[MOAB-dev] commit/MOAB: danwu: Updated unit test write_nc for serial MOAB, which failed with "PARALLEL option not valid, this instance compiled for serial execution".
commits-noreply at bitbucket.org
Wed Apr 30 15:40:27 CDT 2014
1 new commit in MOAB:
https://bitbucket.org/fathomteam/moab/commits/967a5ee16b1b/
Changeset: 967a5ee16b1b
Branch: master
User: danwu
Date: 2014-04-30 22:40:13
Summary: Updated unit test write_nc for serial MOAB, which failed with "PARALLEL option not valid, this instance compiled for serial execution".
Affected #: 1 file
diff --git a/test/io/write_nc.cpp b/test/io/write_nc.cpp
index 54d16d5..2dc8e9a 100644
--- a/test/io/write_nc.cpp
+++ b/test/io/write_nc.cpp
@@ -111,13 +111,20 @@ void test_eul_read_write_T()
ErrorCode rval = mb.create_meshset(MESHSET_SET, set);
CHECK_ERR(rval);
+#ifdef USE_MPI
read_opts = "PARALLEL=READ_PART;PARTITION;PARALLEL_RESOLVE_SHARED_ENTS;PARALLEL_GHOSTS=2.0.1;PARTITION_METHOD=SQIJ;VARIABLE=";
rval = mb.load_file(example_eul, &set, read_opts.c_str());
CHECK_ERR(rval);
- read_opts = "PARALLEL=READ_PART;PARTITION;PARTITION_METHOD=SQIJ;VARIABLE=T,gw;NOMESH;";
+ read_opts = "PARALLEL=READ_PART;PARTITION;PARTITION_METHOD=SQIJ;VARIABLE=T,gw;NOMESH";
+ rval = mb.load_file(example_eul, &set, read_opts.c_str());
+ CHECK_ERR(rval);
+#else
+ read_opts += ";DEBUG_IO=0;VARIABLE=T,gw";
CHECK_ERR(rval);
+#endif
// Write variables T and gw
std::string write_opts;
write_opts = std::string(";;VARIABLE=T,gw;DEBUG_IO=0");
Repository URL: https://bitbucket.org/fathomteam/moab/
This is a commit notification from bitbucket.org. You are receiving
this because you have the service enabled, addressing the recipient of
this email.
