[MOAB-dev] commit/MOAB: danwu: Refactored NC writer code to separate writing of set variables (including used coordinates) and non-set variables.
commits-noreply at bitbucket.org
Wed May 7 15:29:36 CDT 2014
1 new commit in MOAB:
https://bitbucket.org/fathomteam/moab/commits/8b6f486bc0bf/
Changeset: 8b6f486bc0bf
Branch: master
User: danwu
Date: 2014-05-07 22:29:18
Summary: Refactored NC writer code to separate writing of set variables (including used coordinates) and non-set variables.
Affected #: 8 files
diff --git a/src/io/NCWriteGCRM.cpp b/src/io/NCWriteGCRM.cpp
index d72026e..b1e5a7d 100644
--- a/src/io/NCWriteGCRM.cpp
+++ b/src/io/NCWriteGCRM.cpp
@@ -231,12 +231,9 @@ ErrorCode NCWriteGCRM::collect_variable_data(std::vector<std::string>& var_names
return MB_SUCCESS;
-ErrorCode NCWriteGCRM::write_values(std::vector<std::string>& var_names, std::vector<int>& tstep_nums)
+ErrorCode NCWriteGCRM::write_nonset_variables(std::vector<WriteNC::VarData>& vdatas, std::vector<int>& tstep_nums)
Interface*& mbImpl = _writeNC->mbImpl;
- std::set<std::string>& usedCoordinates = _writeNC->usedCoordinates;
- std::set<std::string>& dummyVarNames = _writeNC->dummyVarNames;
- std::map<std::string, WriteNC::VarData>& varInfo = _writeNC->varInfo;
int success;
Range* pLocalEntsOwned = NULL;
@@ -245,170 +242,94 @@ ErrorCode NCWriteGCRM::write_values(std::vector<std::string>& var_names, std::ve
// Now look at requested var_names; if they have time, we will have a list, and write one at a time
// For each variable tag in the indexed lists, write a time step data
// Assume the first dimension is time (need to check); if not, just write regularly
- for (size_t i = 0; i < var_names.size(); i++) {
- std::map<std::string, WriteNC::VarData>::iterator vit = varInfo.find(var_names[i]);
- if (vit == varInfo.end())
- ERRORR(MB_FAILURE, "Can't find variable requested.");
- WriteNC::VarData& variableData = vit->second;
+ for (unsigned int i = 0; i < vdatas.size(); i++) {
+ WriteNC::VarData& variableData = vdatas[i];
// Skip edge variables, if there are no edges
if (localEdgesOwned.empty() && variableData.entLoc == WriteNC::ENTLOCEDGE)
continue;
- if (variableData.has_tsteps) {
- // Time should be the first dimension
- assert(tDim == variableData.varDims[0]);
- // Get local owned entities of this variable
- switch (variableData.entLoc) {
- case WriteNC::ENTLOCVERT:
- // Vertices
- pLocalEntsOwned = &localVertsOwned;
- pLocalGidEntsOwned = &localGidVertsOwned;
- break;
- case WriteNC::ENTLOCEDGE:
- // Edges
- pLocalEntsOwned = &localEdgesOwned;
- pLocalGidEntsOwned = &localGidEdgesOwned;
- break;
- case WriteNC::ENTLOCFACE:
- // Cells
- pLocalEntsOwned = &localCellsOwned;
- pLocalGidEntsOwned = &localGidCellsOwned;
- break;
- default:
- ERRORR(MB_FAILURE, "Unexpected entity location type for GCRM non-set variable.");
+ // Time should be the first dimension
+ assert(tDim == variableData.varDims[0]);
+ // Get local owned entities of this variable
+ switch (variableData.entLoc) {
+ case WriteNC::ENTLOCVERT:
+ // Vertices
+ pLocalEntsOwned = &localVertsOwned;
+ pLocalGidEntsOwned = &localGidVertsOwned;
+ break;
+ case WriteNC::ENTLOCEDGE:
+ // Edges
+ pLocalEntsOwned = &localEdgesOwned;
+ pLocalGidEntsOwned = &localGidEdgesOwned;
+ break;
+ case WriteNC::ENTLOCFACE:
+ // Cells
+ pLocalEntsOwned = &localCellsOwned;
+ pLocalGidEntsOwned = &localGidCellsOwned;
+ break;
+ default:
+ ERRORR(MB_FAILURE, "Unexpected entity location type for MPAS non-set variable.");
- // A typical variable has 3 dimensions as (Time, nCells, nVertLevels)
- for (unsigned int t = 0; t < tstep_nums.size(); t++) {
- // We will write one time step, and count will be one; start will be different
- // Use tag_get_data instead of tag_iterate to get values, as localEntsOwned
- // might not be contiguous.
