[MOAB-dev] commit/MOAB: danwu: Updated "gather set" code for GCRM reader.
commits-noreply at bitbucket.org commits-noreply at bitbucket.org
Fri Jun 6 12:29:09 CDT 2014
1 new commit in MOAB:
https://bitbucket.org/fathomteam/moab/commits/7929743030a8/
Changeset:   7929743030a8
Branch:      master
User:        danwu
Date:        2014-06-06 19:28:54
Summary:     Updated "gather set" code for GCRM reader.
Affected #:  4 files
diff --git a/src/io/NCHelperGCRM.cpp b/src/io/NCHelperGCRM.cpp
index 6870808..cb176f3 100644
--- a/src/io/NCHelperGCRM.cpp
+++ b/src/io/NCHelperGCRM.cpp
@@ -339,10 +339,6 @@ ErrorCode NCHelperGCRM::create_mesh(Range& faces)
   ERRORS(success, "Failed on wait_all.");
 #endif
-  // GCRM is 0 based, convert vertex indices from 0 to 1 based
-  for (std::size_t idx = 0; idx < vertices_on_local_cells.size(); idx++)
-      vertices_on_local_cells[idx] += 1;
   // Correct vertices_on_local_cells array. Pentagons as hexagons should have
   // a connectivity like 123455 and not 122345
   for (int local_cell_idx = 0; local_cell_idx < nLocalCells; local_cell_idx++) {
@@ -358,6 +354,10 @@ ErrorCode NCHelperGCRM::create_mesh(Range& faces)
+  // GCRM is 0 based, convert vertex indices from 0 to 1 based
+  for (std::size_t idx = 0; idx < vertices_on_local_cells.size(); idx++)
+    vertices_on_local_cells[idx] += 1;
   // Create local vertices
   EntityHandle start_vertex;
   ErrorCode rval = create_local_vertices(vertices_on_local_cells, start_vertex);
@@ -374,7 +374,6 @@ ErrorCode NCHelperGCRM::create_mesh(Range& faces)
   ERRORR(rval, "Failed to create local cells for GCRM mesh.");
   if (createGatherSet) {
-#if 0
     EntityHandle gather_set;
     rval = _readNC->readMeshIface->create_gather_set(gather_set);
     ERRORR(rval, "Failed to create gather set.");
@@ -393,7 +392,6 @@ ErrorCode NCHelperGCRM::create_mesh(Range& faces)
     // Create gather set cells with padding
     rval = create_padded_gather_set_cells(gather_set, start_gather_set_vertex);
     ERRORR(rval, "Failed to create gather set cells for GCRM mesh.");
-#endif
   return MB_SUCCESS;
@@ -973,11 +971,10 @@ ErrorCode NCHelperGCRM::create_local_vertices(const std::vector<int>& vertices_o
   // Convert lon/lat/rad to x/y/z
   double* zptr = arrays[2];
-  //const double pideg = acos(-1.0) / 180.0;
   double rad = 8000.0 + levVals[0];
   for (int i = 0; i < nLocalVertices; i++) {
     double cosphi = cos(yptr[i]);
-    double zmult =  sin(yptr[i]);
+    double zmult = sin(yptr[i]);
     double xmult = cosphi * cos(xptr[i]);
     double ymult = cosphi * sin(xptr[i]);
     xptr[i] = rad * xmult;
@@ -1041,7 +1038,7 @@ ErrorCode NCHelperGCRM::create_local_edges(EntityHandle start_vertex)
   // GCRM is 0 based, convert edge indices from 0 to 1 based
   for (std::size_t idx = 0; idx < edges_on_local_cells.size(); idx++)
-      edges_on_local_cells[idx] += 1;
+    edges_on_local_cells[idx] += 1;
   // Collect local edges
   std::sort(edges_on_local_cells.begin(), edges_on_local_cells.end());
@@ -1115,15 +1112,12 @@ ErrorCode NCHelperGCRM::create_local_edges(EntityHandle start_vertex)
 #endif
-  // GCRM is 0 based, convert edge indices from 0 to 1 based
-  for (int idx = 0; idx < nLocalEdges*2; idx++)
-      vertices_on_local_edges[idx] += 1;
   // Populate connectivity data for local edges
