[MOAB-dev] Building MOAB from Scratch: Error when I run 'make'
    Rajeev Jain
    jain at mcs.anl.gov
    Wed Jun 18 11:42:59 CDT 2014
It seems like #include <time.h> is missing from MBZoltan.hpp.
Please try adding it.
Rajeev
To: "moab-dev at mcs.anl.gov" <moab-dev at mcs.anl.gov>
Sent: Wednesday, June 18, 2014 11:18 AM
Subject: [MOAB-dev] Building MOAB from Scratch: Error when I run 'make'
Dear Moab-Dev Community,
I am building MOAB from scratch on a cluster. I am using the following command './configure' command:
./configure --with-mpi --with-hdf5=<hdf5-location> --enable-mbzoltan --with-zoltan=<zoltan_dir>
As you can see, I am using MOAB with hdf5 and Zoltan.  I am using a PGI compiler.  After I am done with the configure, I execute the 'make' command and get the following errors:
$ make
make  all-recursive
make[1]: Entering directory `/home/sharedlib/moab-4.6.3'
Making all in src
make[2]: Entering directory `/home/sharedlib/moab-4.6.3/src'
make  all-recursive
make[3]: Entering directory `/home/sharedlib/moab-4.6.3/src'
Making all in parallel
make[4]: Entering directory `/home/sharedlib/moab-4.6.3/src/parallel'
make  all-am
make[5]: Entering directory `/home/sharedlib/moab-4.6.3/src/parallel'
make[5]: Leaving directory `/home/sharedlib/moab-4.6.3/src/parallel'
make[4]: Leaving directory `/home/sharedlib/moab-4.6.3/src/parallel'
Making all in io
make[4]: Entering directory `/home/sharedlib/moab-4.6.3/src/io'
Making all in mhdf
make[5]: Entering directory `/home/sharedlib/moab-4.6.3/src/io/mhdf'
make[5]: Nothing to be done for `all'.
make[5]: Leaving directory `/home/sharedlib/moab-4.6.3/src/io/mhdf'
Making all in .
make[5]: Entering directory `/home/sharedlib/moab-4.6.3/src/io'
make[5]: Nothing to be done for `all-am'.
make[5]: Leaving directory `/home/sharedlib/moab-4.6.3/src/io'
make[4]: Leaving directory `/home/sharedlib/moab-4.6.3/src/io'
Making all in LocalDiscretization
make[4]: Entering directory `/home/sharedlib/moab-4.6.3/src/LocalDiscretization'
make[4]: Nothing to be done for `all'.
make[4]: Leaving directory `/home/sharedlib/moab-4.6.3/src/LocalDiscretization'
Making all in .
make[4]: Entering directory `/home/sharedlib/moab-4.6.3/src'
    source='./../tools/mbzoltan/MBZoltan.cpp' object='MBZoltan.lo' libtool=yes \
    DEPDIR=.deps depmode=none /bin/sh ../config/depcomp \
    /bin/sh ../libtool  --tag=CXX   --mode=compile mpiCC -DHAVE_CONFIG_H -I. -I.. -I../src/moab -I../src/parallel  -I/home/sharedlib/hdf5_parallel_build/hdf5/include  -DTEMPLATE_SPECIALIZATION -DTEMPLATE_FUNC_SPECIALIZATION -DHAVE_VSNPRINTF -D_FILE_OFFSET_BITS=64
 -DUSE_MPI -DHDF5_FILE -DHDF5_PARALLEL -DHAVE_ZOLTAN -I./parallel -DIS_BUILDING_MB -I. -I./io -I./io/mhdf/include -I./parallel -I./LocalDiscretization -I/home/sharedlib/Zoltan_v3.8/    -O2 -DNDEBUG -c -o MBZoltan.lo `test -f './../tools/mbzoltan/MBZoltan.cpp'
 || echo './'`./../tools/mbzoltan/MBZoltan.cpp
libtool: compile:  mpiCC -DHAVE_CONFIG_H -I. -I.. -I../src/moab -I../src/parallel -I/home/sharedlib/hdf5_parallel_build/hdf5/include -DTEMPLATE_SPECIALIZATION -DTEMPLATE_FUNC_SPECIALIZATION -DHAVE_VSNPRINTF -D_FILE_OFFSET_BITS=64 -DUSE_MPI -DHDF5_FILE -DHDF5_PARALLEL
 -DHAVE_ZOLTAN -I./parallel -DIS_BUILDING_MB -I. -I./io -I./io/mhdf/include -I./parallel -I./LocalDiscretization -I/home/sharedlib/Zoltan_v3.8/ -O2 -DNDEBUG -c ./../tools/mbzoltan/MBZoltan.cpp -o MBZoltan.o
"./../tools/mbzoltan/MBZoltan.cpp", line 254: error: identifier "clock_t" is
          undefined
    clock_t t = clock();
"./../tools/mbzoltan/MBZoltan.cpp", line 254: error: identifier "clock" is
          undefined
"./../tools/mbzoltan/MBZoltan.cpp", line 338: error: identifier
          "CLOCKS_PER_SEC" is undefined
      std::cout << " time to LB_partition " << (clock() - t) / (double) CLOCKS_PER_SEC  << "s. \n";
"./../tools/mbzoltan/MBZoltan.cpp", line 380: error: identifier "clock_t" is
          undefined
"./../tools/mbzoltan/MBZoltan.cpp", line 380: error: identifier "clock" is
          undefined
"./../tools/mbzoltan/MBZoltan.cpp", line 472: error: identifier
      std::cout << " time to assemble graph: " << (clock() - t) / (double) CLOCKS_PER_SEC  << "s. \n";
"./../tools/mbzoltan/MBZoltan.cpp", line 490: error: identifier
      std::cout << " time to initialize points: " << (clock() - t) / (double) CLOCKS_PER_SEC  << "s. \n";
"./../tools/mbzoltan/MBZoltan.cpp", line 592: error: identifier
"./../tools/mbzoltan/MBZoltan.cpp", line 612: error: identifier
      std::cout << " time to write partition in memory " <<(clock() - t) / (double) CLOCKS_PER_SEC  << "s. \n";
9 errors detected in the compilation of "./../tools/mbzoltan/MBZoltan.cpp".
Has anyone encountered these problems? If so, can you recommend something I can do to fix it?  Your help is greatly appreciated.
Best,
Saumil
URL: <http://lists.mcs.anl.gov/pipermail/moab-dev/attachments/20140618/d31c3fae/attachment-0001.html>
