[MOAB-dev] get_entities_by_handle - entities do not include meshset entities
Tim Tautges (ANL) tautges at mcs.anl.gov
Fri Mar 14 10:03:23 CDT 2014
That's almost certainly not true.  Can you confirm this with a simple test?
- tim
On 03/14/2014 09:17 AM, MICHAEL CORTIS wrote:
> Dear Tim,
> I've noticed that when using get_entities_by_handle,
> the range won't contained meshset entities which are in the handle.
> Believe that one should remark in the documentation that only vertices/edges/tri/tet are retrieved,
> if there is no plan to gather the meshset entities from a handle into the range/vector.
> Kind regards
> Michael
   steadfast, because he trusts in you."               Isaiah 26:3
              Tim Tautges            Argonne National Laboratory
          (tautges at mcs.anl.gov)      (telecommuting from UW-Madison)
  phone (gvoice): (608) 354-1459      1500 Engineering Dr.
             fax: (608) 263-4499      Madison, WI 53706