   // Convert in-place from int (stored in the first half) to EntityHandle
   // Reading backward is the trick
   for (int edge_vert = nLocalEdges * 2 - 1; edge_vert >= 0; edge_vert--) {
-    int global_vert_idx = vertices_on_local_edges[edge_vert]; // Global vertex index, 1 based
+    // Note, indices stored in vertices_on_local_edges are 0 based
+    int global_vert_idx = vertices_on_local_edges[edge_vert] + 1; // Global vertex index, 1 based
     int local_vert_idx = localGidVerts.index(global_vert_idx); // Local vertex index, 0 based
     assert(local_vert_idx != -1);
     conn_arr_edges[edge_vert] = start_vertex + local_vert_idx;
@@ -1166,6 +1160,7 @@ ErrorCode NCHelperGCRM::create_padded_local_cells(const std::vector<int>& vertic
   // the last vertices repeated for pentagons, e.g. 122345 => 123455
     for (int i = 0; i < EDGES_PER_CELL; i++) {
+      // Note, indices stored in vertices_on_local_cells are 1 based
       EntityHandle global_vert_idx = vertices_on_local_cells[local_cell_idx * EDGES_PER_CELL + i]; // Global vertex index, 1 based
@@ -1176,7 +1171,6 @@ ErrorCode NCHelperGCRM::create_padded_local_cells(const std::vector<int>& vertic
   return MB_SUCCESS;
-#if 0
 ErrorCode NCHelperGCRM::create_gather_set_vertices(EntityHandle gather_set, EntityHandle& gather_set_start_vertex)
   Interface*& mbImpl = _readNC->mbImpl;
@@ -1197,8 +1191,8 @@ ErrorCode NCHelperGCRM::create_gather_set_vertices(EntityHandle gather_set, Enti
   // Read x coordinates for gather set vertices
   double* xptr = arrays[0];
   int xVertexVarId;
-  int success = NCFUNC(inq_varid)(_fileId, "xVertex", &xVertexVarId);
-  ERRORS(success, "Failed to get variable id of xVertex.");
+  int success = NCFUNC(inq_varid)(_fileId, "grid_corner_lon", &xVertexVarId);
+  ERRORS(success, "Failed to get variable id of grid_corner_lon.");
   NCDF_SIZE read_start = 0;
   NCDF_SIZE read_count = static_cast<NCDF_SIZE>(nVertices);
 #ifdef PNETCDF_FILE
@@ -1206,49 +1200,44 @@ ErrorCode NCHelperGCRM::create_gather_set_vertices(EntityHandle gather_set, Enti
   success = NCFUNC(begin_indep_data)(_fileId);
   ERRORS(success, "Failed to begin independent I/O mode.");
   success = NCFUNCG(_vara_double)(_fileId, xVertexVarId, &read_start, &read_count, xptr);
-  ERRORS(success, "Failed to read xVertex data.");
+  ERRORS(success, "Failed to read grid_corner_lon data.");
   success = NCFUNC(end_indep_data)(_fileId);
   ERRORS(success, "Failed to end independent I/O mode.");
 #else
 #endif
   // Read y coordinates for gather set vertices
   double* yptr = arrays[1];
   int yVertexVarId;
-  success = NCFUNC(inq_varid)(_fileId, "yVertex", &yVertexVarId);
-  ERRORS(success, "Failed to get variable id of yVertex.");
+  success = NCFUNC(inq_varid)(_fileId, "grid_corner_lat", &yVertexVarId);
+  ERRORS(success, "Failed to get variable id of grid_corner_lat.");
 #ifdef PNETCDF_FILE
   // Enter independent I/O mode, since this read is only for the gather processor
   success = NCFUNCG(_vara_double)(_fileId, yVertexVarId, &read_start, &read_count, yptr);
-  ERRORS(success, "Failed to read yVertex data.");
+  ERRORS(success, "Failed to read grid_corner_lat data.");
 #else
 #endif
-  // Read z coordinates for gather set vertices
+  // Convert lon/lat/rad to x/y/z
-  int zVertexVarId;