- variableData.writeStarts[0] = t; // This is time, again
- std::vector<double> tag_data(pLocalEntsOwned->size() * variableData.numLev);
- ErrorCode rval = mbImpl->tag_get_data(variableData.varTags[t], *pLocalEntsOwned, &tag_data[0]);
- ERRORR(rval, "Trouble getting tag data on owned vertices.");
+ // A typical variable has 3 dimensions as (Time, nCells, nVertLevels)
+ for (unsigned int t = 0; t < tstep_nums.size(); t++) {
+ // We will write one time step, and count will be one; start will be different
+ // Use tag_get_data instead of tag_iterate to get values, as localEntsOwned
+ // might not be contiguous.
+ variableData.writeStarts[0] = t; // This is time, again
+ std::vector<double> tag_data(pLocalEntsOwned->size() * variableData.numLev);
+ ErrorCode rval = mbImpl->tag_get_data(variableData.varTags[t], *pLocalEntsOwned, &tag_data[0]);
+ ERRORR(rval, "Trouble getting tag data on owned vertices.");
#ifdef PNETCDF_FILE
- size_t nb_writes = pLocalGidEntsOwned->psize();
- std::vector<int> requests(nb_writes), statuss(nb_writes);
- size_t idxReq = 0;
+ size_t nb_writes = pLocalGidEntsOwned->psize();
+ std::vector<int> requests(nb_writes), statuss(nb_writes);
+ size_t idxReq = 0;
#endif
- // Now write from memory directly
- switch (variableData.varDataType) {
- case NC_DOUBLE: {
- size_t indexInDoubleArray = 0;
- size_t ic = 0;
- for (Range::pair_iterator pair_iter = pLocalGidEntsOwned->pair_begin();
- pair_iter != pLocalGidEntsOwned->pair_end(); ++pair_iter, ic++) {
- EntityHandle starth = pair_iter->first;
- EntityHandle endh = pair_iter->second;
- variableData.writeStarts[1] = (NCDF_SIZE)(starth - 1);
- variableData.writeCounts[1] = (NCDF_SIZE)(endh - starth + 1);
- // Do a partial write, in each subrange
+ // Now write from memory directly
+ switch (variableData.varDataType) {
+ case NC_DOUBLE: {
+ size_t indexInDoubleArray = 0;
+ size_t ic = 0;
+ for (Range::pair_iterator pair_iter = pLocalGidEntsOwned->pair_begin();
+ pair_iter != pLocalGidEntsOwned->pair_end(); ++pair_iter, ic++) {
+ EntityHandle starth = pair_iter->first;
+ EntityHandle endh = pair_iter->second;
+ variableData.writeStarts[1] = (NCDF_SIZE)(starth - 1);
+ variableData.writeCounts[1] = (NCDF_SIZE)(endh - starth + 1);
+ // Do a partial write, in each subrange
#ifdef PNETCDF_FILE
- // Wait outside this loop
- success = NCFUNCREQP(_vara_double)(_fileId, variableData.varId,
- &(variableData.writeStarts[0]), &(variableData.writeCounts[0]),
- &(tag_data[indexInDoubleArray]), &requests[idxReq++]);
+ // Wait outside this loop
+ success = NCFUNCREQP(_vara_double)(_fileId, variableData.varId,
+ &(variableData.writeStarts[0]), &(variableData.writeCounts[0]),
+ &(tag_data[indexInDoubleArray]), &requests[idxReq++]);
#else
- success = NCFUNCAP(_vara_double)(_fileId, variableData.varId,
- &(tag_data[indexInDoubleArray]));
-#endif
- ERRORS(success, "Failed to read double data in loop");
- // We need to increment the index in double array for the
- // next subrange
- indexInDoubleArray += (endh - starth + 1) * variableData.numLev;
- assert(ic == pLocalGidEntsOwned->psize());
-#ifdef PNETCDF_FILE
- success = ncmpi_wait_all(_fileId, requests.size(), &requests[0], &statuss[0]);
- ERRORS(success, "Failed on wait_all.");
+ success = NCFUNCAP(_vara_double)(_fileId, variableData.varId,
+ &(tag_data[indexInDoubleArray]));
#endif
- break;
+ ERRORS(success, "Failed to read double data in loop");
+ // We need to increment the index in double array for the
+ // next subrange
+ indexInDoubleArray += (endh - starth + 1) * variableData.numLev;
- default:
- ERRORR(MB_FAILURE, "Not implemented yet.");
- } // if (variableData.has_tsteps)
- else {
- case NC_DOUBLE:
