[MOAB-dev] commit/MOAB: danwu: Applied TIMESTEP write option to NC	writer.
    commits-noreply at bitbucket.org
    Mon May  5 18:04:45 CDT 2014
1 new commit in MOAB:
https://bitbucket.org/fathomteam/moab/commits/6e49b0694060/
Changeset:   6e49b0694060
Branch:      master
User:        danwu
Date:        2014-05-06 01:04:31
Summary:     Applied TIMESTEP write option to NC writer.
Affected #:  10 files
diff --git a/src/io/NCWriteHOMME.cpp b/src/io/NCWriteHOMME.cpp
index e2bb69e..1dd16d8 100644
--- a/src/io/NCWriteHOMME.cpp
+++ b/src/io/NCWriteHOMME.cpp
@@ -81,9 +81,9 @@ ErrorCode NCWriteHOMME::collect_mesh_info()
   return MB_SUCCESS;
-ErrorCode NCWriteHOMME::collect_variable_data(std::vector<std::string>& var_names)
+ErrorCode NCWriteHOMME::collect_variable_data(std::vector<std::string>& var_names, std::vector<int>& tstep_nums)
-  NCWriteHelper::collect_variable_data(var_names);
+  NCWriteHelper::collect_variable_data(var_names, tstep_nums);
   std::map<std::string, WriteNC::VarData>& varInfo = _writeNC->varInfo;
@@ -136,7 +136,7 @@ ErrorCode NCWriteHOMME::collect_variable_data(std::vector<std::string>& var_name
   return MB_SUCCESS;
-ErrorCode NCWriteHOMME::write_values(std::vector<std::string>& var_names)
+ErrorCode NCWriteHOMME::write_values(std::vector<std::string>& var_names, std::vector<int>& tstep_nums)
   Interface*& mbImpl = _writeNC->mbImpl;
   std::set<std::string>& usedCoordinates = _writeNC->usedCoordinates;
@@ -173,16 +173,14 @@ ErrorCode NCWriteHOMME::write_values(std::vector<std::string>& var_names)
       // A typical variable has 3 dimensions as (time, lev, ncol)
       // At each timestep, we need to transpose tag format (ncol, lev) back
       // to NC format (lev, ncol) for writing
-      // FIXME: Should use tstep_nums (from writing options) later
-      int numTimeSteps = (int)variableData.varTags.size();
-      for (int j = 0; j < numTimeSteps; j++) {
+      for (unsigned int t = 0; t < tstep_nums.size(); t++) {
         // We will write one time step, and count will be one; start will be different
         // Use tag_get_data instead of tag_iterate to get values, as localVertsOwned
         // might not be contiguous. We should also transpose for level so that means
         // deep copy for transpose
-        variableData.writeStarts[0] = j; // This is time, again
+        variableData.writeStarts[0] = t; // This is time, again
         std::vector<double> tag_data(num_local_verts_owned * variableData.numLev);
-        ErrorCode rval = mbImpl->tag_get_data(variableData.varTags[j], localVertsOwned, &tag_data[0]);
+        ErrorCode rval = mbImpl->tag_get_data(variableData.varTags[t], localVertsOwned, &tag_data[0]);
         ERRORR(rval, "Trouble getting tag data on owned vertices.");
 #ifdef PNETCDF_FILE
diff --git a/src/io/NCWriteHOMME.hpp b/src/io/NCWriteHOMME.hpp
index 7bb99d9..ad689f5 100644
--- a/src/io/NCWriteHOMME.hpp
+++ b/src/io/NCWriteHOMME.hpp
@@ -26,10 +26,10 @@ private:
   virtual ErrorCode collect_mesh_info();
   //! Collect data for specified variables
-  virtual ErrorCode collect_variable_data(std::vector<std::string>& var_names);
+  virtual ErrorCode collect_variable_data(std::vector<std::string>& var_names, std::vector<int>& tstep_nums);
   //! Implementation of NCWriteHelper::write_values()
-  virtual ErrorCode write_values(std::vector<std::string>& var_names);
+  virtual ErrorCode write_values(std::vector<std::string>& var_names, std::vector<int>& tstep_nums);
 } // namespace moab
diff --git a/src/io/NCWriteHelper.cpp b/src/io/NCWriteHelper.cpp