-  success = NCFUNC(inq_varid)(_fileId, "zVertex", &zVertexVarId);
-  ERRORS(success, "Failed to get variable id of zVertex.");
-#ifdef PNETCDF_FILE
-  // Enter independent I/O mode, since this read is only for the gather processor
-  success = NCFUNC(begin_indep_data)(_fileId);
-  ERRORS(success, "Failed to begin independent I/O mode.");
-  success = NCFUNCG(_vara_double)(_fileId, zVertexVarId, &read_start, &read_count, zptr);
-  ERRORS(success, "Failed to read zVertex data.");
-  success = NCFUNC(end_indep_data)(_fileId);
-  ERRORS(success, "Failed to end independent I/O mode.");
-#else
-#endif
+  double rad = 8000.0 + levVals[0];
+  for (int i = 0; i < nVertices; i++) {
+    double cosphi = cos(yptr[i]);
+    double xmult = cosphi * cos(xptr[i]);
+    double ymult = cosphi * sin(xptr[i]);
+    xptr[i] = rad * xmult;
+    yptr[i] = rad * ymult;
+    zptr[i] = rad * zmult;
   // Get ptr to GID memory for gather set vertices
   int count = 0;
@@ -1314,8 +1303,8 @@ ErrorCode NCHelperGCRM::create_gather_set_edges(EntityHandle gather_set, EntityH
    for (int edge_vert = nEdges * 2 - 1; edge_vert >= 0; edge_vert--) {
-     int gather_set_vert_idx = vertices_on_gather_set_edges[edge_vert]; // Global vertex index, 1 based
-     gather_set_vert_idx--; // 1 based -> 0 based
+     // Note, indices stored in vertices_on_gather_set_edges are 0 based
+     int gather_set_vert_idx = vertices_on_gather_set_edges[edge_vert]; // Global vertex index, 0 based
      // Connectivity array is shifted by where the gather set vertices start
      conn_arr_gather_set_edges[edge_vert] = gather_set_start_vertex + gather_set_vert_idx;
@@ -1327,26 +1316,6 @@ ErrorCode NCHelperGCRM::create_padded_gather_set_cells(EntityHandle gather_set,
-  // Read number of edges on each gather set cell
-  int nEdgesOnCellVarId;
-  int success = NCFUNC(inq_varid)(_fileId, "nEdgesOnCell", &nEdgesOnCellVarId);
-  ERRORS(success, "Failed to get variable id of nEdgesOnCell.");
-  std::vector<int> num_edges_on_gather_set_cells(nCells);
-  NCDF_SIZE read_start = 0;
-  NCDF_SIZE read_count = static_cast<NCDF_SIZE>(nCells);
-  success = NCFUNCG(_vara_int)(_fileId, nEdgesOnCellVarId, &read_start, &read_count, &num_edges_on_gather_set_cells[0]);
-  ERRORS(success, "Failed to read nEdgesOnCell data.");
-#else
-#endif
   EntityHandle start_element;
   EntityHandle* conn_arr_gather_set_cells = NULL;
@@ -1361,8 +1330,8 @@ ErrorCode NCHelperGCRM::create_padded_gather_set_cells(EntityHandle gather_set,
   // Read vertices on each gather set cell (connectivity)
   int verticesOnCellVarId;
-  success = NCFUNC(inq_varid)(_fileId, "verticesOnCell", &verticesOnCellVarId);
-  ERRORS(success, "Failed to get variable id of verticesOnCell.");
+  int success = NCFUNC(inq_varid)(_fileId, "cell_corners", &verticesOnCellVarId);
+  ERRORS(success, "Failed to get variable id of cell_corners.");
   // Utilize the memory storage pointed by conn_arr_gather_set_cells
   int* vertices_on_gather_set_cells = (int*) conn_arr_gather_set_cells;
   NCDF_SIZE read_starts[2] = {0, 0};
@@ -1380,28 +1349,32 @@ ErrorCode NCHelperGCRM::create_padded_gather_set_cells(EntityHandle gather_set,
   ERRORS(success, "Failed to read verticesOnCell data.");
 #endif
-  // Correct gather set cell vertices array in the same way as local cell vertices array,
