[MOAB-dev] FW: Jenkins build is back to normal : moab_serial #311
    Kenneth Raffenetti
    raffenet at mcs.anl.gov
    Mon May 19 15:55:45 CDT 2014
You might try asking Systems about making Jenkins accessible from
outside the firewall. It's possible, I think, as long as there is enough
demand for it.
Ken
On 05/19/2014 03:53 PM, Grindeanu, Iulian R. wrote:
> I think it is intentional, that it should be accessible only over a vpn connection.
> Anyway, the workspace might get wiped out after a while (and I can't control that, I tried)
> Iulian
> From: Vijay S. Mahadevan [vijay.m at gmail.com]
> Sent: Monday, May 19, 2014 3:37 PM
> To: Grindeanu, Iulian R.
> Cc: MOAB dev
> Subject: Re: [MOAB-dev] FW: Jenkins build is back to normal : moab_serial #311
> Can we also make the jenkins build output publicly visible ? I can't
> access that link. Would be specifically useful to see what failed (in
> case the email output gets trimmed) and what tests are actually
> executed after the commit.
> Vijay
> On Tue, May 20, 2014 at 2:01 AM, Grindeanu, Iulian R.
>> From: jenkins-ci at mcs.anl.gov [jenkins-ci at mcs.anl.gov]
>> Sent: Monday, May 19, 2014 3:30 PM
>> Subject: Jenkins build is back to normal : moab_serial #311
>> See <https://jenkins-ci.mcs.anl.gov/job/moab_serial/311/>
