[MOAB-dev] commit/MOAB: tautges: Changes to eliminate requirement for MPI2, from Russ Whitesides (LLNL).
commits-noreply at bitbucket.org
Thu Feb 20 10:27:58 CST 2014
1 new commit in MOAB:
https://bitbucket.org/fathomteam/moab/commits/eb333bdc81e5/
Changeset: eb333bdc81e5
Branch: master
User: tautges
Date: 2014-02-20 17:27:49
Summary: Changes to eliminate requirement for MPI2, from Russ Whitesides (LLNL).
Affected #: 2 files
diff --git a/tools/mbcoupler/Coupler.cpp b/tools/mbcoupler/Coupler.cpp
index 29dbb3d..b496441 100644
--- a/tools/mbcoupler/Coupler.cpp
+++ b/tools/mbcoupler/Coupler.cpp
@@ -113,11 +113,22 @@ ErrorCode Coupler::initialize_tree()
box.bMax.get(&allBoxes[6*my_rank+3]);
// now communicate to get all boxes
- // use "in place" option
if (myPc) {
- int mpi_err = MPI_Allgather(MPI_IN_PLACE, 0, MPI_DATATYPE_NULL,
+ int mpi_err;
+#if (MPI_VERSION >= 2)
+ // use "in place" option
+ mpi_err = MPI_Allgather(MPI_IN_PLACE, 0, MPI_DATATYPE_NULL,
&allBoxes[0], 6, MPI_DOUBLE,
myPc->proc_config().proc_comm());
+#else
+ std::vector<double> allBoxes_tmp(6*myPc->proc_config().proc_size());
+ mpi_err = MPI_Allgather( &allBoxes[6*my_rank], 6, MPI_DOUBLE,
+ &allBoxes_tmp[0], 6, MPI_DOUBLE,
+ myPc->proc_config().proc_comm());
+ allBoxes = allBoxes_tmp;
+#endif
if (MPI_SUCCESS != mpi_err) return MB_FAILURE;
diff --git a/tools/mbcslam/Intx2Mesh.cpp b/tools/mbcslam/Intx2Mesh.cpp
index 22fdc3f..9859d00 100644
--- a/tools/mbcslam/Intx2Mesh.cpp
+++ b/tools/mbcslam/Intx2Mesh.cpp
@@ -483,10 +483,21 @@ ErrorCode Intx2Mesh::build_processor_euler_boxes(EntityHandle euler_set, Range &
- &allBoxes[0], 6, MPI_DOUBLE,
- parcomm->proc_config().proc_comm());
+ int mpi_err;
+ &allBoxes[0], 6, MPI_DOUBLE,
+ parcomm->proc_config().proc_comm());
+#else
+ std::vector<double> allBoxes_tmp(6*parcomm->proc_config().proc_size());
+#endif
// also process the max number of vertices per cell (4 for quads, but could be more for polygons)
Repository URL: https://bitbucket.org/fathomteam/moab/
This is a commit notification from bitbucket.org. You are receiving
this because you have the service enabled, addressing the recipient of
this email.
