[MOAB-dev] commit/MOAB: danwu: Updated NC writer and its unit test (fixed some issues caused by dummy coordinate variables). For writing a HOMME file, the header part is done. Will continue to work on the data part for non-dimension variables.
commits-noreply at bitbucket.org commits-noreply at bitbucket.org
Tue Apr 15 10:20:43 CDT 2014
1 new commit in MOAB:
https://bitbucket.org/fathomteam/moab/commits/4160ad611092/
Changeset:   4160ad611092
Branch:      ncwriter
User:        danwu
Date:        2014-04-15 17:20:23
Summary:     Updated NC writer and its unit test (fixed some issues caused by dummy coordinate variables). For writing a HOMME file, the header part is done. Will continue to work on the data part for non-dimension variables.
Affected #:  4 files
diff --git a/src/io/NCWriteEuler.cpp b/src/io/NCWriteEuler.cpp
index 70d5bdd..4671ed2 100644
--- a/src/io/NCWriteEuler.cpp
+++ b/src/io/NCWriteEuler.cpp
@@ -24,6 +24,7 @@ ErrorCode NCWriteEuler::write_values(std::vector<std::string>& var_names, Entity
   Interface*& mbImpl = _writeNC->mbImpl;
   std::set<std::string>& usedCoordinates = _writeNC->usedCoordinates;
+  std::set<std::string>& dummyVarNames = _writeNC->dummyVarNames;
   std::map<std::string, WriteNC::VarData>& varInfo = _writeNC->varInfo;
   // Start with coordinates
@@ -31,6 +32,10 @@ ErrorCode NCWriteEuler::write_values(std::vector<std::string>& var_names, Entity
       setIt != usedCoordinates.end(); ++setIt) {
     std::string coordName = *setIt; // Deep copy
+    // Skip dummy coordinate variables (if any)
+    if (dummyVarNames.find(coordName) != dummyVarNames.end())
+      continue;
     std::map<std::string, WriteNC::VarData>::iterator vit = varInfo.find(coordName);
     if (vit == varInfo.end())
       ERRORR(MB_FAILURE, "Can't find one coordinate variable.");
@@ -56,9 +61,7 @@ ErrorCode NCWriteEuler::write_values(std::vector<std::string>& var_names, Entity
   // Now look at requested var_names; if they have time, we will have a list, and write one at a time
-  // We may also need to gather, and transpose stuff
-  // Get all entities of dimension 2 from set
-  // Need to reorder stuff in the order from the file, also transpose from lev dimension
+  // Need to transpose from lev dimension
   ErrorCode rval;
   // For each variable tag in the indexed lists, write a time step data
@@ -74,28 +77,16 @@ ErrorCode NCWriteEuler::write_values(std::vector<std::string>& var_names, Entity
       // Get entities of this variable
       Range ents;
       switch (variableData.entLoc) {
-        case WriteNC::ENTLOCVERT:
-          // Vertices
-          rval = mbImpl->get_entities_by_dimension(fileSet, 0, ents);
-          ERRORR(rval, "Can't get entities for vertices.");
-          break;
         case WriteNC::ENTLOCFACE:
           // Faces
           rval = mbImpl->get_entities_by_dimension(fileSet, 2, ents);
           ERRORR(rval, "Can't get entities for faces.");
           break;
-        case WriteNC::ENTLOCNSEDGE:
-        case WriteNC::ENTLOCEWEDGE:
-        case WriteNC::ENTLOCEDGE:
-          // Edges
-          rval = mbImpl->get_entities_by_dimension(fileSet, 1, ents);
-          ERRORR(rval, "Can't get entities for edges.");
-          break;
         default:
-          break;
+          ERRORR(MB_FAILURE, "Unexpected entity location type for CAM-EUL non-set variable.");
