[MOAB-dev] commit/MOAB: tautges: Merge branch 'master' into tautges/par_spatial_locator
commits-noreply at bitbucket.org commits-noreply at bitbucket.org
Thu Feb 13 11:25:21 CST 2014
1 new commit in MOAB:
https://bitbucket.org/fathomteam/moab/commits/fe8ac7589ddd/
Changeset:   fe8ac7589ddd
Branch:      tautges/par_spatial_locator
User:        tautges
Date:        2014-02-13 18:25:03
Summary:     Merge branch 'master' into tautges/par_spatial_locator
Affected #:  39 files
diff --git a/.gitignore b/.gitignore
index 482fcd4..e60d5d8 100644
--- a/.gitignore
+++ b/.gitignore
@@ -178,7 +178,6 @@ test/obb/obb_time
 test/obb/obb_tree_tool
 test/obb_test
 test/oldinc/test_oldinc
-test/read_mpas_nc
 test/parallel/*.h5m
 test/parallel/mbparallelcomm_test
 test/parallel/mhdf_parallel
diff --git a/MeshFiles/unittest/Makefile.am b/MeshFiles/unittest/Makefile.am
index a1784ee..ab3e23e 100644
--- a/MeshFiles/unittest/Makefile.am
+++ b/MeshFiles/unittest/Makefile.am
@@ -33,5 +33,6 @@ EXTRA_DIST  = 125hex.g \
               poly14.txt \
               BedCrop2.h5m \
               mpas_p8.h5m \
-              Homme_2pt.h5m
+              Homme_2pt.h5m \
+              surfrandomtris-4part.h5m
diff --git a/MeshFiles/unittest/io/cube.sat b/MeshFiles/unittest/io/cube.sat
new file mode 100644
index 0000000..58fd508
--- /dev/null
+++ b/MeshFiles/unittest/io/cube.sat
@@ -0,0 +1,117 @@
+1900 0 1 0
+10 Cubit 12.2 17 ACIS 19.0.2 Linux 24 Mon Jan  6 14:16:03 2014
+1 9.9999999999999995e-07 1e-10
+body $1 -1 -1 $-1 $2 $-1 $-1 T -5 -5 -5 5 5 5 #
+integer_attrib-name_attrib-gen-attrib $-1 -1 $-1 $-1 $0 2 1 1 1 1 1 1 1 1 1 1 1 1 1 0 1 1 1 @8 CUBIT_ID 1 #
+lump $3 -1 -1 $-1 $-1 $4 $0 T -5 -5 -5 5 5 5 #
+integer_attrib-name_attrib-gen-attrib $-1 -1 $-1 $-1 $2 2 1 1 1 1 1 1 1 1 1 1 1 1 1 0 1 1 1 @8 CUBIT_ID 1 #
+shell $-1 -1 -1 $-1 $-1 $-1 $5 $-1 $2 T -5 -5 -5 5 5 5 #
+face $6 -1 -1 $-1 $7 $8 $4 $-1 $9 forward single T -5 -5 5 5 5 5 F #
+integer_attrib-name_attrib-gen-attrib $-1 -1 $-1 $-1 $5 2 1 1 1 1 1 1 1 1 1 1 1 1 1 0 1 1 1 @8 CUBIT_ID 1 #
+face $10 -1 -1 $-1 $11 $12 $4 $-1 $13 reversed single T -5 -5 -5 5 5 -5 F #
+loop $-1 -1 -1 $-1 $-1 $14 $5 T -5 -5 5 5 5 5 unknown #
+plane-surface $-1 -1 -1 $-1 0 0 5 0 0 1 1 0 0 forward_v I I I I #
+integer_attrib-name_attrib-gen-attrib $-1 -1 $-1 $-1 $7 2 1 1 1 1 1 1 1 1 1 1 1 1 1 0 1 1 1 @8 CUBIT_ID 2 #
+face $15 -1 -1 $-1 $16 $17 $4 $-1 $18 reversed single T -5 -5 -5 5 -5 5 F #
+loop $-1 -1 -1 $-1 $-1 $19 $7 T -5 -5 -5 5 5 -5 unknown #
+plane-surface $-1 -1 -1 $-1 0 0 -5 0 0 1 1 0 0 forward_v I I I I #
+coedge $-1 -1 -1 $-1 $20 $21 $22 $23 forward $8 $-1 #
+integer_attrib-name_attrib-gen-attrib $-1 -1 $-1 $-1 $11 2 1 1 1 1 1 1 1 1 1 1 1 1 1 0 1 1 1 @8 CUBIT_ID 3 #
+face $24 -1 -1 $-1 $25 $26 $4 $-1 $27 reversed single T -5 -5 -5 -5 5 5 F #
+loop $-1 -1 -1 $-1 $-1 $28 $11 T -5 -5 -5 5 -5 5 unknown #
+plane-surface $-1 -1 -1 $-1 0 -5 0 0 1 -0 -0 0 1 forward_v I I I I #
+coedge $-1 -1 -1 $-1 $29 $30 $31 $32 forward $12 $-1 #
+coedge $-1 -1 -1 $-1 $33 $14 $34 $35 forward $8 $-1 #
+coedge $-1 -1 -1 $-1 $14 $33 $36 $37 forward $8 $-1 #
+coedge $-1 -1 -1 $-1 $38 $39 $14 $23 reversed $40 $-1 #
+edge $41 -1 -1 $-1 $42 -5 $43 5 $22 $44 forward @7 unknown T 5 -5 5 5 5 5 #
+integer_attrib-name_attrib-gen-attrib $-1 -1 $-1 $-1 $16 2 1 1 1 1 1 1 1 1 1 1 1 1 1 0 1 1 1 @8 CUBIT_ID 4 #
+face $45 -1 -1 $-1 $46 $47 $4 $-1 $48 reversed single T -5 5 -5 5 5 5 F #
+loop $-1 -1 -1 $-1 $-1 $49 $16 T -5 -5 -5 -5 5 5 unknown #
+plane-surface $-1 -1 -1 $-1 -5 0 0 1 0 0 0 0 -1 forward_v I I I I #
+coedge $-1 -1 -1 $-1 $50 $36 $51 $52 forward $17 $-1 #
+coedge $-1 -1 -1 $-1 $53 $19 $50 $54 forward $12 $-1 #
+coedge $-1 -1 -1 $-1 $19 $53 $55 $56 forward $12 $-1 #
+coedge $-1 -1 -1 $-1 $39 $38 $19 $32 reversed $40 $-1 #
+edge $57 -1 -1 $-1 $58 -5 $59 5 $31 $60 forward @7 unknown T 5 -5 -5 5 5 -5 #
+coedge $-1 -1 -1 $-1 $21 $20 $61 $62 forward $8 $-1 #
+coedge $-1 -1 -1 $-1 $63 $64 $20 $35 reversed $47 $-1 #
+edge $65 -1 -1 $-1 $43 -5 $66 5 $34 $67 forward @7 unknown T -5 5 5 5 5 5 #
+coedge $-1 -1 -1 $-1 $28 $68 $21 $37 reversed $17 $-1 #
+edge $69 -1 -1 $-1 $70 -5 $42 5 $36 $71 forward @7 unknown T -5 -5 5 5 -5 5 #
+coedge $-1 -1 -1 $-1 $31 $22 $68 $72 forward $40 $-1 #
+coedge $-1 -1 -1 $-1 $22 $31 $63 $73 reversed $40 $-1 #
+loop $-1 -1 -1 $-1 $-1 $38 $46 T 5 -5 -5 5 5 5 unknown #
+integer_attrib-name_attrib-gen-attrib $-1 -1 $-1 $-1 $23 2 1 1 1 1 1 1 1 1 1 1 1 1 1 0 1 1 1 @8 CUBIT_ID 1 #
+vertex $74 -1 -1 $-1 $23 $75 #
+vertex $76 -1 -1 $-1 $23 $77 #
+straight-curve $-1 -1 -1 $-1 5 0 5 0 1 0 I I #
+integer_attrib-name_attrib-gen-attrib $-1 -1 $-1 $-1 $25 2 1 1 1 1 1 1 1 1 1 1 1 1 1 0 1 1 1 @8 CUBIT_ID 5 #
+face $78 -1 -1 $-1 $-1 $40 $4 $-1 $79 reversed single T 5 -5 -5 5 5 5 F #
+loop $-1 -1 -1 $-1 $-1 $63 $25 T -5 5 -5 5 5 5 unknown #
+plane-surface $-1 -1 -1 $-1 0 5 0 0 -1 0 0 0 -1 forward_v I I I I #
+coedge $-1 -1 -1 $-1 $80 $61 $64 $81 forward $26 $-1 #
+coedge $-1 -1 -1 $-1 $68 $28 $29 $54 reversed $17 $-1 #
+coedge $-1 -1 -1 $-1 $61 $80 $28 $52 reversed $26 $-1 #
+edge $82 -1 -1 $-1 $70 -5 $83 5 $51 $84 forward @7 unknown T -5 -5 -5 -5 -5 5 #
+coedge $-1 -1 -1 $-1 $30 $29 $80 $85 forward $12 $-1 #
+edge $86 -1 -1 $-1 $59 -5 $83 5 $50 $87 forward @7 unknown T -5 -5 -5 5 -5 -5 #
+coedge $-1 -1 -1 $-1 $64 $63 $30 $56 reversed $47 $-1 #
+edge $88 -1 -1 $-1 $89 -5 $58 5 $55 $90 forward @7 unknown T -5 5 -5 5 5 -5 #
+integer_attrib-name_attrib-gen-attrib $-1 -1 $-1 $-1 $32 2 1 1 1 1 1 1 1 1 1 1 1 1 1 0 1 1 1 @8 CUBIT_ID 5 #
+vertex $91 -1 -1 $-1 $32 $92 #
+vertex $93 -1 -1 $-1 $72 $94 #
+straight-curve $-1 -1 -1 $-1 5 0 -5 0 -1 0 I I #