- success = NCFUNCAP(_vara_double)(_fileId, variableData.varId, &variableData.writeStarts[0],
- &variableData.writeCounts[0], (double*)(variableData.memoryHogs[0]));
- ERRORS(success, "Failed to write double data.");
- break;
- default:
- // Write coordinates used by requested var_names
- // Use independent I/O mode put, since this write is only for the root processor
- // CAUTION: if the NetCDF ID is from a previous call to ncmpi_create rather than ncmpi_open,
- // all processors need to call ncmpi_begin_indep_data(). If only the root processor does so,
- // ncmpi_begin_indep_data() call will be blocked forever :(
+ assert(ic == pLocalGidEntsOwned->psize());
#ifdef PNETCDF_FILE
- // Enter independent I/O mode
- success = NCFUNC(begin_indep_data)(_fileId);
- ERRORS(success, "Failed to begin independent I/O mode.");
+ success = ncmpi_wait_all(_fileId, requests.size(), &requests[0], &statuss[0]);
+ ERRORS(success, "Failed on wait_all.");
#endif
- int rank = 0;
-#ifdef USE_MPI
- bool& isParallel = _writeNC->isParallel;
- if (isParallel) {
- ParallelComm*& myPcomm = _writeNC->myPcomm;
- rank = myPcomm->proc_config().proc_rank();
-#endif
- if (0 == rank) {
- for (std::set<std::string>::iterator setIt = usedCoordinates.begin();
- setIt != usedCoordinates.end(); ++setIt) {
- const std::string& coordName = *setIt;
- // Skip dummy coordinate variables (e.g. ncol)
- if (dummyVarNames.find(coordName) != dummyVarNames.end())
- continue;
- std::map<std::string, WriteNC::VarData>::iterator vit = varInfo.find(coordName);
- ERRORR(MB_FAILURE, "Can't find one coordinate variable.");
- WriteNC::VarData& varCoordData = vit->second;
- switch (varCoordData.varDataType) {
- case NC_DOUBLE:
- // Independent I/O mode put
- success = NCFUNCP(_vara_double)(_fileId, varCoordData.varId, &varCoordData.writeStarts[0],
- &varCoordData.writeCounts[0], (double*)(varCoordData.memoryHogs[0]));
- break;
- case NC_INT:
- success = NCFUNCP(_vara_int)(_fileId, varCoordData.varId, &varCoordData.writeStarts[0],
- &varCoordData.writeCounts[0], (int*)(varCoordData.memoryHogs[0]));
- ERRORS(success, "Failed to write int data.");
break;
default:
+ ERRORR(MB_NOT_IMPLEMENTED, "Writing with current data type not implemented yet.");
- // End independent I/O mode
- success = NCFUNC(end_indep_data)(_fileId);
- ERRORS(success, "Failed to end independent I/O mode.");
-#endif
return MB_SUCCESS;
diff --git a/src/io/NCWriteGCRM.hpp b/src/io/NCWriteGCRM.hpp
index 5847632..21b605e 100644
--- a/src/io/NCWriteGCRM.hpp
+++ b/src/io/NCWriteGCRM.hpp
@@ -28,8 +28,8 @@ private:
//! Collect data for specified variables
virtual ErrorCode collect_variable_data(std::vector<std::string>& var_names, std::vector<int>& tstep_nums);
- //! Implementation of NCWriteHelper::write_values()
- virtual ErrorCode write_values(std::vector<std::string>& var_names, std::vector<int>& tstep_nums);
+ //! Implementation of NCWriteHelper::write_nonset_variables()
+ virtual ErrorCode write_nonset_variables(std::vector<WriteNC::VarData>& vdatas, std::vector<int>& tstep_nums);
} // namespace moab
diff --git a/src/io/NCWriteHOMME.cpp b/src/io/NCWriteHOMME.cpp
index 1dd16d8..0e4b55c 100644
--- a/src/io/NCWriteHOMME.cpp
+++ b/src/io/NCWriteHOMME.cpp
@@ -136,12 +136,9 @@ ErrorCode NCWriteHOMME::collect_variable_data(std::vector<std::string>& var_name
return MB_SUCCESS;
-ErrorCode NCWriteHOMME::write_values(std::vector<std::string>& var_names, std::vector<int>& tstep_nums)
+ErrorCode NCWriteHOMME::write_nonset_variables(std::vector<WriteNC::VarData>& vdatas, std::vector<int>& tstep_nums)
int success;
int num_local_verts_owned = localVertsOwned.size();
