[MOAB-dev] commit/MOAB: tautges: Fixing some tests after function name was changed.
    commits-noreply at bitbucket.org
    Mon Mar 17 14:12:52 CDT 2014
1 new commit in MOAB:
https://bitbucket.org/fathomteam/moab/commits/f706e6af436c/
Changeset:   f706e6af436c
Branch:      master
User:        tautges
Date:        2014-03-17 20:12:40
Summary:     Fixing some tests after function name was changed.
Affected #:  3 files
diff --git a/test/perf/point_location/sploc_searching_perf.cpp b/test/perf/point_location/sploc_searching_perf.cpp
index fcda676..d150ec4 100644
--- a/test/perf/point_location/sploc_searching_perf.cpp
+++ b/test/perf/point_location/sploc_searching_perf.cpp
@@ -118,7 +118,7 @@ int main(int argc, char **argv)
                     << cpu_time << " "
                     << perc_outside << " ";
-          tree->tree_stats().output();
+          tree->tree_stats().output_all_stats();
           if (eeval) delete eeval;
diff --git a/test/perf/point_location/tree_searching_perf.cpp b/test/perf/point_location/tree_searching_perf.cpp
index 241aab8..0b09ba0 100644
--- a/test/perf/point_location/tree_searching_perf.cpp
+++ b/test/perf/point_location/tree_searching_perf.cpp
@@ -111,7 +111,7 @@ int main(int argc, char **argv)
                     << cpu_time << " "
         } // tree_tp
diff --git a/test/spatial_locator_test.cpp b/test/spatial_locator_test.cpp
index 404e668..4415d78 100644
--- a/test/spatial_locator_test.cpp
+++ b/test/spatial_locator_test.cpp
@@ -140,7 +140,7 @@ void test_locator(SpatialLocator *sl)
   std::cout << "Traversal stats:" << std::endl;
-  sl->get_tree()->tree_stats().output();
+  sl->get_tree()->tree_stats().output_trav_stats();
   if (print_tree) {
     std::cout << "Tree information: " << std::endl;
Repository URL: https://bitbucket.org/fathomteam/moab/
This is a commit notification from bitbucket.org. You are receiving
this because you have the service enabled, addressing the recipient of
this email.
