[MOAB-dev] commit/MOAB: danwu: Merged master into	error_handling_enhancement
    commits-noreply at bitbucket.org
    Thu Mar  6 09:28:32 CST 2014
1 new commit in MOAB:
https://bitbucket.org/fathomteam/moab/commits/75c833861b21/
Changeset:   75c833861b21
Branch:      error_handling_enhancement
User:        danwu
Date:        2014-03-06 16:28:25
Summary:     Merged master into error_handling_enhancement
Affected #:  4 files
diff --git a/src/MBTagConventions.hpp b/src/MBTagConventions.hpp
index 61e5732..5cb518f 100644
--- a/src/MBTagConventions.hpp
+++ b/src/MBTagConventions.hpp
@@ -108,6 +108,18 @@
 #define NAME_TAG_NAME "NAME"
 #define NAME_TAG_SIZE 32
+/* BLOCK_HEADER: tag
+ * A fixex lenght tag containg block header data
+ * BlockColor, MaterialId and BlockDimension
+#define BLOCK_HEADER "BLOCK_HEADER"
+/* BLOCK_ATTRIBUTES: tag
+ * A varible lenght tag of doubles
+ * Tag contains attributes set to BlockSet in cubit file
+#define BLOCK_ATTRIBUTES "BLOCK_ATTRIBUTES"
 #ifndef MB_PARALLEL_CONVENTIONS_H
 #define MB_PARALLEL_CONVENTIONS_H
diff --git a/src/SpatialLocator.cpp b/src/SpatialLocator.cpp
index 694122c..f976ae7 100644
--- a/src/SpatialLocator.cpp
+++ b/src/SpatialLocator.cpp
@@ -263,7 +263,9 @@ namespace moab
           iargs[1] = TLforward_o.vi_rd[3*i+2];
           iargs[2] = locTable.get_n();
           TLsearch_results_o.push_back(iargs, NULL, NULL, NULL);
-          locTable.push_back(const_cast<int*>(&TLforward_o.vi_rd[3*i+1]), NULL, &ents[i], ¶ms[3*i]);
+          ulong ent_ulong=(ulong)ents[i];
+          sint forward= (sint)TLforward_o.vi_rd[3*i+1];
+          locTable.push_back(&forward, NULL, &ent_ulong, ¶ms[3*i]);
       locTable.disableWriteAccess();
diff --git a/src/io/Tqdcfr.cpp b/src/io/Tqdcfr.cpp
index afc0493..701ff15 100644
--- a/src/io/Tqdcfr.cpp
+++ b/src/io/Tqdcfr.cpp
@@ -592,7 +592,6 @@ ErrorCode Tqdcfr::read_nodeset(const unsigned int nsindex,
     if (MB_SUCCESS != result) return result;
     // check for more data
-    // <- likask
   if (num_read < nodeseth->nsLength) {
     FREADC(2); num_read += 2;
     if (char_buf[0] == 'i' && char_buf[1] == 'd') {
@@ -608,7 +607,7 @@ ErrorCode Tqdcfr::read_nodeset(const unsigned int nsindex,
-  if(debug) { // <-likask
+  if(debug) {
     nodeseth->print();
     if(!bc_data.empty()) {
       std::cout << "bc_data = ";
@@ -623,7 +622,7 @@ ErrorCode Tqdcfr::read_nodeset(const unsigned int nsindex,
       std::cout << std::endl;
-  } // <-likask
     // and put entities into this nodeset's set
   ErrorCode result = put_into_set(nodeseth->setHandle, ns_entities, excl_entities);
@@ -632,7 +631,6 @@ ErrorCode Tqdcfr::read_nodeset(const unsigned int nsindex,
   result = get_names(model->nodesetMD, nsindex, nodeseth->setHandle);
-  // <-likask
   const int def_bc_data_len = 0;
   std::string tag_name = std::string(DIRICHLET_SET_TAG_NAME)+"__BC_DATA";
   Tag nbc_data;
@@ -761,7 +759,7 @@ ErrorCode Tqdcfr::read_sideset(const unsigned int ssindex,
+  if(debug) {
     sideseth->print();
@@ -776,12 +774,11 @@ ErrorCode Tqdcfr::read_sideset(const unsigned int ssindex,
-  } // <-likask
   result = get_names(model->sidesetMD, ssindex, sideseth->setHandle);
-  // <-likask
   std::string tag_name = std::string(NEUMANN_SET_TAG_NAME)+"__BC_DATA";
   Tag nbc_data;
@@ -920,6 +917,7 @@ ErrorCode Tqdcfr::read_block(const unsigned int blindex,
                              Tqdcfr::ModelEntry *model,
                              Tqdcfr::BlockHeader *blockh)
   if (blockh->memCt == 0) return MB_SUCCESS;
     // position file
@@ -949,24 +947,20 @@ ErrorCode Tqdcfr::read_block(const unsigned int blindex,
   ErrorCode result = put_into_set(blockh->setHandle, block_entities, excl_entities);
-    // read attribs if there are any
+  // read attribs if there are any
+  Tag block_attribs;
+    int def_block_attributes_length = 0;
+    result = mdbImpl->tag_get_handle(BLOCK_ATTRIBUTES,def_block_attributes_length,MB_TYPE_DOUBLE,
+      block_attribs,MB_TAG_CREAT|MB_TAG_SPARSE|MB_TAG_VARLEN,NULL);
+    if (MB_SUCCESS != result && MB_ALREADY_ALLOCATED != result) return result;
   if (blockh->attribOrder > 0) {
-    Tag block_attribs;
     FREADD(blockh->attribOrder); num_read += sizeof(double);
-      // now do something with them...