index 1b4b70d..5ccf302 100644
--- a/src/io/NCWriteHelper.cpp
+++ b/src/io/NCWriteHelper.cpp
@@ -41,7 +41,7 @@ NCWriteHelper* NCWriteHelper::get_nc_helper(WriteNC* writeNC, int fileId, const
   return NULL;
-ErrorCode NCWriteHelper::collect_variable_data(std::vector<std::string>& var_names)
+ErrorCode NCWriteHelper::collect_variable_data(std::vector<std::string>& var_names, std::vector<int>& tstep_nums)
   std::vector<std::string>& dimNames = _writeNC->dimNames;
@@ -55,6 +55,12 @@ ErrorCode NCWriteHelper::collect_variable_data(std::vector<std::string>& var_nam
   usedCoordinates.clear();
+  if (tstep_nums.empty() && nTimeSteps > 0) {
+    // No timesteps input, get them all
+    for (int i = 0; i < nTimeSteps; i++)
+      tstep_nums.push_back(i);
   for (size_t i = 0; i < var_names.size(); i++) {
     std::string varname = var_names[i];
     std::map<std::string, WriteNC::VarData>::iterator vit = varInfo.find(varname);
@@ -89,18 +95,14 @@ ErrorCode NCWriteHelper::collect_variable_data(std::vector<std::string>& var_nam
     // Process non-set variables with time steps
     if (currentVarData.has_tsteps) {
-      int index = 0;
-      while (true) {
         Tag indexedTag = 0;
         std::stringstream ssTagNameWithIndex;
-        ssTagNameWithIndex << varname << index;
+        ssTagNameWithIndex << varname << tstep_nums[t];
         rval = mbImpl->tag_get_handle(ssTagNameWithIndex.str().c_str(), indexedTag);
-        if (MB_SUCCESS != rval)
-          break;
-        dbgOut.tprintf(2, "    found indexed tag %d with name %s\n", index, ssTagNameWithIndex.str().c_str());
+        ERRORR(rval, "Can't find one tag.");
+        dbgOut.tprintf(2, "    found indexed tag %d with name %s\n", tstep_nums[t], ssTagNameWithIndex.str().c_str());
         currentVarData.varTags.push_back(indexedTag);
-        index++; // We should get out of the loop at some point
         // The type of the tag is fixed though
         DataType type;
@@ -172,6 +174,14 @@ ErrorCode NCWriteHelper::collect_variable_data(std::vector<std::string>& var_nam
     dbgOut.tprintf(2, "    found coordinate tag with name %s and length %d\n", coordName.c_str(),
         sizeCoordinate);
+    // Find the type of tag, and use it
+    DataType type;
+    rval = mbImpl->tag_get_data_type(coordTag, type);
+    ERRORR(rval, "Can't get tag type.");
+    varCoordData.varDataType = NC_DOUBLE;
+    if (MB_TYPE_INTEGER == type)
+      varCoordData.varDataType = NC_INT;
     // Get dimension length (the only dimension of this coordinate variable, with the same name)
     assert(1 == varCoordData.varDims.size());
     int coordDimLen = dimLens[varCoordData.varDims[0]];
@@ -181,12 +191,30 @@ ErrorCode NCWriteHelper::collect_variable_data(std::vector<std::string>& var_nam
       // The number of coordinates should be set to dimension length, instead of 1
       assert(1 == sizeCoordinate);
       sizeCoordinate = coordDimLen;
+      // No variable data to write
+      data = NULL;
     else {
       // The number of coordinates should be exactly the same as dimension length
       assert(sizeCoordinate == coordDimLen);
+    // For time, the actual output size and values are determined by tstep_nums
+    if (varCoordData.varDims[0] == tDim) {
+      assert(tstep_nums.size() > 0 && tstep_nums.size() <= (size_t)sizeCoordinate);
+      sizeCoordinate = tstep_nums.size();
+      if (NULL != data) {
+        assert(NC_DOUBLE == varCoordData.varDataType);
+        timeStepVals.resize(sizeCoordinate);
+          timeStepVals[t] = ((double*)data)[tstep_nums[t]];