@@ -150,161 +147,85 @@ ErrorCode NCWriteHOMME::write_values(std::vector<std::string>& var_names, std::v
// Need to transpose from lev dimension
- // Assume this variable is on vertices for the time being
- // Vertices
- break;
- default:
- ERRORR(MB_FAILURE, "Unexpected entity location type for HOMME non-set variable.");
+ // Assume this variable is on vertices for the time being
+ // Vertices
+ break;
+ default:
+ ERRORR(MB_FAILURE, "Unexpected entity location type for HOMME non-set variable.");
- // A typical variable has 3 dimensions as (time, lev, ncol)
- // At each timestep, we need to transpose tag format (ncol, lev) back
- // to NC format (lev, ncol) for writing
- // Use tag_get_data instead of tag_iterate to get values, as localVertsOwned
- // might not be contiguous. We should also transpose for level so that means
- // deep copy for transpose
- std::vector<double> tag_data(num_local_verts_owned * variableData.numLev);
- ErrorCode rval = mbImpl->tag_get_data(variableData.varTags[t], localVertsOwned, &tag_data[0]);
+ // A typical HOMME non-set variable has 3 dimensions as (time, lev, ncol)
+ // At each timestep, we need to transpose tag format (ncol, lev) back
+ // to NC format (lev, ncol) for writing
+ // Use tag_get_data instead of tag_iterate to get values, as localVertsOwned
+ // might not be contiguous. We should also transpose for level so that means
+ // deep copy for transpose
+ std::vector<double> tag_data(num_local_verts_owned * variableData.numLev);
+ ErrorCode rval = mbImpl->tag_get_data(variableData.varTags[t], localVertsOwned, &tag_data[0]);
#ifdef PNETCDF_FILE
- size_t nb_writes = localGidVertsOwned.psize();
+ size_t nb_writes = localGidVertsOwned.psize();
#endif
- case NC_DOUBLE: {
- std::vector<double> tmpdoubledata(num_local_verts_owned * variableData.numLev);
- // Transpose (ncol, lev) back to (lev, ncol)
- jik_to_kji(num_local_verts_owned, 1, variableData.numLev, &tmpdoubledata[0], &tag_data[0]);
- size_t ic = 0;
- for (Range::pair_iterator pair_iter = localGidVertsOwned.pair_begin();
- pair_iter != localGidVertsOwned.pair_end(); ++pair_iter, ic++) {
- variableData.writeStarts[2] = (NCDF_SIZE)(starth - 1);
- variableData.writeCounts[2] = (NCDF_SIZE)(endh - starth + 1);
+ case NC_DOUBLE: {
+ std::vector<double> tmpdoubledata(num_local_verts_owned * variableData.numLev);
+ // Transpose (ncol, lev) back to (lev, ncol)
+ jik_to_kji(num_local_verts_owned, 1, variableData.numLev, &tmpdoubledata[0], &tag_data[0]);
+ size_t ic = 0;
+ for (Range::pair_iterator pair_iter = localGidVertsOwned.pair_begin();
+ pair_iter != localGidVertsOwned.pair_end(); ++pair_iter, ic++) {
+ variableData.writeStarts[2] = (NCDF_SIZE)(starth - 1);
+ variableData.writeCounts[2] = (NCDF_SIZE)(endh - starth + 1);
#ifdef PNETCDF_FILE
- &(tmpdoubledata[indexInDoubleArray]), &requests[idxReq++]);
+ &(tmpdoubledata[indexInDoubleArray]), &requests[idxReq++]);
#else
- &(tmpdoubledata[indexInDoubleArray]));
+ &(tmpdoubledata[indexInDoubleArray]));
#endif
- // next subrange
- assert(ic == localGidVertsOwned.psize());
-#endif
- break;
+ // next subrange
- default:
- else {
- case NC_DOUBLE:
- break;
- default:
+ assert(ic == localGidVertsOwned.psize());
#ifdef PNETCDF_FILE
#endif
- int rank = 0;
-#ifdef USE_MPI
- if (isParallel) {
-#endif
- if (0 == rank) {
- continue;
- case NC_DOUBLE:
- break;
- case NC_INT:
break;
default:
-#endif
return MB_SUCCESS;
diff --git a/src/io/NCWriteHOMME.hpp b/src/io/NCWriteHOMME.hpp
index ad689f5..58047d9 100644
--- a/src/io/NCWriteHOMME.hpp
+++ b/src/io/NCWriteHOMME.hpp
} // namespace moab
diff --git a/src/io/NCWriteHelper.cpp b/src/io/NCWriteHelper.cpp
index 5ccf302..aefa572 100644
--- a/src/io/NCWriteHelper.cpp
