[MOAB-dev] buildbot failure in moab-cgns: failed test
    Tautges, Timothy J.
    tautges at mcs.anl.gov
    Tue Mar 18 07:46:09 CDT 2014
Apologies everyone, getting sloppy.
- tim
Sent via the Samsung GALAXY S®4, an AT&T 4G LTE smartphone
-------- Original message --------
Date:03/18/2014 6:55 AM (GMT-06:00)
To: moab-dev at mcs.anl.gov,"Tautges, Timothy J."
Subject: Re: [MOAB-dev] buildbot failure in moab-cgns: failed test
Tim, please fix these. Master needs to be stable and we should not be getting compiler errors after a merge. Was this not tested after the last commit ? Looks like you missed some changes of output to output_all_stats.
Vijay
On Tue, Mar 18, 2014 at 4:22 AM, <moab-dev at mcs.anl.gov<mailto:moab-dev at mcs.anl.gov>> wrote:
Fathom<http://gnep.mcs.anl.gov:8010/>: moab-cgns<http://gnep.mcs.anl.gov:8010/builders/moab-cgns> build #114<http://gnep.mcs.anl.gov:8010/builders/moab-cgns/builds/114>
Results:        failed test
Buildslave:     gnep
Revision:       None
Log Excerpt
/home/fathom/3rdparty/mpich2/mpich2-1.2.1/gcc/include/mpicxx.h:1888: warning: unused parameter ‘oldwin’
/home/fathom/3rdparty/mpich2/mpich2-1.2.1/gcc/include/mpicxx.h:1888: warning: unused parameter ‘keyval’
/home/fathom/3rdparty/mpich2/mpich2-1.2.1/gcc/include/mpicxx.h:1888: warning: unused parameter ‘ex’
mv -f .deps/pcomm_serial.Tpo .deps/pcomm_serial.Po
/bin/sh ../../libtool  --tag=CXX   --mode=link /homes/fathom/3rdparty/mpich2/mpich2-1.2.1/gcc/bin/mpicxx  -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align  -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -R/homes/fathom/install/occparsta/cgm/lib  -L/home/fathom/3rdparty/ParMETIS3_1/gcc -L/home/fathom/3rdparty/Zoltan_v3.3/lib -L/homes/fathom/3rdparty/cgns/cgns314/lib -L/homes/iulian/lib/pnetcdf/lib -L/home/fathom/3rdparty/netcdf/netcdf-4.0.1/parallel/gcc/lib -lnetcdf -L/home/fathom/3rdparty/hdf5/hdf5-1.8.3/parallel/gcc -lhdf5_hl -lhdf5 -L/home/fathom/3rdparty/zlib/zlib-1.2.4/gcc -lz     -L/homes/fathom/3rdparty/zlib/zlib-1.2.4/gcc/lib  -L/homes/fathom/3rdparty/hdf5/hdf5-1.8.3/parallel/gcc/lib -L/homes/fathom/install/occparsta/cgm/lib  -L/homes/fathom/3rdparty/occ/OpenCASCADE6.5.3/gccGnep/lib -L/homes/fathom/3rdparty/zlib/zlib-1.2.4/gcc/lib  -L/homes/fathom/3rdparty/hdf5/hdf5-1.8.3/parallel/gcc/lib  -L/homes/fathom/3rdparty/zlib/zlib
 -1.2.4/gcc/lib  -L/homes/fathom/3rdparty/hdf5/hdf5-1.8.3/parallel/gcc/lib  -L/homes/fathom/3rdparty/zlib/zlib-1.2.4/gcc/lib  -L/homes/fathom/3rdparty/hdf5/hdf5-1.8.3/parallel/gcc/lib -o pcomm_serial pcomm_serial.o ../../src/libMOAB.la -lm
