[MOAB-dev] commit/MOAB: 2 new changesets
commits-noreply at bitbucket.org commits-noreply at bitbucket.org
Tue Mar 11 15:34:35 CDT 2014
2 new commits in MOAB:
https://bitbucket.org/fathomteam/moab/commits/fc3351604b22/
Changeset:   fc3351604b22
Branch:      None
User:        tautges
Date:        2014-02-20 19:44:45
Summary:     DeformMeshRemap.cpp: Write more intermediate files if compiled with local debug flag true; change some of the functions for moving coords to tags and vice versa to facilitate this.
SpatialLocator.cpp: Back out change that automatically chose BVH tree for non-vertex entities, there's a bug in point location there currently...
Affected #:  2 files
diff --git a/examples/DeformMeshRemap.cpp b/examples/DeformMeshRemap.cpp
index f752b4e..a8a0e10 100644
--- a/examples/DeformMeshRemap.cpp
+++ b/examples/DeformMeshRemap.cpp
@@ -110,10 +110,13 @@ private:
   ErrorCode read_file(int m_or_s, string &fname, EntityHandle &seth);
     //! write the input tag to the coordinates for the vertices in the input elems
-  ErrorCode write_to_coords(Range &elems, Tag tagh);
+    //! if non-zero tmp_tag is input, save coords to tmp_tag before over-writing with tag value
+  ErrorCode write_to_coords(Range &elems, Tag tagh, Tag tmp_tag = 0);
     //! write the tag to the vertices, then save to the specified file
-  ErrorCode write_and_save(Range &ents, EntityHandle seth, Tag tagh, const char *filename);
+    //! if restore_coords is true, coords are restored to their initial state after file is written
+  ErrorCode write_and_save(Range &ents, EntityHandle seth, Tag tagh, const char *filename,
+                           bool restore_coords = false);
     //! find fluid/solid sets from complement of solid/fluid sets
   ErrorCode find_other_sets(int m_or_s, EntityHandle file_set);
@@ -262,7 +265,7 @@ ErrorCode DeformMeshRemap::execute()
   src_elems.merge(fluidElems[MASTER]);
     // initialize data coupler on source elements
-  DataCoupler dc_master(mbImpl, NULL, src_elems, 0);
+  DataCoupler dc_master(mbImpl, src_elems, 0, NULL);
   Range tgt_verts;
   if (have_slave) {
@@ -316,6 +319,7 @@ ErrorCode DeformMeshRemap::execute()
     // transfer xNew to coords, for master
   if (debug) std::cout << "Transferring coords tag to vertex coordinates in master mesh..." << std::endl;
+  rval = write_to_coords(solidElems[MASTER], xNew); RR("Failed writing tag to master fluid verts.");
   rval = write_to_coords(fluidElems[MASTER], xNew); RR("Failed writing tag to master fluid verts.");
   if (have_slave) {
@@ -334,8 +338,8 @@ ErrorCode DeformMeshRemap::execute()
     if (pcMaster && pcMaster->size() > 1)
       str = "PARALLEL=WRITE_PART";
 #endif
-    if (debug) std::cout << "Writing smoothed_master.vtk..." << std::endl;
-    rval = mbImpl->write_file("smoothed_master.vtk", NULL, str.c_str(), &masterSet, 1);
+    if (debug) std::cout << "Writing smoothed_master.h5m..." << std::endl;
+    rval = mbImpl->write_file("smoothed_master.h5m", NULL, str.c_str(), &masterSet, 1);
     if (have_slave) {
 #ifdef USE_MPI
@@ -343,8 +347,8 @@ ErrorCode DeformMeshRemap::execute()
       if (pcSlave && pcSlave->size() > 1)
 #endif
-      if (debug) std::cout << "Writing slave_interp.vtk..." << std::endl;
-      rval = mbImpl->write_file("slave_interp.vtk", NULL, str.c_str(), &slaveSet, 1);
+      if (debug) std::cout << "Writing slave_interp.h5m..." << std::endl;
+      rval = mbImpl->write_file("slave_interp.h5m", NULL, str.c_str(), &slaveSet, 1);
     } // if have_slave
   } // if debug
@@ -470,20 +474,38 @@ int main(int argc, char **argv) {
   return rval;
-ErrorCode DeformMeshRemap::write_and_save(Range &ents, EntityHandle seth, Tag tagh, const char *filename)
+ErrorCode DeformMeshRemap::write_and_save(Range &ents, EntityHandle seth, Tag tagh, const char *filename,
+                                          bool restore_coords)
-  ErrorCode rval = write_to_coords(ents, tagh); RR("");
+  Tag tmp_tag = 0;
+  ErrorCode rval;
+  if (restore_coords)
+    rval = mbImpl->tag_get_handle("", 3, MB_TYPE_DOUBLE, tmp_tag, MB_TAG_CREAT|MB_TAG_DENSE);
+  rval = write_to_coords(ents, tagh, tmp_tag); RR("");
   rval = mbImpl->write_file(filename, NULL, NULL, &seth, 1); RR("");
+  if (restore_coords) {
+    rval = write_to_coords(ents, tmp_tag); RR("");
+    rval = mbImpl->tag_delete(tmp_tag);
   return rval;
-ErrorCode DeformMeshRemap::write_to_coords(Range &elems, Tag tagh)
+ErrorCode DeformMeshRemap::write_to_coords(Range &elems, Tag tagh, Tag tmp_tag)
     // write the tag to coordinates
   Range verts;
   ErrorCode rval = mbImpl->get_adjacencies(elems, 0, false, verts, Interface::UNION);
   RR("Failed to get adj vertices.");
   std::vector<double> coords(3*verts.size());
+  if (tmp_tag) {
+      // save the coords to tmp_tag first
+    rval = mbImpl->get_coords(verts, &coords[0]); RR("Failed to get tmp copy of coords.");
+    rval = mbImpl->tag_set_data(tmp_tag, verts, &coords[0]); RR("Failed to save tmp copy of coords.");
   rval = mbImpl->tag_get_data(tagh, verts, &coords[0]);
   RR("Failed to get tag data.");
   rval = mbImpl->set_coords(verts, &coords[0]);
@@ -503,7 +525,6 @@ void deform_func(const BoundBox &bbox, double *xold, double *xnew)