+++ b/src/io/NCWriteHelper.cpp
@@ -69,15 +69,6 @@ ErrorCode NCWriteHelper::collect_variable_data(std::vector<std::string>& var_nam
WriteNC::VarData& currentVarData = vit->second;
- currentVarData.has_tsteps = false;
- if ((std::find(currentVarData.varDims.begin(), currentVarData.varDims.end(), tDim) != currentVarData.varDims.end())
- && (currentVarData.varDims.size() > 1)) // So it is not time itself
- currentVarData.has_tsteps = true;
- currentVarData.numLev = 1;
- if ((std::find(currentVarData.varDims.begin(), currentVarData.varDims.end(), levDim) != currentVarData.varDims.end()))
- currentVarData.numLev = nLevels;
dbgOut.tprintf(2, " for variable %s varDims.size %d \n", varname.c_str(), (int)currentVarData.varDims.size());
for (size_t j = 0; j < currentVarData.varDims.size(); j++) {
std::string dimName = dimNames[currentVarData.varDims[j]];
@@ -93,8 +84,15 @@ ErrorCode NCWriteHelper::collect_variable_data(std::vector<std::string>& var_nam
if (usedCoordinates.find(varname) != usedCoordinates.end())
continue;
- // Process non-set variables with time steps
+ if (std::find(currentVarData.varDims.begin(), currentVarData.varDims.end(), tDim) != currentVarData.varDims.end())
+ currentVarData.has_tsteps = true;
+ if ((std::find(currentVarData.varDims.begin(), currentVarData.varDims.end(), levDim) != currentVarData.varDims.end()))
+ currentVarData.numLev = nLevels;
+ // Process non-coordinate variables with time steps
if (currentVarData.has_tsteps) {
+ // It might be a set variable, e.g. xtime(Time) or xtime(Time, StrLen)
Tag indexedTag = 0;
std::stringstream ssTagNameWithIndex;
@@ -114,8 +112,11 @@ ErrorCode NCWriteHelper::collect_variable_data(std::vector<std::string>& var_nam
currentVarData.varDataType = NC_INT;
- // Process set variables that are not coordinate variables
+ // Process non-coordinate variables without time steps
else {
+ // Should be a set variable
+ assert(WriteNC::ENTLOCSET == currentVarData.entLoc);
// Get the tag with varname
Tag tag = 0;
rval = mbImpl->tag_get_handle(varname.c_str(), tag);
@@ -144,14 +145,15 @@ ErrorCode NCWriteHelper::collect_variable_data(std::vector<std::string>& var_nam
currentVarData.writeCounts.push_back(1);
else {
- assert(1 == currentVarData.varDims.size());
- currentVarData.writeStarts.push_back(0);
- currentVarData.writeCounts.push_back(dimLens[currentVarData.varDims[0]]);
+ for (size_t j = 0; j < currentVarData.varDims.size(); j++) {
+ currentVarData.writeStarts.push_back(0);
+ currentVarData.writeCounts.push_back(dimLens[currentVarData.varDims[j]]);
- // Process coordinate variables
+ // Process coordinate variables here
// Check that for used coordinates we have found the tags
@@ -362,7 +364,7 @@ ErrorCode NCWriteHelper::init_file(std::vector<std::string>& var_names, std::vec
(int)variableData.varDims.size(), &(variableData.varDims[0]),
&variableData.varId);
if (errCode != NC_NOERR)
- ERRORR(MB_FAILURE, "Failed to create coordinate variable.");
+ ERRORR(MB_FAILURE, "Failed to create requested variable.");
dbgOut.tprintf(2, " for variable %s with desired name %s variable id is %d \n", var_names[i].c_str(),
desired_names[i].c_str(), variableData.varId);
@@ -413,6 +415,119 @@ ErrorCode NCWriteHelper::init_file(std::vector<std::string>& var_names, std::vec
return MB_SUCCESS;
+ErrorCode NCWriteHelper::write_values(std::vector<std::string>& var_names, std::vector<int>& tstep_nums)
+ std::set<std::string>& usedCoordinates = _writeNC->usedCoordinates;
+ std::set<std::string>& dummyVarNames = _writeNC->dummyVarNames;
+ std::map<std::string, WriteNC::VarData>& varInfo = _writeNC->varInfo;
+ std::vector<WriteNC::VarData> vdatas;
+ std::vector<WriteNC::VarData> vsetdatas;
