[MOAB-dev] commit/MOAB: danwu: Updated NC writer and its unit test. Parallel write should work now for structured mesh (e.g. CAM_EUL).
commits-noreply at bitbucket.org
Mon Apr 21 12:05:13 CDT 2014
1 new commit in MOAB:
https://bitbucket.org/fathomteam/moab/commits/0da3e5524647/
Changeset: 0da3e5524647
Branch: ncwriter
User: danwu
Date: 2014-04-21 19:04:58
Summary: Updated NC writer and its unit test. Parallel write should work now for structured mesh (e.g. CAM_EUL).
Affected #: 3 files
diff --git a/src/io/NCWriteHelper.cpp b/src/io/NCWriteHelper.cpp
index 8e50903..aa69d0f 100644
--- a/src/io/NCWriteHelper.cpp
+++ b/src/io/NCWriteHelper.cpp
@@ -457,42 +457,15 @@ ErrorCode ScdNCWriteHelper::write_values(std::vector<std::string>& var_names)
std::map<std::string, WriteNC::VarData>& varInfo = _writeNC->varInfo;
ErrorCode rval;
- // Start with coordinates
- for (std::set<std::string>::iterator setIt = usedCoordinates.begin();
- setIt != usedCoordinates.end(); ++setIt) {
- const std::string& coordName = *setIt;
- // Skip dummy coordinate variables (if any)
- if (dummyVarNames.find(coordName) != dummyVarNames.end())
- continue;
- std::map<std::string, WriteNC::VarData>::iterator vit = varInfo.find(coordName);
- if (vit == varInfo.end())
- ERRORR(MB_FAILURE, "Can't find one coordinate variable.");
- WriteNC::VarData& varCoordData = vit->second;
- int success = 0;
- switch (varCoordData.varDataType) {
- case NC_DOUBLE:
- success = NCFUNCAP(_vara_double)(_fileId, varCoordData.varId, &varCoordData.writeStarts[0],
- &varCoordData.writeCounts[0], (double*)(varCoordData.memoryHogs[0]));
- ERRORS(success, "Failed to write double data.");
- break;
- case NC_INT:
- success = NCFUNCAP(_vara_int)(_fileId, varCoordData.varId, &varCoordData.writeStarts[0],
- &varCoordData.writeCounts[0], (int*)(varCoordData.memoryHogs[0]));
- ERRORS(success, "Failed to write int data.");
- break;
- default:
- success = 1;
- break;
+ int success;
// Now look at requested var_names; if they have time, we will have a list, and write one at a time
- // if not, just write regularly
+ // If not, just write regularly
+ // For parallel write, we assume that the data ranges do not overlap across processors (this is true
+ // for Euler and FV variables on quads)
+ // While overlapped writing might still work, we should better not take that risk
+ // Use collective I/O mode put (synchronous write) for the time being, we can try nonblocking put
+ // (request aggregation) later
for (size_t i = 0; i < var_names.size(); i++) {
std::map<std::string, WriteNC::VarData>::iterator vit = varInfo.find(var_names[i]);
@@ -536,7 +509,6 @@ ErrorCode ScdNCWriteHelper::write_values(std::vector<std::string>& var_names)
assert(count == (int)ents.size());
// Now write from memory directly
- int success = 0;
switch (variableData.varDataType) {
case NC_DOUBLE: {
std::vector<double> tmpdoubledata(ni*nj*nk);
@@ -554,7 +526,6 @@ ErrorCode ScdNCWriteHelper::write_values(std::vector<std::string>& var_names)
else {
- int success = 0;
case NC_DOUBLE:
success = NCFUNCAP(_vara_double)(_fileId, variableData.varId, &variableData.writeStarts[0],
@@ -567,6 +538,62 @@ ErrorCode ScdNCWriteHelper::write_values(std::vector<std::string>& var_names)
+ // Write coordinates used by requested var_names
+ // Use independent I/O mode put, since this write is only for the root processor
+ // CAUTION: if the NetCDF ID is from a previous call to ncmpi_create rather than ncmpi_open,
+ // all processors need to call ncmpi_begin_indep_data(). If only the root processor does so,
+ // ncmpi_begin_indep_data() will be blocked forever, :(
