacencies( *i, 0, 1, mbents);
- CHECK_ERR(error);
- CHECK_EQUAL(adjents.size(), mbents.size());
- // 2D Queries
- //IQ2: For every edge, obtain incident faces
- adjents.clear();
- error = ahf.get_up_adjacencies( *i, 2, adjents);
- CHECK_ERR(error);
- mbents.clear();
- error = mbImpl->get_adjacencies( &*i, 1, 2, false, mbents);
- CHECK_ERR(error);
+int number_tests_successful = 0;
+int number_tests_failed = 0;
- //NQ2: For every face, obtain neighbor faces
- for (Range::iterator i = faces.begin(); i != faces.end(); ++i) {
- adjents.clear();
- CHECK_ERR(error);
- mbents.clear();
- error = mtu.get_bridge_adjacencies( *i, 1, 2, mbents);
- CHECK_ERR(error);
+void handle_error_code(ErrorCode rv, int &number_failed, int &number_successful)
+ if (rv == MB_SUCCESS) {
+ std::cout << "Success";
+ number_successful++;
+ } else {
+ std::cout << "Failure";
+ number_failed++;
- // 3D Queries
- // IQ 31: For every edge, obtain incident cells
- adjents.clear();
- error = ahf.get_up_adjacencies( *i, 3, adjents);
- CHECK_ERR(error);
- mbents.clear();
- error = mbImpl->get_adjacencies(&*i, 1, 3, false, mbents);
- CHECK_ERR(error);
- //IQ32: For every face, obtain incident cells
- adjents.clear();
- CHECK_ERR(error);
- mbents.clear();
- CHECK_ERR(error);
+ErrorCode ahf_test(Core *moab)
+ Interface* mbImpl = &*moab;
- //NQ3: For every cell, obtain neighbor cells
- for (Range::iterator i = cells.begin(); i != cells.end(); ++i) {
- adjents.clear();
- CHECK_ERR(error);
- mbents.clear();
- error = mtu.get_bridge_adjacencies( *i, 2, 3, mbents);
+ ErrorCode error = mbImpl->load_file(filename.c_str());
CHECK_ERR(error);
- //ahf.deinitialize();
+ HalfFacetRep ahf(&*moab);
+ ahf.initialize();
+ //ahf.print_tags();
+ //Perform queries
+ //1D Queries //
+ adjents.clear();
+ CHECK_ERR(error);
+ mbents.clear();
+ CHECK_ERR(error);
+ adjents.clear();
+ CHECK_ERR(error);
+ mbents.clear();
+ CHECK_ERR(error);
+ // 2D Queries
+ adjents.clear();
+ CHECK_ERR(error);
+ mbents.clear();
+ CHECK_ERR(error);
+ adjents.clear();
+ CHECK_ERR(error);
+ mbents.clear();
+ CHECK_ERR(error);
+ // 3D Queries
+ adjents.clear();
+ CHECK_ERR(error);
+ mbents.clear();
+ CHECK_ERR(error);
+ adjents.clear();
+ CHECK_ERR(error);
+ mbents.clear();
+ CHECK_ERR(error);
+ adjents.clear();
+ CHECK_ERR(error);
+ mbents.clear();
+ CHECK_ERR(error);
- int result = 0;
- argv[0] = argv[argc - argc]; // Followed read_mpas_nc.cpp test for removing warnings in serial mode about unused variables.
- result += RUN_TEST(ahf_test);
- return result;
+ if (argc==1)
+ else if (argc==2)
+ else {
+ return 1;
+ Core moab;
+ ErrorCode result;
+ std::cout<<" ahf_test: ";
+ result = ahf_test(&moab);
+ handle_error_code(result, number_tests_failed, number_tests_successful);
+ std::cout<<"\n";
+ return number_tests_failed;
https://bitbucket.org/fathomteam/moab/commits/a7e68fae95aa/
Changeset: a7e68fae95aa
Branch: None
User: nray
Date: 2014-07-09 17:54:12
Summary: Removed 'use_ahf' flag from get_adjacencies interface in Core/Interface.
Passed make check.
Affected #: 9 files
diff --git a/src/Core.cpp b/src/Core.cpp
index 692495b..3340934 100644
--- a/src/Core.cpp
+++ b/src/Core.cpp
@@ -280,6 +280,7 @@ ErrorCode Core::initialize()
ahfRep = new HalfFacetRep(this);
if (!ahfRep)
return MB_MEMORY_ALLOCATION_FAILED;
+ mesh_modified = false;
#endif
return MB_SUCCESS;
@@ -1353,14 +1354,11 @@ ErrorCode get_adjacencies_union( Core* gMB,
return result;
-#ifdef USE_AHF
template <typename ITER> static inline
-ErrorCode get_adjacencies_intersection_ahf(Core *mb,
+ErrorCode get_adjacencies_intersection( Core* mb,
ITER begin, ITER end,
std::vector<EntityHandle>& adj_entities )
const size_t SORT_THRESHOLD = 200;
@@ -1378,11 +1376,13 @@ ErrorCode get_adjacencies_intersection_ahf(Core *mb,
// input list), we begin with the adjacencies for the first entity.
