[MOAB-dev] commit/MOAB: iulian07: example to load partially a file, based on tagged sets
commits-noreply at bitbucket.org commits-noreply at bitbucket.org
Fri Feb 21 16:22:08 CST 2014
1 new commit in MOAB:
https://bitbucket.org/fathomteam/moab/commits/91ad4c217024/
Changeset:   91ad4c217024
Branch:      master
User:        iulian07
Date:        2014-02-21 23:18:21
Summary:     example to load partially a file, based on tagged sets
it is a good cherry-picking tool, when you want to extract only some
of the tagged sets in a h5m file. For example, you want to look only at the
mesh from partition 0, 1 and 4. You can use visit / subset capability.
Or you can use this example
It extends the option from mbconvert (-m), which can extract the blocks
for given material sets.
It will work for any tagged sets
Affected #:  2 files
diff --git a/examples/LoadPartial.cpp b/examples/LoadPartial.cpp
new file mode 100644
index 0000000..ef1f2e7
--- /dev/null
+++ b/examples/LoadPartial.cpp
@@ -0,0 +1,63 @@
+/** @example LoadPartial.cpp \n
+ * \brief Load a part of a file  \n
+ * <b>To run</b>: LoadPartial <file><tag_name><val1><val2> ...\n
+ * In this example, it is shown how to load only a part of one file; the file must be organized in sets.
+ * (cherry-picking only the sets we want)
+ * The sets to load are identified by a tag name and the tag values for the sets of interest.
+ * This procedure is used  when reading in parallel, as each processor will load only
+ * its part of the file, identified either by partition or by material/block sets
+ *  by default, this example will load parallel partition sets
+ *  with values 1, 2, and 5 from ../MeshFiles/unittest/64bricks_1khex.h5m
+ *  The example will always write the output to a file name part.h5m
+#include <iostream>
+#include <vector>
+// Include header for MOAB instance and tag conventions for
+#include "moab/Core.hpp"
+#include "MBTagConventions.hpp"
+int main(int argc, char **argv) {
+    // instantiate & load a file
+    moab::Interface *mb = new moab::Core();
+    moab::ErrorCode rval;
+    if (argc <= 1) //
+      // the default file to load
+      int set_tag_values[] = {1, 2, 5};
+      int num_set_tag_values = 3;
+      // this file is in the mesh files directory
+      rval = mb->load_file("../MeshFiles/unittest/64bricks_1khex.h5m",
+              0, 0, PARALLEL_PARTITION_TAG_NAME, set_tag_values, num_set_tag_values);
+    else
+      // first arg is input file, second is tag name, then are the tag values
+      if (argc < 4)
+        std::cout<< " usage is " << argv[0] << " <file><tag_name><value1><value2>  .. \n";
+        return 0;
+      else
+        std::vector<int> vals(argc-3); // the first 3 args are exe, file, tagname; the rest are values
+        for (int i=3; i<argc; i++)
+          vals[i-3] = atoi(argv[i]);
+        rval = mb->load_file(argv[1], 0, 0, argv[2], &vals[0], (int) vals.size() );
+    if (moab::MB_SUCCESS!=rval)
+      std::cout << " failed to read\n";
+    rval = mb->write_file("part.h5m");
+      std::cout << " failed to write partial file.\n";
+    else
+      std::cout << " wrote successfully part.h5m.\n";
+    delete mb;
+    return 0;
diff --git a/examples/makefile b/examples/makefile
index 3692b26..1e8c521 100644
--- a/examples/makefile
+++ b/examples/makefile
@@ -62,6 +62,9 @@ PushParMeshIntoMoabF90: PushParMeshIntoMoabF90.o
 DeformMeshRemap: DeformMeshRemap.o ${MOAB_LIBDIR}/libMOAB.la
 	${MOAB_CXX} -o $@ $< ${MOAB_LIBS_LINK} -lmbcoupler ${MOAB_LIBS_LINK}
+LoadPartial: LoadPartial.o ${MOAB_LIBDIR}/libMOAB.la
+	${MOAB_CXX} -o $@ $< ${MOAB_LIBS_LINK} ${MOAB_LIBS_LINK}
 clean:
 	rm -rf *.o *.mod ${EXAMPLES} ${PAREXAMPLES} ${EXOIIEXAMPLES} ${F90EXAMPLES}
Repository URL: https://bitbucket.org/fathomteam/moab/
This is a commit notification from bitbucket.org. You are receiving
this because you have the service enabled, addressing the recipient of
this email.