   xnew[0] = xold[0] + yfrac * delx;
   xnew[1] = xold[1] + yfrac * (1.0 + xfrac) * 0.05;
 /* Deformation function based on fraction of bounding box dimension in each direction */
   double frac = 0.01; // taken from approximate relative deformation from LLNL Diablo of XX09 assys
   CartVect *xo = reinterpret_cast<CartVect*>(xold), *xn = reinterpret_cast<CartVect*>(xnew);
@@ -517,13 +538,13 @@ ErrorCode DeformMeshRemap::deform_master(Range &fluid_elems, Range &solid_elems,
   ErrorCode rval;
     // get all the vertices and coords in the solid
-  Range verts;
-  rval = mbImpl->get_adjacencies(solid_elems, 0, false, verts, Interface::UNION);
+  Range solid_verts, fluid_verts;
+  rval = mbImpl->get_adjacencies(solid_elems, 0, false, solid_verts, Interface::UNION);
   RR("Failed to get vertices.");
-  std::vector<double> coords(3*verts.size()), new_coords(3*verts.size());
-  rval = mbImpl->get_coords(verts, &coords[0]);
+  std::vector<double> coords(3*solid_verts.size()), new_coords(3*solid_verts.size());
+  rval = mbImpl->get_coords(solid_verts, &coords[0]);
   RR("Failed to get vertex coords.");
-  unsigned int num_verts = verts.size();
+  unsigned int num_verts = solid_verts.size();
     // get or create the tag
@@ -536,7 +557,7 @@ ErrorCode DeformMeshRemap::deform_master(Range &fluid_elems, Range &solid_elems,
     for (int i = 0; i < 3; i++) {
       rval = mbImpl->tag_get_handle(xDispNames[0].c_str(), 1, MB_TYPE_DOUBLE, xDisp[i]);
       RR("Failed to get xDisp tag.");
-      rval = mbImpl->tag_get_data(xDisp[i], verts, &disps[0]);
+      rval = mbImpl->tag_get_data(xDisp[i], solid_verts, &disps[0]);
       RR("Failed to get xDisp tag values.");
       for (unsigned int j = 0; j < num_verts; j++)
         new_coords[3*j+i] = coords[3*j+i] + disps[j];
@@ -547,7 +568,7 @@ ErrorCode DeformMeshRemap::deform_master(Range &fluid_elems, Range &solid_elems,
     RR("Failed to get first xDisp tag.");
     xNew = xDisp[0];
     std::vector<double> disps(3*num_verts);
-    rval = mbImpl->tag_get_data(xDisp[0], verts, &disps[0]);
+    rval = mbImpl->tag_get_data(xDisp[0], solid_verts, &disps[0]);
     for (unsigned int j = 0; j < 3*num_verts; j++)
       new_coords[j] = coords[j] + disps[j];
@@ -584,18 +605,26 @@ ErrorCode DeformMeshRemap::deform_master(Range &fluid_elems, Range &solid_elems,
     // set the new tag to those coords
-  rval = mbImpl->tag_set_data(xNew, verts, &coords[0]);
+  rval = mbImpl->tag_set_data(xNew, solid_verts, &new_coords[0]);
   RR("Failed to set tag data.");
     // get all the vertices and coords in the fluid, set xnew to them
-  verts.clear();
-  rval = mbImpl->get_adjacencies(fluid_elems, 0, false, verts, Interface::UNION);
+  rval = mbImpl->get_adjacencies(fluid_elems, 0, false, fluid_verts, Interface::UNION);
-  coords.resize(3*verts.size());
+  fluid_verts = subtract(fluid_verts, solid_verts);
+  if (coords.size() < 3*fluid_verts.size()) coords.resize(3*fluid_verts.size());
+  rval = mbImpl->get_coords(fluid_verts, &coords[0]);
+  rval = mbImpl->tag_set_data(xNew, fluid_verts, &coords[0]);
   RR("Failed to set xnew tag on fluid verts.");
+  if (debug) {
+      // save deformed mesh coords to new file for visualizing
+    Range tmp_range(fluidElems[MASTER]);
+    tmp_range.merge(solidElems[MASTER]);
+    rval = write_and_save(tmp_range, masterSet, xNew, "deformed_master.h5m", true); RR("");
   return MB_SUCCESS;
diff --git a/src/SpatialLocator.cpp b/src/SpatialLocator.cpp
index a8a8f07..44f8494 100644
--- a/src/SpatialLocator.cpp
+++ b/src/SpatialLocator.cpp
@@ -35,12 +35,12 @@ namespace moab
       if (myTree) return;
-      if (myElems.empty() || mbImpl->type_from_handle(*myElems.rbegin()) == MBVERTEX)
+//      if (myElems.empty() || mbImpl->type_from_handle(*myElems.rbegin()) == MBVERTEX)
           // create a kdtree if only vertices
         myTree = new AdaptiveKDTree(mbImpl);
-      else
+//      else
           // otherwise a BVHtree, since it performs better for elements
-        myTree = new BVHTree(mbImpl);
+//        myTree = new BVHTree(mbImpl);
       iCreatedTree = true;
https://bitbucket.org/fathomteam/moab/commits/41dc120f7e2c/
Changeset:   41dc120f7e2c
Branch:      deformed-mesh-remap
User:        tautges
Date:        2014-03-11 21:31:21
Summary:     Various smallish bug fixes and minor changes, improving the use of SpatialLocator.
ElemEvaluator: in set_ent_handle, if there's no evalSet for that entity type, call EvalSet::get_eval_set
SpatialLocator: set the evaluator on the tree if it's not the same as what's on SpatialLocator; also, replace find_point logic
  (that used distance_search for some reason) with call to Tree::point_search.
AdaptiveKDTree: move parse_options to public function, as it is in Tree
BVHTree: fixed bug, where BVHTree had its own myEval shadowing the one declared in Tree
Tree: fixed bug, initialize myEval to NULL in constructor
spatial_locator_test: test trees with and without evaluators
DataCoupler: improving comments a bit, and move ParallelComm down in arg list for constructor; also, some
  improved comments
datacoupler_test: adding test
Passes make check in parallel.