if (adj_entities.empty()) {
EntityType type = TYPE_FROM_HANDLE(*begin);
- if(to_dimension == 0 && type != MBPOLYHEDRON)
+ if (to_dimension == CN::Dimension(type))
+ adj_entities.push_back(*begin);
+ else if(to_dimension == 0 && type != MBPOLYHEDRON)
result = mb->get_connectivity(&(*begin), 1, adj_entities);
else
- result = mb->a_half_facet_rep()->get_adjacencies(*begin, to_dimension, adj_entities);
+ result = mb->a_entity_factory()->get_adjacencies(*begin, to_dimension,
return result;
++begin;
@@ -1395,10 +1395,13 @@ ErrorCode get_adjacencies_intersection_ahf(Core *mb,
// get the next set of adjacencies
EntityType type = TYPE_FROM_HANDLE(*from_it);
+ temp_vec.push_back(*from_it);
result = mb->get_connectivity(&(*from_it), 1, temp_vec);
else
- result = mb->a_half_facet_rep()->get_adjacencies(*from_it, to_dimension, temp_vec);
+ result = mb->a_entity_factory()->get_adjacencies(*from_it, to_dimension,
+ create_if_missing, temp_vec);
return result;
@@ -1424,14 +1427,43 @@ ErrorCode get_adjacencies_intersection_ahf(Core *mb,
return MB_SUCCESS;
-#endif
+ Range& adj_entities )
+ std::vector<EntityHandle> results;
+ ErrorCode rval = moab::get_adjacencies_intersection( mb, begin, end, to_dimension,
+ create_if_missing, results );
+ if (MB_SUCCESS != rval)
+ return rval;
+ if (adj_entities.empty()) {
+ std::copy( results.begin(), results.end(), range_inserter(adj_entities) );
+ return MB_SUCCESS;
+ Range::iterator it = adj_entities.begin();
+ while (it != adj_entities.end()) {
+ if (std::find( results.begin(), results.end(), *it) == results.end())
+ it = adj_entities.erase( it );
+ else
+ ++it;
+#ifdef USE_AHF
+template <typename ITER> static inline
+ErrorCode get_adjacencies_intersection_ahf(Core *mb,
+ ITER begin, ITER end,
+ const int to_dimension,
@@ -1449,13 +1481,11 @@ ErrorCode get_adjacencies_intersection( Core* mb,
- if (to_dimension == CN::Dimension(type))
- adj_entities.push_back(*begin);
- else if(to_dimension == 0 && type != MBPOLYHEDRON)
+ if(to_dimension == 0 && type != MBPOLYHEDRON)
else
- result = mb->a_entity_factory()->get_adjacencies(*begin, to_dimension,
+ result = mb->a_half_facet_rep()->get_adjacencies(*begin, to_dimension, adj_entities);
return result;
++begin;
@@ -1468,13 +1498,10 @@ ErrorCode get_adjacencies_intersection( Core* mb,
- temp_vec.push_back(*from_it);
else
- result = mb->a_entity_factory()->get_adjacencies(*from_it, to_dimension,
- create_if_missing, temp_vec);
+ result = mb->a_half_facet_rep()->get_adjacencies(*from_it, to_dimension, temp_vec);
return result;
@@ -1500,52 +1527,16 @@ ErrorCode get_adjacencies_intersection( Core* mb,
return MB_SUCCESS;
+#endif
-template <typename ITER> static inline
-ErrorCode get_adjacencies_intersection( Core* mb,
- ITER begin, ITER end,
- Range& adj_entities )
- std::vector<EntityHandle> results;
- ErrorCode rval = moab::get_adjacencies_intersection( mb, begin, end, to_dimension,
- create_if_missing, results );
- if (MB_SUCCESS != rval)
- return rval;
- if (adj_entities.empty()) {
- std::copy( results.begin(), results.end(), range_inserter(adj_entities) );
- return MB_SUCCESS;
- Range::iterator it = adj_entities.begin();
- while (it != adj_entities.end()) {
- if (std::find( results.begin(), results.end(), *it) == results.end())
- it = adj_entities.erase( it );
- else
- ++it;
-#ifdef USE_AHF
- , const bool use_ahf)
-#else
-#endif
-/*ErrorCode Core::get_adjacencies( const EntityHandle *from_entities,
- std::vector<EntityHandle> &adj_entities,
- const int operation_type)*/
#ifdef USE_AHF
@@ -1553,41 +1544,22 @@ ErrorCode Core::get_adjacencies( const EntityHandle *from_entities,
int source_dim = this->dimension_from_handle(from_entities[0]);
if ((source_dim > to_dimension) && (to_dimension != 0))
- std::cout<<"Currently Not Supported by MOAB_AHF: Down Adjacencies"<<std::endl;
- std::cout<<"Reverting to MOAB adjacency functionality"<<std::endl;
- can_handle = false;
- else if (((source_dim == 0) && (to_dimension == 2))||((source_dim == 0) && (to_dimension == 3)))
- std::cout<<"Currently Not Supported by MOAB_AHF: Vertex to face/cell"<<std::endl;
+ can_handle = false; //NOT SUPPORTED: Down adjacencies
- std::cout<<"Currently Not Supported by MOAB_AHF: meshsets"<<std::endl;
- else if (TYPE_FROM_HANDLE(from_entities[0]) == MBPOLYHEDRON)
- std::cout<<"Currently Not Supported by MOAB_AHF: Polyhedron Meshes"<<std::endl;
+ can_handle = false; // NOT SUPPORTED: meshsets
else if (create_if_missing)
- std::cout<<"Currently Not Supporteded by MOAB_AHF: create_if_missing capability "<<std::endl;
+ can_handle = false;//NOT SUPPORTED: create_if_missing
+ bool mixed = ahfRep->check_mixed_entity_type(); //NOT SUPPORTED: mixed entity types or polygonal/hedrals types
+ if (mixed)
can_handle = false;
+ if (mesh_modified)
- if ((use_ahf) && (can_handle))
- //if (can_handle)
+ if (can_handle)
+ ErrorCode result;
if (operation_type == Interface::INTERSECT)
return get_adjacencies_intersection_ahf(this, from_entities, from_entities+num_entities,
to_dimension, adj_entities );
@@ -1595,7 +1567,7 @@ ErrorCode Core::get_adjacencies( const EntityHandle *from_entities,
return MB_FAILURE;
// do union
- ErrorCode result;
std::vector<EntityHandle> tmp_storage;
const EntityHandle* conn;
int len;
@@ -1668,14 +1640,14 @@ ErrorCode Core::get_adjacencies( const EntityHandle *from_entities,
Range &adj_entities,
const int operation_type )
- if (operation_type == Interface::INTERSECT)
- return get_adjacencies_intersection( this, from_entities, from_entities + num_entities,
- to_dimension, create_if_missing, adj_entities );
- else if (operation_type == Interface::UNION)
- return get_adjacencies_union( this, from_entities, from_entities + num_entities,
- else
- return MB_FAILURE;
+ if (operation_type == Interface::INTERSECT)
+ return get_adjacencies_intersection( this, from_entities, from_entities + num_entities,
+ to_dimension, create_if_missing, adj_entities );
+ else if (operation_type == Interface::UNION)
+ return get_adjacencies_union( this, from_entities, from_entities + num_entities,
+ else
+ return MB_FAILURE;
ErrorCode Core::get_connectivity( const Range& from_entities,
@@ -2754,6 +2726,11 @@ ErrorCode Core::create_element(const EntityType type,
if (MB_SUCCESS == status)
status = aEntityFactory->notify_create_entity( handle, connectivity, num_nodes);
+#ifdef USE_AHF
+ mesh_modified = true;
+#endif
return status;
diff --git a/src/HalfFacetRep.cpp b/src/HalfFacetRep.cpp
index 449a48a..18a8a0d 100755
--- a/src/HalfFacetRep.cpp
+++ b/src/HalfFacetRep.cpp
@@ -34,6 +34,8 @@ namespace moab {
assert(NULL != impl);
mb = impl;
mInitAHFmaps = false;
+ chk_mixed = false;
+ is_mixed = false;
HalfFacetRep::~HalfFacetRep()
@@ -65,6 +67,89 @@ namespace moab {
return mesh_type;
+ const HalfFacetRep::adj_matrix HalfFacetRep::adjMatrix[7] =
+ // Stores the adjacency matrix for each mesh type.
