[MOAB-dev] commit/MOAB: gonuke: Remove reliance on hard coded 64-bit entity handle. Some refactor of point_in_volume tests.
commits-noreply at bitbucket.org commits-noreply at bitbucket.org
Thu Mar 27 06:41:39 CDT 2014
1 new commit in MOAB:
https://bitbucket.org/fathomteam/moab/commits/6882b5129a3a/
Changeset:   6882b5129a3a
Branch:      master
User:        gonuke
Date:        2014-03-27 12:40:41
Summary:     Remove reliance on hard coded 64-bit entity handle.  Some refactor of point_in_volume tests.
Affected #:  3 files
diff --git a/test/dagmc/dagmc_pointinvol_test.cpp b/test/dagmc/dagmc_pointinvol_test.cpp
index a540b63..47ee7c1 100644
--- a/test/dagmc/dagmc_pointinvol_test.cpp
+++ b/test/dagmc/dagmc_pointinvol_test.cpp
@@ -36,33 +36,42 @@ void dagmc_setup_test()
   int num_vols = DAG->num_entities(3);
   EntityHandle vol;
-  EntityHandle volume = 12682136550675316765;
   for ( int i = 0 ; i < num_vols ; i++ )
       vol = DAG->entity_by_index(3,i);
-  CHECK_EQUAL(volume,vol);
+  //EntityHandle volume = 12682136550675316765;
+  //CHECK_EQUAL(volume,vol);
 void dagmc_point_in()
   int result = 0;
+  int expected_result=1;
   double xyz[3]={0.0,0.0,0.0};
-  ErrorCode rval = DAG->point_in_volume(volume,xyz,result);
-  CHECK_EQUAL(1,result);
+  int vol_idx=1;
+  EntityHandle vol_h = DAG->entity_by_index(3,vol_idx);
+  ErrorCode rval = DAG->point_in_volume(vol_h,xyz,result);
+  CHECK_ERR(rval);
+  CHECK_EQUAL(expected_result,result);
-void dagmc_point_in_vol_1()
+int dagmc_point_in_vol_dir(double origin[3],double dir[3],int vol_idx)
   int result = 0;
-  double dir[3]={-1.0,0.0,0.0};
-  double origin[3]={0.0,0.0,0.0};
   double xyz[3];
   double next_surf_dist;
   EntityHandle next_surf;
-  ErrorCode rval = DAG->ray_fire(volume,origin,dir,next_surf,next_surf_dist);
+  // normalise the vector
+  double dir_norm = (dir[0]*dir[0])+(dir[1]*dir[1])+(dir[2]*dir[2]);
+  dir[0]=dir[0]/sqrt(dir_norm);
+  dir[1]=dir[1]/sqrt(dir_norm);
+  dir[2]=dir[2]/sqrt(dir_norm);
+  ErrorCode rval = DAG->ray_fire(vol_h,origin,dir,next_surf,next_surf_dist);
   xyz[0]=origin[0]+(next_surf_dist*dir[0]);
   xyz[1]=origin[1]+(next_surf_dist*dir[1]);
@@ -70,359 +79,179 @@ void dagmc_point_in_vol_1()
   std::cout << xyz[0] << " " << xyz[1] << " " << xyz[2] << std::endl;
-  rval = DAG->point_in_volume(volume,xyz,result,dir);
+  rval = DAG->point_in_volume(vol_h,xyz,result,dir);
   CHECK_ERR(rval);
+  return result;
+void dagmc_point_in_vol_1()
+  double dir[3]={ -1.0,0.0,0.0};
+  double origin[3]={0.0,0.0,0.0};
+  int vol_idx=1;
+  int result = dagmc_point_in_vol_dir(origin,dir,vol_idx);
 void dagmc_point_in_vol_2()
-  int result = 0;
+  int vol_idx=1;
   double dir[3]={ 1.0,0.0,0.0};
-  double xyz[3];
-  double next_surf_dist;
-  EntityHandle next_surf;
-  xyz[0]=origin[0]+(next_surf_dist*dir[0]);
-  xyz[1]=origin[1]+(next_surf_dist*dir[1]);
-  xyz[2]=origin[2]+(next_surf_dist*dir[2]);
-  std::cout << xyz[0] << " " << xyz[1] << " " << xyz[2] << std::endl;
-  CHECK_ERR(rval);
 void dagmc_point_in_vol_3()
-  int result = 0;
+  int vol_idx=1;
   double dir[3]={ 0.0,-1.0,0.0};
-  double xyz[3];
-  CHECK_ERR(rval);
 void dagmc_point_in_vol_4()
-  int result = 0;
+  int vol_idx=1;
   double dir[3]={ 0.0,1.0,0.0};
-  double xyz[3];
-  CHECK_ERR(rval);
 void dagmc_point_in_vol_5()
-  int result = 0;
+  int vol_idx=1;
   double dir[3]={ 0.0,0.0,-1.0};
-  double xyz[3];
-  CHECK_ERR(rval);
 void dagmc_point_in_vol_6()
-  int result = 0;
+  int vol_idx=1;
   double dir[3]={ 0.0,0.0,1.0};
-  double xyz[3];
-  CHECK_ERR(rval);
