[MOAB-dev] commit/MOAB: iulian07: remove a warning when built with	occ based cgm
    commits-noreply at bitbucket.org
    Mon Jul  7 13:08:04 CDT 2014
1 new commit in MOAB:
https://bitbucket.org/fathomteam/moab/commits/3f23a9d892b9/
Changeset:   3f23a9d892b9
Branch:      master
User:        iulian07
Date:        2014-07-07 20:06:47
Summary:     remove a warning when built with occ based cgm
group_ent_ids is not used when built wiht occ-based cgm
Affected #:  1 file
diff --git a/test/io/read_cgm_group_test.cpp b/test/io/read_cgm_group_test.cpp
index 3bfb137..6fd2d3c 100644
--- a/test/io/read_cgm_group_test.cpp
+++ b/test/io/read_cgm_group_test.cpp
@@ -129,8 +129,13 @@ void read_cylcube_groups_test()
   check_group_data( g_ids, g_names, g_ent_ids );
-void check_group_data(std::vector<int> & group_ids, std::vector<std::string> & group_names, std::vector<int> & group_ent_ids )
+void check_group_data(std::vector<int> & group_ids, std::vector<std::string> & group_names, std::vector<int> &
+#ifdef HAVE_OCC_STEP
+  /* group_ent_ids */
+#else
+     group_ent_ids
+#endif
   // Step files do not contain group data, MOAB shouldn't return errors when trying to access
Repository URL: https://bitbucket.org/fathomteam/moab/
This is a commit notification from bitbucket.org. You are receiving
this because you have the service enabled, addressing the recipient of
this email.