+        data = &timeStepVals[0];
     // This is the length
     varCoordData.sz = sizeCoordinate;
     varCoordData.writeStarts.resize(1);
@@ -194,15 +222,6 @@ ErrorCode NCWriteHelper::collect_variable_data(std::vector<std::string>& var_nam
     varCoordData.writeCounts.resize(1);
     varCoordData.writeCounts[0] = sizeCoordinate;
-    // Find the type of tag, and use it
-    DataType type;
-    rval = mbImpl->tag_get_data_type(coordTag, type);
-    ERRORR(rval, "Can't get tag type.");
-    varCoordData.varDataType = NC_DOUBLE;
-    if (MB_TYPE_INTEGER == type)
-      varCoordData.varDataType = NC_INT;
     assert(0 == varCoordData.memoryHogs.size()); // Nothing so far
     varCoordData.memoryHogs.push_back((void*)data);
@@ -474,9 +493,9 @@ ErrorCode ScdNCWriteHelper::collect_mesh_info()
   return MB_SUCCESS;
-ErrorCode ScdNCWriteHelper::collect_variable_data(std::vector<std::string>& var_names)
+ErrorCode ScdNCWriteHelper::collect_variable_data(std::vector<std::string>& var_names, std::vector<int>& tstep_nums)
@@ -534,7 +553,7 @@ ErrorCode ScdNCWriteHelper::collect_variable_data(std::vector<std::string>& var_
 // For CAM-EUL and CAM-FV variables on non-shared quads (e.g. T), this is not an issue
 // We assume that there are no variables on vertices and we do not support variables
 // on edges (e.g. US in CAM-FV) for the time being
-ErrorCode ScdNCWriteHelper::write_values(std::vector<std::string>& var_names)
+ErrorCode ScdNCWriteHelper::write_values(std::vector<std::string>& var_names, std::vector<int>& tstep_nums)
@@ -553,7 +572,6 @@ ErrorCode ScdNCWriteHelper::write_values(std::vector<std::string>& var_names)
       ERRORR(MB_FAILURE, "Can't find variable requested.");
     WriteNC::VarData& variableData = vit->second;
     if (variableData.has_tsteps) {
       // Time should be the first dimension
       assert(tDim == variableData.varDims[0]);
@@ -575,15 +593,15 @@ ErrorCode ScdNCWriteHelper::write_values(std::vector<std::string>& var_names)
       size_t nk = variableData.writeCounts[1]; // lev
       variableData.writeCounts[0] = 1; // We will write one time step
         // We will write values directly from tag_iterate, but we should also transpose for level
         // so that means deep copy for transpose
         int count;
         void* dataptr;
-        ErrorCode rval = mbImpl->tag_iterate(variableData.varTags[j], localCellsOwned.begin(), localCellsOwned.end(), count, dataptr);
+        ErrorCode rval = mbImpl->tag_iterate(variableData.varTags[t], localCellsOwned.begin(), localCellsOwned.end(), count, dataptr);
         ERRORR(rval, "Failed to get tag iterator on owned faces.");
         assert(count == (int)localCellsOwned.size());
diff --git a/src/io/NCWriteHelper.hpp b/src/io/NCWriteHelper.hpp
index 8c64eac..ff28da1 100644
--- a/src/io/NCWriteHelper.hpp
+++ b/src/io/NCWriteHelper.hpp
@@ -27,10 +27,10 @@ public:
   virtual ErrorCode collect_mesh_info() = 0;
   //! Take the info from VarData and write first the coordinates, then the actual variables
-  virtual ErrorCode write_values(std::vector<std::string>& var_names) = 0;
+  virtual ErrorCode write_values(std::vector<std::string>& var_names, std::vector<int>& tstep_nums) = 0;
   //! Initialize file: this is where all defines are done
   //! The VarData dimension ids are filled up after define
@@ -63,6 +63,9 @@ protected:
   //! Local owned cells, edges and vertices
   Range localCellsOwned, localEdgesOwned, localVertsOwned;
+  //! Time values of output timesteps
