[MOAB-dev] commit/MOAB: iulian07: example for multiple	communicators
    Robert Jacob
    jacob at mcs.anl.gov
    Tue Jun 10 11:47:47 CDT 2014
On 6/10/14 11:41 AM, commits-noreply at bitbucket.org wrote:
> The original MPI_WORLD_COMM is split into nbComms (a second
> optional argument to ./HelloParMOAB, first is the file to load)
> each communicator will load a full mesh in parallel, which will be distributed
> among  its tasks
> the communicators are completely independent from MOAB's point of view, and they
> will never "inter-communicate" in moab code.
> so MOAB will handle only "intra-communication"
In MCT, we advocate that each model have its own communicator but there
is still a copy of MPI_WORLD_COMM that can be used for
inter-communication.  What is the solution for a coupled model with
MOAB/Coupe?
Rob
> Affected #:  1 file
> diff --git a/examples/HelloParMOAB.cpp b/examples/HelloParMOAB.cpp
> index 5bcc4ab..3611a8d 100644
> --- a/examples/HelloParMOAB.cpp
> +++ b/examples/HelloParMOAB.cpp
> @@ -2,6 +2,12 @@
>    * \brief Read mesh into MOAB and resolve/exchange/report shared and ghosted entities \n
>    * <b>To run</b>: mpiexec -np 4 HelloMoabPar [filename]\n
> + *  It shows how to load the mesh independently, on multiple
> + *  communicators (with second argument, the number of comms)
> + *  mpiexec -np 8 HelloMoabPar [filename] [nbComms]
>   #include "moab/ParallelComm.hpp"
> @@ -26,6 +32,10 @@ int main(int argc, char **argv)
>       test_file_name = argv[1];
> +  int nbComms = 1;
> +  if (argc > 2)
> +    nbComms = atoi(argv[2]);
>     options = "PARALLEL=READ_PART;PARTITION=PARALLEL_PARTITION;PARALLEL_RESOLVE_SHARED_ENTS";
>     // Get MOAB instance and read the file with the specified options
> @@ -33,15 +43,38 @@ int main(int argc, char **argv)
>     if (NULL == mb)
>       return 1;
> +  MPI_Comm comm ;
> +  int global_rank, global_size;
> +  MPI_Comm_rank( MPI_COMM_WORLD, &global_rank );
> +  MPI_Comm_rank( MPI_COMM_WORLD, &global_size );
> +  int color = global_rank%nbComms; // for each angle group a different color
> +  if (nbComms>1)
> +    // split the communicator, into ngroups = nbComms
> +    MPI_Comm_split( MPI_COMM_WORLD, color, global_rank, &comm );
> +  else
> +    comm = MPI_COMM_WORLD;
>     // Get the ParallelComm instance
> -  ParallelComm* pcomm = new ParallelComm(mb, MPI_COMM_WORLD);
> +  ParallelComm* pcomm = new ParallelComm(mb, comm);
>     int nprocs = pcomm->proc_config().proc_size();
>     int rank = pcomm->proc_config().proc_rank();
> -  MPI_Comm comm = pcomm->proc_config().proc_comm();
> +  MPI_Comm rcomm = pcomm->proc_config().proc_comm();
> +  assert(rcomm==comm);
> +  if (global_rank == 0)
> +    cout<< " global rank:" <<global_rank << " color:" << color << " rank:" << rank << " of " << nprocs << " processors\n";
> +  if (global_rank == 1)
> -  if (rank == 0)
> +  MPI_Barrier(MPI_COMM_WORLD);
>       cout << "Reading file " << test_file_name << "\n  with options: " << options << endl
> -         << " on " << nprocs << " processors\n";
> +         << " on " << nprocs << " processors on " << nbComms << " communicator(s) \n";
>     ErrorCode rval = mb->load_file(test_file_name.c_str(), 0, options.c_str());
>     if (rval != MB_SUCCESS) {
> @@ -69,9 +102,9 @@ int main(int argc, char **argv)
>     for (int i = 0; i < 4; i++)
>       nums[i] = (int)owned_entities.num_of_dimension(i);
>     vector<int> rbuf(nprocs*4, 0);
> -  MPI_Gather(nums, 4, MPI_INT, &rbuf[0], 4, MPI_INT, 0, MPI_COMM_WORLD);
> +  MPI_Gather(nums, 4, MPI_INT, &rbuf[0], 4, MPI_INT, 0, comm);
>     // Print the stats gathered:
> -  if (rank == 0) {
> +  if (global_rank == 0) {
>       for (int i = 0; i < nprocs; i++)
>         cout << " Shared, owned entities on proc " << i << ": " << rbuf[4*i] << " verts, " <<
>             rbuf[4*i + 1] << " edges, " << rbuf[4*i + 2] << " faces, " << rbuf[4*i + 3] << " elements" << endl;
> @@ -109,7 +142,7 @@ int main(int argc, char **argv)
>     // gather the statistics on processor 0
> -  if (rank == 0) {
>       cout << " \n\n After exchanging one ghost layer: \n";
>       for (int i = 0; i < nprocs; i++) {
> Repository URL: https://bitbucket.org/fathomteam/moab/
> This is a commit notification from bitbucket.org. You are receiving
> this because you have the service enabled, addressing the recipient of
> this email.
