[MOAB-dev] In PyTAPS, how to create edge entities by pytaps?
Paul Wilson wilsonp at engr.wisc.edu
Wed Jun 18 07:38:16 CDT 2014
Hi Huayi,
I think the issue is that MOAB (the underlying mesh database for this
iMesh implementation) tries to conserve memory by not actually creating
entities at every dimension.  When reading a VTK file, the vertices,
faces and elements are explicitly generated, with the other entities
defined implicitly by their connectivity.
It may be necessary to build these entities explicitly in order to get a
count using some of the get_adjacency calls to determine the
connectivity of the mesh.
Paul
On 06/17/2014 09:23 AM, Huayi Wei wrote:
> Hi, there,
> I loaded a tri mesh by PyTAPS. And I want to get the edge entities,
> but edge entities doesn't exist in this mesh instance. So how to
> create or get the edge entities ?
> >>> s = "4k-tri-plane.vtk"
> >>> mesh = iMesh.Mesh()
> >>> mesh.load(s)
> >>> mesh.getNumOfType(iBase.Type.all)
> 6085
> >>> mesh.getNumOfType(iBase.Type.vertex)
> 2085
> >>> mesh.getNumOfType(iBase.Type.face)
> 4000
> Best
> Huayi
Paul Wilson ~ UW-Madison ~ 608-263-0807 ~ cal: http://bit.ly/pphw-cal
Professor, Engineering Physics. ~ http://cnerg.engr.wisc.edu
Faculty Director, Advanced Computing Infrastructure
Type: application/pkcs7-signature
Desc: S/MIME Cryptographic Signature
URL: <http://lists.mcs.anl.gov/pipermail/moab-dev/attachments/20140618/411fe8ed/attachment.bin>