+ // For set variables, include coordinates used by requested var_names
+ for (std::set<std::string>::iterator setIt = usedCoordinates.begin();
+ setIt != usedCoordinates.end(); ++setIt) {
+ const std::string& coordName = *setIt;
+ // Skip dummy coordinate variables (if any)
+ if (dummyVarNames.find(coordName) != dummyVarNames.end())
+ continue;
+ std::map<std::string, WriteNC::VarData>::iterator vit = varInfo.find(coordName);
+ if (vit == varInfo.end()) {
+ ERRORR(MB_FAILURE, "Can't find one coordinate variable.");
+ vsetdatas.push_back(vit->second);
+ // Collect non-set and set variables from requested var_names
+ for (unsigned int i = 0; i < var_names.size(); i++) {
+ std::map<std::string, WriteNC::VarData>::iterator vit = varInfo.find(var_names[i]);
+ ERRORR(MB_FAILURE, "Can't find variable requested.");
+ WriteNC::VarData& variableData = vit->second;
+ if (WriteNC::ENTLOCSET == variableData.entLoc) {
+ // Used coordinates has all ready been included
+ if (usedCoordinates.find(var_names[i]) != usedCoordinates.end())
+ continue;
+ vsetdatas.push_back(variableData);
+ else
+ vdatas.push_back(variableData);
+ // Assume that the data ranges do not overlap across processors
+ // While overlapped writing might still work, we should better not take that risk
+ write_nonset_variables(vdatas, tstep_nums);
+ // Use independent I/O mode put, since this write is only for the root processor
+ write_set_variables(vsetdatas, tstep_nums);
+ return MB_SUCCESS;
+ErrorCode NCWriteHelper::write_set_variables(std::vector<WriteNC::VarData>& vsetdatas, std::vector<int>& /* tstep_nums */)
+ int success;
+// CAUTION: if the NetCDF ID is from a previous call to ncmpi_create rather than ncmpi_open,
+// all processors need to call ncmpi_begin_indep_data(). If only the root processor does so,
+// ncmpi_begin_indep_data() call will be blocked forever :(
+ #ifdef PNETCDF_FILE
+ // Enter independent I/O mode
+ success = NCFUNC(begin_indep_data)(_fileId);
+ ERRORS(success, "Failed to begin independent I/O mode.");
+ #endif
+ int rank = 0;
+ #ifdef USE_MPI
+ bool& isParallel = _writeNC->isParallel;
+ if (isParallel) {
+ ParallelComm*& myPcomm = _writeNC->myPcomm;
+ rank = myPcomm->proc_config().proc_rank();
+ #endif
+ if (0 == rank) {
+ for (unsigned int i = 0; i < vsetdatas.size(); i++) {
+ WriteNC::VarData& variableData = vsetdatas[i];
+ // Set variables with timesteps, e.g. xtime(Time) or xtime(Time, StrLen)
+ if (variableData.has_tsteps) {
+ ERRORR(MB_NOT_IMPLEMENTED, "Writing set variables with timesteps not implemented yet.");
+ case NC_DOUBLE:
+ // Independent I/O mode put
+ success = NCFUNCP(_vara_double)(_fileId, variableData.varId, &variableData.writeStarts[0],
+ &variableData.writeCounts[0], (double*)(variableData.memoryHogs[0]));
+ ERRORS(success, "Failed to write double data.");
+ break;
+ case NC_INT:
+ success = NCFUNCP(_vara_int)(_fileId, variableData.varId, &variableData.writeStarts[0],
+ &variableData.writeCounts[0], (int*)(variableData.memoryHogs[0]));
+ ERRORS(success, "Failed to write int data.");
+ break;
+ default:
+ // End independent I/O mode
+ success = NCFUNC(end_indep_data)(_fileId);
+ ERRORS(success, "Failed to end independent I/O mode.");
+ #endif
ErrorCode ScdNCWriteHelper::collect_mesh_info()
@@ -548,152 +663,68 @@ ErrorCode ScdNCWriteHelper::collect_variable_data(std::vector<std::string>& var_
return MB_SUCCESS;
-// For parallel write, we assume that the data ranges do not overlap across processors
-// While overlapped writing might still work, we should better not take that risk
-// For CAM-EUL and CAM-FV variables on non-shared quads (e.g. T), this is not an issue
