[MOAB-dev] commit/MOAB: danwu: Updated NC reader unit tests to remove the hard-coded values of levels.
commits-noreply at bitbucket.org
Tue Jun 24 14:07:35 CDT 2014
1 new commit in MOAB:
https://bitbucket.org/fathomteam/moab/commits/62e1ba2276c8/
Changeset: 62e1ba2276c8
Branch: danwu/shrink_unit_test_nc_files
User: danwu
Date: 2014-06-24 21:07:03
Summary: Updated NC reader unit tests to remove the hard-coded values of levels.
Affected #: 3 files
diff --git a/test/io/read_nc.cpp b/test/io/read_nc.cpp
index 369df83..4d503de 100644
--- a/test/io/read_nc.cpp
+++ b/test/io/read_nc.cpp
@@ -35,6 +35,8 @@ void test_read_fv_ghosting();
ErrorCode get_options(std::string& opts);
+const int levels = 26;
int main(int argc, char* argv[])
int result = 0;
@@ -88,10 +90,10 @@ void test_read_eul_all()
// Check for proper tags
Tag Ttag0, Ttag1, coordTag;
- rval = mb.tag_get_handle("T0", 26, MB_TYPE_DOUBLE, Ttag0);
+ rval = mb.tag_get_handle("T0", levels, MB_TYPE_DOUBLE, Ttag0);
CHECK_ERR(rval);
- rval = mb.tag_get_handle("T1", 26, MB_TYPE_DOUBLE, Ttag1);
+ rval = mb.tag_get_handle("T1", levels, MB_TYPE_DOUBLE, Ttag1);
CHECK_ERR(rval);
rval = mb.tag_get_handle("COORDS", 3, MB_TYPE_DOUBLE, coordTag);
@@ -123,10 +125,10 @@ void test_read_eul_onevar()
Tag Ttag0, Ttag1;
CHECK_ERR(rval);
CHECK_ERR(rval);
// Check values of tag T0 (first level) at some strategically chosen places below
@@ -139,7 +141,7 @@ void test_read_eul_onevar()
#endif
const double eps = 0.0001;
- double val[8 * 26];
+ double val[8 * levels];
if (1 == procs) {
Range global_quads;
@@ -151,14 +153,14 @@ void test_read_eul_onevar()
global_quads[48], global_quads[2303], global_quads[2352], global_quads[4607]};
rval = mb.tag_get_data(Ttag0, &gloabl_quad_ents[0], 8, val);
- CHECK_REAL_EQUAL(252.8529, val[0 * 26], eps); // First global quad
- CHECK_REAL_EQUAL(234.8390, val[1 * 26], eps); // 2256th global quad
- CHECK_REAL_EQUAL(232.6458, val[2 * 26], eps); // 2305th global quad
- CHECK_REAL_EQUAL(205.3905, val[3 * 26], eps); // 4560th global quad
- CHECK_REAL_EQUAL(252.7116, val[4 * 26], eps); // 49th global quad
- CHECK_REAL_EQUAL(232.6670, val[5 * 26], eps); // 2304th global quad
- CHECK_REAL_EQUAL(234.6922, val[6 * 26], eps); // 2353th global quad
- CHECK_REAL_EQUAL(200.6828, val[7 * 26], eps); // Last global quad
+ CHECK_REAL_EQUAL(252.8529, val[0 * levels], eps); // First global quad
+ CHECK_REAL_EQUAL(234.8390, val[1 * levels], eps); // 2256th global quad
+ CHECK_REAL_EQUAL(232.6458, val[2 * levels], eps); // 2305th global quad
+ CHECK_REAL_EQUAL(205.3905, val[3 * levels], eps); // 4560th global quad
+ CHECK_REAL_EQUAL(252.7116, val[4 * levels], eps); // 49th global quad
+ CHECK_REAL_EQUAL(232.6670, val[5 * levels], eps); // 2304th global quad
