[MOAB-dev] commit/MOAB: danwu: Merged master into error_handling_enhancement
commits-noreply at bitbucket.org commits-noreply at bitbucket.org
Mon Feb 17 15:03:53 CST 2014
1 new commit in MOAB:
https://bitbucket.org/fathomteam/moab/commits/2b17f018e438/
Changeset:   2b17f018e438
Branch:      error_handling_enhancement
User:        danwu
Date:        2014-02-17 22:03:49
Summary:     Merged master into error_handling_enhancement
Affected #:  2 files
diff --git a/examples/CrystalRouterExample.cpp b/examples/CrystalRouterExample.cpp
new file mode 100644
index 0000000..200f012
--- /dev/null
+++ b/examples/CrystalRouterExample.cpp
@@ -0,0 +1,130 @@
+ * This example will show one of the building blocks of parallel infrastructure in MOAB
+ * More exactly, if we have some homogeneous data to communicate from each processor to a list of other
+ * processors, how do we do it?
+ * introduce the TupleList and crystal router to MOAB users.
+ * This technology is used in resolving shared vertices / sets between partitions
+ * It is used in the mbcoupler for sending data (target points) to the proper processor, and communicate
+ *   back the results.
+ * Also, it is used to communicate departure mesh for intersection in parallel
+ *  It is a way of doing  MPI_gatheralltoallv(), when the communication matrix is sparse
+ *  It is assumed that every proc needs to communicate only with a few of the other processors.
+ *  If every processor needs to communicate with all other, then we will have to use paired isend and irecv, the
+ *  communication matrix is full
+ *  the example needs to be launched in parallel.
+ *  Every proc will build a list of tuples, that will be send to a few procs;
+ *  every proc will send 1 tuple, to proc rank + 1 and rank + rank*(size-1)+2 , with value
+ *    10000 * send + 100* rank
+ *  at the receive, we verify we received
+ *    10000 * rank + 100 * from
+ *    For some reportrank we also print the tuples.
+ *  after routing, we will see if we received, as expected. Should run on at least 2 processors.
+ * Note: We do not need a moab instance for this example
+/** @example CrystalRouterExample.cpp \n
+ * \brief generalized gather scatter using tuples \n
+ * <b>To run</b>: mpiexec -np <n> CrystalRouterExample [reportrank] \n
+#include "moab/ProcConfig.hpp"
+#include "moab/TupleList.hpp"
+#include <iostream>
+using namespace moab;
+using namespace std;
+int main(int argc, char **argv)
+  MPI_Init(&argc, &argv);
+  int reportrank = 1;
+  if (argc>1)
+    reportrank = atoi(argv[1]);
+  ProcConfig pc(MPI_COMM_WORLD);
+  int size = pc.proc_size();
+  int rank = pc.proc_rank();
+  if (reportrank==rank)
+    std::cout << " there are " << size << " procs in example\n";
+  // send some data from proc i to i+n/2, also to i +n/2+1 modulo n, wher en is num procs
+  gs_data::crystal_data *cd = pc.crystal_router();
+  TupleList tl;
+  // at most 100 to send
+  // we do a preallocate with this; some tuples on some processors might need more memory, to be able
+  // to grow locally; 100 is a very large number for this example, considering that each task sends only
+  // 2 tuples. Some tasks might receive more tuples though, and in the process, some might grow more than
+  // others. By doing these logP sends/receives, we do not grow local memory too much.
+  tl.initialize(1, 1, 0, 1, 100);
+  tl.enableWriteAccess();
+  // form 2 tuples, send to rank+1 and rank+2 (mod size)
+  unsigned int n = tl.get_n();
+  int sendTo = rank+1;
+  sendTo = sendTo%size;
+  long intToSend = 100*rank + 10000*sendTo;
+  tl.vi_wr[n]= sendTo;
+  tl.vl_wr[n]= intToSend;
+  tl.vr_wr[n]= 100.*rank;
+  tl.inc_n();
+  n = tl.get_n();
+  sendTo = rank+(rank+1)*rank+2;// just some number relatively different from rank
+  intToSend = 100*rank + 10000*sendTo;
+  tl.vr_wr[n]= 1000.*rank;
+  tl.inc_n();
+    std::cout << "rank " << rank << "\n";
+    tl.print(" before sending");
+  // all communication happens here:
+  ErrorCode rval = cd->gs_transfer(1,tl,0);
+  if (MB_SUCCESS!= rval)
+    std::cout << "error in tuple transfer\n";
+    tl.print(" after transfer");
+  // check that all tuples received have the form 10000* rank + 100*from
+  unsigned int received = tl.get_n();
+  for (int i=0; i<received; i++)
+    int from = tl.vi_rd[i];
+    long valrec = tl.vl_rd[i];
+    int remainder = valrec -10000*rank -100*from;
+    if (remainder != 0 )
+      std::cout << " error: tuple " << i << " received at proc rank " << rank << " from proc " << from << " has value " <<
+         valrec << " remainder " <<  remainder << "\n";
+  MPI_Finalize();
+  return 0;
diff --git a/examples/makefile b/examples/makefile
index 07de492..46d894b 100644
--- a/examples/makefile
+++ b/examples/makefile
@@ -8,7 +8,7 @@ include ${MOAB_DIR}/lib/iMesh-Defs.inc
 MESH_DIR="../MeshFiles/unittest"
 EXAMPLES = HelloMOAB GetEntities SetsNTags structuredmesh StructuredMeshSimple DirectAccessWithHoles DirectAccessNoHoles point_in_elem_search DeformMeshRemap
-PAREXAMPLES = HelloParMOAB ReduceExchangeTags LloydRelaxation
+PAREXAMPLES = HelloParMOAB ReduceExchangeTags LloydRelaxation CrystalRouterExample
 EXOIIEXAMPLES = TestExodusII
 ERROREXAMPLES = TestErrorHandling TestErrorHandlingPar
 F90EXAMPLES = DirectAccessNoHolesF90 PushParMeshIntoMoabF90
@@ -48,6 +48,9 @@ ReduceExchangeTags : ReduceExchangeTags.o ${MOAB_LIBDIR}/libMOAB.la
 HelloParMOAB: HelloParMOAB.o ${MOAB_LIBDIR}/libMOAB.la
 	${MOAB_CXX} -o $@ $< ${MOAB_LIBS_LINK}
+CrystalRouterExample: CrystalRouterExample.o  ${MOAB_LIBDIR}/libMOAB.la
+	${MOAB_CXX} -o $@ $< ${MOAB_LIBS_LINK}
 TestExodusII: TestExodusII.o ${MOAB_LIBDIR}/libMOAB.la
Repository URL: https://bitbucket.org/fathomteam/moab/
This is a commit notification from bitbucket.org. You are receiving
this because you have the service enabled, addressing the recipient of
this email.