-// We assume that there are no variables on vertices and we do not support variables
-// on edges (e.g. US in CAM-FV) for the time being
-ErrorCode ScdNCWriteHelper::write_values(std::vector<std::string>& var_names, std::vector<int>& tstep_nums)
+// Write CAM-EUL and CAM-FV non-set variables on non-shared quads (e.g. T)
+// We assume that there are no variables on vertices and we do not support
+// variables on edges (e.g. US in CAM-FV) for the time being
+ErrorCode ScdNCWriteHelper::write_nonset_variables(std::vector<WriteNC::VarData>& vdatas, std::vector<int>& tstep_nums)
int success;
- // Now look at requested var_names; if they have time, we will have a list, and write one at a time
- // If not, just write regularly
- // Use collective I/O mode put (synchronous write) for the time being, we can try nonblocking put
- // (request aggregation) later
- // Assume this variable is on faces for the time being
- // Faces
- break;
- default:
- ERRORR(MB_FAILURE, "Unexpected entity location type for structured mesh non-set variable.");
- // A typical variable has 4 dimensions as (time, lev, lat, lon)
- // At each timestep, we need to transpose tag format (lat, lon, lev) back
- // to NC format (lev, lat, lon) for writing
- size_t ni = variableData.writeCounts[3]; // lon
- size_t nj = variableData.writeCounts[2]; // lat
- size_t nk = variableData.writeCounts[1]; // lev
- variableData.writeCounts[0] = 1; // We will write one time step
- // We will write values directly from tag_iterate, but we should also transpose for level
- // so that means deep copy for transpose
- int count;
- void* dataptr;
- ErrorCode rval = mbImpl->tag_iterate(variableData.varTags[t], localCellsOwned.begin(), localCellsOwned.end(), count, dataptr);
- ERRORR(rval, "Failed to get tag iterator on owned faces.");
- assert(count == (int)localCellsOwned.size());
- case NC_DOUBLE: {
- std::vector<double> tmpdoubledata(ni*nj*nk);
- // Transpose (lat, lon, lev) back to (lev, lat, lon)
- jik_to_kji(ni, nj, nk, &tmpdoubledata[0], (double*)(dataptr));
- &variableData.writeStarts[0], &variableData.writeCounts[0],
- &tmpdoubledata[0]);
- break;
- default:
- else {
- case NC_DOUBLE:
- break;
- default:
+ // Assume this variable is on faces for the time being
+ // Faces
+ break;
+ default:
+ ERRORR(MB_FAILURE, "Unexpected entity location type for structured mesh non-set variable.");
-#endif
- int rank = 0;
-#ifdef USE_MPI
- if (isParallel) {
-#endif
- if (0 == rank) {
- // Skip dummy coordinate variables (if any)
- continue;
- case NC_DOUBLE:
+ // A typical CAM-EUL or CAM-FV non-set variable has 4 dimensions as (time, lev, lat, lon)
+ // At each timestep, we need to transpose tag format (lat, lon, lev) back
+ // to NC format (lev, lat, lon) for writing
+ size_t ni = variableData.writeCounts[3]; // lon
+ size_t nj = variableData.writeCounts[2]; // lat
+ size_t nk = variableData.writeCounts[1]; // lev
+ variableData.writeCounts[0] = 1; // We will write one time step
+ // We should also transpose for level so that means deep copy for transpose
+ variableData.writeStarts[0] = t; // This is start for time
+ int count;
+ void* dataptr;
+ ErrorCode rval = mbImpl->tag_iterate(variableData.varTags[t], localCellsOwned.begin(), localCellsOwned.end(), count, dataptr);
+ ERRORR(rval, "Failed to get tag iterator on owned faces.");
+ assert(count == (int)localCellsOwned.size());
+ // Use collective I/O mode put (synchronous write) for the time being, we can try nonblocking put
+ // (request aggregation) later
+ case NC_DOUBLE: {
+ std::vector<double> tmpdoubledata(ni*nj*nk);
+ // Transpose (lat, lon, lev) back to (lev, lat, lon)
+ jik_to_kji(ni, nj, nk, &tmpdoubledata[0], (double*)(dataptr));