libtool: link: /homes/fathom/3rdparty/mpich2/mpich2-1.2.1/gcc/bin/mpicxx -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -o pcomm_serial pcomm_serial.o  -L/home/fathom/3rdparty/ParMETIS3_1/gcc -L/home/fathom/3rdparty/Zoltan_v3.3/lib -L/homes/fathom/3rdparty/cgns/cgns314/lib -L/homes/iulian/lib/pnetcdf/lib -L/home/fathom/3rdparty/netcdf/netcdf-4.0.1/parallel/gcc/lib -L/home/fathom/3rdparty/hdf5/hdf5-1.8.3/parallel/gcc/lib -L/home/fathom/3rdparty/zlib/zlib-1.2.4/gcc/lib -L/home/fathom/3rdparty/szip/szip-2.1/gcc/lib -L/home/fathom/3rdparty/hdf5/hdf5-1.8.3/parallel/gcc -L/home/fathom/3rdparty/zlib/zlib-1.2.4/gcc -L/homes/fathom/3rdparty/zlib/zlib-1.2.4/gcc/lib -L/homes/fathom/3rdparty/hdf5/hdf5-1.8.3/parallel/gcc/lib -L/homes/fathom/install/occparsta/cgm/lib -L/homes/fathom/3rdparty/occ/OpenCASCADE6.5.3/gccGnep/lib ../../src/.libs/libMOAB.a -lpnetcdf -lcgns /homes/fathom/install/occparst
 a/cgm/lib/libcgm.a /homes/fathom/3rdparty/occ/OpenCASCADE6.5.3/gccGnep/lib/libTKSTL.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.3/gccGnep/lib/libTKSTEP.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.3/gccGnep/lib/libTKSTEP209.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.3/gccGnep/lib/libTKSTEPAttr.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.3/gccGnep/lib/libTKSTEPBase.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.3/gccGnep/lib/libTKIGES.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.3/gccGnep/lib/libTKXSBase.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.3/gccGnep/lib/libTKBinL.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.3/gccGnep/lib/libTKCAF.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.3/gccGnep/lib/libTKLCAF.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.3/gccGnep/lib/libTKCDF.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.3/gccGnep/lib/libTKV3d.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.3/gccGnep/lib/libTKV2d.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.3/gccGnep/lib/libTKServ
 ice.so -lXmu -lGLU -lGL /homes/fathom/3rdparty/occ/OpenCASCADE6.5.3/gccGnep/lib/libTKHLR.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.3/gccGnep/lib/libTKOffset.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.3/gccGnep/lib/libTKFillet.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.3/gccGnep/lib/libTKFeat.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.3/gccGnep/lib/libTKBool.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.3/gccGnep/lib/libTKShHealing.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.3/gccGnep/lib/libTKBO.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.3/gccGnep/lib/libTKPrim.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.3/gccGnep/lib/libTKMesh.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.3/gccGnep/lib/libTKTopAlgo.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.3/gccGnep/lib/libTKGeomAlgo.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.3/gccGnep/lib/libTKBRep.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.3/gccGnep/lib/libTKGeomBase.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.3/gccGnep