+coedge $-1 -1 -1 $-1 $49 $51 $33 $62 reversed $26 $-1 #
+edge $95 -1 -1 $-1 $66 -5 $70 5 $61 $96 forward @7 unknown T -5 -5 5 -5 5 5 #
+coedge $-1 -1 -1 $-1 $55 $34 $39 $73 forward $47 $-1 #
+coedge $-1 -1 -1 $-1 $34 $55 $49 $81 reversed $47 $-1 #
+integer_attrib-name_attrib-gen-attrib $-1 -1 $-1 $-1 $35 2 1 1 1 1 1 1 1 1 1 1 1 1 1 0 1 1 1 @8 CUBIT_ID 2 #
+vertex $97 -1 -1 $-1 $35 $98 #
+straight-curve $-1 -1 -1 $-1 0 5 5 -1 0 0 I I #
+coedge $-1 -1 -1 $-1 $36 $50 $38 $72 reversed $17 $-1 #
+integer_attrib-name_attrib-gen-attrib $-1 -1 $-1 $-1 $37 2 1 1 1 1 1 1 1 1 1 1 1 1 1 0 1 1 1 @8 CUBIT_ID 4 #
+vertex $99 -1 -1 $-1 $62 $100 #
+straight-curve $-1 -1 -1 $-1 0 -5 5 1 0 0 I I #
+edge $101 -1 -1 $-1 $42 -5 $59 5 $38 $102 forward @7 unknown T 5 -5 -5 5 -5 5 #
+edge $103 -1 -1 $-1 $43 -5 $58 5 $39 $104 forward @7 unknown T 5 5 -5 5 5 5 #
+integer_attrib-name_attrib-gen-attrib $-1 -1 $-1 $-1 $42 2 1 1 1 1 1 1 1 1 1 1 1 1 1 0 1 1 1 @8 CUBIT_ID 1 #
+point $-1 -1 -1 $-1 5 -5 5 #
+integer_attrib-name_attrib-gen-attrib $-1 -1 $-1 $-1 $43 2 1 1 1 1 1 1 1 1 1 1 1 1 1 0 1 1 1 @8 CUBIT_ID 2 #
+point $-1 -1 -1 $-1 5 5 5 #
+integer_attrib-name_attrib-gen-attrib $-1 -1 $-1 $-1 $46 2 1 1 1 1 1 1 1 1 1 1 1 1 1 0 1 1 1 @8 CUBIT_ID 6 #
+plane-surface $-1 -1 -1 $-1 5 0 0 -1 0 0 0 -0 1 forward_v I I I I #
+coedge $-1 -1 -1 $-1 $51 $49 $53 $85 reversed $26 $-1 #
+edge $105 -1 -1 $-1 $66 -5 $89 5 $64 $106 forward @7 unknown T -5 5 -5 -5 5 5 #
+integer_attrib-name_attrib-gen-attrib $-1 -1 $-1 $-1 $52 2 1 1 1 1 1 1 1 1 1 1 1 1 1 0 1 1 1 @8 CUBIT_ID 9 #
+vertex $107 -1 -1 $-1 $85 $108 #
+straight-curve $-1 -1 -1 $-1 -5 -5 0 0 0 -1 I I #
+edge $109 -1 -1 $-1 $83 -5 $89 5 $80 $110 forward @7 unknown T -5 -5 -5 -5 5 -5 #
+integer_attrib-name_attrib-gen-attrib $-1 -1 $-1 $-1 $54 2 1 1 1 1 1 1 1 1 1 1 1 1 1 0 1 1 1 @8 CUBIT_ID 6 #
+straight-curve $-1 -1 -1 $-1 0 -5 -5 -1 0 0 I I #
+integer_attrib-name_attrib-gen-attrib $-1 -1 $-1 $-1 $56 2 1 1 1 1 1 1 1 1 1 1 1 1 1 0 1 1 1 @8 CUBIT_ID 8 #
+vertex $111 -1 -1 $-1 $56 $112 #
+straight-curve $-1 -1 -1 $-1 0 5 -5 1 0 0 I I #
+integer_attrib-name_attrib-gen-attrib $-1 -1 $-1 $-1 $58 2 1 1 1 1 1 1 1 1 1 1 1 1 1 0 1 1 1 @8 CUBIT_ID 5 #
+point $-1 -1 -1 $-1 5 5 -5 #
+integer_attrib-name_attrib-gen-attrib $-1 -1 $-1 $-1 $59 2 1 1 1 1 1 1 1 1 1 1 1 1 1 0 1 1 1 @8 CUBIT_ID 6 #
+point $-1 -1 -1 $-1 5 -5 -5 #
+integer_attrib-name_attrib-gen-attrib $-1 -1 $-1 $-1 $62 2 1 1 1 1 1 1 1 1 1 1 1 1 1 0 1 1 1 @8 CUBIT_ID 3 #
+straight-curve $-1 -1 -1 $-1 -5 0 5 0 -1 0 I I #
+integer_attrib-name_attrib-gen-attrib $-1 -1 $-1 $-1 $66 2 1 1 1 1 1 1 1 1 1 1 1 1 1 0 1 1 1 @8 CUBIT_ID 3 #
+point $-1 -1 -1 $-1 -5 5 5 #
+integer_attrib-name_attrib-gen-attrib $-1 -1 $-1 $-1 $70 2 1 1 1 1 1 1 1 1 1 1 1 1 1 0 1 1 1 @8 CUBIT_ID 4 #
+point $-1 -1 -1 $-1 -5 -5 5 #
+integer_attrib-name_attrib-gen-attrib $-1 -1 $-1 $-1 $72 2 1 1 1 1 1 1 1 1 1 1 1 1 1 0 1 1 1 @8 CUBIT_ID 10 #
+straight-curve $-1 -1 -1 $-1 5 -5 0 0 0 -1 I I #
+integer_attrib-name_attrib-gen-attrib $-1 -1 $-1 $-1 $73 2 1 1 1 1 1 1 1 1 1 1 1 1 1 0 1 1 1 @8 CUBIT_ID 12 #
+straight-curve $-1 -1 -1 $-1 5 5 0 0 0 -1 I I #
+integer_attrib-name_attrib-gen-attrib $-1 -1 $-1 $-1 $81 2 1 1 1 1 1 1 1 1 1 1 1 1 1 0 1 1 1 @8 CUBIT_ID 11 #
+straight-curve $-1 -1 -1 $-1 -5 5 0 0 0 -1 I I #
+integer_attrib-name_attrib-gen-attrib $-1 -1 $-1 $-1 $83 2 1 1 1 1 1 1 1 1 1 1 1 1 1 0 1 1 1 @8 CUBIT_ID 7 #
+point $-1 -1 -1 $-1 -5 -5 -5 #
+integer_attrib-name_attrib-gen-attrib $-1 -1 $-1 $-1 $85 2 1 1 1 1 1 1 1 1 1 1 1 1 1 0 1 1 1 @8 CUBIT_ID 7 #
+straight-curve $-1 -1 -1 $-1 -5 0 -5 0 1 0 I I #
+integer_attrib-name_attrib-gen-attrib $-1 -1 $-1 $-1 $89 2 1 1 1 1 1 1 1 1 1 1 1 1 1 0 1 1 1 @8 CUBIT_ID 8 #
+point $-1 -1 -1 $-1 -5 5 -5 #
+End-of-ACIS-data
\ No newline at end of file
diff --git a/MeshFiles/unittest/io/cube.stp b/MeshFiles/unittest/io/cube.stp
index 0000000..c17645d
--- /dev/null
+++ b/MeshFiles/unittest/io/cube.stp
@@ -0,0 +1,185 @@
+ISO-10303-21;
+HEADER;
+FILE_DESCRIPTION(('STEP AP214'),'1');
+FILE_NAME('/home/iulian/source/MOABsource/MeshFiles/unittest/io/cube.stp','2014-02-11T15:06:47',(' '),(' '),'Spatial InterOp 3D',' ',' ');
+FILE_SCHEMA(('automotive_design'));
+ENDSEC;
+DATA;
+#1=PRODUCT_DEFINITION_CONTEXT('',#9,'design');
+#2=APPLICATION_PROTOCOL_DEFINITION('INTERNATIONAL STANDARD','automotive_design',1994,#9);
+#3=PRODUCT_CATEGORY_RELATIONSHIP('NONE','NONE',#10,#11);
+#4=SHAPE_DEFINITION_REPRESENTATION(#12,#13);
+#5= (GEOMETRIC_REPRESENTATION_CONTEXT(3)GLOBAL_UNCERTAINTY_ASSIGNED_CONTEXT((#16))GLOBAL_UNIT_ASSIGNED_CONTEXT((#18,#19,#20))REPRESENTATION_CONTEXT('NONE','WORKSPACE'));
+#9=APPLICATION_CONTEXT(' ');
+#10=PRODUCT_CATEGORY('part','NONE');
+#11=PRODUCT_RELATED_PRODUCT_CATEGORY('detail',' ',(#22));
+#12=PRODUCT_DEFINITION_SHAPE('NONE','NONE',#23);
+#13=ADVANCED_BREP_SHAPE_REPRESENTATION('1',(#24,#25),#5);
+#16=UNCERTAINTY_MEASURE_WITH_UNIT(LENGTH_MEASURE(1.0E-06),#18,'','');
+#18= (CONVERSION_BASED_UNIT('MILLIMETRE',#28)LENGTH_UNIT()NAMED_UNIT(#31));
+#19= (NAMED_UNIT(#33)PLANE_ANGLE_UNIT()SI_UNIT($,.RADIAN.));
+#20= (NAMED_UNIT(#33)SOLID_ANGLE_UNIT()SI_UNIT($,.STERADIAN.));
+#22=PRODUCT('1','1','PART-1-DESC',(#39));
+#23=PRODUCT_DEFINITION('NONE','NONE',#40,#1);
+#24=MANIFOLD_SOLID_BREP('1',#41);
+#25=AXIS2_PLACEMENT_3D('',#42,#43,#44);
+#28=LENGTH_MEASURE_WITH_UNIT(LENGTH_MEASURE(1.0),#45);
+#31=DIMENSIONAL_EXPONENTS(1.0,0.0,0.0,0.0,0.0,0.0,0.0);
+#33=DIMENSIONAL_EXPONENTS(0.0,0.0,0.0,0.0,0.0,0.0,0.0);
+#39=PRODUCT_CONTEXT('',#9,'mechanical');
+#40=PRODUCT_DEFINITION_FORMATION_WITH_SPECIFIED_SOURCE(' ','NONE',#22,.NOT_KNOWN.);
+#41=CLOSED_SHELL('',(#46,#47,#48,#49,#50,#51));
