[MOAB-dev] missing global ids for cubit 14.1 model
    Grindeanu, Iulian R.
    iulian at mcs.anl.gov
    Wed Apr  9 09:18:46 CDT 2014
Hi Anton,
Yes, indeed, some geometry sets are missing ids.
I will investigate; I will log a ticket.
How is the file created, is something special about it?
Iulian
From: kanaev at ibrae.ac.ru [kanaev at ibrae.ac.ru]
Sent: Tuesday, April 08, 2014 2:32 PM
To: Grindeanu, Iulian R.
Cc: MOAB dev
Subject: RE: [MOAB-dev] write_file freezes on Cetus
Hello Iulian,
 Thanks for advise, i've built the latest version in my home dir and it
worked as well as on my pc
There's something strange still happening while getting global_ids from
Cubit surfaces
Please do mbconvert to .h5m with attached .cub file, and then check
global_ids of surface mbentitysets with mbsize - part of them (5-9) got the
proper ids and the others got zeroes
Anton
On Tue, 8 Apr 2014 00:45:43 +0000, "Grindeanu, Iulian R."
<iulian at mcs.anl.gov> wrote:
> Hi Anton,
> It worked for me on Vesta, even with your file, so it must be something
> with your build
> this is how I configure moab on vesta, mira should be very similar.
> You do not need mbcslam, or zoltan for your test (or pnetcdf)
> ../moab/configure CC=mpixlc CFLAGS=-qarch=qp CXX=mpixlcxx
> CXXFLAGS="-qarch=qp -qpic=large -qmaxmem=-1" FC=mpixlf90
FCFLAGS=-qarch=qp
> --prefix=/home/grindean/lib/moab --enable-optimize --disable-debug
> --with-mpi --build=ppc64-redhat-linux --host=powerpc64-bgq-linux
> --with-zlib=/soft/libraries/alcf/current/xl/ZLIB
> --with-hdf5=/soft/libraries/hdf5/current/cnk-xl/current --disable-shared
> --enable-static QTDIR=/usr/lib64/qt-3.3 build_alias=ppc64-redhat-linux
> host_alias=powerpc64-bgq-linux
> --with-pnetcdf=/soft/libraries/pnetcdf/current/cnk-xl/V1R2M0-20131217
> --enable-mbcslam
--with-zoltan=/home/grindean/3rdparty/lib/Zoltan_trilinos
> --with-netcdf=/soft/libraries/netcdf/4.3.0-f4.2/cnk-xl/current
> All needed libraries are under /soft
> Iulian
> From: moab-dev-bounces at mcs.anl.gov [moab-dev-bounces at mcs.anl.gov] on
> behalf of kanaev at ibrae.ac.ru [kanaev at ibrae.ac.ru]
> Sent: Sunday, April 06, 2014 10:57 AM
> To: Vijay S. Mahadevan
> Cc: MOAB dev
> Subject: Re: [MOAB-dev] write_file freezes on Cetus
> Hi Vijay,
> The problem is still there and really seems to be about my mesh file.
I've
> tried to run ReduceExchangeTags with 64bricks_1khex.h5m
> qsub -n 4 -t 00:30:00 -A ThermHydraX ReduceExchangeTags
64bricks_1khex.h5m
> USERTAG 100
>  and it works but then i tried it with my file
> qsub -n 4 -t 00:30:00 -A ThermHydraX ReduceExchangeTags karmanp4.h5m
> USERTAG 100
> and it freezes on writing test.h5m
> i've also tried
> qsub -n 2 -t 00:30:00 -A ThermHydraX ReduceExchangeTags karmanp4.h5m
> USERTAG 100
> and it worked
> What can be the problem? I've attached the mesh file i used - i made mesh
> in Cubit, converted it to h5m with mbconvert and parted it with mbpart
for
> 4 processors. My MOAB version is 4.7.0 and so are the tools mentioned
> above. MOAB version installed on Mira is older.
> Where can those bin tools from MOAB build be found on Mira filesystem?
> Should i build a new version in my home folder?
> Thanks,
> Anton
> On Fri, 4 Apr 2014 13:56:50 -0500, "Vijay S. Mahadevan"
> <vijay.m at gmail.com>
> wrote:
>>> I run [akanaev at cetuslac1 ~]$ qsub -n 4 -t 01:00:00 -A ThermHydraX
>>> ReduceExchangeTags karmanp4.h5m USERTAG 100
>>> It makes 7600 Bytes file test.h5m and freezes like this forever
>> Can you verify if it works on other combinations of processors (2, 8
>> etc) ? If the example still fails, please send over the input mesh
>> file so that we can find out the actual issue.
>> Vijay
>> On Fri, Apr 4, 2014 at 1:34 PM,  <kanaev at ibrae.ac.ru> wrote:
>>> Hello MOAB-dev,
>>> I've tried to run one of your examples ReduceExchangeTags.cpp on Cetus
>>> Makefile i used:
>>> ZLIB_DIR=/soft/libraries/alcf/current/xl/ZLIB
>>> HDF5_DIR=/soft/libraries/hdf5/current/cnk-xl/current
>>> MOAB_DIR=/soft/applications/moab/4.6.0/cnk-xl/current
>>> LDADD = -lMOAB -liMesh -lhdf5
>>> LIBS =-lz
>>> CXX = mpixlcxx
>>> CXXFLAGS = -O0
>>> LDFLAGS =  -L$(ZLIB_DIR)/lib  -L$(HDF5_DIR)/lib -L$(MOAB_DIR)/lib
>>> INCLUDES=-I$(MOAB_DIR)/include
>>> CXXCOMPILE = $(CXX) $(CXXFLAGS) $(INCLUDES)
>>> ReduceExchangeTags: ReduceExchangeTags.o
>>> @rm -f ReduceExchangeTags
>>> $(CXXCOMPILE) ReduceExchangeTags.o -o ReduceExchangeTags $(LDFLAGS)
>> $(LDADD)
>>> $(LIBS)
>>> ReduceExchangeTags.o: ReduceExchangeTags.cpp
>>> $(CXXCOMPILE) -c ReduceExchangeTags.cpp
>>> clean:
>>> rm -rf *o ReduceExchangeTags
>>> Please check what's wrong
>>> Anton
