[MOAB-dev] commit/MOAB: 3 new changesets
commits-noreply at bitbucket.org
Mon Jun 30 13:39:14 CDT 2014
3 new commits in MOAB:
https://bitbucket.org/fathomteam/moab/commits/ec47665edd1f/
Changeset: ec47665edd1f
Branch: None
User: iulian07
Date: 2014-06-30 17:51:34
Summary: changes for distcheck to work
environment vars could be exported to make distcheck,
we include only CC CXX F90 F77 FC, but we could include more
(LDFLAGS?)
Affected #: 1 file
diff --git a/configure.ac b/configure.ac
index 83d8ea5..0ef0b54 100644
--- a/configure.ac
+++ b/configure.ac
@@ -1205,7 +1205,6 @@ AC_SUBST([AM_CXXFLAGS])
AC_SUBST([AM_CFLAGS])
AC_SUBST([AM_FCFLAGS])
AC_SUBST([AM_FFLAGS])
-AC_SUBST([DISTCHECK_CONFIGURE_FLAGS])
AC_ARG_VAR([FC], [FORTRAN compiler command])
AC_CONFIG_HEADERS([config.h])
@@ -1261,6 +1260,22 @@ AC_CONFIG_FILES([Makefile
AC_CONFIG_COMMANDS([src/MOAB_FCDefs.h],
[sed -e "s/FC_FUNC/MOAB_FC_FUNC/" src/FCDefs.h >src/MOAB_FCDefs.h])
+# make distcheck will use this DISTCHECK_CONFIGURE_FLAGS
+# variable to be passed to configure line
+# some people include a lot of env vars here
+# I think we need only those; only distcheck is affected by this
+# for var in CC CFLAGS CPPFLAGS CXX CXXCPP LDFLAGS LIBS F90 FC F77; do
+for var in CC CXX F90 FC F77; do
+ eval isset=\${$var+set}
+ if test "$isset" = 'set' ; then
+ eval val=$`echo $var`
+ DISTCHECK_CONFIGURE_FLAGS="$DISTCHECK_CONFIGURE_FLAGS $var=\"$val\""
+ fi
+done
+AC_SUBST([DISTCHECK_CONFIGURE_FLAGS])
AC_OUTPUT
AC_MSG_RESULT([C: $CC $CFLAGS $CPPFLAGS])
https://bitbucket.org/fathomteam/moab/commits/ed098f038e6d/
Changeset: ed098f038e6d
Branch: None
User: iulian07
Date: 2014-06-30 19:50:38
Summary: for make distcheck add more env vars
add LIBS and LDFLAGS; the question is if we should
add even more, like CPPFLAGS, CFLAGS, etc?
Affected #: 1 file
index 0ef0b54..5de30e3 100644
--- a/configure.ac
+++ b/configure.ac
@@ -1261,12 +1261,12 @@ AC_CONFIG_COMMANDS([src/MOAB_FCDefs.h],
-# variable to be passed to configure line
-# for var in CC CFLAGS CPPFLAGS CXX CXXCPP LDFLAGS LIBS F90 FC F77; do
-for var in CC CXX F90 FC F77; do
+## original is commented out below; we use only a few
+## for var in CC CFLAGS CPPFLAGS CXX CXXCPP LDFLAGS LIBS F90 FC F77; do
+for var in CC CXX F90 FC F77 LDFLAGS LIBS; do
https://bitbucket.org/fathomteam/moab/commits/7f4a63db6188/
Changeset: 7f4a63db6188
Branch: master
User: iulian07
Date: 2014-06-30 20:36:34
Summary: Merge branch 'iulian07/distcheck_fix'
Affected #: 1 file
index 83d8ea5..5de30e3 100644
--- a/configure.ac
+++ b/configure.ac
+ fi
+done
AC_OUTPUT
Repository URL: https://bitbucket.org/fathomteam/moab/
This is a commit notification from bitbucket.org. You are receiving
this because you have the service enabled, addressing the recipient of
this email.