+#42=CARTESIAN_POINT('',(0.0,0.0,0.0));
+#43=DIRECTION('',(0.0,0.0,1.0));
+#44=DIRECTION('',(1.0,0.0,0.0));
+#45= (NAMED_UNIT(#31)LENGTH_UNIT()SI_UNIT(.MILLI.,.METRE.));
+#46=ADVANCED_FACE('',(#53),#54,.T.);
+#47=ADVANCED_FACE('',(#55),#56,.F.);
+#48=ADVANCED_FACE('',(#57),#58,.F.);
+#49=ADVANCED_FACE('',(#59),#60,.F.);
+#50=ADVANCED_FACE('',(#61),#62,.F.);
+#51=ADVANCED_FACE('',(#63),#64,.F.);
+#53=FACE_OUTER_BOUND('',#65,.T.);
+#54=PLANE('',#66);
+#55=FACE_OUTER_BOUND('',#67,.T.);
+#56=PLANE('',#68);
+#57=FACE_OUTER_BOUND('',#69,.T.);
+#58=PLANE('',#70);
+#59=FACE_OUTER_BOUND('',#71,.T.);
+#60=PLANE('',#72);
+#61=FACE_OUTER_BOUND('',#73,.T.);
+#62=PLANE('',#74);
+#63=FACE_OUTER_BOUND('',#75,.T.);
+#64=PLANE('',#76);
+#65=EDGE_LOOP('',(#77,#78,#79,#80));
+#66=AXIS2_PLACEMENT_3D('',#81,#82,#83);
+#67=EDGE_LOOP('',(#84,#85,#86,#87));
+#68=AXIS2_PLACEMENT_3D('',#88,#89,#90);
+#69=EDGE_LOOP('',(#91,#92,#93,#94));
+#70=AXIS2_PLACEMENT_3D('',#95,#96,#97);
+#71=EDGE_LOOP('',(#98,#99,#100,#101));
+#72=AXIS2_PLACEMENT_3D('',#102,#103,#104);
+#73=EDGE_LOOP('',(#105,#106,#107,#108));
+#74=AXIS2_PLACEMENT_3D('',#109,#110,#111);
+#75=EDGE_LOOP('',(#112,#113,#114,#115));
+#76=AXIS2_PLACEMENT_3D('',#116,#117,#118);
+#77=ORIENTED_EDGE('',*,*,#119,.T.);
+#78=ORIENTED_EDGE('',*,*,#120,.T.);
+#79=ORIENTED_EDGE('',*,*,#121,.T.);
+#80=ORIENTED_EDGE('',*,*,#122,.T.);
+#81=CARTESIAN_POINT('',(0.0,0.0,5.0));
+#82=DIRECTION('',(0.0,0.0,1.0));
+#83=DIRECTION('',(1.0,0.0,0.0));
+#84=ORIENTED_EDGE('',*,*,#123,.T.);
+#85=ORIENTED_EDGE('',*,*,#124,.T.);
+#86=ORIENTED_EDGE('',*,*,#125,.T.);
+#87=ORIENTED_EDGE('',*,*,#126,.T.);
+#88=CARTESIAN_POINT('',(0.0,0.0,-5.0));
+#89=DIRECTION('',(0.0,0.0,1.0));
+#90=DIRECTION('',(1.0,0.0,0.0));
+#91=ORIENTED_EDGE('',*,*,#127,.T.);
+#92=ORIENTED_EDGE('',*,*,#124,.F.);
+#93=ORIENTED_EDGE('',*,*,#128,.F.);
+#94=ORIENTED_EDGE('',*,*,#122,.F.);
+#95=CARTESIAN_POINT('',(0.0,-5.0,0.0));
+#96=DIRECTION('',(0.0,1.0,-0.0));
+#97=DIRECTION('',(-0.0,0.0,1.0));
+#98=ORIENTED_EDGE('',*,*,#129,.T.);
+#99=ORIENTED_EDGE('',*,*,#125,.F.);
+#100=ORIENTED_EDGE('',*,*,#127,.F.);
+#101=ORIENTED_EDGE('',*,*,#121,.F.);
+#102=CARTESIAN_POINT('',(-5.0,0.0,0.0));
+#103=DIRECTION('',(1.0,0.0,0.0));
+#104=DIRECTION('',(0.0,0.0,-1.0));
+#105=ORIENTED_EDGE('',*,*,#130,.T.);
+#106=ORIENTED_EDGE('',*,*,#126,.F.);
+#107=ORIENTED_EDGE('',*,*,#129,.F.);
+#108=ORIENTED_EDGE('',*,*,#120,.F.);
+#109=CARTESIAN_POINT('',(0.0,5.0,0.0));
+#110=DIRECTION('',(0.0,-1.0,0.0));
+#111=DIRECTION('',(0.0,0.0,-1.0));
+#112=ORIENTED_EDGE('',*,*,#128,.T.);
+#113=ORIENTED_EDGE('',*,*,#123,.F.);
+#114=ORIENTED_EDGE('',*,*,#130,.F.);
+#115=ORIENTED_EDGE('',*,*,#119,.F.);
+#116=CARTESIAN_POINT('',(5.0,0.0,0.0));
+#117=DIRECTION('',(-1.0,0.0,0.0));
+#118=DIRECTION('',(0.0,-0.0,1.0));
+#119=EDGE_CURVE('',#131,#132,#133,.T.);
+#120=EDGE_CURVE('',#132,#134,#135,.T.);
+#121=EDGE_CURVE('',#134,#136,#137,.T.);
+#122=EDGE_CURVE('',#136,#131,#138,.T.);
+#123=EDGE_CURVE('',#139,#140,#141,.T.);
+#124=EDGE_CURVE('',#140,#142,#143,.T.);
+#125=EDGE_CURVE('',#142,#144,#145,.T.);
+#126=EDGE_CURVE('',#144,#139,#146,.T.);
+#127=EDGE_CURVE('',#136,#142,#147,.T.);
+#128=EDGE_CURVE('',#131,#140,#148,.T.);
+#129=EDGE_CURVE('',#134,#144,#149,.T.);
+#130=EDGE_CURVE('',#132,#139,#150,.T.);
+#131=VERTEX_POINT('',#151);
+#132=VERTEX_POINT('',#152);
+#133=LINE('',#153,#154);
+#134=VERTEX_POINT('',#155);
+#135=LINE('',#156,#157);
+#136=VERTEX_POINT('',#158);
+#137=LINE('',#159,#160);
+#138=LINE('',#161,#162);
+#139=VERTEX_POINT('',#163);
+#140=VERTEX_POINT('',#164);
+#141=LINE('',#165,#166);
+#142=VERTEX_POINT('',#167);
+#143=LINE('',#168,#169);
+#144=VERTEX_POINT('',#170);
+#145=LINE('',#171,#172);
+#146=LINE('',#173,#174);
+#147=LINE('',#175,#176);
+#148=LINE('',#177,#178);
+#149=LINE('',#179,#180);
+#150=LINE('',#181,#182);
+#151=CARTESIAN_POINT('',(5.0,-5.0,5.0));
+#152=CARTESIAN_POINT('',(5.0,5.0,5.0));
+#153=CARTESIAN_POINT('',(5.0,0.0,5.0));
+#154=VECTOR('',#183,1.0);
+#155=CARTESIAN_POINT('',(-5.0,5.0,5.0));
+#156=CARTESIAN_POINT('',(0.0,5.0,5.0));
+#157=VECTOR('',#184,1.0);
+#158=CARTESIAN_POINT('',(-5.0,-5.0,5.0));
+#159=CARTESIAN_POINT('',(-5.0,0.0,5.0));
+#160=VECTOR('',#185,1.0);
+#161=CARTESIAN_POINT('',(0.0,-5.0,5.0));
+#162=VECTOR('',#186,1.0);
+#163=CARTESIAN_POINT('',(5.0,5.0,-5.0));
+#164=CARTESIAN_POINT('',(5.0,-5.0,-5.0));
+#165=CARTESIAN_POINT('',(5.0,0.0,-5.0));
+#166=VECTOR('',#187,1.0);
+#167=CARTESIAN_POINT('',(-5.0,-5.0,-5.0));
+#168=CARTESIAN_POINT('',(0.0,-5.0,-5.0));
+#169=VECTOR('',#188,1.0);
+#170=CARTESIAN_POINT('',(-5.0,5.0,-5.0));
+#171=CARTESIAN_POINT('',(-5.0,0.0,-5.0));
+#172=VECTOR('',#189,1.0);
+#173=CARTESIAN_POINT('',(0.0,5.0,-5.0));
+#174=VECTOR('',#190,1.0);
+#175=CARTESIAN_POINT('',(-5.0,-5.0,0.0));
+#176=VECTOR('',#191,1.0);
+#177=CARTESIAN_POINT('',(5.0,-5.0,0.0));
+#178=VECTOR('',#192,1.0);
+#179=CARTESIAN_POINT('',(-5.0,5.0,0.0));
+#180=VECTOR('',#193,1.0);
+#181=CARTESIAN_POINT('',(5.0,5.0,0.0));
+#182=VECTOR('',#194,1.0);
+#183=DIRECTION('',(0.0,1.0,0.0));
+#184=DIRECTION('',(-1.0,0.0,0.0));
+#185=DIRECTION('',(0.0,-1.0,0.0));
+#186=DIRECTION('',(1.0,0.0,0.0));
+#187=DIRECTION('',(0.0,-1.0,0.0));
+#188=DIRECTION('',(-1.0,0.0,0.0));
+#189=DIRECTION('',(0.0,1.0,0.0));
+#190=DIRECTION('',(1.0,0.0,0.0));
+#191=DIRECTION('',(0.0,0.0,-1.0));
+#192=DIRECTION('',(0.0,0.0,-1.0));
+#193=DIRECTION('',(0.0,0.0,-1.0));
+#194=DIRECTION('',(0.0,0.0,-1.0));
+ENDSEC;
+END-ISO-10303-21;
diff --git a/config/compiler.m4 b/config/compiler.m4
index ce83a5f..4787100 100644
--- a/config/compiler.m4
+++ b/config/compiler.m4
@@ -548,6 +548,8 @@ case "$cc_compiler:$host_cpu" in