+ //CURVE
+ {{{0,1,0,0},{1,1,0,0},{0,0,0,0},{0,0,0,0}}},
+ //SURFACE
+ {{{0,0,1,0},{0,0,0,0},{1,0,1,0},{0,0,0,0}}},
+ //SURFACE_MIXED
+ {{{0,1,1,0},{1,1,1,0},{1,0,1,0},{0,0,0,0}}},
+ //VOLUME
+ {{{0,0,0,1},{0,0,0,0},{0,0,0,0},{1,0,0,1}}},
+ //VOLUME_MIXED_1
+ {{{0,1,0,1},{1,1,0,1},{0,0,0,0},{1,0,0,1}}},
+ //VOLUME_MIXED_2
+ {{{0,0,1,1},{0,0,0,0},{1,0,1,1},{1,0,0,1}}},
+ //VOLUME_MIXED
+ {{{0,1,1,1},{1,1,1,1},{1,0,1,1},{1,0,0,1}}}
+ int HalfFacetRep::get_index_for_meshtype(MESHTYPE mesh_type)
+ int index;
+ if (mesh_type == CURVE) index = 0;
+ else if (mesh_type == SURFACE) index = 1;
+ else if (mesh_type == SURFACE_MIXED) index = 2;
+ else if (mesh_type == VOLUME) index = 3;
+ else if (mesh_type == VOLUME_MIXED_1) index = 4;
+ else if (mesh_type == VOLUME_MIXED_2) index = 5;
+ else if (mesh_type == VOLUME_MIXED) index = 6;
+ return index;
+ bool HalfFacetRep::check_mixed_entity_type()
+ if (!chk_mixed)
+ chk_mixed = true;
+ ErrorCode error;
+ Range felems, celems;
+ error = mb->get_entities_by_dimension( 0, 2, felems );
+ if (MB_SUCCESS != error) return error;
+ if (felems.size()){
+ Range tris, quad, poly;
+ tris = felems.subset_by_type(MBTRI);
+ quad = felems.subset_by_type(MBQUAD);
+ poly = felems.subset_by_type(MBPOLYGON);
+ if ((tris.size()&&quad.size())||(tris.size()&&poly.size())||(quad.size()&&poly.size()))
+ is_mixed = true;
+ if (poly.size())
+ is_mixed = true;
+ return is_mixed;
+ error = mb->get_entities_by_dimension( 0, 3, celems);
+ if (celems.size()){
+ Range tet, pyr, prism, hex, polyhed;
+ tet = celems.subset_by_type(MBTET);
+ pyr = celems.subset_by_type(MBPYRAMID);
+ prism = celems.subset_by_type(MBPRISM);
+ hex = celems.subset_by_type(MBHEX);
+ polyhed = celems.subset_by_type(MBPOLYHEDRON);
+ if ((tet.size() && pyr.size())||(tet.size() && prism.size())||(tet.size() && hex.size())||(tet.size()&&polyhed.size())||(pyr.size() && prism.size())||(pyr.size() && hex.size()) ||(pyr.size()&&polyhed.size())|| (prism.size() && hex.size())||(prism.size()&&polyhed.size())||(hex.size()&&polyhed.size()))
+ is_mixed = true;
+ if (polyhed.size())
+ is_mixed = true;
+ return is_mixed;
+ return is_mixed;
* initialize *
@@ -93,8 +178,10 @@ namespace moab {
int ncells = _cells.size();
MESHTYPE mesh_type = get_mesh_type(nverts, nedges, nfaces, ncells);
- std::cout<<"MeshType = "<<mesh_type<<std::endl;
+ thismeshtype = mesh_type;
+ std::cout<<"MeshType = "<<thismeshtype<<std::endl;
+ //Initialize mesh type specific maps
if (mesh_type == CURVE){
error = init_curve();
@@ -460,50 +547,78 @@ namespace moab {
if (mInitAHFmaps == false)
- error = initialize();
- if ((source_dimension == 0) && (target_dimension == 1))
- error = get_up_adjacencies_1d(source_entity, target_entities);
+ error = initialize();
- else if ((source_dimension == 1) && (target_dimension == 2))
- error = get_up_adjacencies_2d(source_entity, target_entities);
- else if ((source_dimension == 1) && (target_dimension == 3))
- error = get_up_adjacencies_edg_3d(source_entity, target_entities);
- else if ((source_dimension == 2) && (target_dimension ==3))
- error = get_up_adjacencies_face_3d(source_entity, target_entities);
- else if (source_dimension == target_dimension)
+ int mindex = get_index_for_meshtype(thismeshtype);
+ int adj_possible = adjMatrix[mindex].val[source_dimension][target_dimension];
+ if (adj_possible)
- if (target_dimension == 1)
+ if (source_dimension == 0) // Vertex to up adjacencies
- error = get_neighbor_adjacencies_1d(source_entity, target_entities);
+ if (target_dimension == 1)
+ error = get_up_adjacencies_1d(source_entity, target_entities);
+ else if (target_dimension == 2)
+ error = get_up_adjacencies_vert_2d(source_entity, target_entities);
+ else if (target_dimension == 3)
+ error = get_up_adjacencies_vert_3d(source_entity, target_entities);
- else if (target_dimension == 2)
+ else if (source_dimension == 1) // Edge to up adjacencies
- error = get_neighbor_adjacencies_2d(source_entity, target_entities);
+ if (target_dimension == 2)
+ error = get_up_adjacencies_2d(source_entity, target_entities);
+ error = get_up_adjacencies_edg_3d(source_entity, target_entities);
- else if (target_dimension == 3)
+ else if ((source_dimension == 2) && (target_dimension ==3)) // Face to up adjacencies
- error = get_neighbor_adjacencies_3d(source_entity, target_entities);
+ error = get_up_adjacencies_face_3d(source_entity, target_entities);
+ else if (source_dimension == target_dimension) // Same dimensional adjacencies
+ error = get_neighbor_adjacencies_1d(source_entity, target_entities);
+ error = get_neighbor_adjacencies_2d(source_entity, target_entities);
+ error = get_neighbor_adjacencies_3d(source_entity, target_entities);
+ else
return MB_SUCCESS;
@@ -517,10 +632,23 @@ namespace moab {
ErrorCode error;
int in_dim = mb->dimension_from_handle(ent);
- if ((in_dim == 0) && (out_dim == 1))
+ if (in_dim == 0)
- error = get_up_adjacencies_1d(ent, adjents, local_id, lids);
+ if (out_dim == 1)
+ error = get_up_adjacencies_1d(ent, adjents, local_id, lids);
+ else if (out_dim == 2)
+ error = get_up_adjacencies_vert_2d(ent, adjents);
+ else if (out_dim == 3)
+ error = get_up_adjacencies_vert_3d(ent, adjents);
else if ((in_dim == 1) && (out_dim == 2))
@@ -1070,7 +1198,7 @@ namespace moab {
return MB_SUCCESS;
- /* ErrorCode HalfFacetRep::get_up_adjacencies_2d(EntityHandle vid, std::vector<EntityHandle> &adjents)
