[MOAB-dev] commit/MOAB: iulian07: fix cgm test for occ based builds
commits-noreply at bitbucket.org commits-noreply at bitbucket.org
Tue Feb 11 09:13:45 CST 2014
1 new commit in MOAB:
https://bitbucket.org/fathomteam/moab/commits/a5f72dedf6ae/
Changeset:   a5f72dedf6ae
Branch:      master
User:        iulian07
Date:        2014-02-11 16:12:41
Summary:     fix cgm test for occ based builds
convert cube.sat to cube.stp and ifdefs for OCC step
Affected #:  2 files
diff --git a/MeshFiles/unittest/io/cube.stp b/MeshFiles/unittest/io/cube.stp
new file mode 100644
index 0000000..c17645d
--- /dev/null
+++ b/MeshFiles/unittest/io/cube.stp
@@ -0,0 +1,185 @@
+ISO-10303-21;
+HEADER;
+FILE_DESCRIPTION(('STEP AP214'),'1');
+FILE_NAME('/home/iulian/source/MOABsource/MeshFiles/unittest/io/cube.stp','2014-02-11T15:06:47',(' '),(' '),'Spatial InterOp 3D',' ',' ');
+FILE_SCHEMA(('automotive_design'));
+ENDSEC;
+DATA;
+#1=PRODUCT_DEFINITION_CONTEXT('',#9,'design');
+#2=APPLICATION_PROTOCOL_DEFINITION('INTERNATIONAL STANDARD','automotive_design',1994,#9);
+#3=PRODUCT_CATEGORY_RELATIONSHIP('NONE','NONE',#10,#11);
+#4=SHAPE_DEFINITION_REPRESENTATION(#12,#13);
+#5= (GEOMETRIC_REPRESENTATION_CONTEXT(3)GLOBAL_UNCERTAINTY_ASSIGNED_CONTEXT((#16))GLOBAL_UNIT_ASSIGNED_CONTEXT((#18,#19,#20))REPRESENTATION_CONTEXT('NONE','WORKSPACE'));
+#9=APPLICATION_CONTEXT(' ');
+#10=PRODUCT_CATEGORY('part','NONE');
+#11=PRODUCT_RELATED_PRODUCT_CATEGORY('detail',' ',(#22));
+#12=PRODUCT_DEFINITION_SHAPE('NONE','NONE',#23);
+#13=ADVANCED_BREP_SHAPE_REPRESENTATION('1',(#24,#25),#5);
+#16=UNCERTAINTY_MEASURE_WITH_UNIT(LENGTH_MEASURE(1.0E-06),#18,'','');
+#18= (CONVERSION_BASED_UNIT('MILLIMETRE',#28)LENGTH_UNIT()NAMED_UNIT(#31));
+#19= (NAMED_UNIT(#33)PLANE_ANGLE_UNIT()SI_UNIT($,.RADIAN.));
+#20= (NAMED_UNIT(#33)SOLID_ANGLE_UNIT()SI_UNIT($,.STERADIAN.));
+#22=PRODUCT('1','1','PART-1-DESC',(#39));
+#23=PRODUCT_DEFINITION('NONE','NONE',#40,#1);
+#24=MANIFOLD_SOLID_BREP('1',#41);
+#25=AXIS2_PLACEMENT_3D('',#42,#43,#44);
+#28=LENGTH_MEASURE_WITH_UNIT(LENGTH_MEASURE(1.0),#45);
+#31=DIMENSIONAL_EXPONENTS(1.0,0.0,0.0,0.0,0.0,0.0,0.0);
+#33=DIMENSIONAL_EXPONENTS(0.0,0.0,0.0,0.0,0.0,0.0,0.0);
+#39=PRODUCT_CONTEXT('',#9,'mechanical');
+#40=PRODUCT_DEFINITION_FORMATION_WITH_SPECIFIED_SOURCE(' ','NONE',#22,.NOT_KNOWN.);
+#41=CLOSED_SHELL('',(#46,#47,#48,#49,#50,#51));
+#42=CARTESIAN_POINT('',(0.0,0.0,0.0));
+#43=DIRECTION('',(0.0,0.0,1.0));
+#44=DIRECTION('',(1.0,0.0,0.0));
+#45= (NAMED_UNIT(#31)LENGTH_UNIT()SI_UNIT(.MILLI.,.METRE.));
+#46=ADVANCED_FACE('',(#53),#54,.T.);