Affected #:  10 files
diff --git a/src/LocalDiscretization/moab/ElemEvaluator.hpp b/src/LocalDiscretization/moab/ElemEvaluator.hpp
index 866388c..6a1efd0 100644
--- a/src/LocalDiscretization/moab/ElemEvaluator.hpp
+++ b/src/LocalDiscretization/moab/ElemEvaluator.hpp
@@ -339,8 +339,13 @@ namespace moab {
       std::vector<EntityHandle> dum_vec;
       ErrorCode rval = mbImpl->get_connectivity(ent, vertHandles, numVerts, false, &dum_vec);
       if (MB_SUCCESS != rval) return rval;
+      if (!evalSets[entType].evalFcn)
+        EvalSet::get_eval_set(entType, numVerts, evalSets[entType]);
       rval = mbImpl->get_coords(vertHandles, numVerts, vertPos[0].array());
       if (tagHandle) {
         rval = set_tag_handle(tagHandle);
index 44f8494..6f3cf22 100644
       if (myTree) return;
-//      if (myElems.empty() || mbImpl->type_from_handle(*myElems.rbegin()) == MBVERTEX)
+      if (myElems.empty() || mbImpl->type_from_handle(*myElems.rbegin()) == MBVERTEX)
-//      else
+      else
-//        myTree = new BVHTree(mbImpl);
+        myTree = new BVHTree(mbImpl);
@@ -365,90 +365,29 @@ namespace moab
           // relative epsilon given, translate to absolute epsilon using box dimensions
         tmp_abs_iter_tol = rel_iter_tol * localBox.diagonal_length();
-      EntityHandle closest_leaf;
-      std::vector<double> dists;
-      std::vector<EntityHandle> leaves;
-      ErrorCode rval = MB_SUCCESS;
+      if (elemEval && myTree->get_eval() != elemEval)
+        myTree->set_eval(elemEval);
+      ErrorCode rval = MB_SUCCESS;
       for (int i = 0; i < num_points; i++) {
         int i3 = 3*i;
-        ents[i] = 0;
-        if (tmp_abs_iter_tol) {
-          rval = myTree->distance_search(pos+i3, tmp_abs_iter_tol, leaves, tmp_abs_iter_tol, inside_tol, &dists);
-          if (MB_SUCCESS != rval) return rval;
-          if (!leaves.empty()) {
-              // get closest leaf
-            double min_dist = *dists.begin();
-            closest_leaf = *leaves.begin();
-            std::vector<EntityHandle>::iterator vit = leaves.begin()+1;
-            std::vector<double>::iterator dit = dists.begin()+1;
-            for (; vit != leaves.end() && min_dist; vit++, dit++) {
-              if (*dit < min_dist) {
-                min_dist = *dit;
-                closest_leaf = *vit;
-            dists.clear();
-            leaves.clear();
-        else {
-          rval = myTree->point_search(pos+i3, closest_leaf);
-          if (MB_ENTITY_NOT_FOUND == rval) closest_leaf = 0;
-          else if (MB_SUCCESS != rval) return rval;
-          // if no ElemEvaluator, just return the box
-        if (!elemEval) {
-          ents[i] = closest_leaf;
-          params[i3] = params[i3+1] = params[i3+2] = -2;
-          if (is_inside && closest_leaf) is_inside[i] = true;
+        ErrorCode tmp_rval = myTree->point_search(pos+i3, ents[i], abs_iter_tol, inside_tol, NULL, NULL,
+                                                  (CartVect*)(params+i3));
+        if (MB_SUCCESS != tmp_rval) {
+          rval = tmp_rval;
           continue;
-          // find natural coordinates of point in element(s) in that leaf
-        CartVect tmp_nat_coords;
-        Range range_leaf;
-        rval = mbImpl->get_entities_by_dimension(closest_leaf, myDim, range_leaf, false);
-        if(rval != MB_SUCCESS) return rval;
-          // loop over the range_leaf
-        int tmp_inside;
-        int *is_ptr = (is_inside ? is_inside+i : &tmp_inside);
-        *is_ptr = false;
-        EntityHandle ent = 0;
-        for(Range::iterator rit = range_leaf.begin(); rit != range_leaf.end(); rit++)
-          rval = elemEval->set_ent_handle(*rit);
-          rval = elemEval->reverse_eval(pos+i3, tmp_abs_iter_tol, inside_tol, params+i3, is_ptr);
-          if (*is_ptr) {
-            ent = *rit;
-            break;
-        if (debug && !ent) {
+        if (debug && !ents[i]) {
           std::cout << "Point " << i << " not found; point: ("
                     << pos[i3] << "," << pos[i3+1] << "," << pos[i3+2] << ")" << std::endl;
-          std::cout << "Source element candidates: " << std::endl;
-          range_leaf.print("   ");
-            std::cout << "Candidate " << CN::EntityTypeName(mbImpl->type_from_handle(*rit)) << " " << mbImpl->id_from_handle(*rit) << ": ";
-            std::cout << "Parameters: (" << params[i3] << "," << params[i3+1] << "," << params[i3+2] << ")"
-                      << " inside = " << *is_ptr << std::endl;
-        ents[i] = ent;
-      return MB_SUCCESS;
+        if (is_inside) is_inside[i] = (ents[i] ? true : false);
+      return rval;
         /* Count the number of located points in locTable
diff --git a/src/moab/AdaptiveKDTree.hpp b/src/moab/AdaptiveKDTree.hpp
index 450a418..e4c5078 100644
--- a/src/moab/AdaptiveKDTree.hpp
+++ b/src/moab/AdaptiveKDTree.hpp
@@ -38,6 +38,13 @@ namespace moab {
       ~AdaptiveKDTree();
+        /** \brief Parse options for tree creation
+         * \param options Options passed in by application
+         * \return Failure is returned if any options were passed in and not interpreted; could mean
+         * inappropriate options for a particular tree type
+      ErrorCode parse_options(FileOptions &options);
         /** Build the tree
          * Build a tree with the entities input.  If a non-NULL tree_root_set pointer is input,
          * use the pointed-to set as the root of this tree (*tree_root_set!=0) otherwise construct
@@ -253,13 +260,6 @@ namespace moab {
   private:
       friend class AdaptiveKDTreeIter;
-        /** \brief Parse options for tree creation
-         * \param options Options passed in by application
-         * \return Failure is returned if any options were passed in and not interpreted; could mean
-         * inappropriate options for a particular tree type
-      ErrorCode parse_options(FileOptions &options);
       ErrorCode init();
         /**\brief find a triangle near the input point */
diff --git a/src/moab/BVHTree.hpp b/src/moab/BVHTree.hpp
index d435ebf..354d3a1 100644
--- a/src/moab/BVHTree.hpp
+++ b/src/moab/BVHTree.hpp
@@ -272,7 +272,6 @@ namespace moab {
       Range entityHandles;
       std::vector<TreeNode> myTree;
-      ElemEvaluator *myEval;
       int splitsPerDir;
       EntityHandle startSetHandle;
       static const char *treeName;
@@ -305,7 +304,7 @@ namespace moab {
     inline BVHTree::BVHTree(Interface *impl) :
-            Tree(impl), myEval(NULL), splitsPerDir(3), startSetHandle(0) {boxTagName = treeName;}
+            Tree(impl), splitsPerDir(3), startSetHandle(0) {boxTagName = treeName;}
