[MOAB-dev] commit/MOAB: tautges: Removing some warnings.
commits-noreply at bitbucket.org
Wed Mar 12 10:32:22 CDT 2014
1 new commit in MOAB:
https://bitbucket.org/fathomteam/moab/commits/76a83e8282fc/
Changeset: 76a83e8282fc
Branch: master
User: tautges
Date: 2014-03-12 16:32:09
Summary: Removing some warnings.
Affected #: 7 files
diff --git a/src/io/Tqdcfr.cpp b/src/io/Tqdcfr.cpp
index 701ff15..7416164 100644
--- a/src/io/Tqdcfr.cpp
+++ b/src/io/Tqdcfr.cpp
@@ -959,7 +959,7 @@ ErrorCode Tqdcfr::read_block(const unsigned int blindex,
FREADD(blockh->attribOrder); num_read += sizeof(double);
void const* tag_data[] = { &dbl_buf[0] };
- int tag_sizes[] = { blockh->attribOrder };
+ int tag_sizes[] = { static_cast<int>(blockh->attribOrder) };
result = mdbImpl->tag_set_by_ptr(block_attribs,&(blockh->setHandle),1,tag_data,tag_sizes);
if (MB_SUCCESS != result) return result;
@@ -1932,7 +1932,8 @@ ErrorCode Tqdcfr::BlockHeader::read_info_header(const double data_version,
result = instance->mdbImpl->tag_get_handle(BLOCK_HEADER,3*sizeof(unsigned int),MB_TYPE_INTEGER,
bhTag_header,MB_TAG_CREAT|MB_TAG_SPARSE|MB_TAG_BYTES,&def_uint_zero[0]);
- int block_header_data[] = { block_headers[i].blockCol, block_headers[i].blockMat, block_headers[i].blockDim };
+ int block_header_data[] = { static_cast<int>(block_headers[i].blockCol), static_cast<int>(block_headers[i].blockMat),
+ static_cast<int>(block_headers[i].blockDim) };
result = instance->mdbImpl->tag_set_data(bhTag_header,&(block_headers[i].setHandle), 1,
block_header_data);
diff --git a/src/parallel/WriteHDF5Parallel.cpp b/src/parallel/WriteHDF5Parallel.cpp
index 20a36a3..be692ba 100644
--- a/src/parallel/WriteHDF5Parallel.cpp
+++ b/src/parallel/WriteHDF5Parallel.cpp
@@ -118,6 +118,7 @@ const char* mpi_err_str( int errorcode ) {
template <typename T> inline
void VALGRIND_MAKE_VEC_UNDEFINED( std::vector<T>& v ) {
+ if (v.size()) {}
VALGRIND_MAKE_MEM_UNDEFINED( &v[0], v.size() * sizeof(T) );
diff --git a/tools/mbcoupler/Coupler.cpp b/tools/mbcoupler/Coupler.cpp
index b496441..afee8af 100644
--- a/tools/mbcoupler/Coupler.cpp
+++ b/tools/mbcoupler/Coupler.cpp
@@ -483,10 +483,13 @@ ErrorCode Coupler::test_local_box(double *xyz,
std::vector<EntityHandle> entities;
std::vector<CartVect> nat_coords;
- bool canWrite;
+ bool canWrite = false;
if (tl) {
canWrite = tl->get_writeEnabled();
- if(!canWrite) tl->enableWriteAccess();
+ if(!canWrite) {
+ tl->enableWriteAccess();
+ canWrite = true;
if (rel_eps && !abs_eps) {
@@ -833,7 +836,7 @@ ErrorCode Coupler::interp_field(EntityHandle elem,
else
double vfields[27]; // will work for linear hex, quadratic hex or Tets
- moab::Element::Map *elemMap;
+ moab::Element::Map *elemMap = NULL;
int num_verts = 0;
// get the EntityType
// get the tag values at the vertices
@@ -1533,7 +1536,7 @@ int Coupler::get_group_integ_vals(std::vector< std::vector<iBase_EntityHandle> >
iMesh_getEntTopo(iMeshInst, (*iter_j), &topo_type, &err);
ERRORR("Failed to get topology for entity.", err);
int num_verts = 0;
if (topo_type == iMesh_HEXAHEDRON) {
elemMap = new moab::Element::LinearHex();
diff --git a/tools/mbcoupler/mbcoupler_test.cpp b/tools/mbcoupler/mbcoupler_test.cpp
index c5c826f..20be50d 100644
--- a/tools/mbcoupler/mbcoupler_test.cpp
+++ b/tools/mbcoupler/mbcoupler_test.cpp
@@ -131,8 +131,8 @@ int main(int argc, char **argv)
if (!dbgFile.empty()) {
std::stringstream dfname;
dfname << dbgFile << rank << ".txt";
- std::freopen(dfname.str().c_str(), "a", stdout);
- std::freopen(dfname.str().c_str(), "a", stderr);
+ if (!std::freopen(dfname.str().c_str(), "a", stdout)) return false;
+ if (!std::freopen(dfname.str().c_str(), "a", stderr)) return false;
// create MOAB instance based on that
diff --git a/tools/mbcoupler/ssn_test.cpp b/tools/mbcoupler/ssn_test.cpp
index 21adf72..a7e4188 100644
--- a/tools/mbcoupler/ssn_test.cpp
+++ b/tools/mbcoupler/ssn_test.cpp
@@ -102,8 +102,8 @@ int main(int argc, char **argv) {
// Create an ofstream to write output. One file each for each proc.
std::stringstream fname;
fname << argv[0] << rank << ".out";
- std::freopen(fname.str().c_str(), "a", stdout);
- std::freopen(fname.str().c_str(), "a", stderr);
+ if (!std::freopen(fname.str().c_str(), "a", stdout)) return false;
+ if (!std::freopen(fname.str().c_str(), "a", stderr)) return false;
// Create the moab instance
Interface *mbi = new Core();
diff --git a/tools/mbcslam/Intx2Mesh.cpp b/tools/mbcslam/Intx2Mesh.cpp
index 9859d00..e055beb 100644
--- a/tools/mbcslam/Intx2Mesh.cpp
+++ b/tools/mbcslam/Intx2Mesh.cpp
@@ -782,7 +782,7 @@ ErrorCode Intx2Mesh::create_departure_mesh_2nd_alg(EntityHandle & euler_set, Ent
// construct the conn quad
EntityHandle new_conn[MAXEDGES];
- int nnodes;
+ int nnodes = -1;
for (int j=0; j<max_edges; j++)
int vgid = TLq.vi_rd[sizeTuple*i+2+j];// vertex global ID
@@ -1072,7 +1072,7 @@ ErrorCode Intx2Mesh::create_departure_mesh_3rd_alg(EntityHandle & lagr_set,
- int nnodes;
+ int nnodes = -1;
for (int j = 0; j < max_edges; j++)
int vgid = TLq.vi_rd[sizeTuple * i + 2 + j]; // vertex global ID
diff --git a/tools/mcnpmit/main.cpp b/tools/mcnpmit/main.cpp
index eca4b85..cc2d19a 100644
--- a/tools/mcnpmit/main.cpp
+++ b/tools/mcnpmit/main.cpp
@@ -136,7 +136,7 @@ int main(int argc, char **argv) {
char line[10000];
// Used only when reading a mesh file to get vertex info
- double *cfd_coords;
+ double *cfd_coords = NULL;
moab::Range::iterator cfd_iter;
moab::EntityHandle meshset;
Repository URL: https://bitbucket.org/fathomteam/moab/
This is a commit notification from bitbucket.org. You are receiving
this because you have the service enabled, addressing the recipient of
this email.