-      // This code seems broken.  It is apparently supposed to read
-      // blockh->attribOrder values for each block and store them in
-      // a tag.  However, blockh->attribOrder is not a constant
-      // so the same fixed-length tag cannot be used for all blocks.
-      // For now, just store one value, as that was what the buggy code
-      // previously did.
-    result = mdbImpl->tag_get_handle("Block_Attributes", 1/*blockh->attribOrder*/,
-                                 MB_TYPE_DOUBLE, block_attribs,
-                                 MB_TAG_SPARSE|MB_TAG_CREAT);
-    if (MB_SUCCESS != result && MB_ALREADY_ALLOCATED != result) return result;
-    result = mdbImpl->tag_set_data(block_attribs, &(blockh->setHandle), 1,
-                                   &(dbl_buf[0]));
+    void const* tag_data[] = { &dbl_buf[0] };
+    int tag_sizes[] = { blockh->attribOrder };
+    result = mdbImpl->tag_set_by_ptr(block_attribs,&(blockh->setHandle),1,tag_data,tag_sizes);
@@ -1932,6 +1926,19 @@ ErrorCode Tqdcfr::BlockHeader::read_info_header(const double data_version,
     block_headers[i].blockLength = instance->uint_buf[10];
     block_headers[i].blockDim = instance->uint_buf[11];
+    Tag bhTag_header;
+      std::vector<int> def_uint_zero(3,0);
+      result = instance->mdbImpl->tag_get_handle(BLOCK_HEADER,3*sizeof(unsigned int),MB_TYPE_INTEGER,
+	bhTag_header,MB_TAG_CREAT|MB_TAG_SPARSE|MB_TAG_BYTES,&def_uint_zero[0]);
+      if (MB_SUCCESS != result) return result;
+      int block_header_data[] = { block_headers[i].blockCol, block_headers[i].blockMat, block_headers[i].blockDim };
+      result = instance->mdbImpl->tag_set_data(bhTag_header,&(block_headers[i].setHandle), 1,
+					      block_header_data);
       // adjust element type for data version; older element types didn't include
       // 4 new trishell element types
     if (data_version <= 1.0 && block_headers[i].blockElemType >= 15)
diff --git a/tools/mbcslam/Makefile.am b/tools/mbcslam/Makefile.am
index 0697a15..f6a0292 100644
--- a/tools/mbcslam/Makefile.am
+++ b/tools/mbcslam/Makefile.am
@@ -18,7 +18,7 @@ AM_CPPFLAGS += -DIS_BUILDING_MB \
 lib_LTLIBRARIES = libmbcslam.la
 libmbcslam_la_LIBADD = $(top_builddir)/src/libMOAB.la $(top_builddir)/itaps/imesh/libiMesh.la
-LDADD = $(top_builddir)/src/libMOAB.la libmbcslam.la
+LDADD = libmbcslam.la  $(top_builddir)/src/libMOAB.la
 libmbcslam_la_SOURCES = \
    Intx2Mesh.cpp Intx2Mesh.hpp Intx2MeshOnSphere.cpp Intx2MeshOnSphere.hpp \
@@ -50,8 +50,10 @@ intx_mpas_SOURCES = intx_mpas.cpp
 cslam_par_test_SOURCES = cslam_par_test.cpp
 proj1_SOURCES = proj1.cpp
 intx_imesh_SOURCES = intx_imesh.cpp
+intx_imesh_LDADD = $(LDADD) $(top_builddir)/itaps/imesh/libiMesh.la
 create_dp_SOURCES = create_dp.cpp
 advection_SOURCES = advection.F90
+advection_LDADD = $(LDADD) $(top_builddir)/itaps/imesh/libiMesh.la
 EXTRA_DIST  = lagrangeHomme.vtk  \
               eulerHomme.vtk \
Repository URL: https://bitbucket.org/fathomteam/moab/
This is a commit notification from bitbucket.org. You are receiving
this because you have the service enabled, addressing the recipient of
this email.