+ ErrorCode HalfFacetRep::get_up_adjacencies_vert_2d(EntityHandle vid, std::vector<EntityHandle> &adjents)
ErrorCode error;
@@ -1092,12 +1220,12 @@ namespace moab {
queue_lid[i] = 0;
trackfaces[i] = 0;
- int qsize = 0, tcount = -1;
+ int qsize = 0, count = -1;
int num_qvals = 0;
- error = gather_halfedges(vid, fid, lid, queue_fid, queue_lid, &qsize, trackfaces, &tcount);
+ error = gather_halfedges(vid, fid, lid, queue_fid, queue_lid, &qsize, trackfaces, &count);
- while (num_qvals < *qsize)
+ while (num_qvals < qsize)
EntityHandle curfid = queue_fid[num_qvals];
int curlid = queue_lid[num_qvals];
@@ -1107,22 +1235,23 @@ namespace moab {
error = another_halfedge(vid, curfid, curlid, &he2_fid, &he2_lid);
- bool found_ent = find_match_in_array(he2_fid, trackfaces, tcount[0]);
+ bool found_ent = find_match_in_array(he2_fid, trackfaces, count);
if (found_ent)
continue;
- tcount[0] += 1;
- trackfaces[tcount[0]] = he2_fid;
+ count += 1;
+ trackfaces[count] = he2_fid;
- error = get_up_adjacencies_2d(he2_fid, he2_lid, queue_fid, queue_lid, qsize, trackfaces, tcount);
+ error = get_up_adjacencies_2d(he2_fid, he2_lid, queue_fid, queue_lid, &qsize, trackfaces, &count);
adjents.push_back(he2_fid);
ErrorCode HalfFacetRep::get_up_adjacencies_2d( EntityHandle eid,
@@ -1803,6 +1932,85 @@ namespace moab {
return MB_SUCCESS;
+ ErrorCode HalfFacetRep::get_up_adjacencies_vert_3d(EntityHandle vid, std::vector<EntityHandle> &adjents)
+ ErrorCode error;
+ // Obtain a half-face incident on v
+ EntityHandle cur_cid = 0;
+ error = mb->tag_get_data(v2hf_cid, &vid, 1, &cur_cid);
+ int index = get_index_from_type(cur_cid);
+ int nvpc = lConnMap3D[index].num_verts_in_cell;
+ int nfpc = lConnMap3D[index].num_faces_in_cell;
+ // Collect all incident cells
+ if (cur_cid != 0){
+ EntityHandle Stkcells[MAXSIZE], trackcells[MAXSIZE];
+ for (int i = 0; i< MAXSIZE; i++)
+ Stkcells[i] = 0;
+ trackcells[i] = 0;
+ int Stksize = 0, count = -1;
+ Stkcells[0] = cur_cid;
+ while (Stksize >= 0 ){
+ cur_cid = Stkcells[Stksize];
+ Stksize -= 1 ;
+ bool found = find_match_in_array(cur_cid, trackcells, count);
+ if (!found){
+ count += 1;
+ trackcells[count] = cur_cid;
+ // Add the current cell
+ adjents.push_back(cur_cid);
+ // Connectivity of the cell
+ std::vector<EntityHandle> conn;
+ error = mb->get_connectivity(&cur_cid, 1, conn);
+ // Local id of vid in the cell and the half-faces incident on it
+ int lv;
+ for (int i = 0; i< nvpc; ++i){
+ if (conn[i] == vid)
+ lv = i;
+ int nhf_thisv = lConnMap3D[index].v2hf_num[lv];
+ // Add other cells that are incident on vid to the stack
+ std::vector<EntityHandle> sib_cids(nfpc);
+ error = mb->tag_get_data(sibhfs_cid, &cur_cid, 1, &sib_cids[0]);
+ // Add new cells into the stack
+ EntityHandle ngb;
+ for (int i = 0; i < nhf_thisv; ++i){
+ int ind = lConnMap3D[index].v2hf[lv][i];
+ ngb = sib_cids[ind];
+ if (ngb) {
+ bool found_ent = find_match_in_array(ngb, trackcells, count);
+ if (!found_ent){
+ Stksize += 1;
+ Stkcells[Stksize] = ngb;
+ //adjents.push_back(cur_cid);
ErrorCode HalfFacetRep::get_up_adjacencies_edg_3d( EntityHandle eid,
@@ -2126,23 +2334,23 @@ namespace moab {
- // Local id of fid_verts[0] in the cell
- int lv0;
- for (int i = 0; i< nvpc; ++i){
- if (conn[i] == fid_verts[0])
- lv0 = i;
+ // Local id of fid_verts[0] in the cell
+ int lv0;
+ if (conn[i] == fid_verts[0])
+ lv0 = i;
- int nhf_thisv = lConnMap3D[index].v2hf_num[lv0];
+ int nhf_thisv = lConnMap3D[index].v2hf_num[lv0];
// Search each half-face to match input face
for(int i = 0; i < nhf_thisv; ++i){
int lfid = lConnMap3D[index].v2hf[lv0][i];
int nv_curF = lConnMap3D[index].hf2v_num[lfid];
if (nv_curF != nvF)
- continue;
+ continue;
// Connectivity of the current half-face
@@ -2150,7 +2358,7 @@ namespace moab {
for(int l = 0; l < nvF; ++l){
int ind = lConnMap3D[index].hf2v[lfid][l];
vthisface[l] = conn[ind];
// Match this half-face with input fid
@@ -2163,32 +2371,32 @@ namespace moab {
lid[0] = lfid;
break;
- // Add other cells that are incident on fid_verts[0]
- std::vector<EntityHandle> sib_cids(nfpc);
- error = mb->tag_get_data(sibhfs_cid, &cur_cid, 1, &sib_cids[0]);
+ // Add other cells that are incident on fid_verts[0]
- // Add new cells into the stack
- EntityHandle ngb;
- for (int i = 0; i < nhf_thisv; ++i){
- int ind = lConnMap3D[index].v2hf[lv0][i];
- ngb = sib_cids[ind];
+ EntityHandle ngb;
+ int ind = lConnMap3D[index].v2hf[lv0][i];
- if (ngb) {
+ if (ngb) {
- bool found_ent = find_match_in_array(ngb, trackcells, count);
- if (!found_ent){
- Stksize += 1;
- Stkcells[Stksize] = ngb;
+ if (!found_ent){
+ Stksize += 1;
return found;
diff --git a/src/moab/Core.hpp b/src/moab/Core.hpp
index 20aafdc..d8b155e 100644
--- a/src/moab/Core.hpp
+++ b/src/moab/Core.hpp
@@ -315,30 +315,16 @@ public:
\endcode */
- #ifdef USE_AHF
- , const bool use_ahf = false);
- #else
- #endif
- /*virtual ErrorCode get_adjacencies(const EntityHandle *from_entities,
- const int operation_type = Interface::INTERSECT);*/
@@ -1375,6 +1361,7 @@ private:
#ifdef USE_AHF
+ bool mesh_modified;
#endif
index 344dbd1..a228520 100755
@@ -62,6 +62,8 @@ namespace moab {
~HalfFacetRep();
+ bool check_mixed_entity_type();
//! Creates all the necessary tags to store the maps. Constructs the sibling-half-facet and vertex-to-incident-half-facet maps for each dimension present in the input.