+ CHECK_REAL_EQUAL(234.6922, val[6 * levels], eps); // 2353th global quad
+ CHECK_REAL_EQUAL(200.6828, val[7 * levels], eps); // Last global quad
else if (2 == procs) {
Range local_quads;
@@ -170,16 +172,16 @@ void test_read_eul_onevar()
rval = mb.tag_get_data(Ttag0, &local_quad_ents[0], 4, val);
if (0 == rank) {
- CHECK_REAL_EQUAL(252.8529, val[0 * 26], eps); // First local quad, first global quad
- CHECK_REAL_EQUAL(234.8390, val[1 * 26], eps); // Median local quad, 2256th global quad
- CHECK_REAL_EQUAL(232.6458, val[2 * 26], eps); // Median local quad, 2305th global quad
- CHECK_REAL_EQUAL(205.3905, val[3 * 26], eps); // Last local quad, 4560th global quad
+ CHECK_REAL_EQUAL(252.8529, val[0 * levels], eps); // First local quad, first global quad
+ CHECK_REAL_EQUAL(234.8390, val[1 * levels], eps); // Median local quad, 2256th global quad
+ CHECK_REAL_EQUAL(232.6458, val[2 * levels], eps); // Median local quad, 2305th global quad
+ CHECK_REAL_EQUAL(205.3905, val[3 * levels], eps); // Last local quad, 4560th global quad
else if (1 == rank) {
- CHECK_REAL_EQUAL(252.7116, val[0 * 26], eps); // First local quad, 49th global quad
- CHECK_REAL_EQUAL(232.6670, val[1 * 26], eps); // Median local quad, 2304th global quad
- CHECK_REAL_EQUAL(234.6922, val[2 * 26], eps); // Median local quad, 2353th global quad
- CHECK_REAL_EQUAL(200.6828, val[3 * 26], eps); // Last local quad, last global quad
+ CHECK_REAL_EQUAL(252.7116, val[0 * levels], eps); // First local quad, 49th global quad
+ CHECK_REAL_EQUAL(232.6670, val[1 * levels], eps); // Median local quad, 2304th global quad
+ CHECK_REAL_EQUAL(234.6922, val[2 * levels], eps); // Median local quad, 2353th global quad
+ CHECK_REAL_EQUAL(200.6828, val[3 * levels], eps); // Last local quad, last global quad
@@ -198,10 +200,10 @@ void test_read_eul_onetimestep()
Tag Ttag0, Ttag1;
CHECK_EQUAL(rval, MB_TAG_NOT_FOUND);
CHECK_ERR(rval);
@@ -225,10 +227,10 @@ void test_read_eul_nomesh()
Tag Ttag0, Ttag1;
CHECK_ERR(rval);
// Now read 2nd timestep with nomesh option
@@ -237,7 +239,7 @@ void test_read_eul_nomesh()
CHECK_ERR(rval);
CHECK_ERR(rval);
@@ -265,17 +267,17 @@ void test_read_eul_novars()
Tag Ttag0, Ttag1;
opts = orig + std::string(";VARIABLE=T;TIMESTEP=0;NOMESH");
rval = mb.load_file(example_eul, &set, opts.c_str());
CHECK_ERR(rval);
CHECK_ERR(rval);
@@ -284,7 +286,7 @@ void test_read_eul_novars()
CHECK_ERR(rval);
CHECK_ERR(rval);
@@ -302,10 +304,10 @@ void test_read_fv_all()
CHECK_ERR(rval);
CHECK_ERR(rval);
@@ -326,10 +328,10 @@ void test_read_fv_onevar()
Tag Ttag0, Ttag1;
CHECK_ERR(rval);
CHECK_ERR(rval);
@@ -342,7 +344,7 @@ void test_read_fv_onevar()
#endif
if (1 == procs) {
Range global_quads;
