[MOAB-dev] about meshkit using stl as input
Grindeanu, Iulian R.
iulian at mcs.anl.gov
Fri May 9 15:16:59 CDT 2014
can you send me the file directly?
I can't download it from there. It is not too big, is it?
It seems to be a problem with the tree creation
There were some changes lately
Iulian
Sent: Friday, May 09, 2014 11:16 AM
To: Grindeanu, Iulian R.
Subject: Re: about meshkit using stl as input
~/Desktop/fathom/meshkit-git/pshriwise-meshkit-4d07ffc4f849/example$ ~/Desktop/fathom/moab/bin/mbsize N2601082.stl
File N2601082.stl:
type count total minimum average rms maximum std.dev.
Tri 18363 1e+02 3.3883e-06 0.0057172 0.0096592 0.061782 0.0077855
1D Side 55089 6.7e+03 0.0028465 0.12151 0.15355 0.6083 0.093877
Vertex 9199
I run mbsize, it seems no problem
zhiyong
On Fri, May 9, 2014 at 11:10 AM, Zhi-Yong Hu <hu at iit.edu<mailto:hu at iit.edu>> wrote:
I download it from the http://cncartguild.forumotion.net/t176-stone-horse. It is used in the paper "EBMesh: An Embedded Boundary Meshing Tool Hong-Jun Kim1 and Timothy J. Tautges2". I will try mbsize N*.stl.
zhiyong
On Fri, May 9, 2014 at 10:43 AM, Grindeanu, Iulian R. <iulian at mcs.anl.gov<mailto:iulian at mcs.anl.gov>> wrote:
It is using moab's stl reader
Try to read the stl file with moab
(you can try mbsize N2601082.stl), there could be some problems with the model
Where is this file from?
It has to be watertight geometry, otherwise ray tracing will fail.
Iulian
From: Zhi-Yong Hu [hu at iit.edu<mailto:hu at iit.edu>]
Sent: Friday, May 09, 2014 10:18 AM
To: meshkit-dev at mcs.anl.gov<mailto:meshkit-dev at mcs.anl.gov>
Cc: Grindeanu, Iulian R.
Subject: about meshkit using stl as input
Hi, Iulian,
I have another question about stl input in ebmesh
Here is my running and output:
./example_ebmesh N2601082.stl 1 10 10 10 1 output2.h5m 0.03 5 | tee output.log
starting to construct obb tree.
terminate called after throwing an instance of 'MeshKit::Error'
what(): EBMesher.cpp, line 2148: N2601082.stl: Success
How can I solve this problem?
Thanks
Zhiyong Hu
URL: <http://lists.mcs.anl.gov/pipermail/moab-dev/attachments/20140509/e249577c/attachment.html>