@@ -177,8 +179,7 @@ namespace moab {
- /* ErrorCode get_up_adjacencies_2d(EntityHandle vid,
- std::vector<EntityHandle> &adjents);*/
+ ErrorCode get_up_adjacencies_vert_2d(EntityHandle vid, std::vector<EntityHandle> &adjents);
@@ -260,6 +261,9 @@ namespace moab {
Tag isborder);
+ ErrorCode get_up_adjacencies_vert_3d(EntityHandle vid, std::vector<EntityHandle> &adjents);
* collects all the incident cells via the sibhfs map.
@@ -353,9 +357,20 @@ namespace moab {
Tag sibhes_fid, sibhes_leid, v2he_fid, v2he_leid;
Tag sibhfs_cid, sibhfs_lfid, v2hf_cid, v2hf_lfid;
+ MESHTYPE thismeshtype;
MESHTYPE get_mesh_type(int nverts, int nedges, int nfaces, int ncells);
+ struct adj_matrix{
+ int val[4][4];
+ static const adj_matrix adjMatrix[7];
+ int get_index_for_meshtype(MESHTYPE mesh_type);
+ // These two flags are for checking mixed entity type meshes
+ bool is_mixed;
+ bool chk_mixed;
ErrorCode init_curve();
ErrorCode init_surface();
ErrorCode init_volume();
@@ -364,6 +379,7 @@ namespace moab {
ErrorCode deinit_surface();
ErrorCode deinit_volume();
//! Contains the local information for 2D entities
/** Given a face, find the face type specific information
* Parameters:
index 57252e9..0b9e8e9 100644
@@ -619,23 +619,13 @@ public:
get_adjacencies( from_entities, 2, 1, false, adjacencies, Interface::INTERSECT);
\endcode
const int num_entities,
const bool create_if_missing,
std::vector<EntityHandle>& adj_entities,
- #ifdef USE_AHF
- , const bool use_ahf = false) = 0;
- #else
- ) = 0;
- #endif
- const int num_entities,
- const int to_dimension,
- const bool create_if_missing,
- std::vector<EntityHandle>& adj_entities,
- const int operation_type = Interface::INTERSECT) = 0; */
diff --git a/test/MBTest.cpp b/test/MBTest.cpp
index d70753f..a4f5d8a 100644
--- a/test/MBTest.cpp
+++ b/test/MBTest.cpp
@@ -6559,7 +6559,7 @@ ErrorCode mb_skin_verts_common( unsigned dim, bool skin_elems )
std::cout << "Extra/non-returned elements created: " << extra << std::endl;
return MB_FAILURE;
// check that each skin vertex has the correct number of adjacent quads
missing.clear(); extra.clear();
for (Range::iterator i = expected.begin(); i != expected.end(); ++i) {
index 1354e3c..33ca518 100644
lloyd_smoother_test
endif
-# if ENABLE_ahf
-# TESTS += ahf_mbintf_test
-# endif
+if ENABLE_ahf
+endif
-# if ENABLE_ahf
-# ahf_mbintf_test_SOURCES = test_ahf_mb_interface.cpp
-# endif
+if ENABLE_ahf
+ ahf_mbintf_test_SOURCES = test_ahf_mb_interface.cpp
+endif
if PARALLEL
index 9bf76ef..3d8257f 100755
--- a/test/test_ahf_mb_interface.cpp
@@ -41,7 +41,7 @@ void ahf_mbintf_test()
adjents.clear();
- error = mbImpl->get_adjacencies( &*i, 1, 1, false, adjents, Interface::INTERSECT, true);
+ error = mbImpl->get_adjacencies( &*i, 1, 1, false, adjents);
CHECK_ERR(error);
mbents.clear();
@@ -58,7 +58,7 @@ void ahf_mbintf_test()
adjents.clear();
CHECK_ERR(error);
mbents.clear();
@@ -76,7 +76,7 @@ void ahf_mbintf_test()
adjents.clear();
- error = mbImpl->get_adjacencies( &*i, 1, 2, false, adjents, Interface::INTERSECT, true);
+ error = mbImpl->get_adjacencies( &*i, 1, 2, false, adjents);
CHECK_ERR(error);
mbents.clear();
@@ -93,7 +93,7 @@ void ahf_mbintf_test()
adjents.clear();
CHECK_ERR(error);
mbents.clear();
@@ -111,7 +111,7 @@ void ahf_mbintf_test()
adjents.clear();
- error = mbImpl->get_adjacencies( &*i, 1, 3, false, adjents, Interface::INTERSECT, true);
+ error = mbImpl->get_adjacencies( &*i, 1, 3, false, adjents);
CHECK_ERR(error);
mbents.clear();
@@ -128,7 +128,7 @@ void ahf_mbintf_test()
adjents.clear();
CHECK_ERR(error);
mbents.clear();
@@ -145,7 +145,7 @@ void ahf_mbintf_test()
adjents.clear();
CHECK_ERR(error);
mbents.clear();
index e415186..a9185ae 100755
@@ -97,7 +97,25 @@ ErrorCode ahf_test(Core *moab)
// 2D Queries
+ // IQ21: For every vertex, obtain incident faces
+ adjents.clear();
+ CHECK_ERR(error);
+ mbents.clear();
+ CHECK_ERR(error);
+ //IQ22: For every edge, obtain incident faces
adjents.clear();
@@ -132,7 +150,24 @@ ErrorCode ahf_test(Core *moab)
// 3D Queries
+ //IQ 31: For every vertex, obtain incident cells
+ adjents.clear();
+ CHECK_ERR(error);
+ mbents.clear();
+ CHECK_ERR(error);
+ // IQ 32: For every edge, obtain incident cells
adjents.clear();
@@ -149,7 +184,7 @@ ErrorCode ahf_test(Core *moab)
+ //IQ33: For every face, obtain incident cells
adjents.clear();
https://bitbucket.org/fathomteam/moab/commits/1420cc507911/
Changeset: 1420cc507911
Branch: None
User: nray
Summary: Removed unnecessary printouts. Added two examples for comparing timing
and memory efficiency of MOAB and MOAB_AHF adjacencies.