       bgq)
         FATHOM_CC_32BIT=-q32
         FATHOM_CC_64BIT=-q64
+	FATHOM_CC_SPECIAL=-qarch=qp
+	FATHOM_CXX_SPECIAL="-qarch=qp -qpic=large -qmaxmem=-1"
         AR="ar"
         NM="nm -B"
diff --git a/examples/makefile b/examples/makefile
index a6e3d1f..6c1ed9a 100644
--- a/examples/makefile
+++ b/examples/makefile
@@ -36,7 +36,7 @@ DirectAccessNoHoles: DirectAccessNoHoles.o ${MOAB_LIBDIR}/libMOAB.la
 	${MOAB_CXX} -o $@ $< ${MOAB_LIBS_LINK}
 DirectAccessNoHolesF90: DirectAccessNoHolesF90.o ${MOAB_LIBDIR}/libMOAB.la
-	${MOAB_CXX} -o $@ $< ${IMESH_LIBS}
+	${MOAB_FC} -o $@ $< ${IMESH_LIBS}
 ReduceExchangeTags : ReduceExchangeTags.o ${MOAB_LIBDIR}/libMOAB.la
@@ -51,7 +51,7 @@ point_in_elem_search: point_in_elem_search.o ${MOAB_LIBDIR}/libMOAB.la
 PushParMeshIntoMoabF90: PushParMeshIntoMoabF90.o
-	${MOAB_CXX} -o $@ $< ${IMESH_LIBS} -lgfortran -L/usr/lib/openmpi/lib -lmpi_f90 -lmpi_f77 -lmpi -lopen-rte -lopen-pal -ldl
 DeformMeshRemap: DeformMeshRemap.o ${MOAB_LIBDIR}/libMOAB.la
 	${MOAB_CXX} -o $@ $< ${MOAB_LIBS_LINK} -lmbcoupler ${MOAB_LIBS_LINK}
diff --git a/examples/point_in_elem_search.cpp b/examples/point_in_elem_search.cpp
index a917fa0..ce22928 100644
--- a/examples/point_in_elem_search.cpp
+++ b/examples/point_in_elem_search.cpp
@@ -27,7 +27,7 @@ int main(int argc, char **argv) {
   int num_queries = 1000000;
-  if (argc == 1) {
+  if (argc < 2 || argc > 3) {
     std::cout << "Usage: " << argv[0] << "<filename> [num_queries]" << std::endl;
     return 0;
@@ -37,7 +37,7 @@ int main(int argc, char **argv) {
   moab::Core mb;
     // load the file
-  ErrorCode rval = mb.load_file(argv[argc-1]); ERR("Error loading file");
+  ErrorCode rval = mb.load_file(argv[1]); ERR("Error loading file");
     // get all 3d elements in the file
   Range elems;
@@ -66,7 +66,7 @@ int main(int argc, char **argv) {
   for (int i = 0; i < num_queries; i++) {
     pos = box.bMin +
         CartVect(box_extents[0]*.01*(rand()%100), box_extents[1]*.01*(rand()%100), box_extents[2]*.01*(rand()%100));
-    ErrorCode tmp_rval = sl.locate_point(pos.array(), elem, params.array(), 0.0, 0.0, &is_inside);
+    ErrorCode tmp_rval = sl.locate_point(pos.array(), elem, params.array(), &is_inside, 0.0, 0.0);
     if (MB_SUCCESS != tmp_rval) rval = tmp_rval;
     if (is_inside) num_inside++;
diff --git a/src/CMakeLists.txt b/src/CMakeLists.txt
index 280b203..40f7a59 100644
--- a/src/CMakeLists.txt
+++ b/src/CMakeLists.txt
@@ -7,6 +7,7 @@
     AxisBox.cpp
     BitPage.cpp
     BitTag.cpp
+    BoundBox.cpp
     BSPTree.cpp
     BSPTreePoly.cpp
     CN.cpp
@@ -46,6 +47,8 @@
     SweptVertexData.cpp
     SysUtil.cpp
     TagInfo.cpp
+    Tree.cpp
+    TupleList.cpp
     Types.cpp
     TypeSequenceManager.cpp
     UnstructuredElemSeq.cpp
@@ -93,14 +96,27 @@
     io/WriteVtk.cpp
     ReaderWriterSet.cpp
+  set ( MOABLD_LIB_SRCS
+    LocalDiscretization/ElemEvaluator.cpp
+    LocalDiscretization/LinearHex.cpp
+    LocalDiscretization/LinearQuad.cpp
+    LocalDiscretization/LinearTet.cpp
+    LocalDiscretization/LinearTri.cpp
+    LocalDiscretization/QuadraticHex.cpp
+#    LocalDiscretization/SpectralHex.cpp
+#    LocalDiscretization/SpectralQuad.cpp
   include_directories(
-    ${MOAB_BINARY_DIR}
     ${MOAB_SOURCE_DIR}/src
-    ${MOAB_BINARY_DIR}/src
     ${MOAB_SOURCE_DIR}/src/io
     ${MOAB_SOURCE_DIR}/src/parallel
-    ${MOAB_BINARY_DIR}/src/parallel
+    ${MOAB_SOURCE_DIR}/src/LocalDiscretization
     ${MOAB_SOURCE_DIR}/src/moab/point_locater/lotte
+    ${MOAB_BINARY_DIR}
+    ${MOAB_BINARY_DIR}/src
+    ${MOAB_BINARY_DIR}/src/parallel
   if ( NetCDF_FOUND )
@@ -143,7 +159,7 @@
   endif ( HDF5_FOUND )
-  SET(MOAB_LIB_SRCS ${MOABCORE_LIB_SRCS} ${MOABPTLOC_LIB_SRCS} ${MOABIO_LIB_SRCS})
+  SET(MOAB_LIB_SRCS ${MOABCORE_LIB_SRCS} ${MOABPTLOC_LIB_SRCS} ${MOABIO_LIB_SRCS} ${MOABLD_LIB_SRCS})
   set_source_files_properties( ${MOAB_LIB_SRCS}
     COMPILE_FLAGS "-DIS_BUILDING_MB ${MOAB_DEFINES}"
diff --git a/src/Makefile.am b/src/Makefile.am
index 0d474b0..5772d12 100644
--- a/src/Makefile.am
+++ b/src/Makefile.am
@@ -124,6 +124,7 @@ libMOAB_la_SOURCES = \
   TagInfo.cpp \
   TagInfo.hpp \
   Tree.cpp \
+  TupleList.cpp \
   Types.cpp \
   TypeSequenceManager.cpp \
   TypeSequenceManager.hpp \
@@ -195,9 +196,11 @@ nobase_libMOAB_la_include_HEADERS = \
   moab/SpectralMeshTool.hpp \
   moab/Tree.hpp \
   moab/TreeStats.hpp \
+  moab/TupleList.hpp \
   moab/Types.hpp \
   moab/UnknownInterface.hpp \
   moab/Util.hpp \
+  moab/Version.h \
   moab/WriteUtilIface.hpp \
   moab/WriterIface.hpp \
   MBEntityType.h \
diff --git a/src/SpatialLocator.cpp b/src/SpatialLocator.cpp
index ae124dc..694122c 100644
--- a/src/SpatialLocator.cpp
+++ b/src/SpatialLocator.cpp
@@ -319,7 +319,7 @@ namespace moab
       locTable.enableWriteAccess();
         // pass storage directly into locate_points, since we know those arrays are contiguous
-      ErrorCode rval = locate_points(pos, num_points, locTable.vul_wr, locTable.vr_wr, NULL, rel_iter_tol, abs_iter_tol,
+      ErrorCode rval = locate_points(pos, num_points, (EntityHandle*)locTable.vul_wr, locTable.vr_wr, NULL, rel_iter_tol, abs_iter_tol,
                                      inside_tol);
       std::fill(locTable.vi_wr, locTable.vi_wr+num_points, 0);
       locTable.set_n(num_points);
diff --git a/src/TupleList.cpp b/src/TupleList.cpp
index 0000000..bf08946
--- /dev/null
+++ b/src/TupleList.cpp
@@ -0,0 +1,860 @@
+#include <string.h>
+#include <limits.h>
+#include <stdio.h>
+#include <stdlib.h>
+#include <stdarg.h>
+#include <iostream>
+#include "moab/TupleList.hpp"
+namespace moab {
+void fail(const char *fmt, ...)