+  std::vector<double> timeStepVals;
 //! Child helper class for scd mesh, e.g. CAM_EL or CAM_FV
@@ -84,10 +87,10 @@ private:
 protected:
   //! Dimensions of my local part of grid
diff --git a/src/io/NCWriteMPAS.cpp b/src/io/NCWriteMPAS.cpp
index 8fca53d..36b2a65 100644
--- a/src/io/NCWriteMPAS.cpp
+++ b/src/io/NCWriteMPAS.cpp
@@ -117,9 +117,9 @@ ErrorCode NCWriteMPAS::collect_mesh_info()
   return MB_SUCCESS;
-ErrorCode NCWriteMPAS::collect_variable_data(std::vector<std::string>& var_names)
+ErrorCode NCWriteMPAS::collect_variable_data(std::vector<std::string>& var_names, std::vector<int>& tstep_nums)
   std::vector<int>& dimLens = _writeNC->dimLens;
@@ -231,7 +231,7 @@ ErrorCode NCWriteMPAS::collect_variable_data(std::vector<std::string>& var_names
   return MB_SUCCESS;
-ErrorCode NCWriteMPAS::write_values(std::vector<std::string>& var_names)
+ErrorCode NCWriteMPAS::write_values(std::vector<std::string>& var_names, std::vector<int>& tstep_nums)
@@ -282,15 +282,13 @@ ErrorCode NCWriteMPAS::write_values(std::vector<std::string>& var_names)
       // A typical variable has 3 dimensions as (Time, nCells, nVertLevels)
         // Use tag_get_data instead of tag_iterate to get values, as localEntsOwned
         std::vector<double> tag_data(pLocalEntsOwned->size() * variableData.numLev);
-        ErrorCode rval = mbImpl->tag_get_data(variableData.varTags[j], *pLocalEntsOwned, &tag_data[0]);
+        ErrorCode rval = mbImpl->tag_get_data(variableData.varTags[t], *pLocalEntsOwned, &tag_data[0]);
 #ifdef PNETCDF_FILE
diff --git a/src/io/NCWriteMPAS.hpp b/src/io/NCWriteMPAS.hpp
index 3c145cf..757a76b 100644
--- a/src/io/NCWriteMPAS.hpp
+++ b/src/io/NCWriteMPAS.hpp
 } // namespace moab
diff --git a/src/io/WriteNC.cpp b/src/io/WriteNC.cpp
index ca63367..21a2c19 100644
--- a/src/io/WriteNC.cpp
+++ b/src/io/WriteNC.cpp
@@ -132,13 +132,13 @@ ErrorCode WriteNC::write_file(const char* file_name,
   rval = myHelper->collect_mesh_info();
   ERRORR(rval, "Trouble collecting mesh info.");
-  rval = myHelper->collect_variable_data(var_names);
+  rval = myHelper->collect_variable_data(var_names, tstep_nums);
   ERRORR(rval, "Trouble collecting variable data.");
   rval = myHelper->init_file(var_names, desired_names, append);
   ERRORR(rval, "Failed to initialize file.");
-  rval = myHelper->write_values(var_names);
+  rval = myHelper->write_values(var_names, tstep_nums);
   ERRORR(rval, "Failed to write values.");
   success = NCFUNC(close)(fileId);
diff --git a/test/io/Makefile.am b/test/io/Makefile.am
index 256c8f2..b33eed8 100644
--- a/test/io/Makefile.am
+++ b/test/io/Makefile.am
@@ -93,5 +93,6 @@ MOSTLYCLEANFILES = dumped_acis.sat \
                    test_fv_T.nc \
                    test_homme_T.nc \
                    test_mpas_vars.nc \
+                   test_eul_T2.nc \
                    test_eul_append.nc \
                    test_eul_ghosting.nc
diff --git a/test/io/write_nc.cpp b/test/io/write_nc.cpp
index 96ff728..c71b6c8 100644
--- a/test/io/write_nc.cpp
+++ b/test/io/write_nc.cpp
@@ -46,6 +46,10 @@ void test_homme_check_T();
 void test_mpas_read_write_vars();
 void test_mpas_check_vars();
+// Test timestep option
+void test_eul_read_write_timestep();
+void test_eul_check_timestep();
 // Test append option
 void test_eul_read_write_append();
 void test_eul_check_append();
@@ -85,6 +89,9 @@ int main(int argc, char* argv[])
   result += RUN_TEST(test_mpas_read_write_vars);
   result += RUN_TEST(test_mpas_check_vars);
+  result += RUN_TEST(test_eul_read_write_timestep);
+  result += RUN_TEST(test_eul_check_timestep);