-      // FIXME: assume now the variable has 4 dimensions as (time, lev, lat, lon)
+      // A typical variable has 4 dimensions as (time, lev, lat, lon)
       // At each timestep, we need to transpose tag format (lat, lon, lev) back
       // to NC format (lev, lat, lon) for writing
       size_t ni = variableData.writeCounts[3]; // lon
@@ -114,7 +105,6 @@ ErrorCode NCWriteEuler::write_values(std::vector<std::string>& var_names, Entity
         assert(count == (int)ents.size());
         // Now write from memory directly
-        // FIXME: we need to gather for multiple processors
         int success = 0;
         switch (variableData.varDataType) {
           case NC_DOUBLE: {
diff --git a/src/io/NCWriteHOMME.cpp b/src/io/NCWriteHOMME.cpp
index 3b500b5..8625f14 100644
--- a/src/io/NCWriteHOMME.cpp
+++ b/src/io/NCWriteHOMME.cpp
@@ -22,7 +22,50 @@ NCWriteHOMME::~NCWriteHOMME()
 ErrorCode NCWriteHOMME::write_values(std::vector<std::string>& var_names, EntityHandle fileSet)
-  return MB_NOT_IMPLEMENTED;
+  Interface*& mbImpl = _writeNC->mbImpl;
+  std::set<std::string>& usedCoordinates = _writeNC->usedCoordinates;
+  std::map<std::string, WriteNC::VarData>& varInfo = _writeNC->varInfo;
+  // Start with coordinates
+  for (std::set<std::string>::iterator setIt = usedCoordinates.begin();
+      setIt != usedCoordinates.end(); ++setIt) {
+    std::string coordName = *setIt; // Deep copy
+    // Skip dummy coordinate variables (e.g. ncol)
+      continue;
+    std::map<std::string, WriteNC::VarData>::iterator vit = varInfo.find(coordName);
+    if (vit == varInfo.end())
+      ERRORR(MB_FAILURE, "Can't find one coordinate variable.");
+    WriteNC::VarData& varCoordData = vit->second;
+    int success = 0;
+    switch (varCoordData.varDataType) {
+      case NC_DOUBLE:
+        success = NCFUNCAP(_vara_double)(_fileId, varCoordData.varId, &varCoordData.writeStarts[0],
+                  &varCoordData.writeCounts[0], (double*)(varCoordData.memoryHogs[0]));
+        ERRORS(success, "Failed to write double data.");
+        break;
+      case NC_INT:
+        success = NCFUNCAP(_vara_int)(_fileId, varCoordData.varId, &varCoordData.writeStarts[0],
+                  &varCoordData.writeCounts[0], (int*)(varCoordData.memoryHogs[0]));
+        ERRORS(success, "Failed to write int data.");
+        break;
+      default:
+        success = 1;
+        break;
+  // Now look at requested var_names; if they have time, we will have a list, and write one at a time
+  // Write data, to be implemented ...
+  return MB_SUCCESS;
 } /* namespace moab */
diff --git a/src/io/WriteNC.cpp b/src/io/WriteNC.cpp
index d359c83..e05dadf 100644
--- a/src/io/WriteNC.cpp
+++ b/src/io/WriteNC.cpp
@@ -533,7 +533,7 @@ ErrorCode WriteNC::collect_variable_data(std::vector<std::string>& var_names, st
         currentVarData.has_tsteps = true;
       // Probably will have to look at tstep_vals to match them
-      sizeVar *= dimLens[j];
+      sizeVar *= dimLens[currentVarData.varDims[j]];
       usedCoordinates.insert(dimName); // Collect those used, we will need to write them to the file
       dbgOut.tprintf(2, "    for variable %s need dimension %s with length %d\n", varname.c_str(), dimName.c_str(), dimLens[currentVarData.varDims[j]]);
@@ -543,7 +543,7 @@ ErrorCode WriteNC::collect_variable_data(std::vector<std::string>& var_names, st
     if (currentVarData.has_tsteps) {
       int index = 0;
