[MOAB-dev] OCC CGM testing
    Jiangtao Hu
    jiangtao_ma at yahoo.com
    Fri Mar 21 11:10:33 CDT 2014
Hi, Patrick-
I've just finished the cgm13.1 on occ6.6.0 build, then your moab on top of it. All four tests passed.
PASS: read_cgm_connectivity_test
PASS: read_cgm_basic_test
PASS: read_cgm_senses_test
PASS: read_cgm_load_test
Please let me know if you have other stuff to test out. You may stop by if you'd want to see details of the build test.
Jane
Asst. Researcher
Dept. of Engineering Physics
UW @ Madison
"And we know that for those who love God, that is, for those who are called according to his purpose, all things are working together for good." (Romans 8:28)
On Friday, March 21, 2014 10:17 AM, "Grindeanu, Iulian R." <iulian at mcs.anl.gov> wrote:
http://gnep.mcs.anl.gov:8010/waterfall?category=cgm
any build that contains occ in its name is built with occ653
We actually test on cgm13.1 too, on buildbot
http://gnep.mcs.anl.gov:8010/builders/cgm131-occ
"trunk", "tr", "tru" means current cgm master repo (former trunk on svn)
the others are with cgm branch cgm12.2
From: moab-dev-bounces at mcs.anl.gov [moab-dev-bounces at mcs.anl.gov] on behalf of Grindeanu, Iulian R. [iulian at mcs.anl.gov]
Sent: Thursday, March 20, 2014 3:59 PM
To: Patrick Shriwise; MOAB-dev at mcs.anl.gov
Subject: Re: [MOAB-dev] OCC CGM testing
occ 653 with cgm master, and occ 653 with cgm branch cgm12.2 (serial and parallel)
we used to test with cgm13.1 branch, too, but it should be fine
Iulian
From: moab-dev-bounces at mcs.anl.gov [moab-dev-bounces at mcs.anl.gov] on behalf of Patrick Shriwise [shriwise at wisc.edu]
Sent: Thursday, March 20, 2014 1:52 PM
To: MOAB-dev at mcs.anl.gov
Subject: [MOAB-dev] OCC CGM testing
Hi all,
What version(s) of OCC and CGM are tested in the MOAB nightlies?
Going to create a similar set of builds for testing on my local machine.
Thanks!
Patrick C. Shriwise
Research Assistant
University of Wisconsin - Madison
Engineering Research Building - Rm. 428
1500 Engineering Drive
Madison, WI 53706
(608) 446-8173
URL: <http://lists.mcs.anl.gov/pipermail/moab-dev/attachments/20140321/410266f2/attachment.html>