+ &variableData.writeStarts[0], &variableData.writeCounts[0],
+ &tmpdoubledata[0]);
break;
- case NC_INT:
- break;
default:
-#endif
return MB_SUCCESS;
diff --git a/src/io/NCWriteHelper.hpp b/src/io/NCWriteHelper.hpp
index ff28da1..42425d2 100644
--- a/src/io/NCWriteHelper.hpp
+++ b/src/io/NCWriteHelper.hpp
@@ -23,20 +23,27 @@ public:
//! Get appropriate helper instance for WriteNC class based on some info in the file set
static NCWriteHelper* get_nc_helper(WriteNC* writeNC, int fileId, const FileOptions& opts, EntityHandle fileSet);
- //! Collect necessary info about local mesh
+ //! Collect necessary info about local mesh (implemented in child classes)
virtual ErrorCode collect_mesh_info() = 0;
- //! Collect data for specified variables
+ //! Collect data for specified variables (partially implemented in child classes)
- //! Take the info from VarData and write first the coordinates, then the actual variables
- virtual ErrorCode write_values(std::vector<std::string>& var_names, std::vector<int>& tstep_nums) = 0;
//! Initialize file: this is where all defines are done
//! The VarData dimension ids are filled up after define
ErrorCode init_file(std::vector<std::string>& var_names, std::vector<std::string>& desired_names, bool _append);
+ //! Take the info from VarData and write first non-set variables, then set variables
+ ErrorCode write_values(std::vector<std::string>& var_names, std::vector<int>& tstep_nums);
+private:
+ // Write set variables (common to scd mesh and ucd mesh)
+ ErrorCode write_set_variables(std::vector<WriteNC::VarData>& vsetdatas, std::vector<int>& tstep_nums);
protected:
+ // Write non-set variables (implemented in child classes)
+ virtual ErrorCode write_nonset_variables(std::vector<WriteNC::VarData>& vdatas, std::vector<int>& tstep_nums) = 0;
template <typename T> void jik_to_kji(size_t ni, size_t nj, size_t nk, T* dest, T* source)
size_t nik = ni * nk, nij = ni * nj;
@@ -89,8 +96,8 @@ private:
protected:
//! Dimensions of my local part of grid
diff --git a/src/io/NCWriteMPAS.cpp b/src/io/NCWriteMPAS.cpp
index 36b2a65..d149b03 100644
--- a/src/io/NCWriteMPAS.cpp
+++ b/src/io/NCWriteMPAS.cpp
@@ -231,12 +231,9 @@ ErrorCode NCWriteMPAS::collect_variable_data(std::vector<std::string>& var_names
return MB_SUCCESS;
-ErrorCode NCWriteMPAS::write_values(std::vector<std::string>& var_names, std::vector<int>& tstep_nums)
+ErrorCode NCWriteMPAS::write_nonset_variables(std::vector<WriteNC::VarData>& vdatas, std::vector<int>& tstep_nums)
int success;
@@ -245,170 +242,94 @@ ErrorCode NCWriteMPAS::write_values(std::vector<std::string>& var_names, std::ve
continue;
- // Vertices
- break;
- // Edges
- break;
- // Cells
- break;
- default:
- ERRORR(MB_FAILURE, "Unexpected entity location type for MPAS non-set variable.");
+ // Vertices
+ break;
+ // Edges
+ break;
+ // Cells
+ break;
+ default:
#ifdef PNETCDF_FILE
#endif
- case NC_DOUBLE: {
- size_t ic = 0;
+ case NC_DOUBLE: {
+ size_t ic = 0;
#ifdef PNETCDF_FILE
#else
-#endif
- // next subrange
#endif
- break;
+ // next subrange
- default:
- else {
- case NC_DOUBLE:
- break;
- default:
#ifdef PNETCDF_FILE
#endif
- int rank = 0;
-#ifdef USE_MPI
- if (isParallel) {
-#endif
- if (0 == rank) {
- continue;
- case NC_DOUBLE:
- break;
- case NC_INT:
break;
default:
-#endif
return MB_SUCCESS;
diff --git a/src/io/NCWriteMPAS.hpp b/src/io/NCWriteMPAS.hpp
index 757a76b..6df4874 100644
--- a/src/io/NCWriteMPAS.hpp
+++ b/src/io/NCWriteMPAS.hpp
} // namespace moab
Repository URL: https://bitbucket.org/fathomteam/moab/
This is a commit notification from bitbucket.org. You are receiving
this because you have the service enabled, addressing the recipient of
this email.
