[MOAB-dev] Surface Senses
    shriwise
    shriwise at wisc.edu
    Fri May  2 15:03:17 CDT 2014
Hi all,
Just wanted to check that I'm reading this convention correctly. Each
surface can have up to two parent volumes. The senses of a surface are
contained in a tag that is comprised of two entity handles. The first
entity handle has the sense forward and the second a sense reversed. Is
that so?
Cheers,
Patrick C. Shriwise
Research Assistant
University of Wisconsin - Madison
Engineering Research Building - Rm. 428
1500 Engineering Drive
Madison, WI 53706
(608) 446-8173