+#47=ADVANCED_FACE('',(#55),#56,.F.);
+#48=ADVANCED_FACE('',(#57),#58,.F.);
+#49=ADVANCED_FACE('',(#59),#60,.F.);
+#50=ADVANCED_FACE('',(#61),#62,.F.);
+#51=ADVANCED_FACE('',(#63),#64,.F.);
+#53=FACE_OUTER_BOUND('',#65,.T.);
+#54=PLANE('',#66);
+#55=FACE_OUTER_BOUND('',#67,.T.);
+#56=PLANE('',#68);
+#57=FACE_OUTER_BOUND('',#69,.T.);
+#58=PLANE('',#70);
+#59=FACE_OUTER_BOUND('',#71,.T.);
+#60=PLANE('',#72);
+#61=FACE_OUTER_BOUND('',#73,.T.);
+#62=PLANE('',#74);
+#63=FACE_OUTER_BOUND('',#75,.T.);
+#64=PLANE('',#76);
+#65=EDGE_LOOP('',(#77,#78,#79,#80));
+#66=AXIS2_PLACEMENT_3D('',#81,#82,#83);
+#67=EDGE_LOOP('',(#84,#85,#86,#87));
+#68=AXIS2_PLACEMENT_3D('',#88,#89,#90);
+#69=EDGE_LOOP('',(#91,#92,#93,#94));
+#70=AXIS2_PLACEMENT_3D('',#95,#96,#97);
+#71=EDGE_LOOP('',(#98,#99,#100,#101));
+#72=AXIS2_PLACEMENT_3D('',#102,#103,#104);
+#73=EDGE_LOOP('',(#105,#106,#107,#108));
+#74=AXIS2_PLACEMENT_3D('',#109,#110,#111);
+#75=EDGE_LOOP('',(#112,#113,#114,#115));
+#76=AXIS2_PLACEMENT_3D('',#116,#117,#118);
+#77=ORIENTED_EDGE('',*,*,#119,.T.);
+#78=ORIENTED_EDGE('',*,*,#120,.T.);
+#79=ORIENTED_EDGE('',*,*,#121,.T.);
+#80=ORIENTED_EDGE('',*,*,#122,.T.);
+#81=CARTESIAN_POINT('',(0.0,0.0,5.0));
+#82=DIRECTION('',(0.0,0.0,1.0));
+#83=DIRECTION('',(1.0,0.0,0.0));
+#84=ORIENTED_EDGE('',*,*,#123,.T.);
+#85=ORIENTED_EDGE('',*,*,#124,.T.);
+#86=ORIENTED_EDGE('',*,*,#125,.T.);
+#87=ORIENTED_EDGE('',*,*,#126,.T.);
+#88=CARTESIAN_POINT('',(0.0,0.0,-5.0));
+#89=DIRECTION('',(0.0,0.0,1.0));
+#90=DIRECTION('',(1.0,0.0,0.0));
+#91=ORIENTED_EDGE('',*,*,#127,.T.);
+#92=ORIENTED_EDGE('',*,*,#124,.F.);
+#93=ORIENTED_EDGE('',*,*,#128,.F.);
+#94=ORIENTED_EDGE('',*,*,#122,.F.);
+#95=CARTESIAN_POINT('',(0.0,-5.0,0.0));
+#96=DIRECTION('',(0.0,1.0,-0.0));
+#97=DIRECTION('',(-0.0,0.0,1.0));
+#98=ORIENTED_EDGE('',*,*,#129,.T.);
+#99=ORIENTED_EDGE('',*,*,#125,.F.);
+#100=ORIENTED_EDGE('',*,*,#127,.F.);
+#101=ORIENTED_EDGE('',*,*,#121,.F.);
+#102=CARTESIAN_POINT('',(-5.0,0.0,0.0));
+#103=DIRECTION('',(1.0,0.0,0.0));
+#104=DIRECTION('',(0.0,0.0,-1.0));
+#105=ORIENTED_EDGE('',*,*,#130,.T.);
+#106=ORIENTED_EDGE('',*,*,#126,.F.);
+#107=ORIENTED_EDGE('',*,*,#129,.F.);
+#108=ORIENTED_EDGE('',*,*,#120,.F.);
+#109=CARTESIAN_POINT('',(0.0,5.0,0.0));
+#110=DIRECTION('',(0.0,-1.0,0.0));
+#111=DIRECTION('',(0.0,0.0,-1.0));
+#112=ORIENTED_EDGE('',*,*,#128,.T.);
+#113=ORIENTED_EDGE('',*,*,#123,.F.);
+#114=ORIENTED_EDGE('',*,*,#130,.F.);
+#115=ORIENTED_EDGE('',*,*,#119,.F.);
+#116=CARTESIAN_POINT('',(5.0,0.0,0.0));
+#117=DIRECTION('',(-1.0,0.0,0.0));
+#118=DIRECTION('',(0.0,-0.0,1.0));