 /lib/libTKG3d.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.3/gccGnep/lib/libTKG2d.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.3/gccGnep/lib/libTKMath.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.3/gccGnep/lib/libTKernel.so -lXt -lX11 -ldl /home/fathom/3rdparty/netcdf/netcdf-4.0.1/parallel/gcc/lib/libnetcdf.so /home/fathom/3rdparty/hdf5/hdf5-1.8.3/parallel/gcc/lib/libhdf5_hl.so /home/fathom/3rdparty/hdf5/hdf5-1.8.3/parallel/gcc/lib/libhdf5.so -lz -lzoltan -lparmetis -lmetis -lm -Wl,-rpath -Wl,/homes/fathom/3rdparty/occ/OpenCASCADE6.5.3/gccGnep/lib -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/parallel/gcc/lib -Wl,-rpath -Wl,/home/fathom/3rdparty/hdf5/hdf5-1.8.3/parallel/gcc/lib -Wl,-rpath -Wl,/homes/fathom/3rdparty/occ/OpenCASCADE6.5.3/gccGnep/lib -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/parallel/gcc/lib -Wl,-rpath -Wl,/home/fathom/3rdparty/hdf5/hdf5-1.8.3/parallel/gcc/lib -Wl,-rpath -Wl,/homes/fathom/install/occparsta/cgm/lib
/homes/fathom/3rdparty/mpich2/mpich2-1.2.1/gcc/bin/mpicxx -DHAVE_CONFIG_H -I. -I../.. -I../../src/moab -I../../src/parallel -I../../src  -I/homes/fathom/3rdparty/cgns/cgns314/include -I/homes/iulian/lib/pnetcdf/include -I/home/fathom/3rdparty/netcdf/netcdf-4.0.1/parallel/gcc/include    -I/homes/fathom/3rdparty/hdf5/hdf5-1.8.3/parallel/gcc/include -isystem /homes/fathom/3rdparty/hdf5/hdf5-1.8.3/parallel/gcc/include  -DTEMPLATE_SPECIALIZATION -DTEMPLATE_FUNC_SPECIALIZATION -DHAVE_VSNPRINTF -D_FILE_OFFSET_BITS=64   -DUSE_MPI -DHDF5_FILE -DHDF5_PARALLEL -DNETCDF_FILE -DPNETCDF_FILE -DCGNS_FILE -DHAVE_ZOLTAN -DCGM -DIS_BUILDING_MB -DSRCDIR=. -DMESHDIR=../../MeshFiles/unittest -I. -I.. -I./.. -I../../src -I../../src -I../../src/parallel -I../../src/io/mhdf/include -I../../tools/mbcoupler -I../../itaps -I../../itaps/imesh -I../../itaps/imesh -I../../src/moab/point_locater/lotte -I../../tools/mbcslam -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map -DHAVE_UNORDERED_
 SET=tr1/unordered_set  -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align  -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -MT par_spatial_locator_test.o -MD -MP -MF .deps/par_spatial_locator_test.Tpo -c -o par_spatial_locator_test.o par_spatial_locator_test.cpp
In file included from /home/fathom/3rdparty/mpich2/mpich2-1.2.1/gcc/include/mpi.h:1188,
                 from ../../src/parallel/moab_mpi.h:19,
                 from ../../src/moab/SpatialLocatorTimes.hpp:21,
                 from ../../src/moab/SpatialLocator.hpp:38,
                 from par_spatial_locator_test.cpp:2:
/home/fathom/3rdparty/mpich2/mpich2-1.2.1/gcc/include/mpicxx.h:384: warning: unused parameter ‘oldtype’
/home/fathom/3rdparty/mpich2/mpich2-1.2.1/gcc/include/mpicxx.h:384: warning: unused parameter ‘keyval’
/home/fathom/3rdparty/mpich2/mpich2-1.2.1/gcc/include/mpicxx.h:384: warning: unused parameter ‘ex’
/home/fathom/3rdparty/mpich2/mpich2-1.2.1/gcc/include/mpicxx.h:384: warning: unused parameter ‘attr_in’
/home/fathom/3rdparty/mpich2/mpich2-1.2.1/gcc/include/mpicxx.h:384: warning: unused parameter ‘attr_out’
/home/fathom/3rdparty/mpich2/mpich2-1.2.1/gcc/include/mpicxx.h:386: warning: unused parameter ‘type’
/home/fathom/3rdparty/mpich2/mpich2-1.2.1/gcc/include/mpicxx.h:386: warning: unused parameter ‘keyval’