@@ -354,14 +356,14 @@ void test_read_fv_onevar()
global_quads[36], global_quads[1655], global_quads[1692], global_quads[3311]};
- CHECK_REAL_EQUAL(253.6048, val[0 * 26], eps); // First global quad
- CHECK_REAL_EQUAL(232.2170, val[1 * 26], eps); // 1620th global quad
- CHECK_REAL_EQUAL(232.7454, val[2 * 26], eps); // 1657th global quad
- CHECK_REAL_EQUAL(210.2581, val[3 * 26], eps); // 3276th global quad
- CHECK_REAL_EQUAL(253.6048, val[4 * 26], eps); // 37th global quad
- CHECK_REAL_EQUAL(232.9553, val[5 * 26], eps); // 1656th global quad
- CHECK_REAL_EQUAL(232.1704, val[6 * 26], eps); // 1693th global quad
- CHECK_REAL_EQUAL(210.2581, val[7 * 26], eps); // Last global quad
+ CHECK_REAL_EQUAL(253.6048, val[0 * levels], eps); // First global quad
+ CHECK_REAL_EQUAL(232.2170, val[1 * levels], eps); // 1620th global quad
+ CHECK_REAL_EQUAL(232.7454, val[2 * levels], eps); // 1657th global quad
+ CHECK_REAL_EQUAL(210.2581, val[3 * levels], eps); // 3276th global quad
+ CHECK_REAL_EQUAL(253.6048, val[4 * levels], eps); // 37th global quad
+ CHECK_REAL_EQUAL(232.9553, val[5 * levels], eps); // 1656th global quad
+ CHECK_REAL_EQUAL(232.1704, val[6 * levels], eps); // 1693th global quad
+ CHECK_REAL_EQUAL(210.2581, val[7 * levels], eps); // Last global quad
Range local_quads;
@@ -373,16 +375,16 @@ void test_read_fv_onevar()
if (0 == rank) {
- CHECK_REAL_EQUAL(253.6048, val[0 * 26], eps); // First local quad, first global quad
- CHECK_REAL_EQUAL(232.2170, val[1 * 26], eps); // Median local quad, 1620th global quad
- CHECK_REAL_EQUAL(232.7454, val[2 * 26], eps); // Median local quad, 1657th global quad
- CHECK_REAL_EQUAL(210.2581, val[3 * 26], eps); // Last local quad, 3276th global quad
+ CHECK_REAL_EQUAL(253.6048, val[0 * levels], eps); // First local quad, first global quad
+ CHECK_REAL_EQUAL(232.2170, val[1 * levels], eps); // Median local quad, 1620th global quad
+ CHECK_REAL_EQUAL(232.7454, val[2 * levels], eps); // Median local quad, 1657th global quad
+ CHECK_REAL_EQUAL(210.2581, val[3 * levels], eps); // Last local quad, 3276th global quad
- CHECK_REAL_EQUAL(253.6048, val[0 * 26], eps); // First local quad, 37th global quad
- CHECK_REAL_EQUAL(232.9553, val[1 * 26], eps); // Median local quad, 1656th global quad
- CHECK_REAL_EQUAL(232.1704, val[2 * 26], eps); // Median local quad, 1693th global quad
- CHECK_REAL_EQUAL(210.2581, val[3 * 26], eps); // Last local quad, last global quad
+ CHECK_REAL_EQUAL(253.6048, val[0 * levels], eps); // First local quad, 37th global quad
+ CHECK_REAL_EQUAL(232.9553, val[1 * levels], eps); // Median local quad, 1656th global quad
+ CHECK_REAL_EQUAL(232.1704, val[2 * levels], eps); // Median local quad, 1693th global quad