-  // replace the padded vertices with the last vertices in the corresponding cells
+  // Correct gather set cell vertices array in the same way as local cell vertices array
+  // Pentagons as hexagons should have a connectivity like 123455 and not 122345
   for (int gather_set_cell_idx = 0; gather_set_cell_idx < nCells; gather_set_cell_idx++) {
-    int num_edges = num_edges_on_gather_set_cells[gather_set_cell_idx];
-    int idx_in_gather_set_vert_arr = gather_set_cell_idx * EDGES_PER_CELL;
-    int last_vert_idx = vertices_on_gather_set_cells[idx_in_gather_set_vert_arr + num_edges - 1];
-    for (int i = num_edges; i < EDGES_PER_CELL; i++)
-      vertices_on_gather_set_cells[idx_in_gather_set_vert_arr + i] = last_vert_idx;
+    int* pvertex = vertices_on_gather_set_cells + gather_set_cell_idx * EDGES_PER_CELL;
+    for (int k = 0; k < EDGES_PER_CELL - 2; k++) {
+      if (*(pvertex + k) == *(pvertex + k + 1)) {
+        // Shift the connectivity
+        for (int kk = k + 1; kk < EDGES_PER_CELL - 1; kk++)
+          *(pvertex + kk) = *(pvertex + kk + 1);
+        // No need to try next k
+        break;
   // Populate connectivity data for gather set cells
   for (int cell_vert = nCells * EDGES_PER_CELL - 1; cell_vert >= 0; cell_vert--) {
-    int gather_set_vert_idx = vertices_on_gather_set_cells[cell_vert]; // Global vertex index, 1 based
+    // Note, indices stored in vertices_on_gather_set_cells are 0 based
+    int gather_set_vert_idx = vertices_on_gather_set_cells[cell_vert]; // Global vertex index, 0 based
     conn_arr_gather_set_cells[cell_vert] = gather_set_start_vertex + gather_set_vert_idx;
   return MB_SUCCESS;
-#endif
 } // namespace moab
diff --git a/src/io/NCHelperGCRM.hpp b/src/io/NCHelperGCRM.hpp
index 1e5f55b..160e538 100644
--- a/src/io/NCHelperGCRM.hpp
+++ b/src/io/NCHelperGCRM.hpp
@@ -56,7 +56,6 @@ private:
   ErrorCode create_padded_local_cells(const std::vector<int>& vertices_on_local_cells,
                                       EntityHandle start_vertex, Range& faces);
-#if 0
   //! Create gather set vertices
   ErrorCode create_gather_set_vertices(EntityHandle gather_set, EntityHandle& gather_set_start_vertex);
@@ -65,7 +64,6 @@ private:
   //! Create gather set cells with padding (pentagons are padded to hexagons)
   ErrorCode create_padded_gather_set_cells(EntityHandle gather_set, EntityHandle gather_set_start_vertex);
-#endif
 private:
   bool createGatherSet;
diff --git a/test/io/read_gcrm_nc.cpp b/test/io/read_gcrm_nc.cpp
index 35d6bcb..c4a2290 100644
--- a/test/io/read_gcrm_nc.cpp
+++ b/test/io/read_gcrm_nc.cpp
@@ -48,7 +48,7 @@ int main(int argc, char* argv[])
   result += RUN_TEST(test_read_nomesh);
   result += RUN_TEST(test_read_novars);
   result += RUN_TEST(test_read_no_edges);
-  //result += RUN_TEST(test_gather_onevar);
+  result += RUN_TEST(test_gather_onevar);
 #ifdef USE_MPI
   fail = MPI_Finalize();
@@ -494,7 +494,80 @@ void test_read_no_edges()
 void test_gather_onevar()
-  // TBD
+  Core moab;
+  Interface& mb = moab;
+  EntityHandle file_set;
+  ErrorCode rval = mb.create_meshset(MESHSET_SET, file_set);
+  CHECK_ERR(rval);
+  std::string opts;
+  get_options(opts);
+  // Read cell variable vorticity and create gather set on processor 0
+  opts += ";VARIABLE=vorticity;GATHER_SET=0";
