[MOAB-dev] commit/MOAB: danwu: Restored two CHECK_EQUAL calls in NC reader parallel unit test for GCRM, after fixing the bug with padded polygons.
    commits-noreply at bitbucket.org
    Wed Jun  4 11:11:44 CDT 2014
1 new commit in MOAB:
https://bitbucket.org/fathomteam/moab/commits/e6aa7cfd39b6/
Changeset:   e6aa7cfd39b6
Branch:      master
User:        danwu
Date:        2014-06-04 18:11:30
Summary:     Restored two CHECK_EQUAL calls in NC reader parallel unit test for GCRM, after fixing the bug with padded polygons.
Affected #:  1 file
diff --git a/test/parallel/gcrm_par.cpp b/test/parallel/gcrm_par.cpp
index 1defb0e..b2dae0a 100644
--- a/test/parallel/gcrm_par.cpp
+++ b/test/parallel/gcrm_par.cpp
@@ -602,8 +602,7 @@ void multiple_loads_of_same_file()
     if (0 == rank) {
       CHECK_EQUAL((size_t)687, local_verts.size());
-      // FIXME: Previous result is 1010
-      //CHECK_EQUAL((size_t)1007, local_edges.size());
+      CHECK_EQUAL((size_t)1007, local_edges.size());
       // Layer 0
       CHECK_REAL_EQUAL(3.629994, vorticity0_val[0 * layers], eps);
@@ -616,8 +615,7 @@ void multiple_loads_of_same_file()
     else if (1 == rank) {
       CHECK_EQUAL((size_t)688, local_verts.size());
-      //CHECK_EQUAL((size_t)1008, local_edges.size());
+      CHECK_EQUAL((size_t)1008, local_edges.size());
       // Layer 0
       CHECK_REAL_EQUAL(-0.554888, vorticity0_val[0 * layers], eps);
Repository URL: https://bitbucket.org/fathomteam/moab/
This is a commit notification from bitbucket.org. You are receiving
this because you have the service enabled, addressing the recipient of
this email.
