[MOAB-dev] exchanging both quads and edges while exchanging ghosts cells
Grindeanu, Iulian R.
iulian at mcs.anl.gov
Thu Apr 17 17:10:22 CDT 2014
do you need edges or not?
what is the bug? Are edges duplicated when you ghost? can you replicate a problem in a small moab test?
Can you delete edges before writing the file?
Or when you write, write only the hexas + quads (put in a set what you need, and write in parallel just that set)
Why can't you read in parallel after writing?
From: kanaev at ibrae.ac.ru [kanaev at ibrae.ac.ru]
Sent: Thursday, April 17, 2014 4:18 PM
To: Grindeanu, Iulian R.
Cc: MOAB dev
Subject: exchanging both quads and edges while exchanging ghosts cells
Hello Iulian,
I exchange one layer of ghost dim 3
result = pcomm->exchange_ghost_cells(3, // int ghost_dim,
0, // int bridge_dim,
1, //int num_layers,
2, //int addl_ents,
true); // bool store_remote_handles);
then if i do:
result = mb->get_entities_by_dimension(0, 3, ents);
PRINT_LAST_ERROR;
for (moab::Range::iterator it = ents.begin(); it != ents.end(); it++) {
EntityHandle ent = *it;
HandleVec edges;
result = mb->get_adjacencies(&(ent), 1, 1, true, edges);
i'll have additional edges created which i don't need (because after i save file writing everything i cannot load from it in parallel afterwards)
I think i have to echange edges besides of quads during exchange_ghost_cells but it's not an option.
How can i avoid unnecessary doubling of edges in this case?
Thanks
Anton
URL: <http://lists.mcs.anl.gov/pipermail/moab-dev/attachments/20140417/c3d6ff0f/attachment.html>