Affected #: 6 files
index 18a8a0d..af8c187 100755
@@ -179,7 +179,6 @@ namespace moab {
- std::cout<<"MeshType = "<<thismeshtype<<std::endl;
@@ -812,7 +811,6 @@ namespace moab {
- std::cout<<"Finished creating sibling half-verts map"<<std::endl;
delete [] is_index;
@@ -846,7 +844,6 @@ namespace moab {
- std::cout<<"Finished creating incident half-verts map"<<std::endl;
return MB_SUCCESS;
@@ -1155,7 +1152,6 @@ namespace moab {
delete [] v2he_map_fid;
delete [] v2he_map_leid;
- std::cout<<"Finished creating sibling half-edges map"<<std::endl;
return MB_SUCCESS;
@@ -1190,10 +1186,10 @@ namespace moab {
error = mb->tag_set_data(v2he_leid, &v, 1, &lid);
- std::cout<<"Finished creating incident half-edges map"<<std::endl;
return MB_SUCCESS;
@@ -1837,7 +1833,6 @@ namespace moab {
delete [] v2hf_map_cid;
delete [] v2hf_map_lfid;
- std::cout<<"Finished creating sibling half-faces map"<<std::endl;
return MB_SUCCESS;
@@ -1891,7 +1886,6 @@ namespace moab {
- std::cout<<"Finished creating incident half-faces"<<std::endl;
return MB_SUCCESS;
index 32e2a57..556554c 100644
@@ -7,7 +7,7 @@ AM_CPPFLAGS += -I$(top_srcdir)/src \
-check_PROGRAMS = perf seqperf adj_time perftool ahf_mem_time
+check_PROGRAMS = perf seqperf adj_time perftool ahf_mem_time adj_without_ahf
noinst_PROGRAMS =
@@ -15,6 +15,7 @@ seqperf_SOURCES = seqperf.cpp
+adj_without_ahf_SOURCES = adj_without_ahf_mem_time.cpp
if ENABLE_imesh
@@ -24,4 +25,9 @@ if ENABLE_imesh
tstt_perf_binding_SOURCES = tstt_perf_binding.cpp
endif
+if ENABLE_ahf
+ check_PROGRAMS += adj_with_ahf
+ adj_with_ahf_SOURCES = adj_with_ahf_mem_time.cpp
+endif
diff --git a/test/perf/adj_with_ahf_mem_time.cpp b/test/perf/adj_with_ahf_mem_time.cpp
new file mode 100755
index 0000000..dbf4558
--- /dev/null
+++ b/test/perf/adj_with_ahf_mem_time.cpp
@@ -0,0 +1,209 @@
+#include <time.h>
+#include <vector>
+#include "moab/HalfFacetRep.hpp"
+#ifdef MESHDIR
+#else
+#endif
+double wtime() {
+ double y = -1;
+ return (y);
+ if (argc==1)
+ else if (argc==2)
+ else {
+ return 1;
+ ErrorCode error;
+ Core moab;
+ return error;
+ std::cout<<"STORAGE BEFORE CALLING ADJACENCIES"<<std::endl;
+ double time_start, time_avg;
+ //Perform queries
+ // This call should create all the necessary ahf maps
+ error = mbImpl->get_adjacencies( &*verts.begin(), 1, 1, false, adjents );
+ //1D Queries //
+ adjents.clear();
+ std::cout<<"QUERY: Vertex -> Edges :: MOAB_AHF: Average time = "<< time_avg<<" secs" <<std::endl;
+ adjents.clear();
+ std::cout<<"QUERY: Edge -> Edges :: MOAB_AHF: Average time = "<<time_avg<<" secs" << std::endl;
+ // 2D Queries
+ //IQ21: For every vertex, obtain incident faces
+ adjents.clear();
+ std::cout<<"QUERY: Vertex -> Faces :: MOAB_AHF: Average time = "<<time_avg<<" secs" <<std::endl;
+ adjents.clear();
+ std::cout<<"QUERY: Edge -> Faces :: MOAB_AHF: Average time = "<<time_avg<<" secs" <<std::endl;
+ adjents.clear();
+ std::cout<<"QUERY: Face -> Faces :: MOAB_AHF: Average time = "<< time_avg<<" secs" <<std::endl;
+ // 3D Queries
+ //IQ31: For every vertex, obtain incident cells
+ adjents.clear();
+ error = mbImpl->get_adjacencies(&*i, 1, 3, false, adjents);
+ std::cout<<"QUERY: Vertex -> Cells :: MOAB_AHF: Average time = "<<time_avg <<" secs"<<std::endl;
+ adjents.clear();
+ std::cout<<"QUERY: Edge -> Cells :: MOAB_AHF: Average time = "<<time_avg <<" secs"<<std::endl;
+ adjents.clear();
+ std::cout<<"QUERY: Face -> Cells :: MOAB_AHF: Average time = "<<time_avg <<" secs"<<std::endl;
+ adjents.clear();
+ std::cout<<"QUERY: Cell -> Cells :: MOAB_AHF: Average time = "<< time_avg <<" secs" << std::endl;
+ std::cout<<"STORAGE AFTER CALLING ADJACENCIES"<<std::endl;
+ return 0;
diff --git a/test/perf/adj_without_ahf_mem_time.cpp b/test/perf/adj_without_ahf_mem_time.cpp
index 0000000..cd4d58c
--- /dev/null
+++ b/test/perf/adj_without_ahf_mem_time.cpp
@@ -0,0 +1,223 @@
+#include <time.h>
+#include <vector>
+#ifdef MESHDIR
+#else
+#endif
+double wtime() {
+ double y = -1;
+ return (y);
+ if (argc==1)
+ else if (argc==2)
+ else {
+ return 1;
+ ErrorCode error;
+ Core moab;
+ return error;
+ //Perform queries
+ std::vector<EntityHandle> mbents;
+ Range ngbents;
+ // This call should create all the necessary moab adjacency lists
+ //1D Queries //
+ mbents.clear();
+ std::cout<<"QUERY: Vertex -> Edges :: MOAB: Average time = "<< time_avg<<" secs" <<std::endl;
+ error = mtu.get_bridge_adjacencies( *edges.begin(), 0, 1, ngbents);
+ ngbents.clear();
+ error = mtu.get_bridge_adjacencies( *i, 0, 1, ngbents);
+ std::cout<<"QUERY: Edge -> Edges :: MOAB: Average time = "<<time_avg<<" secs" << std::endl;
+ // 2D Queries
+ mbents.clear();
+ std::cout<<"QUERY: Vertex -> Faces :: MOAB: Average time = "<<time_avg<<" secs" <<std::endl;
+ mbents.clear();
+ std::cout<<"QUERY: Edge -> Faces :: MOAB: Average time = "<<time_avg<<" secs" <<std::endl;
+ error = mtu.get_bridge_adjacencies( *faces.begin(), 1, 2, ngbents);
+ ngbents.clear();
+ error = mtu.get_bridge_adjacencies( *i, 1, 2, ngbents);
+ std::cout<<"QUERY: Face -> Faces :: MOAB: Average time = "<< time_avg<<" secs" <<std::endl;