     inline unsigned int BVHTree::set_interval(BoundBox &interval,
                                               std::vector<Bucket>::const_iterator begin,
diff --git a/src/moab/Tree.hpp b/src/moab/Tree.hpp
index 67b67f9..0a995b4 100644
--- a/src/moab/Tree.hpp
+++ b/src/moab/Tree.hpp
@@ -236,7 +236,7 @@ namespace moab {
     inline Tree::Tree(Interface* iface)
             : mbImpl(iface), maxPerLeaf(6), maxDepth(30), treeDepth(-1), minWidth(1.0e-10),
-              meshsetFlags(0), cleanUp(true), myRoot(0), boxTag(0)
+              meshsetFlags(0), cleanUp(true), myRoot(0), boxTag(0), myEval(0)
     inline Tree::~Tree()
diff --git a/test/spatial_locator_test.cpp b/test/spatial_locator_test.cpp
index 0171bf9..404e668 100644
--- a/test/spatial_locator_test.cpp
+++ b/test/spatial_locator_test.cpp
@@ -4,7 +4,9 @@
 #include "moab/HomXform.hpp"
 #include "moab/ScdInterface.hpp"
 #include "moab/CartVect.hpp"
+#include "moab/AdaptiveKDTree.hpp"
 #include "moab/BVHTree.hpp"
+#include "moab/ElemEvaluator.hpp"
 #include "moab/ProgOptions.hpp"
 #include "moab/CpuTimer.hpp"
@@ -69,11 +71,21 @@ void test_kd_tree()
   Range elems;
   rval = create_hex_mesh(mb, elems, ints, 3); CHECK_ERR(rval);
-    // initialize spatial locator with the elements and the default tree type
-  SpatialLocator *sl = new SpatialLocator(&mb, elems);
+    // initialize spatial locator with the elements and KDtree
+  AdaptiveKDTree kd(&mb);
+  std::ostringstream opts;
+  opts << "MAX_DEPTH=" << max_depth << ";MAX_PER_LEAF=" << leaf;
+  FileOptions fo(opts.str().c_str());
+  rval = kd.parse_options(fo);
+  SpatialLocator *sl = new SpatialLocator(&mb, elems, &kd);
   test_locator(sl);
+    // test with an evaluator
+  ElemEvaluator eval(&mb);
+  kd.set_eval(&eval);
+  test_locator(sl);
     // destroy spatial locator, and tree along with it
   delete sl;
@@ -96,6 +108,11 @@ void test_bvh_tree()
   SpatialLocator *sl = new SpatialLocator(&mb, elems, &bvh);
   test_locator(sl);
+  bvh.set_eval(&eval);
+  test_locator(sl);
   delete sl;
diff --git a/tools/mbcoupler/DataCoupler.cpp b/tools/mbcoupler/DataCoupler.cpp
index a5a3ec1..06a8564 100644
--- a/tools/mbcoupler/DataCoupler.cpp
+++ b/tools/mbcoupler/DataCoupler.cpp
@@ -1,24 +1,27 @@
 #include "DataCoupler.hpp"
-#include "moab/ParallelComm.hpp"
 #include "moab/Tree.hpp"
 #include "moab/TupleList.hpp"
 #include "moab/SpatialLocator.hpp"
 #include "moab/Error.hpp"
+#ifdef USE_MPI
+#include "moab/ParallelComm.hpp"
+#endif
 #include "iostream"
-#include <stdio.h>
 #include <algorithm>
 #include <sstream>
+#include <stdio.h>
 #include "assert.h"
 namespace moab {
 DataCoupler::DataCoupler(Interface *impl,
-                         ParallelComm *pc,
                          Range &source_ents,
                          int coupler_id,
+                         ParallelComm *pc,
                          bool init_locator,
                          int dim)
         : mbImpl(impl), myPcomm(pc), myId(coupler_id), myDim(dim)
@@ -64,7 +67,12 @@ ErrorCode DataCoupler::locate_points(Range &targ_ents,
                                      const double inside_tol)
   targetEnts = targ_ents;
+#ifdef USE_MPI
+  if (myPcomm && myPcomm->size() > 1)
+    return myLocator->par_locate_points(myPcomm, targ_ents, rel_iter_tol, abs_iter_tol, inside_tol);
+#endif
   return myLocator->locate_points(targ_ents, rel_iter_tol, abs_iter_tol, inside_tol);
@@ -72,6 +80,11 @@ ErrorCode DataCoupler::locate_points(double *xyz, int num_points,
                                      const double rel_iter_tol, const double abs_iter_tol,
+#ifdef USE_MPI
+    return myLocator->par_locate_points(myPcomm, xyz, num_points, rel_iter_tol, abs_iter_tol, inside_tol);
+#endif
   return myLocator->locate_points(xyz, num_points, rel_iter_tol, abs_iter_tol, inside_tol);
@@ -95,7 +108,7 @@ ErrorCode DataCoupler::interpolate(/*DataCoupler::Method*/ int method,
   return interpolate(method, tag, interp_vals, point_indices, normalize);
-ErrorCode DataCoupler::interpolate(/*DataCoupler::Method*/ int *methods,
+ErrorCode DataCoupler::interpolate(/*DataCoupler::Method*/ int */* methods */,
                                    Tag *tags,
                                    int *points_per_method,
                                    int num_methods,
@@ -111,7 +124,12 @@ ErrorCode DataCoupler::interpolate(/*DataCoupler::Method*/ int *methods,
   for (int i = 0; i < num_methods; i++) pts_total += (points_per_method ? points_per_method[i] : targetEnts.size());
   unsigned int num_indices = (point_indices ? point_indices->size() : targetEnts.size());
+    // # points and indices should be identical
+  if (pts_total != num_indices)
+    return MB_FAILURE;
+    // since each tuple contains one interpolated tag, if we're interpolating multiple tags, every tuple
+    // needs to be able to store up to max tag size
   int max_tsize = -1;
   for (int i = 0; i < num_methods; i++) {
     int tmp_tsize;
@@ -120,75 +138,82 @@ ErrorCode DataCoupler::interpolate(/*DataCoupler::Method*/ int *methods,
     max_tsize = std::max(max_tsize, tmp_tsize);
-    // if tl was passed in non-NULL, just have those points, otherwise have targetPts plus
-    // locally mapped pts
-  if (pts_total != num_indices)
-    return MB_FAILURE;
-  if (myPcomm) {
-      // TL to send interpolation indices to target procs
-      // Tuple structure: (pto_i, ridx_i, lidx_i, meth_i, tagidx_i, interp_val[max_tsize]_d)
-    TupleList tinterp;
-    tinterp.initialize(5, 0, 0, max_tsize, num_indices);
-    int t = 0;
-    tinterp.enableWriteAccess();
-    for (int i = 0; i < num_methods; i++) {
-      int num_points = (points_per_method ? points_per_method[i] : targetEnts.size());
+  if (myPcomm && myPcomm->size() > 1) {
+      // build up the tuple list to distribute from my target points; assume that
+      // all procs use same method/tag input
+    TupleList TLob; // TLob structure: (pto_i, ridx_i, lidx_i, meth_tagidx_i)
+    TLob.initialize(4, 0, 0, 0, num_indices);
+    int tn = 0; // the tuple number we're currently on
+    TLob.enableWriteAccess();
+    for (int m = 0; m < num_methods; m++) {
+      int num_points = (points_per_method ? points_per_method[m] : targetEnts.size());
       for (int j = 0; j < num_points; j++) {
-        int idx = (point_indices ? (*point_indices)[j] : j);
+        int idx = (point_indices ? (*point_indices)[j] : j); // the index in my targetEnts for this interpolation point
           // remote proc/idx from myLocator->parLocTable
