[MOAB-dev] [PyNE] Install instructions with MOAB for MCNP?
    Anthony Scopatz
    scopatz at gmail.com
    Thu Mar 20 22:50:53 CDT 2014
On Sat, Mar 15, 2014 at 4:52 PM, Andrew Davis
<andrewdavis.davis at gmail.com>wrote:
> Comping with verbose mode suggests that headers variable is not set
> correctly
> cd /data/opt/pyne/build/pyne && /usr/bin/c++   -D_dagmc_EXPORTS
> -D__LINUX__ -DJSON_IS_AMALGAMATION -O3 -DNDEBUG -fPIC
> -I/data/opt/dagmc/hdf5/include
> -I/usr/lib/python2.7/dist-packages/numpy/core/include -I/data/opt/pyne/cpp
> -I/usr/include/python2.7    -o CMakeFiles/_dagmc.dir/_dagmc.cxx.o -c
> /data/opt/pyne/build/pyne/_dagmc.cxx
> So is there somekind of mismatch between the MOAB_INCLUDE_DIRS env wanted
> by cmake/FindMOAB and the MOAB_INCLUDE_DIR suggested by the cmake build
> echo.
Hey Andy,
There very well might be.  I am not super confident in the FindMOAB.cmake.
 This seems like the thing that MOAB itself should support. Maybe they do
and I missed it when I wrote the dagmc wrapper. For expediency, I just used
the best thing that I found online.  It could probably use love & official
support.
Be Well
Anthony
> Andy
> On Sat, Mar 15, 2014 at 4:44 PM, Andrew Davis <andrewdavis.davis at gmail.com
> > wrote:
>> Can anyone confirm is this is true? When I try it I get the following
>>     python setup.py install --user --
>> -DMOAB_INCLUDE_DIR=/data/opt/dagmc/moab/include
>> -DMOAB_LIBRARY=/data/opt/dagmc/moab/lib/libMOAB.so
>> It finds MOAB,
>> -- Found MOAB: /data/opt/dagmc/moab/lib/libMOAB.so
>> -- MOAB header files: /data/opt/dagmc/moab/include
>> -- MOAB library: /data/opt/dagmc/moab/lib/libMOAB.so
>> -- MOAB Found: TRUE
>> Then fails during build
>> /data/opt/pyne/build/pyne/_dagmc.cxx:322:26: fatal error: moab/Types.hpp:
>> No such file or directory
>>  #include "moab/Types.hpp"
>> compilation terminated.
>> make[2]: *** [pyne/CMakeFiles/_dagmc.dir/_dagmc.cxx.o] Error 1
>> make[1]: *** [pyne/CMakeFiles/_dagmc.dir/all] Error 2
>> make: *** [all] Error 2
>> Traceback (most recent call last):
>>   File "setup.py", line 106, in <module>
>>     main()
>>   File "setup.py", line 100, in main
>>     main_body()
>>   File "setup.py", line 91, in main_body
>>     rtn = subprocess.check_call(['make'] + make_args, cwd='build')
>>   File "/usr/lib/python2.7/subprocess.py", line 540, in check_call
>>     raise CalledProcessError(retcode, cmd)
>> subprocess.CalledProcessError: Command '['make']' returned non-zero exit
>> status 2
>> My MOAB is setup correctly, this is a fresh pull from staging, I can
>> confirm that the header is where it should be.
>> Any ideas?
>> Thanks
>> Andy
>> On Mon, Mar 10, 2014 at 1:31 PM, Elliott Biondo <Biondo at wisc.edu> wrote:
>>> I actually ran into this last week. Anthony helped me with the cmake
>>> flags:
>>> -DMOAB_INCLUDE_DIR=/PATH/TO/MOAB/include
>>> -DMOAB_LIBRARY=/PATH/TO/MOAB/lib/libMOAB.so
>>> On Mon, Mar 10, 2014 at 12:42 PM, Matthew Gidden <gidden at wisc.edu>wrote:
>>>> It will involve setting pyne's cmake flags, where the setup looks like
>>>>  setup.py install <python flags> -- <cmake flags>
>>>> You can see such an example in moab_build.sh in pyne-ci.
>>>> On Mon, Mar 10, 2014 at 12:41 PM, Paul Wilson <wilsonp at engr.wisc.edu>wrote:
>>>>> Hmmmm...  I guess I can look in the pyne-ci repo... I'll do that.
>>>>> Paul
>>>>> On 03/10/2014 12:31 PM, Paul Wilson wrote:
>>>>>> Hi all,
>>>>>> Do we have any install instructions that describe how to pass the
>>>>>> right path and variable info to build PyNE with MOAB?  I don't see it at
>>>>>> pyne.io or the README.
>>>>>> Paul
>>>>> Paul Wilson ~ UW-Madison ~ 608-263-0807 ~ cal: http://bit.ly/pphw-cal
>>>>> Professor, Engineering Physics. ~ http://cnerg.engr.wisc.edu
>>>>> Faculty Director, Advanced Computing Infrastructure
>>>> Matthew Gidden
>>>> Ph.D. Candidate, Nuclear Engineering
>>>> The University of Wisconsin -- Madison
>>>> Ph. 225.892.3192
>>>> You received this message because you are subscribed to the Google
>>>> Groups "PyNE" group.
>>>> To unsubscribe from this group and stop receiving emails from it, send
>>>> an email to pyne-dev+unsubscribe at googlegroups.com.
>>>> For more options, visit https://groups.google.com/d/optout.
>>> Elliott D. Biondo
>>> Nuclear Regulatory Commission Fellow
>>> Computational Nuclear Engineering Research Group (CNERG)
>>> Department of Nuclear Engineering and Engineering Physics
>>> University of Wisconsin - Madison
>>> 434 Engineering Research Building
>>> 1500 Engineering Drive
>>> Madison, WI 53706
>>> Calendar<https://www.google.com/calendar/embed?src=elliott.biondo%40gmail.com&ctz=America/Chicago>
> You received this message because you are subscribed to the Google Groups
> "PyNE" group.
> To unsubscribe from this group and stop receiving emails from it, send an
URL: <http://lists.mcs.anl.gov/pipermail/moab-dev/attachments/20140320/7cf16f30/attachment.html>