+ // 3D Queries
+ mbents.clear();
+ std::cout<<"QUERY: Vertex -> Cells :: MOAB: Average time = "<<time_avg <<" secs"<<std::endl;
+ mbents.clear();
+ std::cout<<"QUERY: Edge -> Cells :: MOAB: Average time = "<<time_avg <<" secs"<<std::endl;
+ mbents.clear();
+ std::cout<<"QUERY: Face -> Cells :: MOAB: Average time = "<<time_avg <<" secs"<<std::endl;
+ error = mtu.get_bridge_adjacencies( *cells.begin(), 2, 3, ngbents);
+ ngbents.clear();
+ error = mtu.get_bridge_adjacencies( *i, 2, 3, ngbents);
+ std::cout<<"QUERY: Cell -> Cells :: MOAB: Average time = "<< time_avg <<" secs" << std::endl;
+ return 0;
diff --git a/test/perf/ahf_intfc_mem_time.cpp b/test/perf/ahf_intfc_mem_time.cpp
index 0000000..6d8ef14
--- /dev/null
+++ b/test/perf/ahf_intfc_mem_time.cpp
@@ -0,0 +1,309 @@
+#include <time.h>
+#include <vector>
+#ifdef MESHDIR
+#else
+#endif
+double wtime() {
+ double y = -1;
+ return (y);
+ if (argc==1)
+ else if (argc==2)
+ else {
+ return 1;
+ ErrorCode error;
+ Core moab;
+ return error;
+ //Perform queries
+ Range mbents;
+ //1D Queries //
+ adjents.clear();
+ mbents.clear();
+ adjents.clear();
+ mbents.clear();
+ // 2D Queries
+ adjents.clear();
+ mbents.clear();
+ adjents.clear();
+ mbents.clear();
+ adjents.clear();
+ mbents.clear();
+ // 3D Queries
+ adjents.clear();
+ mbents.clear();
+ adjents.clear();
+ mbents.clear();
+ adjents.clear();
+ mbents.clear();
+ adjents.clear();
+ mbents.clear();
+ return 0;
index 3d8257f..f4f754f 100755
@@ -73,7 +73,24 @@ void ahf_mbintf_test()
// 2D Queries
+ adjents.clear();
+ CHECK_ERR(error);
+ mbents.clear();
+ CHECK_ERR(error);
adjents.clear();
@@ -108,7 +125,24 @@ void ahf_mbintf_test()
// 3D Queries
+ adjents.clear();
+ CHECK_ERR(error);
+ mbents.clear();
+ CHECK_ERR(error);
adjents.clear();
https://bitbucket.org/fathomteam/moab/commits/4e137dcdeafe/
Changeset: 4e137dcdeafe
Branch: None
User: nray
Summary: Corrected memory deallocation. Removed warnings when configured with
--enable-ahf.
Affected #: 3 files
index 3340934..9bfb9ca 100644
--- a/src/Core.cpp
+++ b/src/Core.cpp
@@ -302,6 +302,11 @@ void Core::deinitialize()
delete *vit;
#endif
+#ifdef USE_AHF
+ delete ahfRep;
+ ahfRep = 0;
+#endif
if (aEntityFactory)
delete aEntityFactory;
@@ -334,10 +339,6 @@ void Core::deinitialize()
MPI_Finalize();
#endif
-#ifdef USE_AHF
- delete ahfRep;
- ahfRep = 0;
-#endif
ErrorCode Core::query_interface_type( const std::type_info& type, void*& ptr )
index af8c187..fbda680 100755
@@ -38,16 +38,12 @@ namespace moab {
is_mixed = false;
- HalfFacetRep::~HalfFacetRep()
- ErrorCode result;
- result = deinitialize();
- //if (MB_SUCCESS != result) return result;
+ HalfFacetRep::~HalfFacetRep() {}
MESHTYPE HalfFacetRep::get_mesh_type(int nverts, int nedges, int nfaces, int ncells)
- MESHTYPE mesh_type;
+ MESHTYPE mesh_type = CURVE;
if (nverts && nedges && (!nfaces) && (!ncells))
mesh_type = CURVE;
@@ -94,7 +90,7 @@ namespace moab {
- int index;
+ int index = 0;
@@ -181,42 +177,42 @@ namespace moab {
- if (mesh_type == CURVE){
+ if (thismeshtype == CURVE){
- else if (mesh_type == SURFACE){
+ else if (thismeshtype == SURFACE){
error = init_surface();
- else if (mesh_type == SURFACE_MIXED){
+ else if (thismeshtype == SURFACE_MIXED){
- else if (mesh_type == VOLUME){
+ else if (thismeshtype == VOLUME){
error = init_volume();
- else if (mesh_type == VOLUME_MIXED_1){
+ else if (thismeshtype == VOLUME_MIXED_1){
- else if (mesh_type == VOLUME_MIXED_2){
+ else if (thismeshtype == VOLUME_MIXED_2){
- else if (mesh_type == VOLUME_MIXED){
+ else if (thismeshtype == VOLUME_MIXED){
@@ -329,39 +325,38 @@ namespace moab {
ErrorCode HalfFacetRep::deinitialize()
ErrorCode error;
- MESHTYPE mesh_type = get_mesh_type(_verts.size(), _edges.size(), _faces.size(), _cells.size());
error = deinit_curve();
error = deinit_surface();
error = deinit_volume();
@@ -946,7 +941,7 @@ namespace moab {
// nepf: Number of edges per face
EntityType type = mb->type_from_handle(face);
- int nepf;
+ int nepf = 0;
@@ -1603,7 +1598,7 @@ namespace moab {
int HalfFacetRep::get_index_from_type(EntityHandle cid)
- int index;
+ int index = 0;
EntityType type = mb->type_from_handle(cid);
if (type == MBTET)
index = 0;
@@ -1822,8 +1817,8 @@ namespace moab {
delete [] setcid;
delete [] setlfid;
- delete sibcid;
- delete siblfid;
+ delete [] sibcid;
+ delete [] siblfid;
@@ -1970,7 +1965,7 @@ namespace moab {
- int lv;
+ int lv = -1;
if (conn[i] == vid)
lv = i;
@@ -2241,7 +2236,7 @@ namespace moab {
error =mb->get_connectivity(&cell_id, 1, conn);
- int lv0 = -1, lv1 = -1, lv;
+ int lv0 = -1, lv1 = -1, lv = -1;
//locate v_origin in poped out tet, check if v_end is in
for (int i = 0; i<nvpc; i++){
@@ -2329,7 +2324,7 @@ namespace moab {
- int lv0;
+ int lv0 = -1;
index a9185ae..759f7b0 100755
@@ -218,6 +218,8 @@ ErrorCode ahf_test(Core *moab)
return MB_SUCCESS;
https://bitbucket.org/fathomteam/moab/commits/0860f588ba44/
Changeset: 0860f588ba44
Branch: nray/feature_ahf
User: nray
Summary: Changed ahf moab interface test to accept an input file.