-        tinterp.vi_wr[5*t]   = myLocator->par_loc_table().vi_rd[2*idx]; // proc
-        tinterp.vi_wr[5*t+1] = myLocator->par_loc_table().vi_rd[2*idx+1]; // remote idx
+        TLob.vi_wr[4*tn]   = myLocator->par_loc_table().vi_rd[2*idx]; // proc
+        TLob.vi_wr[4*tn+1] = myLocator->par_loc_table().vi_rd[2*idx+1]; // remote idx
           // local entity index, tag/method index from my data
-        tinterp.vi_wr[5*t+2] = idx;
-        tinterp.vi_wr[5*t+3] = methods[i];
-        tinterp.vi_wr[5*t+4] = i;
-        tinterp.inc_n();
-        t++;
+        TLob.vi_wr[4*tn+2] = idx;
+        TLob.vi_wr[4*tn+3] = m;
+        TLob.inc_n();
+        tn++;
       // scatter/gather interpolation points
-    myPcomm->proc_config().crystal_router()->gs_transfer(1, tinterp, 0);
-      // perform interpolation on local source mesh; put results into
-      // tinterp.vr_wr
-    for (unsigned int i = 0; i < tinterp.get_n(); i++) {
-      int lidx = tinterp.vi_rd[5*i+1];
-//    /*Method*/ int method = (/*Method*/ int)tinterp.vi_rd[5*i+3];
-      Tag tag = tags[tinterp.vi_rd[5*i+4]];
+    myPcomm->proc_config().crystal_router()->gs_transfer(1, TLob, 0);
+      // perform interpolation on local source mesh; put results into TLinterp
+    TupleList TLinterp; // TLinterp structure: (pto_i, ridx_i, vals[max_tsize]_d)
+    TLinterp.initialize(2, 0, 0, max_tsize, TLob.get_n());
+    TLinterp.set_n(TLob.get_n()); // set the size right away
+    TLinterp.enableWriteAccess();
+    for (unsigned int i = 0; i < TLob.get_n(); i++) {
+      int lidx = TLob.vi_rd[4*i+1]; // index into myLocator's local table
+        // method and tag indexed with same index
+//      /*Method*/ int method = methods[TLob.vi_rd[4*i+3]];
+      Tag tag = tags[TLob.vi_rd[4*i+3]];
+        // copy proc/remote index from TLob
+      TLinterp.vi_wr[2*i] = TLob.vi_rd[4*i];
+      TLinterp.vi_wr[2*i+1] = TLob.vi_rd[4*i+2];
+        // set up the evaluator for the tag and entity, then interpolate, putting result in TLinterp
       myLocator->elem_eval()->set_tag_handle(tag);
       myLocator->elem_eval()->set_ent_handle(myLocator->loc_table().vul_rd[lidx]);
-      result = myLocator->elem_eval()->eval(myLocator->loc_table().vr_rd+3*lidx, tinterp.vr_rd+i*max_tsize);
+      result = myLocator->elem_eval()->eval(myLocator->loc_table().vr_rd+3*lidx, TLinterp.vr_rd+i*max_tsize);
       if (MB_SUCCESS != result) return result;
       // scatter/gather interpolation data
+    myPcomm->proc_config().crystal_router()->gs_transfer(1, TLinterp, 0);
       // copy the interpolated field as a unit
-    std::copy(tinterp.vr_rd, tinterp.vr_rd+tinterp.get_n()*max_tsize, interp_vals);
+    std::copy(TLinterp.vr_rd, TLinterp.vr_rd+TLinterp.get_n()*max_tsize, interp_vals);
   else {
+      // if called serially, interpolate directly from local locations/entities,
+      // into either interp_vals or by setting data directly on tags on those entities
     std::vector<double> tmp_vals;
     std::vector<EntityHandle> tmp_ents;
     double *tmp_dbl = interp_vals;
-        // interpolated data is tsize long, which is either max size (if data passed back to caller in tinterp)
+        // interpolated data is tsize long, which is either max size (if data passed back to caller in interp_vals)
         // or tag size (if data will be set on entities, in which case it shouldn't have padding)
+        // set sizes here, inside loop over methods, to reduce memory usage
       int tsize = max_tsize, tsize_bytes = 0;
       if (!interp_vals) {
         tmp_vals.resize(num_points*max_tsize);
         tmp_dbl = &tmp_vals[0];
         tmp_ents.resize(num_points);
         result = mbImpl->tag_get_length(tags[i], tsize);
+        if (MB_SUCCESS != result) return result;
         result = mbImpl->tag_get_bytes(tags[i], tsize_bytes);
@@ -206,7 +231,7 @@ ErrorCode DataCoupler::interpolate(/*DataCoupler::Method*/ int *methods,
         result = myLocator->elem_eval()->eval(myLocator->loc_table().vr_rd+3*lidx, tmp_dbl);
         tmp_dbl += tsize;
-      } // for j
+      } // for j over points
       if (!interp_vals) {
           // set tags on tmp_ents; data is already w/o padding, due to tsize setting above
@@ -214,7 +239,7 @@ ErrorCode DataCoupler::interpolate(/*DataCoupler::Method*/ int *methods,
-    } // for i
+    } // for i over methods
   } // if myPcomm
       // done
diff --git a/tools/mbcoupler/DataCoupler.hpp b/tools/mbcoupler/DataCoupler.hpp
index bfe2ba5..a9d6f5e 100644
--- a/tools/mbcoupler/DataCoupler.hpp
+++ b/tools/mbcoupler/DataCoupler.hpp
@@ -39,21 +39,23 @@ class DataCoupler
 public:
+  enum Method {CONSTANT, LINEAR_FE, QUADRATIC_FE, SPECTRAL} ;
   enum IntegType {VOLUME};
     /* constructor
      * Constructor, which also optionally initializes the coupler
+     * \param source_ents Elements in the source mesh
+     * \param coupler_id Id of this coupler, should be the same over all procs
      * \param pc ParallelComm object to be used with this coupler, representing the union
      *    of processors containing source and target meshes
-     * \param source_elems Elements in the source mesh
-     * \param coupler_id Id of this coupler, should be the same over all procs
      * \param init_locator If true, initializes a spatial locator inside the constructor
      * \param dim Dimension of entities to be coupled; if -1, get from source_elems
-              ParallelComm *pc,
               Range &source_ents,
               int coupler_id,
+              ParallelComm *pc = NULL,
               bool init_locator = true,
               int dim = -1);
diff --git a/tools/mbcoupler/Makefile.am b/tools/mbcoupler/Makefile.am
index ea32ff9..8114a52 100644
--- a/tools/mbcoupler/Makefile.am
+++ b/tools/mbcoupler/Makefile.am
@@ -40,7 +40,8 @@ libmbcoupler_la_includedir = $(includedir)
 # check that only libraries are going in $(libdir)
 cfgdir = $(libdir)
-TESTS = elem_util_test element_test
+TESTS = elem_util_test element_test datacoupler_test
+datacoupler_test_SOURCES = datacoupler_test.cpp
 check_PROGRAMS = $(TESTS)
 elem_util_test_SOURCES = ElemUtilTest.cpp
 element_test_SOURCES = ElementTest.cpp
diff --git a/tools/mbcoupler/datacoupler_test.cpp b/tools/mbcoupler/datacoupler_test.cpp
new file mode 100644
index 0000000..b39ca0e
--- /dev/null
+++ b/tools/mbcoupler/datacoupler_test.cpp
@@ -0,0 +1,682 @@
+#include "moab/Core.hpp"
+#include "moab/CpuTimer.hpp"
+#include "DataCoupler.hpp"
+#include "ElemUtil.hpp"
+#include "iMesh.h"
+#include "MBiMesh.hpp"
+#include <iostream>
+#include <iomanip>
+#include <sstream>
+#include <assert.h>
