[MOAB-dev] commit/MOAB: danwu: Updated some comments on optional levels for MPAS and GCRM.
    commits-noreply at bitbucket.org
    Mon Jun  2 13:26:26 CDT 2014
1 new commit in MOAB:
https://bitbucket.org/fathomteam/moab/commits/ae3e2ce384ba/
Changeset:   ae3e2ce384ba
Branch:      master
User:        danwu
Date:        2014-06-02 20:26:05
Summary:     Updated some comments on optional levels for MPAS and GCRM.
Affected #:  3 files
diff --git a/src/io/NCHelperGCRM.cpp b/src/io/NCHelperGCRM.cpp
index f61cca5..f563261 100644
--- a/src/io/NCHelperGCRM.cpp
+++ b/src/io/NCHelperGCRM.cpp
@@ -103,10 +103,10 @@ ErrorCode NCHelperGCRM::init_mesh_vals()
   levDim = idx;
   nLevels = dimLens[idx];
-  // Dimension numbers for other optional levels
+  // Dimension indices for other optional levels
   std::vector<unsigned int> opt_lev_dims;
-  // Get number of interface levels
+  // Get index of interface levels
   if ((vit = std::find(dimNames.begin(), dimNames.end(), "interfaces")) != dimNames.end()) {
     idx = vit - dimNames.begin();
     opt_lev_dims.push_back(idx);
diff --git a/src/io/NCHelperMPAS.cpp b/src/io/NCHelperMPAS.cpp
index 5c964b9..a02e4ce 100644
--- a/src/io/NCHelperMPAS.cpp
+++ b/src/io/NCHelperMPAS.cpp
@@ -122,22 +122,22 @@ ErrorCode NCHelperMPAS::init_mesh_vals()
   levDim = idx;
-  // Get number of vertex levels P1
+  // Get index of vertex levels P1
   if ((vit = std::find(dimNames.begin(), dimNames.end(), "nVertLevelsP1")) != dimNames.end()) {
-  // Get number of vertex levels P2
+  // Get index of vertex levels P2
   if ((vit = std::find(dimNames.begin(), dimNames.end(), "nVertLevelsP2")) != dimNames.end()) {
-  // Get number of soil levels
+  // Get index of soil levels
   if ((vit = std::find(dimNames.begin(), dimNames.end(), "nSoilLevels")) != dimNames.end()) {
diff --git a/src/io/NCWriteMPAS.cpp b/src/io/NCWriteMPAS.cpp
index 0ece324..512c1d5 100644
--- a/src/io/NCWriteMPAS.cpp
+++ b/src/io/NCWriteMPAS.cpp
@@ -126,25 +126,25 @@ ErrorCode NCWriteMPAS::collect_variable_data(std::vector<std::string>& var_names
   std::vector<std::string>& dimNames = _writeNC->dimNames;
   std::vector<int>& dimLens = _writeNC->dimLens;
   unsigned int lev_idx;
   std::vector<std::string>::iterator vecIt;
   if ((vecIt = std::find(dimNames.begin(), dimNames.end(), "nVertLevelsP1")) != dimNames.end()) {
     lev_idx = vecIt - dimNames.begin();
     opt_lev_dims.push_back(lev_idx);
   if ((vecIt = std::find(dimNames.begin(), dimNames.end(), "nVertLevelsP2")) != dimNames.end()) {
   if ((vecIt = std::find(dimNames.begin(), dimNames.end(), "nSoilLevels")) != dimNames.end()) {
Repository URL: https://bitbucket.org/fathomteam/moab/
This is a commit notification from bitbucket.org. You are receiving
this because you have the service enabled, addressing the recipient of
this email.