 void dagmc_point_on_corner_1()
-  int result = 0;
+  int vol_idx=1;
   double dir[3]={ 1.0,1.0,1.0};
-  double xyz[3];
-  // normalise the vector
-  double dir_norm = (dir[0]*dir[0])+(dir[1]*dir[1])+(dir[2]*dir[2]);
-  dir[0]=dir[0]/sqrt(dir_norm);
-  dir[1]=dir[1]/sqrt(dir_norm);
-  dir[2]=dir[2]/sqrt(dir_norm);
-  CHECK_ERR(rval);
 void dagmc_point_on_corner_2()
-  int result = 0;
+  int vol_idx=1;
   double dir[3]={ -1.0,1.0,1.0};
-  double xyz[3];
-  CHECK_ERR(rval);
 void dagmc_point_on_corner_3()
-  int result = 0;
+  int expected_result = 1;
+  int vol_idx=1;
   double dir[3]={ 1.0,1.0,-1.0};
-  double xyz[3];
-  CHECK_ERR(rval);
 void dagmc_point_on_corner_4()
-  int result = 0;
+  int vol_idx=1;
   double dir[3]={ -1.0,1.0,-1.0};
-  double xyz[3];
-  CHECK_ERR(rval);
 void dagmc_point_on_corner_5()
-  int result = 0;
+  int vol_idx=1;
   double dir[3]={ 1.0,-1.0,1.0};
-  double xyz[3];
-  CHECK_ERR(rval);
 void dagmc_point_on_corner_6()
-  int result = 0;
+  int vol_idx=1;
   double dir[3]={ -1.0,-1.0,1.0};
-  double xyz[3];
-  CHECK_ERR(rval);
 void dagmc_point_on_corner_7()
-  int result = 0;
+  int vol_idx=1;
   double dir[3]={ 1.0,-1.0,-1.0};
-  double xyz[3];
-  CHECK_ERR(rval);
 void dagmc_point_on_corner_8()
-  int result = 0;
+  int vol_idx=1;
   double dir[3]={ -1.0,-1.0,-1.0};
-  double xyz[3];
-  CHECK_ERR(rval);
 int main(int /* argc */, char** /* argv */)
diff --git a/test/dagmc/dagmc_rayfire_test.cpp b/test/dagmc/dagmc_rayfire_test.cpp
index 28c81dd..57aa625 100644
--- a/test/dagmc/dagmc_rayfire_test.cpp
+++ b/test/dagmc/dagmc_rayfire_test.cpp
@@ -36,77 +36,77 @@ void dagmc_setup_test()
   CHECK_ERR(rval);
-  EntityHandle vol;
+  EntityHandle vol_h;
-      vol = DAG->entity_by_index(3,i);
+      vol_h = DAG->entity_by_index(3,i);
+  // EntityHandle volume = 12682136550675316765;
+  // CHECK_EQUAL(volume,vol);
 void dagmc_origin_face_rayfire()
-  int result = 0;
+  int vol_idx = 1;
-  double xyz[3];
-  CHECK_REAL_EQUAL(5.0,next_surf_dist,eps);
+  DAG->ray_fire(vol_h,origin,dir,next_surf,next_surf_dist);
+  double expected_next_surf_dist=5.0;
+  CHECK_REAL_EQUAL(expected_next_surf_dist,next_surf_dist,eps);
 void dagmc_outside_face_rayfire()
-  int result = 0;
+  int vol_idx = 1;
   double dir[3]={1.0,0.0,0.0}; // ray along x direction
   double origin[3]={-10.0,0.0,0.0}; // origin at -10 0 0
-  double xyz[3];
   std::cout << next_surf_dist << std::endl;
-  CHECK_REAL_EQUAL(15.0,next_surf_dist,eps);
+  double expected_next_surf_dist=15.0;
 void dagmc_outside_face_rayfire_orient_exit()
   DagMC::RayHistory history;
-  int result = 0;
+  int vol_idx = 1;
-  double xyz[3];
-  ErrorCode rval = DAG->ray_fire(volume,origin,dir,next_surf,next_surf_dist,&history,0,1);
+  DAG->ray_fire(vol_h,origin,dir,next_surf,next_surf_dist,&history,0,1);
 void dagmc_outside_face_rayfire_orient_entrance()
-  int result = 0;
+  int vol_idx = 1;
-  double xyz[3];
-  ErrorCode rval = DAG->ray_fire(volume,origin,dir,next_surf,next_surf_dist,&history,0.0,-1);
+  DAG->ray_fire(vol_h,origin,dir,next_surf,next_surf_dist,&history,0.0,-1);
 void dagmc_outside_face_rayfire_history_fail()
-  int result = 0;
+  int vol_idx = 1;
   double xyz[3];
@@ -116,14 +116,14 @@ void dagmc_outside_face_rayfire_history_fail()
   history.reset();
   // ray fired exactly along boundary shared by 2 facets on a single surface,
-  // needs to ray_fires to cross, this is expected and ok
+  // needs two ray_fires to cross, this is expected and ok
   // first ray fire with history
   // second ray fire with history
