[MOAB-dev] commit/MOAB: danwu: Partially applied error handling code to NC reader for testing. If we load a CAM-FV file and read variables that are on edges (not supported yet), error messages and stack traces will be printed out (examples/TestErrorHandling.cpp is updated to demonstrate this feature).
commits-noreply at bitbucket.org
Fri Feb 21 17:59:28 CST 2014
1 new commit in MOAB:
https://bitbucket.org/fathomteam/moab/commits/617c8f597924/
Changeset: 617c8f597924
Branch: error_handling_enhancement
User: danwu
Date: 2014-02-22 00:59:00
Summary: Partially applied error handling code to NC reader for testing. If we load a CAM-FV file and read variables that are on edges (not supported yet), error messages and stack traces will be printed out (examples/TestErrorHandling.cpp is updated to demonstrate this feature).
Affected #: 3 files
diff --git a/examples/TestErrorHandling.cpp b/examples/TestErrorHandling.cpp
index 0ea0fa4..3e16667 100644
--- a/examples/TestErrorHandling.cpp
+++ b/examples/TestErrorHandling.cpp
@@ -159,6 +159,19 @@ ErrorCode TestErrorHandling_5()
return MB_SUCCESS;
+// In this test case, a real error MB_NOT_IMPLEMENTED is returned by MOAB
+ErrorCode TestErrorHandling_6()
+ Core moab;
+ Interface& mb = moab;
+ // Load a CAM-FV file and read a variable on edges (not supported yet)
+ string test_file = string(MESH_DIR) + string("/io/fv26x46x72.t.3.nc");
+ ErrorCode rval = mb.load_file(test_file.c_str(), NULL, "VARIABLE=US");CHK_ERR(rval);
+ return MB_SUCCESS;
#endif
int main(int argc, char** argv)
@@ -190,6 +203,10 @@ int main(int argc, char** argv)
cout << "--------------------Running test case 5 start--------------------" << endl;
TestErrorHandling_5();
cout << "--------------------Running test case 5 end----------------------\n" << endl;
+ cout << "--------------------Running test case 6 start--------------------" << endl;
+ TestErrorHandling_6();
+ cout << "--------------------Running test case 6 end----------------------\n" << endl;
#endif
MBErrorHandler_Finalize();
diff --git a/src/io/NCHelper.cpp b/src/io/NCHelper.cpp
index 9ef1332..2bed0c9 100644
--- a/src/io/NCHelper.cpp
+++ b/src/io/NCHelper.cpp
@@ -1027,7 +1027,8 @@ ErrorCode ScdNCHelper::read_variables(std::vector<std::string>& var_names, std::
if (!vdatas.empty()) {
rval = read_scd_variable_to_nonset(vdatas, tstep_nums);
- ERRORR(rval, "Trouble read variables to entities verts/edges/faces.");
+ if (MB_SUCCESS != rval)
+ SET_ERR(rval, "Trouble reading variables to entities verts/edges/faces");
return MB_SUCCESS;
@@ -1103,11 +1104,8 @@ ErrorCode ScdNCHelper::read_scd_variable_to_nonset_allocate(std::vector<ReadNC::
range = &verts;
break;
case ReadNC::ENTLOCNSEDGE:
- ERRORR(MB_FAILURE, "Reading edge data not implemented yet.");
- break;
case ReadNC::ENTLOCEWEDGE:
- break;
+ SET_ERR(MB_NOT_IMPLEMENTED, "Reading edge data not implemented yet");
case ReadNC::ENTLOCFACE:
// Faces
vdatas[i].readStarts[2] = lCDims[1];
@@ -1164,7 +1162,8 @@ ErrorCode ScdNCHelper::read_scd_variable_to_nonset(std::vector<ReadNC::VarData>&
DebugOutput& dbgOut = _readNC->dbgOut;
ErrorCode rval = read_scd_variable_to_nonset_allocate(vdatas, tstep_nums);
- ERRORR(rval, "Trouble allocating read variables.");
+ SET_ERR(rval, "Trouble allocating space to read variables");
// Finally, read into that space
int success;
diff --git a/src/io/ReadNC.cpp b/src/io/ReadNC.cpp
index a0e02b4..38cafd2 100644
--- a/src/io/ReadNC.cpp
+++ b/src/io/ReadNC.cpp
@@ -127,9 +127,7 @@ ErrorCode ReadNC::load_file(const char* file_name, const EntityHandle* file_set,
// Read variables onto grid
if (!noVars) {
- rval = myHelper->read_variables(var_names, tstep_nums);
- if (MB_FAILURE == rval)
- return rval;
+ rval = myHelper->read_variables(var_names, tstep_nums);CHK_ERR(rval);
else {
// Read dimension variables by default (the dimensions that are also variables)
Repository URL: https://bitbucket.org/fathomteam/moab/
This is a commit notification from bitbucket.org. You are receiving
this because you have the service enabled, addressing the recipient of
this email.