+ // Enter independent I/O mode
+ success = NCFUNC(begin_indep_data)(_fileId);
+ ERRORS(success, "Failed to begin independent I/O mode.");
+ int rank = 0;
+#ifdef USE_MPI
+ bool& isParallel = _writeNC->isParallel;
+ if (isParallel) {
+ ParallelComm*& myPcomm = _writeNC->myPcomm;
+ rank = myPcomm->proc_config().proc_rank();
+#endif
+ if (0 == rank) {
+ for (std::set<std::string>::iterator setIt = usedCoordinates.begin();
+ setIt != usedCoordinates.end(); ++setIt) {
+ const std::string& coordName = *setIt;
+ // Skip dummy coordinate variables (if any)
+ if (dummyVarNames.find(coordName) != dummyVarNames.end())
+ continue;
+ std::map<std::string, WriteNC::VarData>::iterator vit = varInfo.find(coordName);
+ if (vit == varInfo.end())
+ ERRORR(MB_FAILURE, "Can't find one coordinate variable.");
+ WriteNC::VarData& varCoordData = vit->second;
+ switch (varCoordData.varDataType) {
+ case NC_DOUBLE:
+ // Independent I/O mode put
+ success = NCFUNCP(_vara_double)(_fileId, varCoordData.varId, &varCoordData.writeStarts[0],
+ &varCoordData.writeCounts[0], (double*)(varCoordData.memoryHogs[0]));
+ ERRORS(success, "Failed to write double data.");
+ break;
+ case NC_INT:
+ success = NCFUNCP(_vara_int)(_fileId, varCoordData.varId, &varCoordData.writeStarts[0],
+ &varCoordData.writeCounts[0], (int*)(varCoordData.memoryHogs[0]));
+ ERRORS(success, "Failed to write int data.");
+ break;
+ default:
+ ERRORR(MB_FAILURE, "Not implemented yet.");
+ // End independent I/O mode
+ success = NCFUNC(end_indep_data)(_fileId);
+ ERRORS(success, "Failed to end independent I/O mode.");
return MB_SUCCESS;
diff --git a/src/io/WriteNC.hpp b/src/io/WriteNC.hpp
index f9af683..1c5d78e 100644
--- a/src/io/WriteNC.hpp
+++ b/src/io/WriteNC.hpp
@@ -41,7 +41,10 @@
//! Collective I/O mode put
#define NCFUNCAP(func) ncmpi_put ## func ## _all
-//! Nonblocking put (request aggregation), used so far only for ucd mesh
+//! Independent I/O mode put
+#define NCFUNCP(func) ncmpi_put ## func
+//! Nonblocking put (request aggregation)
#define NCFUNCREQP(func) ncmpi_iput ## func
#define NCDF_SIZE MPI_Offset
@@ -50,6 +53,7 @@
#include "netcdf.h"
#define NCFUNC(func) nc_ ## func
#define NCFUNCAP(func) nc_put ## func
+#define NCFUNCP(func) nc_put ## func
#define NCDF_SIZE size_t
#define NCDF_DIFF ptrdiff_t
#endif
diff --git a/test/io/write_nc.cpp b/test/io/write_nc.cpp
index 30b3f15..6f2c9af 100644
--- a/test/io/write_nc.cpp
+++ b/test/io/write_nc.cpp
@@ -27,8 +27,8 @@ void test_eul_check_T();
void test_homme_read_write_T();
void test_homme_check_T();
-void get_eul_options(std::string& opts);
-void get_homme_options(std::string& opts);
+void get_eul_read_options(std::string& opts);
+void get_homme_read_options(std::string& opts);
int main(int argc, char* argv[])
@@ -60,118 +60,170 @@ int main(int argc, char* argv[])
// In test_eul_check_T(), we need to load the output file with mesh
void test_eul_read_write_T()
+ int procs = 1;
+#ifdef USE_MPI
+ MPI_Comm_size(MPI_COMM_WORLD, &procs);
+#endif
Core moab;
Interface& mb = moab;
- std::string orig;
- get_eul_options(orig);
+ std::string read_opts;
+ get_eul_read_options(read_opts);
EntityHandle set;
ErrorCode rval = mb.create_meshset(MESHSET_SET, set);
CHECK_ERR(rval);
// Load non-set variable T, set variable gw, and the mesh
- std::string opts = orig + std::string(";DEBUG_IO=0;VARIABLE=T,gw");
- rval = mb.load_file(example_eul, &set, opts.c_str());
+ read_opts += ";DEBUG_IO=0;VARIABLE=T,gw";
+ rval = mb.load_file(example_eul, &set, read_opts.c_str());
CHECK_ERR(rval);
// Write variables T and gw
- std::string writeopts;
- writeopts = std::string(";;VARIABLE=T,gw;DEBUG_IO=0;");