+ CHECK_REAL_EQUAL(210.2581, val[3 * levels], eps); // Last local quad, last global quad
@@ -401,10 +403,10 @@ void test_read_fv_onetimestep()
Tag Ttag0, Ttag1;
CHECK_ERR(rval);
// Check for some tags with double underscore in the tag name
@@ -439,10 +441,10 @@ void test_read_fv_nomesh()
Tag Ttag0, Ttag1;
CHECK_ERR(rval);
@@ -451,7 +453,7 @@ void test_read_fv_nomesh()
CHECK_ERR(rval);
CHECK_ERR(rval);
@@ -479,17 +481,17 @@ void test_read_fv_novars()
Tag Ttag0, Ttag1;
rval = mb.load_file(example_fv, &set, opts.c_str());
CHECK_ERR(rval);
CHECK_ERR(rval);
@@ -498,7 +500,7 @@ void test_read_fv_novars()
CHECK_ERR(rval);
CHECK_ERR(rval);
diff --git a/test/io/read_ucd_nc.cpp b/test/io/read_ucd_nc.cpp
index 561d68a..0d2d045 100644
--- a/test/io/read_ucd_nc.cpp
+++ b/test/io/read_ucd_nc.cpp
@@ -30,6 +30,8 @@ void test_read_conn(); // Test reading connectivity file only
void get_options(std::string& opts);
int result = 0;
@@ -73,10 +75,10 @@ void test_read_all()
Tag Ttag0, Ttag1;
CHECK_ERR(rval);
CHECK_ERR(rval);
@@ -103,9 +105,9 @@ void test_read_onevar()
if (1 == procs) {
Tag Ttag0, Ttag1;
CHECK_ERR(rval);
CHECK_ERR(rval);
// Get vertices
@@ -125,10 +127,10 @@ void test_read_onevar()
double* data = (double*) Tbuf;
// Check first level values on 4 strategically selected vertices
- CHECK_REAL_EQUAL(233.1136, data[0 * 26], eps); // First vert
- CHECK_REAL_EQUAL(236.1505, data[1728 * 26], eps); // Median vert
- CHECK_REAL_EQUAL(235.7722, data[1729 * 26], eps); // Median vert
- CHECK_REAL_EQUAL(234.0416, data[3457 * 26], eps); // Last vert
+ CHECK_REAL_EQUAL(233.1136, data[0 * levels], eps); // First vert
+ CHECK_REAL_EQUAL(236.1505, data[1728 * levels], eps); // Median vert
+ CHECK_REAL_EQUAL(235.7722, data[1729 * levels], eps); // Median vert
+ CHECK_REAL_EQUAL(234.0416, data[3457 * levels], eps); // Last vert
@@ -146,10 +148,10 @@ void test_read_onetimestep()
Tag Ttag0, Ttag1;
CHECK_ERR(rval);
@@ -172,10 +174,10 @@ void test_read_nomesh()
Tag Ttag0, Ttag1;
CHECK_ERR(rval);
@@ -184,7 +186,7 @@ void test_read_nomesh()
CHECK_ERR(rval);
CHECK_ERR(rval);
@@ -211,17 +213,17 @@ void test_read_novars()
Tag Ttag0, Ttag1;
rval = mb.load_file(example, &set, opts.c_str());
CHECK_ERR(rval);
CHECK_ERR(rval);
@@ -230,7 +232,7 @@ void test_read_novars()
CHECK_ERR(rval);
CHECK_ERR(rval);
@@ -266,7 +268,7 @@ void test_read_coord_vars()
// Check lev tag size and values on file_set
rval = mb.tag_get_by_ptr(var_tag, &file_set, 1, &var_data, &var_len);
CHECK_ERR(rval);
- CHECK_EQUAL(26, var_len);
+ CHECK_EQUAL(levels, var_len);
double* lev_val = (double*)var_data;
const double eps = 1e-10;
CHECK_REAL_EQUAL(3.54463800000002, lev_val[0], eps);
@@ -307,7 +309,7 @@ void test_read_coord_vars()
// Check lev tag size and values on file_set2