       while (true) {
-        Tag indexedTag;
+        Tag indexedTag = 0;
         std::stringstream ssTagNameWithIndex;
         ssTagNameWithIndex << varname << index;
         rval = mbImpl->tag_get_handle(ssTagNameWithIndex.str().c_str(), indexedTag);
@@ -566,18 +566,18 @@ ErrorCode WriteNC::collect_variable_data(std::vector<std::string>& var_names, st
     else {
       // Get the tag with varname
-      Tag coordtag = 0;
-      rval = mbImpl->tag_get_handle(varname.c_str(), coordtag);
+      Tag tag = 0;
+      rval = mbImpl->tag_get_handle(varname.c_str(), tag);
       ERRORR(rval, "Can't find one tag.");
-      currentVarData.varTags.push_back(coordtag); // Really, only one for these
+      currentVarData.varTags.push_back(tag); // Really, only one for these
       const void* data;
-      int sizeCoordinate;
-      rval = mbImpl->tag_get_by_ptr(coordtag, &fileSet, 1, &data, &sizeCoordinate);
-      ERRORR(rval, "Can't get coordinate values.");
+      int size;
+      rval = mbImpl->tag_get_by_ptr(tag, &fileSet, 1, &data, &size);
+      ERRORR(rval, "Can't get tag values.");
       // Find the type of tag, and use it
       DataType type;
-      rval = mbImpl->tag_get_data_type(coordtag, type);
+      rval = mbImpl->tag_get_data_type(tag, type);
       ERRORR(rval, "Can't get tag type.");
       currentVarData.varDataType = NC_DOUBLE;
@@ -599,18 +599,33 @@ ErrorCode WriteNC::collect_variable_data(std::vector<std::string>& var_names, st
-    Tag coordtag = 0;
-    rval = mbImpl->tag_get_handle(coordName.c_str(), coordtag);
+    Tag coordTag = 0;
+    rval = mbImpl->tag_get_handle(coordName.c_str(), coordTag);
-    varCoordData.varTags.push_back(coordtag); // Really, only one for these
+    varCoordData.varTags.push_back(coordTag); // Really, only one for these
     const void* data;
     int sizeCoordinate;
+    rval = mbImpl->tag_get_by_ptr(coordTag, &fileSet, 1, &data, &sizeCoordinate);
     dbgOut.tprintf(2, "    found coordinate tag with name %s and length %d\n", coordName.c_str(),
         sizeCoordinate);
+    // Get dimension length (the only dimension of this coordinate variable, with the same name)
+    assert(1 == varCoordData.varDims.size());
+    int coordDimLen = dimLens[varCoordData.varDims[0]];
+    if (dummyVarNames.find(coordName) != dummyVarNames.end()) {
+      // For a dummy coordinate variable, the tag size is always 1
+      // The number of coordinates should be set to dimension length, instead of 1
+      assert(1 == sizeCoordinate);
+      sizeCoordinate = coordDimLen;
+    else {
+      // The number of coordinates should be exactly the same as dimension length
+      assert(sizeCoordinate == coordDimLen);
     // This is the length
     varCoordData.sz = sizeCoordinate;
     varCoordData.writeStarts.resize(1);
@@ -620,7 +635,7 @@ ErrorCode WriteNC::collect_variable_data(std::vector<std::string>& var_names, st
     DataType type;
+    rval = mbImpl->tag_get_data_type(coordTag, type);
     varCoordData.varDataType = NC_DOUBLE;
@@ -639,7 +654,7 @@ ErrorCode WriteNC::initialize_file(std::vector<std::string>& var_names)
   // First initialize all coordinates, then fill VarData for actual variables (and dimensions)
   // Check that for used coordinates we have found the tags
-      setIt != usedCoordinates.end(); setIt++) {
     std::map<std::string, VarData>::iterator vit = varInfo.find(coordName);