+  va_list ap;
+  va_start(ap, fmt);
+  vfprintf(stderr, fmt, ap);
+  va_end(ap);
+  exit(1);
+TupleList::buffer::buffer(size_t sz)
+  ptr = NULL;
+  buffSize = 0;
+  this->buffer_init_(sz, __FILE__);
+TupleList::buffer::buffer()
+  buffSize = 0;
+  ptr = NULL;
+void TupleList::buffer::buffer_init_(size_t sizeIn, const char *file)
+  this->buffSize = sizeIn;
+  void *res = malloc(this->buffSize);
+  if (!res && buffSize > 0)
+    fail("%s: allocation of %d bytes failed\n", file, (int) buffSize);
+  ptr = (char*) res;
+void TupleList::buffer::buffer_reserve_(size_t min, const char *file)
+  if (this->buffSize < min)
+    size_t newSize = this->buffSize;
+    newSize += newSize / 2 + 1;
+    if (newSize < min)
+      newSize = min;
+    void *res = realloc(ptr, newSize);
+    if (!res && newSize > 0)
+      fail("%s: allocation of %d bytes failed\n", file, (int) this->buffSize);
+    this->buffSize = newSize;
+void TupleList::buffer::reset()
+  free(ptr);
+  ptr = NULL;
+  buffSize = 0;
+TupleList::TupleList(uint p_mi, uint p_ml, uint p_mul, uint p_mr, uint p_max)
+  vi = NULL;
+  vl = NULL;
+  vul = NULL;
+  vr = NULL;
+  initialize(p_mi, p_ml, p_mul, p_mr, p_max);
+TupleList::TupleList()
+  vi = NULL;
+  vl = NULL;
+  vul = NULL;
+  vr = NULL;
+  disableWriteAccess();
+// Allocates space for the tuple list in memory according to parameters
+void TupleList::initialize(uint p_mi, uint p_ml, uint p_mul, uint p_mr,
+    uint p_max)
+  this->n = 0;
+  this->max = p_max;
+  this->mi = p_mi;
+  this->ml = p_ml;
+  this->mul = p_mul;
+  this->mr = p_mr;
+  size_t sz;
+  if (max * mi > 0)
+    sz = max * mi * sizeof(sint);
+    void *resi = malloc(sz);
+    if (!resi && max * mi > 0)
+      fail("%s: allocation of %d bytes failed\n", __FILE__, (int) sz);
+    vi = (sint*) resi;
+  else
+    vi = NULL;
+  if (max * ml > 0)
+    sz = max * ml * sizeof(slong);
+    void *resl = malloc(sz);
+    if (!resl && max * ml > 0)
+    vl = (slong*) resl;
+  else
+    vl = NULL;
+  if (max * mul > 0)
+    sz = max * mul * sizeof(ulong);
+    void *resu = malloc(sz);
+    if (!resu && max * mul > 0)
+    vul = (ulong*) resu;
+  else
+    vul = NULL;
+  if (max * mr > 0)
+    sz = max * mr * sizeof(realType);
+    void *resr = malloc(sz);
+    if (!resr && max * ml > 0)
+    vr = (realType*) resr;
+  else
+    vr = NULL;
+  //Begin with write access disabled
+  this->disableWriteAccess();
+  //Set read variables
+  vi_rd = vi;
+  vl_rd = vl;
+  vul_rd = vul;
+  vr_rd = vr;
+// Resizes a tuplelist to the given uint max
+ErrorCode TupleList::resize(uint maxIn)
+  this->max = maxIn;
+  size_t sz;
+  if (vi || (max * mi > 0))
+    void *resi = realloc(vi, sz);
+      return moab::MB_MEMORY_ALLOCATION_FAILED;
+  if (vl || (max * ml > 0))
+    void *resl = realloc(vl, sz);
+  if (vul || (max * mul > 0))
+    void *resu = realloc(vul, sz);
+  if (vr || (max * mr > 0))
+    void *resr = realloc(vr, sz);
+    if (!resr && max * mr > 0)
+  vi_rd = vi;
+  vl_rd = vl;
+  vul_rd = vul;
+  vr_rd = vr;
+  //Set the write variables if necessary
+  if (writeEnabled)
+    vi_wr = vi;
+    vl_wr = vl;
+    vul_wr = vul;
+    vr_wr = vr;
+  return moab::MB_SUCCESS;
+// Frees the memory used by the tuplelist
+void TupleList::reset()
+  //free up the pointers
+  free(vi);
+  free(vl);
+  free(vul);
+  free(vr);
+  //Set them all to null
+  vr = NULL;
+  vi = NULL;
+  vul = NULL;
+  vl = NULL;
+  //Set the read and write pointers to null
+  vi_rd = NULL;
+  vl_rd = NULL;
+  vul_rd = NULL;
+  vr_rd = NULL;
+// Increments n; if n>max, increase the size of the tuplelist
+void TupleList::reserve()
+  n++;
+  while (n > max)
+    resize((max ? max + max / 2 + 1 : 2));
+  last_sorted = -1;
+// Given the value and the position in the field, finds the index of the tuple
+// to which the value belongs
+int TupleList::find(unsigned int key_num, sint value)
+  ulong uvalue = (ulong) value;
+  if (!(key_num > mi))
+    // Binary search: only if the tuple_list is sorted
+    if (last_sorted == (int) key_num)
+      int lb = 0, ub = n, index; // lb=lower bound, ub=upper bound, index=mid
+      for (; lb <= ub;)
+        index = (lb + ub) / 2;
+        if (vi[index * mi + key_num] == (long) uvalue)
+          return index;
+        else if (vi[index * mi + key_num] > (long) uvalue)
+          ub = index - 1;
+        else if (vi[index * mi + key_num] < (long) uvalue)
+          lb = index + 1;
+    else
+      // Sequential search: if tuple_list is not sorted
+      for (long index = 0; index < n; index++)
+          return index;
+  return -1; // If the value wasn't present or an invalid key was given
+int TupleList::find(unsigned int key_num, slong value)
+  if (!(key_num > ml))
+    if (last_sorted - mi == key_num)
+      for (; lb <= ub;)
+        if (vl[index * ml + key_num] == (long) uvalue)
+          return index;
+        else if (vl[index * ml + key_num] > (long) uvalue)
+          ub = index - 1;
+        else if (vl[index * ml + key_num] < (long) uvalue)
+          lb = index + 1;
+    else
+      for (uint index = 0; index < n; index++)
+          return index;
+int TupleList::find(unsigned int key_num, ulong value)
+  if (!(key_num > mul))
+    if (last_sorted - mi - ml == key_num)
+      int lb = 0, ub = n - 1, index; // lb=lower bound, ub=upper bound, index=mid
+      for (; lb <= ub;)
+        if (vul[index * mul + key_num] == value)
+          return index;
+        else if (vul[index * mul + key_num] > value)
+          ub = index - 1;
+        else if (vul[index * mul + key_num] < value)
+          lb = index + 1;
+    else
+          return index;
+int TupleList::find(unsigned int key_num, realType value)
+  if (!key_num > mr)
+    // Sequential search: TupleList cannot be sorted by reals
+      if (vr[index * mr + key_num] == value)
+        return index;
+sint TupleList::get_sint(unsigned int index, unsigned int m)
+  if (mi > m && n > index)
+    return vi[index * mi + m];
+  return 0;
+slong TupleList::get_int(unsigned int index, unsigned int m)
+  if (ml > m && n > index)
+    return vl[index * ml + m];
+  return 0;
+ulong TupleList::get_ulong(unsigned int index, unsigned int m)
+  if (mul > m && n > index)
+    return vul[index * mul + m];
+  return 0;
+realType TupleList::get_double(unsigned int index, unsigned int m)
+  if (mr > m && n > index)
+    return vr[index * mr + m];
+  return 0;
+ErrorCode TupleList::get(unsigned int index, const sint *&sp, const slong *&ip,
+    const ulong *&lp, const realType *&dp)
+  if (index <= n)
+    if (mi)
+      *&sp = &vi[index * mi];
+    else
+      *&sp = NULL;
+    if (ml)
+      *&ip = &vl[index * ml];
+    else
+      *&ip = NULL;
+    if (mul)
+      *&lp = &vul[index * mul];
+    else
+      *&lp = NULL;
+    if (mr)
+      *&dp = &vr[index * mr];
+    else
+      *&dp = NULL;
+    return MB_SUCCESS;
+  return MB_FAILURE;
+unsigned int TupleList::push_back(sint *sp, slong *ip, ulong *lp, realType *dp)
+  reserve();
+  if (mi)
+    memcpy(&vi[mi * (n - 1)], sp, mi * sizeof(sint));
+  if (ml)
+    memcpy(&vl[ml * (n - 1)], ip, ml * sizeof(long));
+  if (mul)
+    memcpy(&vul[mul * (n - 1)], lp, mul * sizeof(ulong));
+  if (mr)
+    memcpy(&vr[mr * (n - 1)], dp, mr * sizeof(realType));
+  last_sorted = -1;
+  return n - 1;
+void TupleList::enableWriteAccess()
+  writeEnabled = true;
+  last_sorted = -1;
+  vi_wr = vi;
+  vl_wr = vl;
+  vul_wr = vul;
+  vr_wr = vr;
+void TupleList::disableWriteAccess()
+  writeEnabled = false;
+  vi_wr = NULL;
+  vl_wr = NULL;
+  vul_wr = NULL;
+  vr_wr = NULL;
+void TupleList::getTupleSize(uint &mi_out, uint &ml_out, uint &mul_out,