rval = mb.tag_get_by_ptr(var_tag, &file_set2, 1, &var_data, &var_len);
CHECK_ERR(rval);
CHECK_REAL_EQUAL(992.556100000005, lev_val[25], eps);
@@ -368,7 +370,7 @@ void test_gather_onevar()
Tag Ttag0, gid_tag;
- rval = mb.tag_get_handle("T0", 26, MB_TYPE_DOUBLE, Ttag0, MB_TAG_DENSE);
+ rval = mb.tag_get_handle("T0", levels, MB_TYPE_DOUBLE, Ttag0, MB_TAG_DENSE);
CHECK_ERR(rval);
rval = mb.tag_get_handle(GLOBAL_ID_TAG_NAME, 1, MB_TYPE_INTEGER, gid_tag, MB_TAG_DENSE);
@@ -384,7 +386,7 @@ void test_gather_onevar()
CHECK_EQUAL((size_t)3458, gather_set_verts.size());
// Get T0 tag values on 4 strategically selected gather set vertices
- double T0_val[4 * 26];
+ double T0_val[4 * levels];
EntityHandle vert_ents[] = {gather_set_verts[0], gather_set_verts[1728],
gather_set_verts[1729], gather_set_verts[3457]};
rval = mb.tag_get_data(Ttag0, vert_ents, 4, T0_val);
@@ -393,10 +395,10 @@ void test_gather_onevar()
const double eps = 0.001;
- CHECK_REAL_EQUAL(233.1136, T0_val[0 * 26], eps); // First vert
- CHECK_REAL_EQUAL(236.1505, T0_val[1 * 26], eps); // Median vert
- CHECK_REAL_EQUAL(235.7722, T0_val[2 * 26], eps); // Median vert
- CHECK_REAL_EQUAL(234.0416, T0_val[3 * 26], eps); // Last vert
+ CHECK_REAL_EQUAL(233.1136, T0_val[0 * levels], eps); // First vert
+ CHECK_REAL_EQUAL(236.1505, T0_val[1 * levels], eps); // Median vert
+ CHECK_REAL_EQUAL(235.7722, T0_val[2 * levels], eps); // Median vert
+ CHECK_REAL_EQUAL(234.0416, T0_val[3 * levels], eps); // Last vert
#endif
diff --git a/test/parallel/ucdtrvpart.cpp b/test/parallel/ucdtrvpart.cpp
index 0800b4c..a67c519 100644
--- a/test/parallel/ucdtrvpart.cpp
+++ b/test/parallel/ucdtrvpart.cpp
@@ -18,6 +18,7 @@ void test_read_parallel(int num_verts, bool test_nb_nodes);
void test_multiple_loads_of_same_file();
std::string partition_method;
@@ -192,7 +193,7 @@ void test_multiple_loads_of_same_file()
Tag Ttag0;
CHECK_ERR(rval);
int count;
@@ -205,14 +206,14 @@ void test_multiple_loads_of_same_file()
if (0 == rank) {
- CHECK_REAL_EQUAL(237.1977, data[912 * 26], eps); // Median vert
- CHECK_REAL_EQUAL(234.9711, data[1824 * 26], eps); // Last vert
+ CHECK_REAL_EQUAL(237.1977, data[912 * levels], eps); // Median vert
+ CHECK_REAL_EQUAL(234.9711, data[1824 * levels], eps); // Last vert
- CHECK_REAL_EQUAL(231.0446, data[912 * 26], eps); // Median vert
- CHECK_REAL_EQUAL(234.0416, data[1824 * 26], eps); // Last vert
+ CHECK_REAL_EQUAL(231.0446, data[912 * levels], eps); // Median vert
+ CHECK_REAL_EQUAL(234.0416, data[1824 * levels], eps); // Last vert
Repository URL: https://bitbucket.org/fathomteam/moab/
This is a commit notification from bitbucket.org. You are receiving
this because you have the service enabled, addressing the recipient of
this email.