+#ifdef USE_MPI
+#include "MBParallelConventions.h"
+#endif
+using namespace moab;
+#define STRINGIFY_(A) #A
+#define STRINGIFY(A) STRINGIFY_(A)
+#ifdef MESHDIR
+std::string TestDir( STRINGIFY(MESHDIR) );
+#else
+std::string TestDir(".");
+#endif
+#define RRA(a) if (MB_SUCCESS != result) {\
+      std::string tmp_str; mbImpl->get_last_error(tmp_str);\
+      tmp_str.append("\n"); tmp_str.append(a);\
+      dynamic_cast<Core*>(mbImpl)->get_error_handler()->set_last_error(tmp_str.c_str()); \
+      return result;}
+#define PRINT_LAST_ERROR \
+    if (MB_SUCCESS != result) {\
+      std::string tmp_str;\
+      std::cout << "Failure; message:" << std::endl;\
+      mbImpl->get_last_error(tmp_str);\
+      std::cout << tmp_str << std::endl;\
+      MPI_Abort(MPI_COMM_WORLD, result);        \
+      return result;\
+#define PRINT_LAST_ERR \
+    if (iBase_SUCCESS != err) {\
+      return result;\
+void print_usage(char **argv);
+ErrorCode get_file_options(int argc, char **argv,
+                           std::vector<std::string> &meshFiles,
+                           DataCoupler::Method &method,
+                           std::string &interpTag,
+                           std::string &gNormTag,
+                           std::string &ssNormTag,
+                           std::vector<const char *> &ssTagNames,
+                           std::vector<const char *> &ssTagValues,
+                           std::string &readOpts,
+                           std::string &outFile,
+                           std::string &writeOpts,
+                           std::string &dbgFile,
+                           bool &help,
+                           double & epsilon);
+// ErrorCode get_file_options(int argc, char **argv,
+//                              std::vector<const char *> &filenames,
+//                              std::string &tag_name,
+//                              std::string &out_fname,
+//                              std::string &opts);
+#ifdef USE_MPI
+ErrorCode report_iface_ents(Interface *mbImpl,
+                              std::vector<ParallelComm *> &pcs,
+                              bool print_results);
+#endif
+ErrorCode test_interpolation(Interface *mbImpl,
+                             DataCoupler::Method method,
+                             iBase_EntitySetHandle *roots,
+                             double &instant_time,
+                             double &pointloc_time,
+                             double &interp_time,
+                             double &gnorm_time,
+                             double &ssnorm_time,
+                             double & toler);
+void reduceMax(double &v){
+  double buf;
+  MPI_Barrier(MPI_COMM_WORLD);
+  MPI_Allreduce( &v, &buf, 1, MPI_DOUBLE, MPI_MAX, MPI_COMM_WORLD);
+  v=buf;
+int main(int argc, char **argv)
+  int err;
+#ifdef USE_MPI
+    // need to init MPI first, to tell how many procs and rank
+  err = MPI_Init(&argc, &argv);
+#endif
+  std::vector<const char *> ssTagNames, ssTagValues;
+  std::vector<std::string> meshFiles;
+  std::string interpTag, gNormTag, ssNormTag, readOpts, outFile, writeOpts, dbgFile;
+  DataCoupler::Method method = DataCoupler::CONSTANT;
+  ErrorCode result = MB_SUCCESS;
+  bool help = false;
+  double toler = 5.e-10;
+  result = get_file_options(argc, argv, meshFiles, method, interpTag,
+                            gNormTag, ssNormTag, ssTagNames, ssTagValues,
+                            readOpts, outFile, writeOpts, dbgFile, help, toler);
+  if (result != MB_SUCCESS || help) {
+    print_usage(argv);
+#ifdef USE_MPI
+    err = MPI_Finalize();
+#endif
+    return 1;
+  int nprocs = 1, rank = 0;
+#ifdef USE_MPI
+  err = MPI_Comm_size(MPI_COMM_WORLD, &nprocs);
+  err = MPI_Comm_rank(MPI_COMM_WORLD, &rank);
+  std::vector<ParallelComm *> pcs(meshFiles.size());
+#endif
+    // redirect stdout and stderr if dbgFile is not null
+  if (!dbgFile.empty()) {
+    std::stringstream dfname;
+    dfname << dbgFile << rank << ".txt";
+    std::freopen(dfname.str().c_str(), "a", stdout);
+    std::freopen(dfname.str().c_str(), "a", stderr);
+  // create MOAB instance based on that
+  Interface *mbImpl = new Core();
+  if (NULL == mbImpl) return 1;
+  iMesh_Instance iMeshInst = reinterpret_cast<iMesh_Instance>( new MBiMesh(mbImpl) );
+    // read in mesh(es)
+    // Create root sets for each mesh using the iMesh API.  Then pass these
+    // to the load_file functions to be populated.
+  iBase_EntitySetHandle *roots = (iBase_EntitySetHandle *) malloc(sizeof(iBase_EntitySetHandle) * meshFiles.size());
+  for (unsigned int i = 0; i < meshFiles.size(); i++) {
+    std::string newReadopts;
+    std::ostringstream extraOpt;
+#ifdef USE_MPI
+    pcs[i] = new ParallelComm(mbImpl, MPI_COMM_WORLD);
+    int index = pcs[i]->get_id();
+    extraOpt  << ";PARALLEL_COMM=" << index;
+    newReadopts = readOpts+extraOpt.str();
+#endif
+    iMesh_createEntSet(iMeshInst, 0, &(roots[i]), &err);
+    result = mbImpl->load_file( meshFiles[i].c_str(), (EntityHandle *)&roots[i], newReadopts.c_str() );
+    PRINT_LAST_ERROR;
+#ifdef USE_MPI
+  result = report_iface_ents(mbImpl, pcs, true);
+  PRINT_LAST_ERROR;
+#endif
+  double instant_time=0.0, pointloc_time=0.0, interp_time=0.0, gnorm_time=0.0, ssnorm_time=0.0;
+    // test interpolation and global normalization and subset normalization
+  result = test_interpolation(mbImpl, method, interpTag, gNormTag, ssNormTag,
+                              ssTagNames, ssTagValues, roots, pcs,
+                              instant_time, pointloc_time, interp_time,
+                              gnorm_time, ssnorm_time, toler);
+  PRINT_LAST_ERROR;
+  reduceMax(instant_time);
+  reduceMax(pointloc_time);
+  reduceMax(interp_time);
+  if(0==rank)
+    printf("\nMax time : %g %g %g (inst loc interp -- %d procs )\n", instant_time,
+	   pointloc_time, interp_time, nprocs);
+    // output mesh
+  if (!outFile.empty()) {
+    Range partSets;
+      // only save the target mesh
+    partSets.insert((EntityHandle)roots[1]);
+    std::string newwriteOpts = writeOpts;
+#ifdef USE_MPI
+    extraOpt  << ";PARALLEL_COMM=" << 1;
+    newwriteOpts += extraOpt.str();
+#endif
+    result = mbImpl->write_file(outFile.c_str(), NULL, newwriteOpts.c_str(), partSets);
+    PRINT_LAST_ERROR;
+    std::cout << "Wrote " << outFile << std::endl;
+    std::cout << "mbcoupler_test complete." << std::endl;
+#ifdef USE_MPI
+    delete pcs[i];
+#endif
+  delete mbImpl;
+  //may be leaking iMeshInst, don't care since it's end of program. Remove above deletes?