- rval = mb.write_file("test_eul_T.nc", 0, writeopts.c_str(), &set, 1);
- CHECK_ERR(rval);
+ std::string write_opts;
+ write_opts = std::string(";;VARIABLE=T,gw;DEBUG_IO=0");
+#ifdef USE_MPI
+ // Use parallel options
+ write_opts += std::string(";PARALLEL=WRITE_PART");
+#endif
+ if (procs > 1)
+ rval = mb.write_file("test_par_eul_T.nc", 0, write_opts.c_str(), &set, 1);
+ else
+ rval = mb.write_file("test_eul_T.nc", 0, write_opts.c_str(), &set, 1);
// Check non-set variable T on some quads
// Also check set variable gw
+ int rank = 0;
+ int procs = 1;
+#ifdef USE_MPI
+ MPI_Comm_rank(MPI_COMM_WORLD, &rank);
+#endif
Core moab;
- std::string opts;
- get_eul_options(opts);
EntityHandle set;
CHECK_ERR(rval);
- opts += std::string(";VARIABLE=T,gw");
- rval = mb.load_file("test_eul_T.nc", &set, opts.c_str());
+ read_opts += ";VARIABLE=T,gw";
+ if (procs > 1)
+ rval = mb.load_file("test_par_eul_T.nc", &set, read_opts.c_str());
+ else
+ rval = mb.load_file("test_eul_T.nc", &set, read_opts.c_str());
CHECK_ERR(rval);
- int procs = 1;
-#ifdef USE_MPI
- ParallelComm* pcomm = ParallelComm::get_pcomm(&mb, 0);
- procs = pcomm->proc_config().proc_size();
-#endif
+ double eps = 1e-10;
- // Only test serial case for the time being
- if (1 == procs) {
+ // Only check tag gw values on the root processor
+ if (0 == rank) {
// Get tag gw
Tag gw_tag;
rval = mb.tag_get_handle("gw", 0, MB_TYPE_OPAQUE, gw_tag, MB_TAG_SPARSE | MB_TAG_VARLEN);
CHECK_ERR(rval);
- // Check some values of tag gw
const void* var_data;
int var_len = 0;
rval = mb.tag_get_by_ptr(gw_tag, &set, 1, &var_data, &var_len);
CHECK_ERR(rval);
CHECK_EQUAL(48, var_len);
double* gw_val = (double*)var_data;
- double eps = 1e-10;
CHECK_REAL_EQUAL(0.00315334605230584, gw_val[0], eps);
CHECK_REAL_EQUAL(0.0647376968126839, gw_val[23], eps);
CHECK_REAL_EQUAL(0.0647376968126839, gw_val[24], eps);
CHECK_REAL_EQUAL(0.00315334605230584, gw_val[47], eps);
- // Get tag T0
- Tag Ttag0;
- rval = mb.tag_get_handle("T0", 26, MB_TYPE_DOUBLE, Ttag0);
- CHECK_ERR(rval);
+ // Get tag T0
+ Tag Ttag0;
+ rval = mb.tag_get_handle("T0", 26, MB_TYPE_DOUBLE, Ttag0);
+ CHECK_ERR(rval);
- // Check some values of tag T0 on first level
- double val[4 * 26];
+ eps = 0.0001;
+ double val[8 * 26];
+ if (1 == procs) {
Range global_quads;
- rval = mb.get_entities_by_type(set, MBQUAD, global_quads);
+ rval = mb.get_entities_by_type(0, MBQUAD, global_quads);
CHECK_ERR(rval);
CHECK_EQUAL((size_t)4608, global_quads.size());
- EntityHandle gloabl_quad_ents[] = {global_quads[0], global_quads[2303], global_quads[2304], global_quads[4607]};
- rval = mb.tag_get_data(Ttag0, &gloabl_quad_ents[0], 4, val);
- CHECK_ERR(rval);
- eps = 0.0001;
+ EntityHandle gloabl_quad_ents[] = {global_quads[0], global_quads[2255], global_quads[2304], global_quads[4559],
+ global_quads[48], global_quads[2303], global_quads[2352], global_quads[4607]};
+ rval = mb.tag_get_data(Ttag0, &gloabl_quad_ents[0], 8, val);
CHECK_REAL_EQUAL(252.8529, val[0 * 26], eps); // First global quad
- CHECK_REAL_EQUAL(232.6670, val[1 * 26], eps); // 2304th global quad
+ CHECK_REAL_EQUAL(234.8390, val[1 * 26], eps); // 2256th global quad
CHECK_REAL_EQUAL(232.6458, val[2 * 26], eps); // 2305th global quad
- CHECK_REAL_EQUAL(200.6828, val[3 * 26], eps); // Last global quad
+ CHECK_REAL_EQUAL(205.3905, val[3 * 26], eps); // 4560th global quad
+ CHECK_REAL_EQUAL(252.7116, val[4 * 26], eps); // 49th global quad
+ CHECK_REAL_EQUAL(232.6670, val[5 * 26], eps); // 2304th global quad
+ CHECK_REAL_EQUAL(234.6922, val[6 * 26], eps); // 2353th global quad
