[MOAB-dev] possible bug in WriteHDF5Parallel.cpp
Mark Filipiak mjf at staffmail.ed.ac.uk
Mon Jun 30 08:39:06 CDT 2014
Is the test_write_different_tags test in parallel_hdf5_test.cc valid for any
number of MPI processes?  I find that up to 9 processes the test passes,
then for 10 processes and up I get a failure like:
Wrote file: "test_write_different_tags.h5m"
HDF5-DIAG: Error detected in HDF5 (1.8.11) MPI-process 0:
  #000: H5A.c line 1092 in H5Aread(): unable to read attribute
    major: Attribute
    minor: Read failed
  #001: H5A.c line 1152 in H5A_read(): unable to convert between src and dst
dat
atypes
    major: Attribute
    minor: Feature is unsupported
  #002: H5T.c line 4525 in H5T_path_find(): no appropriate function for
conversi
on path
    major: Datatype
    minor: Unable to initialize object
ErrorCode Test Failed: MB_SUCCESS == rval
  at line 412 of 'parallel_hdf5_test.cc'
  Expected value: Success (0)
  Actual value:   Failure (16)
  test_write_different_tags: FAILED
The failure appears to be in the read step.
Mark Filipiak
EPCC
The University of Edinburgh
James Clerk Maxwell Building
Mayfield Road
Edinburgh
EH9 3JZ
UK
Telephone +44 131 651 3467
Fax +44 131 650 6555
The University of Edinburgh is a charitable body, registered in
Scotland, with registration number SC005336.