+    uint &mr_out) const
+  mi_out = mi;
+  ml_out = ml;
+  mul_out = mul;
+  mr_out = mr;
+uint TupleList::inc_n()
+  //Check for direct write access
+  if (!writeEnabled)
+    enableWriteAccess();
+  n++;
+  return n;
+void TupleList::set_n(uint n_in)
+  //Check for direct write access;
+  n = n_in;
+void TupleList::print(const char *name) const
+  std::cout << "Printing Tuple " << name << "===================" << std::endl;
+  unsigned long i = 0, l = 0, ul = 0, r = 0;
+  for (uint k = 0; k < n; k++)
+    for (uint j = 0; j < mi; j++)
+      std::cout << vi[i++] << " | ";
+    for (uint j = 0; j < ml; j++)
+      std::cout << vl[l++] << " | ";
+    for (uint j = 0; j < mul; j++)
+      std::cout << vul[ul++] << " | ";
+    for (uint j = 0; j < mr; j++)
+      std::cout << vr[r++] << " | ";
+    std::cout << std::endl;
+  std::cout << "=======================================" << std::endl
+      << std::endl;
+void TupleList::permute(uint *perm, void *work)
+  const unsigned int_size = mi * sizeof(sint), long_size = ml * sizeof(slong),
+      ulong_size = mul * sizeof(ulong), real_size = mr * sizeof(realType);
+  if (mi)
+    uint *p = perm, *pe = p + n;
+    char *sorted = (char *) work;
+    while (p != pe)
+      memcpy((void *) sorted, &vi[mi * (*p++)], int_size), sorted += int_size;
+    memcpy(vi, work, int_size * n);
+  if (ml)
+    while (p != pe)
+      memcpy((void *) sorted, &vl[ml * (*p++)], long_size), sorted += long_size;
+    memcpy(vl, work, long_size * n);
+  if (mul)
+    while (p != pe)
+      memcpy((void *) sorted, &vul[mul * (*p++)], ulong_size), sorted +=
+          ulong_size;
+    memcpy(vul, work, ulong_size * n);
+  if (mr)
+    while (p != pe)
+      memcpy((void *) sorted, &vr[mr * (*p++)], real_size), sorted += real_size;
+    memcpy(vr, work, real_size * n);
+# define umax_2(a, b) (((a)>(b)) ? (a):(b))
+ErrorCode TupleList::sort(uint key, TupleList::buffer *buf)
+  const unsigned int_size = mi * sizeof(sint);
+  const unsigned long_size = ml * sizeof(slong);
+  const unsigned ulong_size = mul * sizeof(ulong);
+  const unsigned real_size = mr * sizeof(realType);
+  const unsigned width = umax_2(umax_2(int_size,long_size),
+      umax_2(ulong_size,real_size));
+  const unsigned data_size =
+      key >= mi ? sizeof(SortData<long> ) : sizeof(SortData<uint> );
+  uint work_min = n * umax_2(2*data_size,sizeof(sint)+width);
+  uint *work;
+  buf->buffer_reserve(work_min);
+  work = (uint *) buf->ptr;
+  if (key < mi)
+    index_sort((uint *) &vi[key], n, mi, work, (SortData<uint>*) work);
+  else if (key < mi + ml)
+    index_sort((long*) &vl[key - mi], n, ml, work, (SortData<long>*) work);
+  else if (key < mi + ml + mul)
+    index_sort((ulong*) &vul[key - mi - ml], n, mul, work,
+        (SortData<ulong>*) work);
+  else
+    return MB_NOT_IMPLEMENTED;
+  permute(work, work + n);
+    last_sorted = key;
+#undef umax_2
+#define DIGIT_BITS   8
+#define DIGIT_VALUES (1<<DIGIT_BITS)
+#define DIGIT_MASK   ((Value)(DIGIT_VALUES-1))
+#define CEILDIV(a,b) (((a)+(b)-1)/(b))
+#define DIGITS       CEILDIV(CHAR_BIT*sizeof(Value),DIGIT_BITS)
+#define VALUE_BITS   (DIGIT_BITS*DIGITS)
+#define COUNT_SIZE   (DIGITS*DIGIT_VALUES)
+/* used to unroll a tiny loop: */
+#define COUNT_DIGIT_01(n,i) \
+    if(n>i) count[i][val&DIGIT_MASK]++, val>>=DIGIT_BITS
+#define COUNT_DIGIT_02(n,i) COUNT_DIGIT_01(n,i); COUNT_DIGIT_01(n,i+ 1)
+#define COUNT_DIGIT_04(n,i) COUNT_DIGIT_02(n,i); COUNT_DIGIT_02(n,i+ 2)
+#define COUNT_DIGIT_08(n,i) COUNT_DIGIT_04(n,i); COUNT_DIGIT_04(n,i+ 4)
+#define COUNT_DIGIT_16(n,i) COUNT_DIGIT_08(n,i); COUNT_DIGIT_08(n,i+ 8)
+#define COUNT_DIGIT_32(n,i) COUNT_DIGIT_16(n,i); COUNT_DIGIT_16(n,i+16)
+#define COUNT_DIGIT_64(n,i) COUNT_DIGIT_32(n,i); COUNT_DIGIT_32(n,i+32)
+template<class Value>
+Value TupleList::radix_count(const Value *A, const Value *end, Index stride,
+    Index count[DIGITS][DIGIT_VALUES])
+  Value bitorkey = 0;
+  memset(count, 0, COUNT_SIZE * sizeof(Index));
+  do
+    Value val = *A;
+    bitorkey |= val;
+    COUNT_DIGIT_64(DIGITS, 0);
+    // above macro expands to:
+    //if(DIGITS> 0) count[ 0][val&DIGIT_MASK]++, val>>=DIGIT_BITS;
+    //if(DIGITS> 1) count[ 1][val&DIGIT_MASK]++, val>>=DIGIT_BITS;
+    //if(DIGITS>63) count[63][val&DIGIT_MASK]++, val>>=DIGIT_BITS;
+  } while (A += stride, A != end);
+  return bitorkey;
+#undef COUNT_DIGIT_01
+#undef COUNT_DIGIT_02
+#undef COUNT_DIGIT_04
+#undef COUNT_DIGIT_08
+#undef COUNT_DIGIT_16
+#undef COUNT_DIGIT_32
+#undef COUNT_DIGIT_64
+void TupleList::radix_offsets(Index *c)
+  Index sum = 0, t, *ce = c + DIGIT_VALUES;
+  do
+    t = *c, *c++ = sum, sum += t;
+  while (c != ce);
+unsigned TupleList::radix_zeros(Value bitorkey,
+    Index count[DIGITS][DIGIT_VALUES], unsigned *shift, Index **offsets)
+  unsigned digits = 0, sh = 0;
+  Index *c = &count[0][0];
+  do
+    if (bitorkey & DIGIT_MASK)
+      *shift++ = sh, *offsets++ = c, ++digits, radix_offsets(c);
+  } while (bitorkey >>= DIGIT_BITS,sh += DIGIT_BITS,c += DIGIT_VALUES,sh
+      != VALUE_BITS);
+  return digits;
+void TupleList::radix_index_pass_b(const Value *A, Index n, Index stride,
+    unsigned sh, Index *off, SortData<Value> *out)
+  Index i = 0;
+  do
+    Value v = *A;
+    SortData<Value> *d = &out[off[(v >> sh) & DIGIT_MASK]++];
+    d->v = v, d->i = i++;
+  } while (A += stride, i != n);
+void TupleList::radix_index_pass_m(const SortData<Value> *src,
+    const SortData<Value> *end, unsigned sh, Index *off, SortData<Value> *out)
+  do
+    SortData<Value> *d = &out[off[(src->v >> sh) & DIGIT_MASK]++];
+    d->v = src->v, d->i = src->i;
+  } while (++src != end);
+void TupleList::radix_index_pass_e(const SortData<Value> *src,
+    const SortData<Value> *end, unsigned sh, Index *off, Index *out)
+  do
+    out[off[(src->v >> sh) & DIGIT_MASK]++] = src->i;
+  while (++src != end);
+void TupleList::radix_index_pass_be(const Value *A, Index n, Index stride,
+    unsigned sh, Index *off, Index *out)
+  Index i = 0;
+  do
+    out[off[(*A >> sh) & DIGIT_MASK]++] = i++;
+  while (A += stride, i != n);
+void TupleList::radix_index_sort(const Value *A, Index n, Index stride,
+    Index *idx, SortData<Value> *work)
+  Index count[DIGITS][DIGIT_VALUES];
+  Value bitorkey = radix_count(A, A + n * stride, stride, count);
+  unsigned shift[DIGITS];
+  Index *offsets[DIGITS];
+  unsigned digits = radix_zeros(bitorkey, count, shift, offsets);
+  if (digits == 0)
+    Index i = 0;
+    do
+      *idx++ = i++;
+    while (i != n);
+  else if (digits == 1)
+    radix_index_pass_be(A, n, stride, shift[0], offsets[0], idx);
+  else
+    SortData<Value> *src, *dst;
+    unsigned d;
+    if ((digits & 1) == 0)
+      dst = work, src = dst + n;
+    else
+      src = work, dst = src + n;
+    radix_index_pass_b(A, n, stride, shift[0], offsets[0], src);
+    for (d = 1; d != digits - 1; ++d)
+      SortData<Value> *t;
+      radix_index_pass_m(src, src + n, shift[d], offsets[d], dst);
+      t = src, src = dst, dst = t;
+    radix_index_pass_e(src, src + n, shift[d], offsets[d], idx);
+void TupleList::merge_index_sort(const Value *A, const Index An, Index stride,
+  SortData<Value> * const buf[2] = { work + An, work };
+  Index n = An, base = -n, odd = 0, c = 0, b = 1;
+  Index i = 0;
+  for (;;)
+    SortData<Value> *p;
+    if ((c & 1) == 0)
+      base += n, n += (odd & 1), c |= 1, b ^= 1;
+      while (n > 3)
+        odd <<= 1, odd |= (n & 1), n >>= 1, c <<= 1, b ^= 1;
+    else
+      base -= n - (odd & 1), n <<= 1, n -= (odd & 1), odd >>= 1, c >>= 1;
+    if (c == 0)
+      break;
+    p = buf[b] + base;
+    if (n == 2)