/home/fathom/3rdparty/mpich2/mpich2-1.2.1/gcc/include/mpicxx.h:386: warning: unused parameter ‘attr’
/home/fathom/3rdparty/mpich2/mpich2-1.2.1/gcc/include/mpicxx.h:386: warning: unused parameter ‘ex’
/home/fathom/3rdparty/mpich2/mpich2-1.2.1/gcc/include/mpicxx.h:388: warning: unused parameter ‘oldtype’
/home/fathom/3rdparty/mpich2/mpich2-1.2.1/gcc/include/mpicxx.h:388: warning: unused parameter ‘keyval’
/home/fathom/3rdparty/mpich2/mpich2-1.2.1/gcc/include/mpicxx.h:388: warning: unused parameter ‘ex’
/home/fathom/3rdparty/mpich2/mpich2-1.2.1/gcc/include/mpicxx.h:1451: warning: unused parameter ‘oldcomm’
/home/fathom/3rdparty/mpich2/mpich2-1.2.1/gcc/include/mpicxx.h:1451: warning: unused parameter ‘keyval’
/home/fathom/3rdparty/mpich2/mpich2-1.2.1/gcc/include/mpicxx.h:1451: warning: unused parameter ‘ex’
/home/fathom/3rdparty/mpich2/mpich2-1.2.1/gcc/include/mpicxx.h:1451: warning: unused parameter ‘attr_in’
/home/fathom/3rdparty/mpich2/mpich2-1.2.1/gcc/include/mpicxx.h:1451: warning: unused parameter ‘attr_out’
/home/fathom/3rdparty/mpich2/mpich2-1.2.1/gcc/include/mpicxx.h:1453: warning: unused parameter ‘comm’
/home/fathom/3rdparty/mpich2/mpich2-1.2.1/gcc/include/mpicxx.h:1453: warning: unused parameter ‘keyval’
/home/fathom/3rdparty/mpich2/mpich2-1.2.1/gcc/include/mpicxx.h:1453: warning: unused parameter ‘attr’
/home/fathom/3rdparty/mpich2/mpich2-1.2.1/gcc/include/mpicxx.h:1453: warning: unused parameter ‘ex’
/home/fathom/3rdparty/mpich2/mpich2-1.2.1/gcc/include/mpicxx.h:1455: warning: unused parameter ‘oldcomm’
/home/fathom/3rdparty/mpich2/mpich2-1.2.1/gcc/include/mpicxx.h:1455: warning: unused parameter ‘keyval’
/home/fathom/3rdparty/mpich2/mpich2-1.2.1/gcc/include/mpicxx.h:1455: warning: unused parameter ‘ex’
/home/fathom/3rdparty/mpich2/mpich2-1.2.1/gcc/include/mpicxx.h:1884: warning: unused parameter ‘oldwin’
/home/fathom/3rdparty/mpich2/mpich2-1.2.1/gcc/include/mpicxx.h:1884: warning: unused parameter ‘keyval’
/home/fathom/3rdparty/mpich2/mpich2-1.2.1/gcc/include/mpicxx.h:1884: warning: unused parameter ‘ex’
/home/fathom/3rdparty/mpich2/mpich2-1.2.1/gcc/include/mpicxx.h:1884: warning: unused parameter ‘attr_in’
/home/fathom/3rdparty/mpich2/mpich2-1.2.1/gcc/include/mpicxx.h:1884: warning: unused parameter ‘attr_out’
/home/fathom/3rdparty/mpich2/mpich2-1.2.1/gcc/include/mpicxx.h:1886: warning: unused parameter ‘win’
/home/fathom/3rdparty/mpich2/mpich2-1.2.1/gcc/include/mpicxx.h:1886: warning: unused parameter ‘keyval’
/home/fathom/3rdparty/mpich2/mpich2-1.2.1/gcc/include/mpicxx.h:1886: warning: unused parameter ‘attr’
/home/fathom/3rdparty/mpich2/mpich2-1.2.1/gcc/include/mpicxx.h:1886: warning: unused parameter ‘ex’
par_spatial_locator_test.cpp: In function ‘void test_locator(moab::SpatialLocator*)’:
par_spatial_locator_test.cpp:144: error: ‘class moab::TreeStats’ has no member named ‘output’
URL: <http://lists.mcs.anl.gov/pipermail/moab-dev/attachments/20140318/b0cfa6e1/attachment-0001.html>