@@ -667,6 +682,11 @@ ErrorCode WriteNC::initialize_file(std::vector<std::string>& var_names)
        example: http://www.unidata.ucar.edu/software/netcdf/docs/netcdf-c/nc_005fdef_005fvar.html#nc_005fdef_005fvar
+      continue;
+    // Define a coordinate variable
     if (NCFUNC(def_var)(fileId, coordName.c_str(), varCoordData.varDataType,
         1, &(varCoordData.varDims[0]), &varCoordData.varId) != NC_NOERR)
       ERRORR(MB_FAILURE, "Failed to create coordinate variable.");
diff --git a/test/io/write_nc.cpp b/test/io/write_nc.cpp
index 72256e5..5261532 100644
--- a/test/io/write_nc.cpp
+++ b/test/io/write_nc.cpp
@@ -7,9 +7,11 @@ using namespace moab;
 #ifdef MESHDIR
 static const char example_eul[] = STRINGIFY(MESHDIR) "/io/camEul26x48x96.t3.nc";
 static const char example_homme[] = STRINGIFY(MESHDIR) "/io/homme26x3458.t.3.nc";
+static const char example_homme_mapping[] = STRINGIFY(MESHDIR) "/io/HommeMapping.nc";
 #else
 static const char example_eul[] = "/io/camEul26x48x96.t3.nc";
 static const char example_homme[] = "/io/homme26x3458.t.3.nc";
+static const char example_homme_mapping[] = "/io/HommeMapping.nc";
 #endif
 #ifdef USE_MPI
@@ -18,12 +20,12 @@ static const char example_homme[] = "/io/homme26x3458.t.3.nc";
 #endif
 // CAM-EUL
-void test_eul_read_write_T_gw();
-void test_eul_check_T_gw_values();
+void test_eul_read_write_T();
+void test_eul_check_T();
 // CAM-SE (HOMME)
 void test_homme_read_write_T();
-void test_homme_check_T_values();
+void test_homme_check_T();
 void get_eul_options(std::string& opts);
 void get_homme_options(std::string& opts);
@@ -40,10 +42,10 @@ int main(int argc, char* argv[])
   argv[0] = argv[argc - argc]; // To remove the warnings in serial mode about unused variables
 #endif
-  result += RUN_TEST(test_eul_read_write_T_gw);
-  result += RUN_TEST(test_eul_check_T_gw_values);
-  //result += RUN_TEST(test_homme_read_write_T);
-  //result += RUN_TEST(test_homme_check_T_values);
+  result += RUN_TEST(test_eul_read_write_T);
+  result += RUN_TEST(test_eul_check_T);
+  result += RUN_TEST(test_homme_read_write_T);
+  //result += RUN_TEST(test_homme_check_T);
 #ifdef USE_MPI
   fail = MPI_Finalize();
@@ -54,7 +56,9 @@ int main(int argc, char* argv[])
   return result;
+// We also read and write set variable gw, which is required to create the mesh
+// In test_eul_check_T_values(), we need to load the output file with mesh
   Core moab;
   Interface& mb = moab;
@@ -71,15 +75,16 @@ void test_eul_read_write_T_gw()
   rval = mb.load_file(example_eul, &set, opts.c_str());
   CHECK_ERR(rval);
-  // This test will write information about variable T and gw
-  // To load the output file with mesh, variable gw is required
+  // Write variables T and gw
   std::string writeopts;
   writeopts = std::string(";;VARIABLE=T,gw;DEBUG_IO=2;");
-  rval = mb.write_file("test_eul_T_gw.nc", 0, writeopts.c_str(), &set, 1);
+  rval = mb.write_file("test_eul_T.nc", 0, writeopts.c_str(), &set, 1);
   CHECK_ERR(rval);
+// Check non-set variable T on some quads
+// Also check set variable gw
   Core moab;
@@ -93,7 +98,7 @@ void test_eul_check_T_gw_values()
   // Load non-set variable T, set variable gw, and the mesh
   opts += std::string(";VARIABLE=T,gw");
-  rval = mb.load_file("test_eul_T_gw.nc", &set, opts.c_str());
+  rval = mb.load_file("test_eul_T.nc", &set, opts.c_str());
   CHECK_ERR(rval);
   int procs = 1;