   result += RUN_TEST(test_eul_read_write_append);
   result += RUN_TEST(test_eul_check_append);
@@ -708,6 +715,118 @@ void test_mpas_check_vars()
+// Read non-set variable T on all 3 timesteps, and write only timestep 2
+  int procs = 1;
+#ifdef USE_MPI
+  MPI_Comm_size(MPI_COMM_WORLD, &procs);
+#endif
+// We will not test NC writer in parallel without pnetcdf support
+#ifndef PNETCDF_FILE
+  if (procs > 1)
+    return;
+#endif
+  Core moab;
+  Interface& mb = moab;
+  std::string read_opts;
+  get_eul_read_options(read_opts);
+  EntityHandle set;
+  ErrorCode rval = mb.create_meshset(MESHSET_SET, set);
+  CHECK_ERR(rval);
+  // Read non-set variable T
+  read_opts += ";VARIABLE=T;DEBUG_IO=0";
+  rval = mb.load_file(example_eul, &set, read_opts.c_str());
+  CHECK_ERR(rval);
+  // Write variable T on timestep 2
+  std::string write_opts = ";;VARIABLE=T;TIMESTEP=2;DEBUG_IO=0";
+#ifdef USE_MPI
+  // Use parallel options
+  write_opts += ";PARALLEL=WRITE_PART";
+#endif
+  if (procs > 1)
+    rval = mb.write_file("test_par_eul_T2.nc", 0, write_opts.c_str(), &set, 1);
+  else
+    rval = mb.write_file("test_eul_T2.nc", 0, write_opts.c_str(), &set, 1);
+  CHECK_ERR(rval);
+  int rank = 0;
+  int procs = 1;
+#ifdef USE_MPI
+  MPI_Comm_rank(MPI_COMM_WORLD, &rank);
+#endif
+  if (procs > 1)
+    return;
+#endif
+  if (0 == rank) {
+    int ncid;
+    int success;
+    std::string filename;
+    if (procs > 1)
+      filename = "test_par_eul_T2.nc";
+    else
+      filename = "test_eul_T2.nc";
+#ifdef PNETCDF_FILE
+    success = NCFUNC(open)(MPI_COMM_SELF, filename.c_str(), NC_NOWRITE, MPI_INFO_NULL, &ncid);
+#else
+    success = NCFUNC(open)(filename.c_str(), NC_NOWRITE, &ncid);
+#endif
+    CHECK_EQUAL(0, success);
+    int T_id;
+    success = NCFUNC(inq_varid)(ncid, "T", &T_id);
+    // Enter independent I/O mode
+    success = NCFUNC(begin_indep_data)(ncid);
+#endif
+    NCDF_SIZE start[] = {0, 0, 0, 0};
+    NCDF_SIZE count[] = {1, 1, 48, 96}; // Read one timestep and one level
+    // Read variable T on 48 * 96 quads (first level)
+    double T_vals_lev1[48 * 96];
+    success = NCFUNC(get_vara_double)(ncid, T_id, start, count, T_vals_lev1);
+    // End independent I/O mode
+    success = NCFUNC(end_indep_data)(ncid);
+#endif
+    double eps = 0.0001;
+    // Check T values at some strategically chosen places (first level)
+    // Timestep 2
+    CHECK_REAL_EQUAL(224.1966, T_vals_lev1[0], eps); // First quad
+    CHECK_REAL_EQUAL(236.1357, T_vals_lev1[2303], eps); // Median quad
+    CHECK_REAL_EQUAL(235.9430, T_vals_lev1[2304], eps); // Median quad
+    CHECK_REAL_EQUAL(218.7719, T_vals_lev1[4607], eps); // Last quad
+    success = NCFUNC(close)(ncid);
 // Read non-set variables T, U and V
 // Write variable T, append U, and then append V (with a new name)
diff --git a/test/parallel/Makefile.am b/test/parallel/Makefile.am
index db37e48..c0824c9 100644
--- a/test/parallel/Makefile.am
+++ b/test/parallel/Makefile.am
@@ -125,5 +125,6 @@ MOSTLYCLEANFILES = mhdf_ll.h5m tmp0.h5m tmp1.h5m tmp2.h5m tmp3.h5m \
                    test_par_fv_T.nc \
                    test_par_homme_T.nc \
                    test_par_mpas_vars.nc \
+                   test_par_eul_T2.nc \
                    test_par_eul_append.nc \
                    test_par_eul_ghosting.nc
Repository URL: https://bitbucket.org/fathomteam/moab/
This is a commit notification from bitbucket.org. You are receiving
this because you have the service enabled, addressing the recipient of
this email.