Affected #: 1 file
diff --git a/test/test_ahf_mb_interface.cpp b/test/test_ahf_mb_interface.cpp
index f4f754f..321d043 100755
+++ b/test/test_ahf_mb_interface.cpp
@@ -11,198 +11,228 @@
using namespace moab;
#ifdef MESHDIR
#else
#endif
-void ahf_mbintf_test()
- Core moab;
- CHECK_ERR(error);
- //Perform queries
- //1D Queries //
- adjents.clear();
- error = mbImpl->get_adjacencies( &*i, 1, 1, false, adjents);
- CHECK_ERR(error);
- mbents.clear();
- CHECK_ERR(error);
- adjents.clear();
- CHECK_ERR(error);
- mbents.clear();
- CHECK_ERR(error);
- // 2D Queries
- // IQ21: For every vertex, obtain incident faces
- adjents.clear();
- error = mbImpl->get_adjacencies( &*i, 1, 2, false, adjents);
- CHECK_ERR(error);
- mbents.clear();
- CHECK_ERR(error);
- //IQ22: For every edge, obtain incident faces
- adjents.clear();
- CHECK_ERR(error);
- mbents.clear();
- CHECK_ERR(error);
- adjents.clear();
- CHECK_ERR(error);
- mbents.clear();
- CHECK_ERR(error);
- // 3D Queries
- //IQ 31: For every vertex, obtain incident cells
- adjents.clear();
- error = mbImpl->get_adjacencies( &*i, 1, 3, false, adjents);
- CHECK_ERR(error);
- mbents.clear();
- CHECK_ERR(error);
- // IQ 32: For every edge, obtain incident cells
- adjents.clear();
- CHECK_ERR(error);
- mbents.clear();
- CHECK_ERR(error);
+ } else {
+ number_failed++;
- adjents.clear();
- CHECK_ERR(error);
- mbents.clear();
- CHECK_ERR(error);
+ErrorCode ahf_mbintfc_test(Core *moab)
+ MeshTopoUtil mtu(mbImpl);
- adjents.clear();
CHECK_ERR(error);
- mbents.clear();
- CHECK_ERR(error);
+ /*Create ranges for handles of explicit elements of the mixed mesh*/
+ Range verts, edges, faces, cells;
+ error = mbImpl->get_entities_by_dimension( 0, 0, verts);
+ error = mbImpl->get_entities_by_dimension( 0, 1, edges);
+ error = mbImpl->get_entities_by_dimension( 0, 2, faces);
+ error = mbImpl->get_entities_by_dimension( 0, 3, cells);
+ //Perform queries
+ std::vector<EntityHandle> adjents;
+ Range mbents, ahfents;
+ //1D Queries //
+ //IQ1: For every vertex, obtain incident edges
+ for (Range::iterator i = verts.begin(); i != verts.end(); ++i) {
+ adjents.clear();
+ CHECK_ERR(error);
+ mbents.clear();
+ error = mbImpl->get_adjacencies( &*i, 1, 1, false, mbents );
+ CHECK_ERR(error);
+ CHECK_EQUAL(adjents.size(),mbents.size());
+ std::sort(adjents.begin(), adjents.end());
+ std::copy(adjents.begin(), adjents.end(), range_inserter(ahfents));
+ mbents = subtract(mbents, ahfents);
+ CHECK(!mbents.size());
+ //NQ1: For every edge, obtain neighbor edges
+ for (Range::iterator i = edges.begin(); i != edges.end(); ++i) {
+ adjents.clear();
+ CHECK_ERR(error);
+ mbents.clear();
+ error = mtu.get_bridge_adjacencies( *i, 0, 1, mbents);
+ CHECK_ERR(error);
+ CHECK_EQUAL(adjents.size(), mbents.size());
+ // 2D Queries
+ adjents.clear();
+ CHECK_ERR(error);
+ mbents.clear();
+ error = mbImpl->get_adjacencies( &*i, 1, 2, false, mbents);
+ CHECK_ERR(error);
+ adjents.clear();
+ CHECK_ERR(error);
+ mbents.clear();
+ CHECK_ERR(error);
+ //NQ2: For every face, obtain neighbor faces
+ for (Range::iterator i = faces.begin(); i != faces.end(); ++i) {
+ adjents.clear();
+ CHECK_ERR(error);
+ mbents.clear();
+ error = mtu.get_bridge_adjacencies( *i, 1, 2, mbents);
+ CHECK_ERR(error);
+ // 3D Queries
+ adjents.clear();
+ CHECK_ERR(error);
+ mbents.clear();
+ error = mbImpl->get_adjacencies(&*i, 1, 3, false, mbents);
+ CHECK_ERR(error);
+ adjents.clear();
+ CHECK_ERR(error);
+ mbents.clear();
+ CHECK_ERR(error);
+ //IQ32: For every face, obtain incident cells
+ adjents.clear();
+ CHECK_ERR(error);
+ mbents.clear();
+ CHECK_ERR(error);
+ //NQ3: For every cell, obtain neighbor cells
+ for (Range::iterator i = cells.begin(); i != cells.end(); ++i) {
+ adjents.clear();
+ CHECK_ERR(error);
+ mbents.clear();
+ error = mtu.get_bridge_adjacencies( *i, 2, 3, mbents);
+ CHECK_ERR(error);
int main(int argc, char *argv[])
- int result = 0;
+ if (argc==1)
+ else if (argc==2)
+ else {
+ return 1;
+ Core moab;
+ ErrorCode result;
- result += RUN_TEST(ahf_mbintf_test);
+ std::cout<<" ahf_mbintfc_test: ";
+ result = ahf_mbintfc_test(&moab);
+ std::cout<<"\n";
- return result;
Repository URL: https://bitbucket.org/fathomteam/moab/
This is a commit notification from bitbucket.org. You are receiving
this because you have the service enabled, addressing the recipient of
this email.