+#ifdef USE_MPI
+#endif
+  return 0;
+#ifdef USE_MPI
+                              const bool print_results)
+  Range iface_ents[6];
+  ErrorCode result = MB_SUCCESS, tmp_result;
+    // now figure out which vertices are shared
+  for (unsigned int p = 0; p < pcs.size(); p++) {
+    for (int i = 0; i < 4; i++) {
+      tmp_result = pcs[p]->get_iface_entities(-1, i, iface_ents[i]);
+      if (MB_SUCCESS != tmp_result) {
+        std::cerr << "get_iface_entities returned error on proc "
+                  << pcs[p]->proc_config().proc_rank() << "; message: " << std::endl;
+        std::string last_error;
+        result = mbImpl->get_last_error(last_error);
+        if (last_error.empty()) std::cerr << "(none)" << std::endl;
+        else std::cerr << last_error << std::endl;
+        result = tmp_result;
+      if (0 != i) iface_ents[4].merge(iface_ents[i]);
+    // report # iface entities
+  result = mbImpl->get_adjacencies(iface_ents[4], 0, false, iface_ents[5],
+                                   Interface::UNION);
+  int rank;
+  MPI_Comm_rank(MPI_COMM_WORLD, &rank);
+  if (print_results || iface_ents[0].size() != iface_ents[5].size()) {
+    std::cerr << "Proc " << rank << " iface entities: " << std::endl;
+      std::cerr << "    " << iface_ents[i].size() << " "
+                << i << "d iface entities." << std::endl;
+    std::cerr << "    (" << iface_ents[5].size()
+              << " verts adj to other iface ents)" << std::endl;
+  return result;
+#endif
+// Print usage
+void print_usage(char **argv) {
+  std::cerr << "Usage: ";
+  std::cerr << argv[0] << " -meshes <source_mesh><target_mesh> -itag <interp_tag> [-gnorm <gnorm_tag>] [-ssnorm <ssnorm_tag><ssnorm_selection>] [-ropts <roptions>] [-outfile <out_file> [-wopts <woptions>]] [-dbgout [<dbg_file>]]" << std::endl;
+  std::cerr << "    -meshes" << std::endl;
+  std::cerr << "        Read in mesh files <source_mesh> and <target_mesh>." << std::endl;
+  std::cerr << "    -itag" << std::endl;
+  std::cerr << "        Interpolate tag <interp_tag> from source mesh to target mesh." << std::endl;
+  std::cerr << "    -gnorm" << std::endl;
+  std::cerr << "        Normalize the value of tag <gnorm_tag> over then entire mesh and save to" << std::endl;
+  std::cerr << "        tag \"<gnorm_tag>_normf\" on the mesh set.  Do this for all meshes." << std::endl;
+  std::cerr << "    -ssnorm" << std::endl;
+  std::cerr << "        Normalize the value of tag <ssnorm_tag> over subsets of a mesh and save to" << std::endl;
+  std::cerr << "        tag \"<ssnorm_tag>_normf\" on the Entity Set for each subset.  Subsets are selected" << std::endl;
+  std::cerr << "        using criteria in <ssnorm_selection>.  Do this for all meshes." << std::endl;
+  std::cerr << "    -ropts" << std::endl;
+  std::cerr << "        Read in the mesh files using options in <roptions>." << std::endl;
+  std::cerr << "    -outfile" << std::endl;
+  std::cerr << "        Write out target mesh to <out_file>." << std::endl;
+  std::cerr << "    -wopts" << std::endl;
+  std::cerr << "        Write out mesh files using options in <woptions>." << std::endl;
+  std::cerr << "    -dbgout" << std::endl;
+  std::cerr << "        Write stdout and stderr streams to the file \'<dbg_file>.txt\'." << std::endl;
+  std::cerr << "    -eps" << std::endl;
+  std::cerr << "        epsilon" << std::endl;
+  std::cerr << "    -meth <method> (0=CONSTANT, 1=LINEAR_FE, 2=QUADRATIC_FE, 3=SPECTRAL)" << std::endl;
+// Check first character for a '-'.
+// Return true if one is found.  False otherwise.
+bool check_for_flag(const char *str) {
+  if (str[0] == '-')
+    return true;
+  else
+    return false;
+// New get_file_options() function with added possibilities for mbcoupler_test.
+                           bool &help,
+                           double & epsilon)
+  // Initialize some of the outputs to null values indicating not present
+  // in the argument list.
+  gNormTag = "";
+  ssNormTag = "";
+  readOpts = "PARALLEL=READ_PART;PARTITION=PARALLEL_PARTITION;PARTITION_DISTRIBUTE;PARALLEL_RESOLVE_SHARED_ENTS;PARALLEL_GHOSTS=3.0.1;CPUTIME";
+  outFile = "";
+  writeOpts = "PARALLEL=WRITE_PART;CPUTIME";
+  dbgFile = "";
+  std::string defaultDbgFile = argv[0];  // The executable name will be the default debug output file.
+  // These will indicate if we've gotten our required parameters at the end of parsing.
+  bool haveMeshes = false;
+  bool haveInterpTag = false;
+  // Loop over the values in argv pulling out an parsing each one
+  int npos = 1;
+  if (argc > 1 && argv[1] == std::string("-h")) {
+    help = true;
+    return MB_SUCCESS;
+  while (npos < argc) {
+    if (argv[npos] == std::string("-meshes")) {
+      // Parse out the mesh filenames
+      npos++;
+      int numFiles = 2;
+      meshFiles.resize(numFiles);
+      for (int i = 0; i < numFiles; i++) {
+        if ((npos < argc) && (!check_for_flag(argv[npos])))
+          meshFiles[i] = argv[npos++];
+        else {
+          std::cerr << "    ERROR - missing correct number of mesh filenames" << std::endl;
+      haveMeshes = true;
+    else if (argv[npos] == std::string("-itag")) {
+      // Parse out the interpolation tag
+      npos++;
+        interpTag = argv[npos++];
+      else {
+        std::cerr << "    ERROR - missing <interp_tag>" << std::endl;
+      haveInterpTag = true;
+    else if (argv[npos] == std::string("-meth")) {
+      npos++;
+      if (argv[npos][0] == '0') method = DataCoupler::CONSTANT;
+      else if (argv[npos][0] == '1') method = DataCoupler::LINEAR_FE;
+      else if (argv[npos][0] == '2') method = DataCoupler::QUADRATIC_FE;
+      else if (argv[npos][0] == '3') method = DataCoupler::SPECTRAL;
+      else {
+        std::cerr << "    ERROR - unrecognized method number " << method << std::endl;
+      npos++;
+    else if (argv[npos] == std::string("-eps")) {
+      // Parse out the tolerance
+      npos++;
+        epsilon = atof(argv[npos++]);
+      else {
+        std::cerr << "    ERROR - missing <epsilon>" << std::endl;
+    else if (argv[npos] == std::string("-gnorm")) {
+      // Parse out the global normalization tag
+      npos++;
+        gNormTag = argv[npos++];
+      else {
+        std::cerr << "    ERROR - missing <gnorm_tag>" << std::endl;
+    else if (argv[npos] == std::string("-ssnorm")) {
+      // Parse out the subset normalization tag and selection criteria
+      npos++;
+        ssNormTag = argv[npos++];
+      else {
+        std::cerr << "    ERROR - missing <ssnorm_tag>" << std::endl;
+      if ((npos < argc) && (!check_for_flag(argv[npos]))) {
+        char* opts = argv[npos++];
+        char sep1[1] = {';'};
+        char sep2[1] = {'='};
+        bool end_vals_seen = false;
+        std::vector<char *> tmpTagOpts;
+        // first get the options
+        for (char* i = strtok(opts, sep1); i; i = strtok(0, sep1)) {
+          tmpTagOpts.push_back(i);
+        // parse out the name and val or just name.