+      Value v[2];
+      v[0] = *A, A += stride, v[1] = *A, A += stride;
+      if (v[1] < v[0])
+        p[0].v = v[1], p[0].i = i + 1, p[1].v = v[0], p[1].i = i;
+      else
+        p[0].v = v[0], p[0].i = i, p[1].v = v[1], p[1].i = i + 1;
+      i += 2;
+    else if (n == 3)
+      Value v[3];
+      v[0] = *A, A += stride, v[1] = *A, A += stride, v[2] = *A, A += stride;
+      if (v[1] < v[0])
+        if (v[2] < v[1])
+          p[0].v = v[2], p[1].v = v[1], p[2].v = v[0], p[0].i = i + 2, p[1].i =
+              i + 1, p[2].i = i;
+        else
+          if (v[2] < v[0])
+            p[0].v = v[1], p[1].v = v[2], p[2].v = v[0], p[0].i = i + 1, p[1].i =
+                i + 2, p[2].i = i;
+          else
+            p[0].v = v[1], p[1].v = v[0], p[2].v = v[2], p[0].i = i + 1, p[1].i =
+                i, p[2].i = i + 2;
+      else
+        if (v[2] < v[0])
+          p[0].v = v[2], p[1].v = v[0], p[2].v = v[1], p[0].i = i + 2, p[1].i =
+              i, p[2].i = i + 1;
+        else
+          if (v[2] < v[1])
+            p[0].v = v[0], p[1].v = v[2], p[2].v = v[1], p[0].i = i, p[1].i = i
+                + 2, p[2].i = i + 1;
+          else
+            p[0].v = v[0], p[1].v = v[1], p[2].v = v[2], p[0].i = i, p[1].i = i
+                + 1, p[2].i = i + 2;
+      i += 3;
+    else
+      const Index na = n >> 1, nb = (n + 1) >> 1;
+      const SortData<Value> *ap = buf[b ^ 1] + base, *ae = ap + na;
+      SortData<Value> *bp = p + na, *be = bp + nb;
+      for (;;)
+        if (bp->v < ap->v)
+          *p++ = *bp++;
+          if (bp != be)
+            continue;
+          do
+            *p++ = *ap++;
+          while (ap != ae);
+          break;
+        else
+          *p++ = *ap++;
+          if (ap == ae)
+            break;
+    const SortData<Value> *p = buf[0], *pe = p + An;
+    do
+      *idx++ = (p++)->i;
+    while (p != pe);
+void TupleList::index_sort(const Value *A, Index n, Index stride, Index *idx,
+    SortData<Value> *work)
+  if (n < DIGIT_VALUES)
+    if (n == 0)
+      return;
+    if (n == 1)
+      *idx = 0;
+    else
+      merge_index_sort(A, n, stride, idx, work);
+  else
+    radix_index_sort(A, n, stride, idx, work);
+#undef DIGIT_BITS
+#undef DIGIT_VALUES
+#undef DIGIT_MASK
+#undef CEILDIV
+#undef DIGITS
+#undef VALUE_BITS
+#undef COUNT_SIZE
+#undef sort_data_long
+} //namespace
diff --git a/src/io/NCHelper.cpp b/src/io/NCHelper.cpp
index c915382..9ef1332 100644
--- a/src/io/NCHelper.cpp
+++ b/src/io/NCHelper.cpp
@@ -48,6 +48,9 @@ NCHelper* NCHelper::get_nc_helper(ReadNC* readNC, int fileId, const FileOptions&
   else {
     if (NCHelperMPAS::can_read_file(readNC))
       return new (std::nothrow) NCHelperMPAS(readNC, fileId, opts, fileSet);
+    // For a HOMME connectivity file, there might be no CF convention
+    else if (NCHelperHOMME::can_read_file(readNC, fileId))
+      return new (std::nothrow) NCHelperHOMME(readNC, fileId, opts, fileSet);
   // Unknown NetCDF grid (will fill this in later for POP, CICE and CLM)
diff --git a/src/io/NCHelperHOMME.cpp b/src/io/NCHelperHOMME.cpp
index efddb0c..53fa9ad 100644
--- a/src/io/NCHelperHOMME.cpp
+++ b/src/io/NCHelperHOMME.cpp
@@ -15,7 +15,7 @@ namespace moab {
 NCHelperHOMME::NCHelperHOMME(ReadNC* readNC, int fileId, const FileOptions& opts, EntityHandle fileSet)
 : UcdNCHelper(readNC, fileId, opts, fileSet),
-_spectralOrder(-1), connectId(-1)
+_spectralOrder(-1), connectId(-1), isConnFile(false)
   // Calculate spectral order
   std::map<std::string, ReadNC::AttData>::iterator attIt = readNC->globalAtts.find("np");
@@ -26,6 +26,11 @@ _spectralOrder(-1), connectId(-1)
     else
       _spectralOrder--; // Spectral order is one less than np
+  else {
+    // As can_read_file() returns true and there is no global attribute "np", it should be a connectivity file
+    isConnFile = true;
+    _spectralOrder = 3; // Assume np is 4
 bool NCHelperHOMME::can_read_file(ReadNC* readNC, int fileId)
@@ -52,6 +57,15 @@ bool NCHelperHOMME::can_read_file(ReadNC* readNC, int fileId)
     return true;
+  else {
+    // If dimension names "ncol" AND "ncorners" AND "ncells" exist, then it should be the HOMME connectivity file
+    // In this case, the mesh can still be created
+    std::vector<std::string>& dimNames = readNC->dimNames;
+    if ((std::find(dimNames.begin(), dimNames.end(), std::string("ncol")) != dimNames.end()) &&
+        (std::find(dimNames.begin(), dimNames.end(), std::string("ncorners")) != dimNames.end()) &&
+        (std::find(dimNames.begin(), dimNames.end(), std::string("ncells")) != dimNames.end()))
+      return true;
   return false;
@@ -67,15 +81,20 @@ ErrorCode NCHelperHOMME::init_mesh_vals()
   std::vector<std::string>::iterator vit;
   // Look for time dimension
-  if ((vit = std::find(dimNames.begin(), dimNames.end(), "time")) != dimNames.end())
-    idx = vit - dimNames.begin();
-  else if ((vit = std::find(dimNames.begin(), dimNames.end(), "t")) != dimNames.end())
+  if (isConnFile) {
+    // Connectivity file might not have time dimension
   else {
-    ERRORR(MB_FAILURE, "Couldn't find 'time' or 't' dimension.");
+    if ((vit = std::find(dimNames.begin(), dimNames.end(), "time")) != dimNames.end())
+      idx = vit - dimNames.begin();
+    else if ((vit = std::find(dimNames.begin(), dimNames.end(), "t")) != dimNames.end())
+    else {
+      ERRORR(MB_FAILURE, "Couldn't find 'time' or 't' dimension.");
+    tDim = idx;
+    nTimeSteps = dimLens[idx];
-  tDim = idx;
-  nTimeSteps = dimLens[idx];
   // Get number of vertices (labeled as number of columns)
   if ((vit = std::find(dimNames.begin(), dimNames.end(), "ncol")) != dimNames.end())
@@ -90,15 +109,20 @@ ErrorCode NCHelperHOMME::init_mesh_vals()
   nCells = nVertices - 2;
   // Get number of levels
-  if ((vit = std::find(dimNames.begin(), dimNames.end(), "lev")) != dimNames.end())
-  else if ((vit = std::find(dimNames.begin(), dimNames.end(), "ilev")) != dimNames.end())
+  if (isConnFile) {
+    // Connectivity file might not have level dimension
   else {
-    ERRORR(MB_FAILURE, "Couldn't find 'lev' or 'ilev' dimension.");
+    if ((vit = std::find(dimNames.begin(), dimNames.end(), "lev")) != dimNames.end())
+    else if ((vit = std::find(dimNames.begin(), dimNames.end(), "ilev")) != dimNames.end())
+    else {
+      ERRORR(MB_FAILURE, "Couldn't find 'lev' or 'ilev' dimension.");
+    levDim = idx;
+    nLevels = dimLens[idx];
-  levDim = idx;
-  nLevels = dimLens[idx];
   // Store lon values in xVertVals
   std::map<std::string, ReadNC::VarData>::iterator vmit;
@@ -120,35 +144,45 @@ ErrorCode NCHelperHOMME::init_mesh_vals()
   // Store lev values in levVals
-  if ((vmit = varInfo.find("lev")) != varInfo.end() && (*vmit).second.varDims.size() == 1) {
-    rval = read_coordinate("lev", 0, nLevels - 1, levVals);
-    ERRORR(rval, "Trouble reading 'lev' variable.");
-    // Decide whether down is positive
-    char posval[10];
-    int success = NCFUNC(get_att_text)(_fileId, (*vmit).second.varId, "positive", posval);
-    if (0 == success && !strcmp(posval, "down")) {
-      for (std::vector<double>::iterator dvit = levVals.begin(); dvit != levVals.end(); ++dvit)
-        (*dvit) *= -1.0;
+  if (isConnFile) {
+    // Connectivity file might not have level variable
   else {
-    ERRORR(MB_FAILURE, "Couldn't find 'lev' variable.");
+    if ((vmit = varInfo.find("lev")) != varInfo.end() && (*vmit).second.varDims.size() == 1) {
+      rval = read_coordinate("lev", 0, nLevels - 1, levVals);
+      ERRORR(rval, "Trouble reading 'lev' variable.");
+      // Decide whether down is positive
+      char posval[10];
