[MOAB-dev] commit/MOAB: danwu: Simplified the code that gets the data type of __<dim_name>_LOC_VALS tag in NCHelperEuler.cpp and NCHelperFV.cpp.
    commits-noreply at bitbucket.org
    Wed Jun 25 17:27:19 CDT 2014
1 new commit in MOAB:
https://bitbucket.org/fathomteam/moab/commits/c48f097a353d/
Changeset:   c48f097a353d
Branch:      master
User:        danwu
Date:        2014-06-26 00:26:30
Summary:     Simplified the code that gets the data type of __<dim_name>_LOC_VALS tag in NCHelperEuler.cpp and NCHelperFV.cpp.
Affected #:  2 files
diff --git a/src/io/NCHelperEuler.cpp b/src/io/NCHelperEuler.cpp
index 5bf8eec..1f1e7a3 100644
--- a/src/io/NCHelperEuler.cpp
+++ b/src/io/NCHelperEuler.cpp
@@ -377,6 +377,15 @@ ErrorCode NCHelperEuler::init_mesh_vals()
   // __<dim_name>_LOC_VALS (for virtual slon, virtual slat, lon and lat)
+  // Assume all have the same data type as lon (expected type is float or double)
+  switch (varInfo["lon"].varDataType) {
+    case NC_FLOAT:
+    case NC_DOUBLE:
+      break;
+    default:
+      ERRORR(MB_FAILURE, "Unexpected data type for coordinate variable 'lon'");
   for (unsigned int i = 0; i != ijdimNames.size(); i++) {
     void* val = NULL;
     int val_len = 0;
@@ -397,31 +406,10 @@ ErrorCode NCHelperEuler::init_mesh_vals()
       val_len = jlCVals.size();
-    DataType data_type;
-    // Assume all has same data type as lon
-    switch (varInfo["lon"].varDataType) {
-      case NC_BYTE:
-      case NC_CHAR:
-      case NC_DOUBLE:
-        data_type = MB_TYPE_DOUBLE;
-        break;
-      case NC_FLOAT:
-        break;
-      case NC_INT:
-        data_type = MB_TYPE_INTEGER;
-        break;
-      case NC_SHORT:
-      default:
-        std::cerr << "Unrecognized data type for tag " << tag_name << std::endl;
-        ERRORR(MB_FAILURE, "Unrecognized data type");
-        break;
     std::stringstream ss_tag_name;
     ss_tag_name << ijdimNames[i] << "_LOC_VALS";
     tag_name = ss_tag_name.str();
-    rval = mbImpl->tag_get_handle(tag_name.c_str(), 0, data_type, tagh, MB_TAG_CREAT | MB_TAG_SPARSE | MB_TAG_VARLEN);
+    rval = mbImpl->tag_get_handle(tag_name.c_str(), 0, MB_TYPE_DOUBLE, tagh, MB_TAG_CREAT | MB_TAG_SPARSE | MB_TAG_VARLEN);
     ERRORR(rval, "Trouble creating __<dim_name>_LOC_VALS tag.");
     rval = mbImpl->tag_set_by_ptr(tagh, &_fileSet, 1, &val, &val_len);
     ERRORR(rval, "Trouble setting data for __<dim_name>_LOC_VALS tag.");
diff --git a/src/io/NCHelperFV.cpp b/src/io/NCHelperFV.cpp
index affd0ef..a26ebe6 100644
--- a/src/io/NCHelperFV.cpp
+++ b/src/io/NCHelperFV.cpp
@@ -378,6 +378,15 @@ ErrorCode NCHelperFV::init_mesh_vals()
   // __<dim_name>_LOC_VALS (for slon, slat, lon and lat)
+    case NC_FLOAT:
+    case NC_DOUBLE:
+      break;
+    default:
     void* val = NULL;
     int val_len = 0;
@@ -398,31 +407,10 @@ ErrorCode NCHelperFV::init_mesh_vals()
-      case NC_BYTE:
-      case NC_CHAR:
-      case NC_DOUBLE:
-        break;
-      case NC_FLOAT:
-        break;
-      case NC_INT:
-        break;
-      case NC_SHORT:
-      default:
-        break;
Repository URL: https://bitbucket.org/fathomteam/moab/
This is a commit notification from bitbucket.org. You are receiving
this because you have the service enabled, addressing the recipient of
this email.
