[MOAB-dev] commit/MOAB: danwu: Added a new read option TRIVIAL_PARTITION_SHIFT to NC reader (for HOMME, MPAS and GCRM), which can be used to rotate trivial partition across processors. In parallel unit test of NC writer, localGidVertsOwned.psize() is always 1 for HOMME after trivial partition, so we can apply this option to test cases where localGidVertsOwned.psize() > 1 (and get better code coverage).
    commits-noreply at bitbucket.org
    Wed Jun 11 15:18:10 CDT 2014
1 new commit in MOAB:
https://bitbucket.org/fathomteam/moab/commits/21b3e843c6b5/
Changeset:   21b3e843c6b5
Branch:      master
User:        danwu
Date:        2014-06-11 22:17:53
Summary:     Added a new read option TRIVIAL_PARTITION_SHIFT to NC reader (for HOMME, MPAS and GCRM), which can be used to rotate trivial partition across processors. In parallel unit test of NC writer, localGidVertsOwned.psize() is always 1 for HOMME after trivial partition, so we can apply this option to test cases where localGidVertsOwned.psize() > 1 (and get better code coverage).
Affected #:  6 files
diff --git a/src/io/NCHelperGCRM.cpp b/src/io/NCHelperGCRM.cpp
index 14c4b5f..13103a8 100644
--- a/src/io/NCHelperGCRM.cpp
+++ b/src/io/NCHelperGCRM.cpp
@@ -248,6 +248,7 @@ ErrorCode NCHelperGCRM::check_existing_mesh()
 ErrorCode NCHelperGCRM::create_mesh(Range& faces)
   int& gatherSetRank = _readNC->gatherSetRank;
+  int& trivialPartitionShift = _readNC->trivialPartitionShift;
   bool& noEdges = _readNC->noEdges;
   DebugOutput& dbgOut = _readNC->dbgOut;
@@ -267,19 +268,24 @@ ErrorCode NCHelperGCRM::create_mesh(Range& faces)
     createGatherSet = true;
   if (procs >= 2) {
+    // Shift rank to obtain a rotated trivial partition
+    int shifted_rank = rank;
+    if (trivialPartitionShift > 0)
+      shifted_rank = (rank + trivialPartitionShift) % procs;
     // Compute the number of local cells on this proc
     nLocalCells = int(std::floor(1.0 * nCells / procs));
     // The starting global cell index in the GCRM file for this proc
-    int start_cell_idx = rank * nLocalCells;
+    int start_cell_idx = shifted_rank * nLocalCells;
     // Number of extra cells after equal split over procs
     int iextra = nCells % procs;
     // Allocate extra cells over procs
-    if (rank < iextra)
+    if (shifted_rank < iextra)
       nLocalCells++;
-    start_cell_idx += std::min(rank, iextra);
+    start_cell_idx += std::min(shifted_rank, iextra);
     start_cell_idx++; // 0 based -> 1 based
diff --git a/src/io/NCHelperHOMME.cpp b/src/io/NCHelperHOMME.cpp
index 85f3a69..a296314 100644
--- a/src/io/NCHelperHOMME.cpp
+++ b/src/io/NCHelperHOMME.cpp
@@ -258,6 +258,7 @@ ErrorCode NCHelperHOMME::create_mesh(Range& faces)
   bool& spectralMesh = _readNC->spectralMesh;
   int rank = 0;
   int procs = 1;
@@ -355,24 +356,29 @@ ErrorCode NCHelperHOMME::create_mesh(Range& faces)
     tmp_conn[4 * i + 3] = tmp_conn2[i + 3 * num_quads];
-  // Need to know whether we'll be creating gather mesh later, to make sure we allocate enough space
-  // in one shot
+  // Need to know whether we'll be creating gather mesh later, to make sure
+  // we allocate enough space in one shot
   bool create_gathers = false;
   if (rank == gatherSetRank)
     create_gathers = true;
+  if (procs >= 2 && trivialPartitionShift > 0)
   // Compute the number of local quads, accounting for coarse or fine representation
   // spectral_unit is the # fine quads per coarse quad, or spectralOrder^2
   int spectral_unit = (spectralMesh ? _spectralOrder * _spectralOrder : 1);