+ CHECK_REAL_EQUAL(200.6828, val[7 * 26], eps); // Last global quad
+ else if (2 == procs) {
+ Range local_quads;
+ rval = mb.get_entities_by_type(0, MBQUAD, local_quads);
+ CHECK_ERR(rval);
+ CHECK_EQUAL((size_t)2304, local_quads.size());
+ EntityHandle local_quad_ents[] = {local_quads[0], local_quads[1151], local_quads[1152], local_quads[2303]};
+ rval = mb.tag_get_data(Ttag0, &local_quad_ents[0], 4, val);
+ if (0 == rank) {
+ CHECK_REAL_EQUAL(252.8529, val[0 * 26], eps); // First local quad, first global quad
+ CHECK_REAL_EQUAL(234.8390, val[1 * 26], eps); // Median local quad, 2256th global quad
+ CHECK_REAL_EQUAL(232.6458, val[2 * 26], eps); // Median local quad, 2305th global quad
+ CHECK_REAL_EQUAL(205.3905, val[3 * 26], eps); // Last local quad, 4560th global quad
+ else if (1 == rank) {
+ CHECK_REAL_EQUAL(252.7116, val[0 * 26], eps); // First local quad, 49th global quad
+ CHECK_REAL_EQUAL(232.6670, val[1 * 26], eps); // Median local quad, 2304th global quad
+ CHECK_REAL_EQUAL(234.6922, val[2 * 26], eps); // Median local quad, 2353th global quad
+ CHECK_REAL_EQUAL(200.6828, val[3 * 26], eps); // Last local quad, last global quad
-// We also read and write set variables lat and lon, which are are required to create the mesh
+// We also read and write set variables lat and lon, which are required to create the mesh
// In test_homme_check_T(), we need to load the output file with mesh
+ int procs = 1;
+#ifdef USE_MPI
+#endif
+ // Only test serial case for the time being
+ if (procs > 1)
+ return;
Core moab;
- std::string orig;
- get_homme_options(orig);
+ get_homme_read_options(read_opts);
EntityHandle set;
CHECK_ERR(rval);
// Load non-set variable T, set variable lat, set variable lon, and the mesh
- std::string opts = orig + std::string(";DEBUG_IO=0;VARIABLE=T,lat,lon");
- rval = mb.load_file(example_homme, &set, opts.c_str());
+ read_opts += ";DEBUG_IO=0;VARIABLE=T,lat,lon";
+ rval = mb.load_file(example_homme, &set, read_opts.c_str());
CHECK_ERR(rval);
// Write variables T, lat and lon
- writeopts = std::string(";;VARIABLE=T,lat,lon;DEBUG_IO=0;");
- rval = mb.write_file("test_homme_T.nc", 0, writeopts.c_str(), &set, 1);
+ std::string write_opts = ";;VARIABLE=T,lat,lon;DEBUG_IO=0;";
+ rval = mb.write_file("test_homme_T.nc", 0, write_opts.c_str(), &set, 1);
CHECK_ERR(rval);
@@ -179,30 +231,31 @@ void test_homme_read_write_T()
// Also check set variables lat and lon
+ int procs = 1;
+#ifdef USE_MPI
+#endif
+ if (procs > 1)
+ return;
Core moab;
- std::string opts;
- get_homme_options(opts);
EntityHandle set;
CHECK_ERR(rval);
- opts += std::string(";VARIABLE=T,lat,lon");
- opts += ";CONN=";
- opts += example_homme_mapping;
- rval = mb.load_file("test_homme_T.nc", &set, opts.c_str());
+ read_opts += ";VARIABLE=T,lat,lon";
+ read_opts += ";CONN=";
+ read_opts += example_homme_mapping;
+ rval = mb.load_file("test_homme_T.nc", &set, read_opts.c_str());
CHECK_ERR(rval);
- int procs = 1;
-#ifdef USE_MPI
-#endif
if (1 == procs) {
// Get tag lat
Tag lat_tag;
@@ -266,22 +319,22 @@ void test_homme_check_T()
#ifdef USE_MPI
- opts = std::string(";;PARALLEL=READ_PART;PARTITION_METHOD=SQIJ");
+ opts = ";;PARALLEL=READ_PART;PARTITION_METHOD=SQIJ";
#else
- opts = std::string(";;");
+ opts = ";;";
#endif
#ifdef USE_MPI
- opts = std::string(";;PARALLEL=READ_PART;PARTITION_METHOD=TRIVIAL");
+ opts = ";;PARALLEL=READ_PART;PARTITION_METHOD=TRIVIAL";
#else
+ opts = ";;";
#endif
Repository URL: https://bitbucket.org/fathomteam/moab/
This is a commit notification from bitbucket.org. You are receiving
this because you have the service enabled, addressing the recipient of
this email.