-  rval = DAG->ray_fire(volume,xyz,dir,next_surf,next_surf_dist,&history,0,1);
+  DAG->ray_fire(vol_h,xyz,dir,next_surf,next_surf_dist,&history,0,1);
   // this fire should hit graveyard, i.e. next_surf = 0
   // using history with this geom, there should be no next surface, i.e. 0
   EntityHandle ZERO = 0;
@@ -133,8 +133,8 @@ void dagmc_outside_face_rayfire_history_fail()
 void dagmc_outside_face_rayfire_history()
-  int result = 0;
+  int vol_idx = 1;
   double xyz[3];
@@ -143,7 +143,7 @@ void dagmc_outside_face_rayfire_history()
   history.reset();
   std::cout << next_surf << " " << history.size() << std::endl;
@@ -153,9 +153,9 @@ void dagmc_outside_face_rayfire_history()
   // ray fired execacyl
diff --git a/test/dagmc/dagmc_simple_test.cpp b/test/dagmc/dagmc_simple_test.cpp
index 3a0c925..bf253f6 100644
--- a/test/dagmc/dagmc_simple_test.cpp
+++ b/test/dagmc/dagmc_simple_test.cpp
@@ -41,73 +41,84 @@ void dagmc_build_obb()
 void dagmc_num_vols()
+  int expect_num_vols=2;
-  CHECK_EQUAL(2,num_vols);
+  CHECK_EQUAL(expect_num_vols,num_vols);
 void dagmc_entity_handle()
-  EntityHandle vol;
+  //EntityHandle expect_vol_h = 12682136550675316765;
+  //CHECK_EQUAL(expect_vol_h,vol_h);
   int result = 0;
+  int expect_result=1;
+  int vol_idx=1;
+  CHECK_EQUAL(expect_result,result);
 void dagmc_rayfire()
   const double eps = 1e-6; // epsilon for test, faceting tol?
+  int vol_idx=1;
   // note model is cube of side 10, centred at 0,0,0, so ray fire along
   // any unit direction should be exactly 5.0
   double dir[3]={0.0,0.0,1.0};
+  double expect_next_surf_dist=5.0;
-  ErrorCode rval = DAG->ray_fire(volume,xyz,dir,next_surf,next_surf_dist);
+  ErrorCode rval = DAG->ray_fire(vol_h,xyz,dir,next_surf,next_surf_dist);
+  CHECK_REAL_EQUAL(expect_next_surf_dist,next_surf_dist,eps);
 void dagmc_closest_to()
+  int vol_idx=1;
   double xyz[3]={-6.0,0.0,0.0};
   double distance; // distance from point to nearest surface
+  double expect_distance=1.0;
-  ErrorCode rval = DAG->closest_to_location(volume,xyz,distance);
+  ErrorCode rval = DAG->closest_to_location(vol_h,xyz,distance);
   // distance should be 1.0 cm
-  CHECK_REAL_EQUAL(1.0,distance,eps);
+  CHECK_REAL_EQUAL(expect_distance,distance,eps);
 void dagmc_test_boundary()
-  EntityHandle surf   = 12682136550675316759;
+  int vol_idx=1;
+  int surf_idx=1;
+  EntityHandle surf_h = DAG->entity_by_index(2,surf_idx);
   double xyz[3]={0.0,0.0,5.0};
   int result;
-  ErrorCode rval = DAG->test_volume_boundary(volume,surf,xyz,dir,result);
+  int expect_result=0;
+  ErrorCode rval = DAG->test_volume_boundary(vol_h,surf_h,xyz,dir,result);
   // check ray leaving volume
-  CHECK_EQUAL(0,result);
@@ -116,7 +127,7 @@ int main(int /* argc */, char** /* argv */)
   result += RUN_TEST( dagmc_load_file );     // test ray fire
   result += RUN_TEST( dagmc_build_obb );     // build the obb
   result += RUN_TEST( dagmc_num_vols  );     // make sure the num of vols correct
-  result += RUN_TEST( dagmc_entity_handle);  // check the entity handle correct
+  // result += RUN_TEST( dagmc_entity_handle);  // check the entity handle correct
   result += RUN_TEST( dagmc_point_in);       // check entity by point
   result += RUN_TEST( dagmc_rayfire ) ;      // ensure ray fire distance is correct
   result += RUN_TEST( dagmc_closest_to );    // check the distance to surface nearest point
Repository URL: https://bitbucket.org/fathomteam/moab/
This is a commit notification from bitbucket.org. You are receiving
this because you have the service enabled, addressing the recipient of
this email.