   // num_coarse_quads is the number of quads instantiated in MOAB; if !spectralMesh, num_coarse_quads = num_fine_quads
   num_coarse_quads = int(std::floor(1.0 * num_quads / (spectral_unit * procs)));
   // start_idx is the starting index in the HommeMapping connectivity list for this proc, before converting to coarse quad representation
-  start_idx = 4 * rank * num_coarse_quads * spectral_unit;
+  start_idx = 4 * shifted_rank * num_coarse_quads * spectral_unit;
   // iextra = # coarse quads extra after equal split over procs
   int iextra = num_quads % (procs * spectral_unit);
     num_coarse_quads++;
-  start_idx += 4 * spectral_unit * std::min(rank, iextra);
+  start_idx += 4 * spectral_unit * std::min(shifted_rank, iextra);
   // num_fine_quads is the number of quads in the connectivity list in HommeMapping file assigned to this proc
   num_fine_quads = spectral_unit * num_coarse_quads;
diff --git a/src/io/NCHelperMPAS.cpp b/src/io/NCHelperMPAS.cpp
index a02e4ce..b453b82 100644
--- a/src/io/NCHelperMPAS.cpp
+++ b/src/io/NCHelperMPAS.cpp
@@ -299,6 +299,7 @@ ErrorCode NCHelperMPAS::create_mesh(Range& faces)
   Interface*& mbImpl = _readNC->mbImpl;
   bool& noMixedElements = _readNC->noMixedElements;
@@ -318,19 +319,24 @@ ErrorCode NCHelperMPAS::create_mesh(Range& faces)
   if (procs >= 2) {
     // The starting global cell index in the MPAS file for this proc
       nLocalCells++;
diff --git a/src/io/ReadNC.cpp b/src/io/ReadNC.cpp
index cd2c004..4543b64 100644
--- a/src/io/ReadNC.cpp
+++ b/src/io/ReadNC.cpp
@@ -25,7 +25,7 @@ ReadNC::ReadNC(Interface* impl) :
   myPcomm(NULL),
 #endif
   noMesh(false), noVars(false), spectralMesh(false), noMixedElements(false), noEdges(false),
-  gatherSetRank(-1), tStepBase(-1), myHelper(NULL)
+  gatherSetRank(-1), tStepBase(-1), trivialPartitionShift(0), myHelper(NULL)
   assert(impl != NULL);
   impl->query_interface(readMeshIface);
@@ -289,6 +289,12 @@ ErrorCode ReadNC::parse_options(const FileOptions& opts, std::vector<std::string
     return rval;
+  rval = opts.get_int_option("TRIVIAL_PARTITION_SHIFT", 1, trivialPartitionShift);
+  if (MB_TYPE_OUT_OF_RANGE == rval) {
+    readMeshIface->report_error("Invalid value for TRIVIAL_PARTITION_SHIFT option");
+    return rval;
 #ifdef USE_MPI
   isParallel = (opts.match_option("PARALLEL","READ_PART") != MB_ENTITY_NOT_FOUND);
diff --git a/src/io/ReadNC.hpp b/src/io/ReadNC.hpp
index 1b81d15..b4ec60b 100644
--- a/src/io/ReadNC.hpp
+++ b/src/io/ReadNC.hpp
@@ -209,6 +209,7 @@ private:
   bool noEdges;
   int gatherSetRank;
   int tStepBase;
+  int trivialPartitionShift;
   //! Helper class instance
   NCHelper* myHelper;
diff --git a/test/io/write_nc.cpp b/test/io/write_nc.cpp
index 7dd8d4f..d0ee024 100644
--- a/test/io/write_nc.cpp
+++ b/test/io/write_nc.cpp
@@ -465,8 +465,10 @@ void test_homme_read_write_T()
   // Read non-set variable T and set variable lat
   read_opts += ";VARIABLE=T,lat;DEBUG_IO=0";
-  if (procs > 1)
-    read_opts += ";PARALLEL_RESOLVE_SHARED_ENTS";
+  if (procs > 1) {
+    // Rotate trivial partition, otherwise localGidVertsOwned.psize() is always 1
+    read_opts += ";PARALLEL_RESOLVE_SHARED_ENTS;TRIVIAL_PARTITION_SHIFT=1";
   rval = mb.load_file(example_homme, &set, read_opts.c_str());
   CHECK_ERR(rval);
Repository URL: https://bitbucket.org/fathomteam/moab/
This is a commit notification from bitbucket.org. You are receiving
this because you have the service enabled, addressing the recipient of
this email.