+  rval = mb.load_file(example, &file_set, opts.c_str());
+  CHECK_ERR(rval);
+#ifdef USE_MPI
+  ParallelComm* pcomm = ParallelComm::get_pcomm(&mb, 0);
+  int rank = pcomm->proc_config().proc_rank();
+  Range cells, cells_owned;
+  rval = mb.get_entities_by_type(file_set, MBPOLYGON, cells);
+  CHECK_ERR(rval);
+  // Get local owned cells
+  rval = pcomm->filter_pstatus(cells, PSTATUS_NOT_OWNED, PSTATUS_NOT, -1, &cells_owned);
+  CHECK_ERR(rval);
+  EntityHandle gather_set = 0;
+  if (0 == rank) {
+    // Get gather set
+    ReadUtilIface* readUtilIface;
+    mb.query_interface(readUtilIface);
+    rval = readUtilIface->get_gather_set(gather_set);
+    CHECK_ERR(rval);
+    assert(gather_set != 0);
+  Tag vorticity_tag0, gid_tag;
+  rval = mb.tag_get_handle("vorticity0", layers, MB_TYPE_DOUBLE, vorticity_tag0, MB_TAG_DENSE);
+  CHECK_ERR(rval);
+  rval = mb.tag_get_handle(GLOBAL_ID_TAG_NAME, 1, MB_TYPE_INTEGER, gid_tag, MB_TAG_DENSE);
+  CHECK_ERR(rval);
+  pcomm->gather_data(cells_owned, vorticity_tag0, gid_tag, gather_set, 0);
+  if (0 == rank) {
+    // Get gather set cells
+    Range gather_set_cells;
+    rval = mb.get_entities_by_type(gather_set, MBPOLYGON, gather_set_cells);
+    CHECK_ERR(rval);
+    CHECK_EQUAL((size_t)642, gather_set_cells.size());
+    CHECK_EQUAL((size_t)1, gather_set_cells.psize());
+    // Check vorticity0 tag values on 4 gather set cells: first cell, two median cells, and last cell
+    EntityHandle cell_ents[] = {gather_set_cells[0], gather_set_cells[320],
+                                gather_set_cells[321], gather_set_cells[641]};
+    double vorticity0_val[4 * layers];
+    rval = mb.tag_get_data(vorticity_tag0, cell_ents, 4, vorticity0_val);
+    CHECK_ERR(rval);
+    // Only check first two layers
+    // Layer 0
+    CHECK_REAL_EQUAL(3.629994, vorticity0_val[0 * layers], eps);
+    CHECK_REAL_EQUAL(0.131688, vorticity0_val[1 * layers], eps);
+    CHECK_REAL_EQUAL(-0.554888, vorticity0_val[2 * layers], eps);
+    CHECK_REAL_EQUAL(-0.554888, vorticity0_val[3 * layers], eps);
+    // Layer 1
+    CHECK_REAL_EQUAL(3.629944, vorticity0_val[0 * layers + 1], eps);
+    CHECK_REAL_EQUAL(0.131686, vorticity0_val[1 * layers + 1], eps);
+    CHECK_REAL_EQUAL(-0.554881, vorticity0_val[2 * layers + 1], eps);
+    CHECK_REAL_EQUAL(-0.554881, vorticity0_val[3 * layers + 1], eps);
+#endif
 void get_options(std::string& opts)
diff --git a/test/parallel/gcrm_par.cpp b/test/parallel/gcrm_par.cpp
index f433759..c6b6fe4 100644
--- a/test/parallel/gcrm_par.cpp
+++ b/test/parallel/gcrm_par.cpp
@@ -54,8 +54,8 @@ int main(int argc, char* argv[])
   result += RUN_TEST(test_read_mesh_parallel_rcbzoltan);
 #endif
-  //result += RUN_TEST(test_gather_onevar_on_rank0);
-  //result += RUN_TEST(test_gather_onevar_on_rank1);
+  result += RUN_TEST(test_gather_onevar_on_rank0);
+  result += RUN_TEST(test_gather_onevar_on_rank1);
   result += RUN_TEST(test_multiple_loads_of_same_file);
@@ -509,7 +509,7 @@ void gather_one_cell_var(int gather_set_rank)
-  rval = mb.tag_get_handle("vorticity0", 1, MB_TYPE_DOUBLE, vorticity_tag0, MB_TAG_DENSE);
   CHECK_ERR(rval);
Repository URL: https://bitbucket.org/fathomteam/moab/
This is a commit notification from bitbucket.org. You are receiving
this because you have the service enabled, addressing the recipient of
this email.