@@ -144,6 +149,8 @@ void test_eul_check_T_gw_values()
+// We also read and write set variables lat and lon, which are are required to create the mesh
+// In test_homme_check_T_values(), we need to load the output file with mesh
   Core moab;
@@ -156,19 +163,21 @@ void test_homme_read_write_T()
   ErrorCode rval = mb.create_meshset(MESHSET_SET, set);
   CHECK_ERR(rval);
-  // Load non-set variable T and the mesh
-  std::string opts = orig + std::string(";DEBUG_IO=0;VARIABLE=T");
+  // Load non-set variable T, set variable lat, set variable lon, and the mesh
+  std::string opts = orig + std::string(";DEBUG_IO=0;VARIABLE=T,lat,lon");
   rval = mb.load_file(example_homme, &set, opts.c_str());
   CHECK_ERR(rval);
+  // Write variables T, lat and lon
-  writeopts = std::string(";;VARIABLE=T;DEBUG_IO=0;");
+  writeopts = std::string(";;VARIABLE=T,lat,lon;DEBUG_IO=0;");
   rval = mb.write_file("test_homme_T.nc", 0, writeopts.c_str(), &set, 1);
   CHECK_ERR(rval);
+// Check non-set variable T on some vertices
+// Also check set variables lat and lon
   Core moab;
@@ -180,8 +189,10 @@ void test_homme_check_T_values()
   CHECK_ERR(rval);
-  opts += std::string(";VARIABLE=T");
+  opts += std::string(";VARIABLE=T,lat,lon");
+  opts += ";CONN=";
+  opts += example_homme_mapping;
   rval = mb.load_file("test_homme_T.nc", &set, opts.c_str());
   CHECK_ERR(rval);
@@ -193,6 +204,40 @@ void test_homme_check_T_values()
   // Only test serial case for the time being
   if (1 == procs) {
+    // Get tag lat
+    Tag lat_tag;
+    rval = mb.tag_get_handle("lat", 0, MB_TYPE_OPAQUE, lat_tag, MB_TAG_SPARSE | MB_TAG_VARLEN);
+    CHECK_ERR(rval);
+    // Check some values of tag lat
+    const void* var_data;
+    int var_len = 0;
+    rval = mb.tag_get_by_ptr(lat_tag, &set, 1, &var_data, &var_len);
+    CHECK_ERR(rval);
+    CHECK_EQUAL(3458, var_len);
+    double* lat_val = (double*)var_data;
+    double eps = 1e-10;
+    CHECK_REAL_EQUAL(-35.2643896827547, lat_val[0], eps);
+    CHECK_REAL_EQUAL(23.8854752772335, lat_val[1728], eps);
+    CHECK_REAL_EQUAL(29.8493120043874, lat_val[1729], eps);
+    CHECK_REAL_EQUAL(38.250274171077, lat_val[3457], eps);
+    // Get tag lon
+    Tag lon_tag;
+    rval = mb.tag_get_handle("lon", 0, MB_TYPE_OPAQUE, lon_tag, MB_TAG_SPARSE | MB_TAG_VARLEN);
+    CHECK_ERR(rval);
+    // Check some values of tag lon
+    var_len = 0;
+    rval = mb.tag_get_by_ptr(lon_tag, &set, 1, &var_data, &var_len);
+    CHECK_ERR(rval);
+    double* lon_val = (double*)var_data;
+    CHECK_REAL_EQUAL(315, lon_val[0], eps);
+    CHECK_REAL_EQUAL(202.5, lon_val[1728], eps);
+    CHECK_REAL_EQUAL(194.359423525313, lon_val[1729], eps);
+    CHECK_REAL_EQUAL(135, lon_val[3457], eps);
     // Get tag T0
     Tag Ttag0;
     rval = mb.tag_get_handle("T0", 26, MB_TYPE_DOUBLE, Ttag0);
@@ -212,7 +257,7 @@ void test_homme_check_T_values()
     CHECK_EQUAL((size_t)count, verts.size());
     // Check some values of tag T0 on first level
-    const double eps = 0.0001;
+    eps = 0.0001;
     double* data = (double*) Tbuf;
     CHECK_REAL_EQUAL(233.1136, data[0 * 26], eps); // First vert
     CHECK_REAL_EQUAL(236.1505, data[1728 * 26], eps); // Median vert
Repository URL: https://bitbucket.org/fathomteam/moab/
This is a commit notification from bitbucket.org. You are receiving
this because you have the service enabled, addressing the recipient of
this email.