+      int success = NCFUNC(get_att_text)(_fileId, (*vmit).second.varId, "positive", posval);
+      if (0 == success && !strcmp(posval, "down")) {
+        for (std::vector<double>::iterator dvit = levVals.begin(); dvit != levVals.end(); ++dvit)
+          (*dvit) *= -1.0;
+    else {
+      ERRORR(MB_FAILURE, "Couldn't find 'lev' variable.");
   // Store time coordinate values in tVals
-  if ((vmit = varInfo.find("time")) != varInfo.end() && (*vmit).second.varDims.size() == 1) {
-    rval = read_coordinate("time", 0, nTimeSteps - 1, tVals);
-    ERRORR(rval, "Trouble reading 'time' variable.");
-  else if ((vmit = varInfo.find("t")) != varInfo.end() && (*vmit).second.varDims.size() == 1) {
-    rval = read_coordinate("t", 0, nTimeSteps - 1, tVals);
-    ERRORR(rval, "Trouble reading 't' variable.");
+  if (isConnFile) {
+    // Connectivity file might not have time variable
   else {
-    // If expected time variable is not available, set dummy time coordinate values to tVals
-    for (int t = 0; t < nTimeSteps; t++)
-      tVals.push_back((double)t);
+    if ((vmit = varInfo.find("time")) != varInfo.end() && (*vmit).second.varDims.size() == 1) {
+      rval = read_coordinate("time", 0, nTimeSteps - 1, tVals);
+      ERRORR(rval, "Trouble reading 'time' variable.");
+    else if ((vmit = varInfo.find("t")) != varInfo.end() && (*vmit).second.varDims.size() == 1) {
+      rval = read_coordinate("t", 0, nTimeSteps - 1, tVals);
+      ERRORR(rval, "Trouble reading 't' variable.");
+    else {
+      // If expected time variable is not available, set dummy time coordinate values to tVals
+      for (int t = 0; t < nTimeSteps; t++)
+        tVals.push_back((double)t);
   // For each variable, determine the entity location type and number of levels
@@ -225,23 +259,6 @@ ErrorCode NCHelperHOMME::create_mesh(Range& faces)
   bool& spectralMesh = _readNC->spectralMesh;
   int& gatherSetRank = _readNC->gatherSetRank;
-  // Need to get/read connectivity data before creating elements
-  std::string conn_fname;
-  // Try to open the connectivity file through CONN option, if used
-  ErrorCode rval = _opts.get_str_option("CONN", conn_fname);
-  if (MB_SUCCESS != rval) {
-    // Default convention for reading HOMME is a file HommeMapping.nc in same dir as data file
-    conn_fname = std::string(fileName);
-    size_t idx = conn_fname.find_last_of("/");
-    if (idx != std::string::npos)
-      conn_fname = conn_fname.substr(0, idx).append("/HommeMapping.nc");
-    else
-      conn_fname = "HommeMapping.nc";
-  int success = 0;
   int rank = 0;
   int procs = 1;
 #ifdef USE_MPI
@@ -253,19 +270,42 @@ ErrorCode NCHelperHOMME::create_mesh(Range& faces)
 #endif
+  ErrorCode rval;
+  int success = 0;
+  // Need to get/read connectivity data before creating elements
+  std::string conn_fname;
+  if (isConnFile) {
+    // Connectivity file has already been read
+    connectId = _readNC->fileId;
+  else {
+    // Try to open the connectivity file through CONN option, if used
+    rval = _opts.get_str_option("CONN", conn_fname);
+    if (MB_SUCCESS != rval) {
+      // Default convention for reading HOMME is a file HommeMapping.nc in same dir as data file
+      conn_fname = std::string(fileName);
+      size_t idx = conn_fname.find_last_of("/");
+      if (idx != std::string::npos)
+        conn_fname = conn_fname.substr(0, idx).append("/HommeMapping.nc");
+      else
+        conn_fname = "HommeMapping.nc";
 #ifdef PNETCDF_FILE
 #ifdef USE_MPI
-  if (isParallel) {
-    ParallelComm*& myPcomm = _readNC->myPcomm;
-    success = NCFUNC(open)(myPcomm->proc_config().proc_comm(), conn_fname.c_str(), 0, MPI_INFO_NULL, &connectId);
-  else
-    success = NCFUNC(open)(MPI_COMM_SELF, conn_fname.c_str(), 0, MPI_INFO_NULL, &connectId);
+    if (isParallel) {
+      ParallelComm*& myPcomm = _readNC->myPcomm;
+      success = NCFUNC(open)(myPcomm->proc_config().proc_comm(), conn_fname.c_str(), 0, MPI_INFO_NULL, &connectId);
+    else
+      success = NCFUNC(open)(MPI_COMM_SELF, conn_fname.c_str(), 0, MPI_INFO_NULL, &connectId);
 #endif
 #else
-  success = NCFUNC(open)(conn_fname.c_str(), 0, &connectId);
+    success = NCFUNC(open)(conn_fname.c_str(), 0, &connectId);
 #endif
-  ERRORS(success, "Failed on open.");
+    ERRORS(success, "Failed on open.");
   std::vector<std::string> conn_names;
   std::vector<int> conn_vals;
@@ -286,7 +326,7 @@ ErrorCode NCHelperHOMME::create_mesh(Range& faces)
     ERRORR(MB_FAILURE, "Failed to get number of quads.");
   int num_quads = conn_vals[idx];
-  if (num_quads != nCells) {
+  if (!isConnFile && num_quads != nCells) {
     dbgOut.tprintf(1, "Warning: number of quads from %s and cells from %s are inconsistent; num_quads = %d, nCells = %d.\n",
         conn_fname.c_str(), fileName.c_str(), num_quads, nCells);
@@ -300,8 +340,13 @@ ErrorCode NCHelperHOMME::create_mesh(Range& faces)
   std::vector<int> tmp_conn(4 * num_quads), tmp_conn2(4 * num_quads);
   success = NCFUNCAG(_vara_int)(connectId, cornerVarId, tmp_starts, tmp_counts, &tmp_conn2[0]);
   ERRORS(success, "Failed to get temporary connectivity.");
-  success = NCFUNC(close)(connectId);
-  ERRORS(success, "Failed on close.");
+  if (isConnFile) {
+    // This data/connectivity file will be closed later in ReadNC::load_file()
+  else {
+    success = NCFUNC(close)(connectId);
+    ERRORS(success, "Failed on close.");
   // Permute the connectivity
   for (int i = 0; i < num_quads; i++) {
     tmp_conn[4 * i] = tmp_conn2[i];
@@ -383,12 +428,12 @@ ErrorCode NCHelperHOMME::create_mesh(Range& faces)
   // Convert lon/lat/rad to x/y/z
   const double pideg = acos(-1.0) / 180.0;
+  double rad = (isConnFile) ? 8000.0 : 8000.0 + levVals[0];
   for (i = 0; i < nLocalVertices; i++) {
     double cosphi = cos(pideg * yptr[i]);
     double zmult = sin(pideg * yptr[i]);
     double xmult = cosphi * cos(xptr[i] * pideg);
     double ymult = cosphi * sin(xptr[i] * pideg);
-    double rad = 8000.0 + levVals[0];
     xptr[i] = rad * xmult;
     yptr[i] = rad * ymult;
     zptr[i] = rad * zmult;
@@ -463,7 +508,6 @@ ErrorCode NCHelperHOMME::create_mesh(Range& faces)
       double zmult = sin(pideg * yVertVals[i]);
       double xmult = cosphi * cos(xVertVals[i] * pideg);
       double ymult = cosphi * sin(xVertVals[i] * pideg);
diff --git a/src/io/NCHelperHOMME.hpp b/src/io/NCHelperHOMME.hpp
index 82ba90e..a6d50f0 100644
--- a/src/io/NCHelperHOMME.hpp
+++ b/src/io/NCHelperHOMME.hpp
@@ -46,6 +46,7 @@ private:
 private:
   int _spectralOrder; // Read from variable 'np'
   int connectId; // For connectivity file
+  bool isConnFile; // Is the data file being read actually a connectivity file in disguise?
 } // namespace moab
diff --git a/src/moab/SpatialLocator.hpp b/src/moab/SpatialLocator.hpp
index 0307b1c..f07cff7 100644
--- a/src/moab/SpatialLocator.hpp
+++ b/src/moab/SpatialLocator.hpp
@@ -133,6 +133,12 @@ namespace moab {
       Interface* moab() { return mbImpl; }
+        /* locate a point */
+      ErrorCode locate_point(const double *pos,
+                             EntityHandle &ent, double *params, bool *is_inside = NULL,
+                              const double rel_iter_tol = 1.0e-10, const double abs_iter_tol = 1.0e-10,
+                              const double inside_tol = 1.0e-6);
         /* return the tree */
       Tree *get_tree() {return myTree;}
This diff is so big that we needed to truncate the remainder.
Repository URL: https://bitbucket.org/fathomteam/moab/
This is a commit notification from bitbucket.org. You are receiving
this because you have the service enabled, addressing the recipient of
this email.