+        for (unsigned int j = 0; j < tmpTagOpts.size(); j++) {
+          char* e = strtok(tmpTagOpts[j], sep2);
+          ssTagNames.push_back(e);
+          e = strtok(0, sep2);
+          if (e != NULL) {
+            // We have a value
+            if (end_vals_seen) {
+              // ERROR we should not have a value after none are seen
+              std::cerr << "    ERROR - new value seen after end of values in <ssnorm_selection>" << std::endl;
+            // Otherwise get the value string from e and convert it to an int
+            int *valp = new int;
+            *valp = atoi(e);
+            ssTagValues.push_back((const char *) valp);
+          else {
+            // Otherwise there is no '=' so push a null on the list
+            end_vals_seen = true;
+            ssTagValues.push_back((const char *) 0);
+      else {
+        std::cerr << "    ERROR - missing <ssnorm_selection>" << std::endl;
+    else if (argv[npos] == std::string("-ropts")) {
+      // Parse out the mesh file read options
+      npos++;
+        readOpts = argv[npos++];
+      else {
+        std::cerr << "    ERROR - missing <roptions>" << std::endl;
+    else if (argv[npos] == std::string("-outfile")) {
+      // Parse out the output file name
+      npos++;
+        outFile = argv[npos++];
+      else {
+        std::cerr << "    ERROR - missing <out_file>" << std::endl;
+    else if (argv[npos] == std::string("-wopts")) {
+      // Parse out the output file write options
+      npos++;
+        writeOpts = argv[npos++];
+      else {
+        std::cerr << "    ERROR - missing <woptions>" << std::endl;
+    else if (argv[npos] == std::string("-dbgout")) {
+      // Parse out the debug output file name.
+      // If no name then use the default.
+      npos++;
+        dbgFile = argv[npos++];
+      else
+        dbgFile = defaultDbgFile;
+    else {
+      // Unrecognized parameter.  Skip it and move along.
+      std::cerr << "    ERROR - Unrecognized parameter:" << argv[npos] << std::endl;
+      std::cerr << "            Skipping..." << std::endl;
+      npos++;
+  if (!haveMeshes) {
+    meshFiles.resize(2);
+    meshFiles[0] = std::string(TestDir + "/64bricks_1khex.h5m");
+    meshFiles[1] = std::string(TestDir + "/64bricks_12ktet.h5m");
+    std::cout << "Mesh files not entered; using default files "
+              << meshFiles[0] << " and " << meshFiles[1] << std::endl;
+  if (!haveInterpTag) {
+    interpTag = "vertex_field";
+    std::cout << "Interpolation field name not given, using default of " << interpTag << std::endl;
+#ifdef HDF5_FILE
+  if (1 == argc) {
+    std::cout << "No arguments given; using output file dum.h5m." << std::endl;
+    outFile = "dum.h5m";
+#endif
+// End new get_file_options()
+                             double & toler)
+  assert(method >= DataCoupler::CONSTANT && method <= DataCoupler::SPECTRAL);
+    // source is 1st mesh, target is 2nd
+  Range src_elems, targ_elems, targ_verts;
+  ErrorCode result = pcs[0]->get_part_entities(src_elems, 3);
+  PRINT_LAST_ERROR;
+  CpuTimer timer;
+    // instantiate a coupler, which also initializes the tree
+  DataCoupler dc(mbImpl, src_elems, 0, pcs[0]);
+  // initialize spectral elements, if they exist
+  bool specSou=false, specTar = false;
+//  result =  mbc.initialize_spectral_elements((EntityHandle)roots[0], (EntityHandle)roots[1], specSou, specTar);
+  instant_time = timer.time_since_birth();
+    // get points from the target mesh to interpolate
+  // we have to treat differently the case when the target is a spectral mesh
+  // in that case, the points of interest are the GL points, not the vertex nodes
+  std::vector<double> vpos; // this will have the positions we are interested in
+  int numPointsOfInterest = 0;
+#ifdef USE_MPI
+  result = pcs[1]->get_part_entities(targ_elems, 3);
+#else
+  result = mbImpl->get_entities_by_dimension((EntityHandle)roots[1], 3);
+#endif
+  PRINT_LAST_ERROR;
+    // first get all vertices adj to partition entities in target mesh
+  if (DataCoupler::CONSTANT == method)
+    targ_verts = targ_elems;
+  else
+    result = mbImpl->get_adjacencies(targ_elems, 0, false, targ_verts,
+  PRINT_LAST_ERROR;
+#ifdef USE_MPI
+    // then get non-owned verts and subtract
+  Range tmp_verts;
+  result = pcs[1]->get_pstatus_entities(0, PSTATUS_NOT_OWNED, tmp_verts);
+  PRINT_LAST_ERROR;
+  targ_verts = subtract( targ_verts, tmp_verts);
+#endif
+    // get position of these entities; these are the target points
+  numPointsOfInterest = (int)targ_verts.size();
+  vpos.resize(3*targ_verts.size());
+  result = mbImpl->get_coords(targ_verts, &vpos[0]);
+  PRINT_LAST_ERROR;
+    // locate those points in the source mesh
+#ifdef USE_MPI
+  std::cout << "rank "<< pcs[0]->proc_config().proc_rank();
+#endif
+  std::cout << " points of interest: " << numPointsOfInterest << "\n";
+  result = dc.locate_points(&vpos[0], numPointsOfInterest, toler);
+  PRINT_LAST_ERROR;
+  pointloc_time = timer.time_elapsed();
+    // now interpolate tag onto target points
+  std::vector<double> field(numPointsOfInterest);
+  result = dc.interpolate(method, interpTag, &field[0]);
+  PRINT_LAST_ERROR;
+  interp_time = timer.time_elapsed();
+    // do global normalization if specified
+  if (!gNormTag.empty()) {
+    int err;
+    // Normalize the source mesh
+    err = dc.normalize_mesh(roots[0], gNormTag.c_str(), DataCoupler::VOLUME, 4);
+    PRINT_LAST_ERR;
+    // Normalize the target mesh
+    err = dc.normalize_mesh(roots[1], gNormTag.c_str(), DataCoupler::VOLUME, 4);
+    PRINT_LAST_ERR;
+  gnorm_time = timer.time_elapsed();
+    // do subset normalization if specified
+  if (!ssNormTag.empty()) {
+    int err;
+    err = dc.normalize_subset(roots[0],
+                               ssNormTag.c_str(),
+                               &ssTagNames[0],
+                               ssTagNames.size(),
+                               &ssTagValues[0],
+                              DataCoupler::VOLUME,
+                               4);
+    PRINT_LAST_ERR;
+    err = dc.normalize_subset(roots[1],
+                               &ssTagNames[0],
+                               &ssTagValues[0],
+                               4);
+    PRINT_LAST_ERR;
+  ssnorm_time = timer.time_elapsed();
+    // set field values as tag on target vertices
+    // use original tag
+  Tag tag;
+  result = mbImpl->tag_get_handle(interpTag.c_str(), 1, MB_TYPE_DOUBLE, tag); PRINT_LAST_ERROR;
+  result = mbImpl->tag_set_data(tag, targ_verts, &field[0]);
+  PRINT_LAST_ERROR;
+    // done
Repository URL: https://bitbucket.org/fathomteam/moab/
This is a commit notification from bitbucket.org. You are receiving
this because you have the service enabled, addressing the recipient of
this email.
