[MOAB-dev] write_file freezes on Cetus
Grindeanu, Iulian R.
iulian at mcs.anl.gov
Tue Apr 8 11:56:53 CDT 2014
Anton,
To get a better feel of what is going on, please run with DEBUG_IO=1 for writing.
so you will need to recompile the example to write with these options:
about line 219 in the file MOABsource/examples/ReduceExchangeTags.cpp
// Write out to output file to visualize reduction/exchange of tag data
mbi->write_file("test.h5m", "H5M", "PARALLEL=WRITE_PART;DEBUG_IO=1;");
Or you can even try with DEBUG_IO=3, and send us the output. do not give 30 minutes, give the minimum (on vesta is 5), it should take less than a minute to write ( or hang up )
Iulian
From: moab-dev-bounces at mcs.anl.gov [moab-dev-bounces at mcs.anl.gov] on behalf of Rob Latham [robl at mcs.anl.gov]
Sent: Tuesday, April 08, 2014 10:39 AM
To: moab-dev at mcs.anl.gov
Subject: Re: [MOAB-dev] write_file freezes on Cetus
On 04/07/2014 07:45 PM, Grindeanu, Iulian R. wrote:
> Hi Anton,
> It worked for me on Vesta, even with your file, so it must be something with your build
> this is how I configure moab on vesta, mira should be very similar.
> You do not need mbcslam, or zoltan for your test (or pnetcdf)
he did say cetus, which is running a slightly older driver.
I'd like to see a stack trace of the hang, in case it's actually just
doing i/o really really slowly.
==rob
> ../moab/configure CC=mpixlc CFLAGS=-qarch=qp CXX=mpixlcxx CXXFLAGS="-qarch=qp -qpic=large -qmaxmem=-1" FC=mpixlf90 FCFLAGS=-qarch=qp --prefix=/home/grindean/lib/moab --enable-optimize --disable-debug --with-mpi --build=ppc64-redhat-linux --host=powerpc64-bgq-linux --with-zlib=/soft/libraries/alcf/current/xl/ZLIB --with-hdf5=/soft/libraries/hdf5/current/cnk-xl/current --disable-shared --enable-static QTDIR=/usr/lib64/qt-3.3 build_alias=ppc64-redhat-linux host_alias=powerpc64-bgq-linux --with-pnetcdf=/soft/libraries/pnetcdf/current/cnk-xl/V1R2M0-20131217 --enable-mbcslam --with-zoltan=/home/grindean/3rdparty/lib/Zoltan_trilinos --with-netcdf=/soft/libraries/netcdf/4.3.0-f4.2/cnk-xl/current
> All needed libraries are under /soft
> Iulian
> From: moab-dev-bounces at mcs.anl.gov [moab-dev-bounces at mcs.anl.gov] on behalf of kanaev at ibrae.ac.ru [kanaev at ibrae.ac.ru]
> Sent: Sunday, April 06, 2014 10:57 AM
> To: Vijay S. Mahadevan
> Cc: MOAB dev
> Hi Vijay,
> The problem is still there and really seems to be about my mesh file. I've
> tried to run ReduceExchangeTags with 64bricks_1khex.h5m
> qsub -n 4 -t 00:30:00 -A ThermHydraX ReduceExchangeTags 64bricks_1khex.h5m
> USERTAG 100
> and it works but then i tried it with my file
> qsub -n 4 -t 00:30:00 -A ThermHydraX ReduceExchangeTags karmanp4.h5m
> USERTAG 100
> and it freezes on writing test.h5m
> i've also tried
> qsub -n 2 -t 00:30:00 -A ThermHydraX ReduceExchangeTags karmanp4.h5m
> USERTAG 100
> and it worked
> What can be the problem? I've attached the mesh file i used - i made mesh
> in Cubit, converted it to h5m with mbconvert and parted it with mbpart for
> 4 processors. My MOAB version is 4.7.0 and so are the tools mentioned
> above. MOAB version installed on Mira is older.
> Where can those bin tools from MOAB build be found on Mira filesystem?
> Should i build a new version in my home folder?
> Thanks,
> Anton
> On Fri, 4 Apr 2014 13:56:50 -0500, "Vijay S. Mahadevan" <vijay.m at gmail.com>
> wrote:
>>> I run [akanaev at cetuslac1 ~]$ qsub -n 4 -t 01:00:00 -A ThermHydraX
>>> ReduceExchangeTags karmanp4.h5m USERTAG 100
>>> It makes 7600 Bytes file test.h5m and freezes like this forever
>> Can you verify if it works on other combinations of processors (2, 8
>> etc) ? If the example still fails, please send over the input mesh
>> file so that we can find out the actual issue.
>> Vijay
>> On Fri, Apr 4, 2014 at 1:34 PM, <kanaev at ibrae.ac.ru> wrote:
>>> Hello MOAB-dev,
>>> I've tried to run one of your examples ReduceExchangeTags.cpp on Cetus
>>> Makefile i used:
>>> ZLIB_DIR=/soft/libraries/alcf/current/xl/ZLIB
>>> HDF5_DIR=/soft/libraries/hdf5/current/cnk-xl/current
>>> MOAB_DIR=/soft/applications/moab/4.6.0/cnk-xl/current
>>> LDADD = -lMOAB -liMesh -lhdf5
>>> LIBS =-lz
>>> CXX = mpixlcxx
>>> CXXFLAGS = -O0
>>> LDFLAGS = -L$(ZLIB_DIR)/lib -L$(HDF5_DIR)/lib -L$(MOAB_DIR)/lib
>>> INCLUDES=-I$(MOAB_DIR)/include
>>> CXXCOMPILE = $(CXX) $(CXXFLAGS) $(INCLUDES)
>>> ReduceExchangeTags: ReduceExchangeTags.o
>>> @rm -f ReduceExchangeTags
>>> $(CXXCOMPILE) ReduceExchangeTags.o -o ReduceExchangeTags $(LDFLAGS)
>> $(LDADD)
>>> $(LIBS)
>>> ReduceExchangeTags.o: ReduceExchangeTags.cpp
>>> $(CXXCOMPILE) -c ReduceExchangeTags.cpp
>>> clean:
>>> rm -rf *o ReduceExchangeTags
>>> Please check what's wrong
>>> Anton
Rob Latham
Mathematics and Computer Science Division
Argonne National Lab, IL USA