+#119=EDGE_CURVE('',#131,#132,#133,.T.);
+#120=EDGE_CURVE('',#132,#134,#135,.T.);
+#121=EDGE_CURVE('',#134,#136,#137,.T.);
+#122=EDGE_CURVE('',#136,#131,#138,.T.);
+#123=EDGE_CURVE('',#139,#140,#141,.T.);
+#124=EDGE_CURVE('',#140,#142,#143,.T.);
+#125=EDGE_CURVE('',#142,#144,#145,.T.);
+#126=EDGE_CURVE('',#144,#139,#146,.T.);
+#127=EDGE_CURVE('',#136,#142,#147,.T.);
+#128=EDGE_CURVE('',#131,#140,#148,.T.);
+#129=EDGE_CURVE('',#134,#144,#149,.T.);
+#130=EDGE_CURVE('',#132,#139,#150,.T.);
+#131=VERTEX_POINT('',#151);
+#132=VERTEX_POINT('',#152);
+#133=LINE('',#153,#154);
+#134=VERTEX_POINT('',#155);
+#135=LINE('',#156,#157);
+#136=VERTEX_POINT('',#158);
+#137=LINE('',#159,#160);
+#138=LINE('',#161,#162);
+#139=VERTEX_POINT('',#163);
+#140=VERTEX_POINT('',#164);
+#141=LINE('',#165,#166);
+#142=VERTEX_POINT('',#167);
+#143=LINE('',#168,#169);
+#144=VERTEX_POINT('',#170);
+#145=LINE('',#171,#172);
+#146=LINE('',#173,#174);
+#147=LINE('',#175,#176);
+#148=LINE('',#177,#178);
+#149=LINE('',#179,#180);
+#150=LINE('',#181,#182);
+#151=CARTESIAN_POINT('',(5.0,-5.0,5.0));
+#152=CARTESIAN_POINT('',(5.0,5.0,5.0));
+#153=CARTESIAN_POINT('',(5.0,0.0,5.0));
+#154=VECTOR('',#183,1.0);
+#155=CARTESIAN_POINT('',(-5.0,5.0,5.0));
+#156=CARTESIAN_POINT('',(0.0,5.0,5.0));
+#157=VECTOR('',#184,1.0);
+#158=CARTESIAN_POINT('',(-5.0,-5.0,5.0));
+#159=CARTESIAN_POINT('',(-5.0,0.0,5.0));
+#160=VECTOR('',#185,1.0);
+#161=CARTESIAN_POINT('',(0.0,-5.0,5.0));
+#162=VECTOR('',#186,1.0);
+#163=CARTESIAN_POINT('',(5.0,5.0,-5.0));
+#164=CARTESIAN_POINT('',(5.0,-5.0,-5.0));
+#165=CARTESIAN_POINT('',(5.0,0.0,-5.0));
+#166=VECTOR('',#187,1.0);
+#167=CARTESIAN_POINT('',(-5.0,-5.0,-5.0));
+#168=CARTESIAN_POINT('',(0.0,-5.0,-5.0));
+#169=VECTOR('',#188,1.0);
+#170=CARTESIAN_POINT('',(-5.0,5.0,-5.0));
+#171=CARTESIAN_POINT('',(-5.0,0.0,-5.0));
+#172=VECTOR('',#189,1.0);
+#173=CARTESIAN_POINT('',(0.0,5.0,-5.0));
+#174=VECTOR('',#190,1.0);
+#175=CARTESIAN_POINT('',(-5.0,-5.0,0.0));
+#176=VECTOR('',#191,1.0);
+#177=CARTESIAN_POINT('',(5.0,-5.0,0.0));
+#178=VECTOR('',#192,1.0);
+#179=CARTESIAN_POINT('',(-5.0,5.0,0.0));
+#180=VECTOR('',#193,1.0);
+#181=CARTESIAN_POINT('',(5.0,5.0,0.0));
+#182=VECTOR('',#194,1.0);
+#183=DIRECTION('',(0.0,1.0,0.0));
+#184=DIRECTION('',(-1.0,0.0,0.0));
+#185=DIRECTION('',(0.0,-1.0,0.0));
+#186=DIRECTION('',(1.0,0.0,0.0));
+#187=DIRECTION('',(0.0,-1.0,0.0));
+#188=DIRECTION('',(-1.0,0.0,0.0));
+#189=DIRECTION('',(0.0,1.0,0.0));
+#190=DIRECTION('',(1.0,0.0,0.0));
+#191=DIRECTION('',(0.0,0.0,-1.0));
+#192=DIRECTION('',(0.0,0.0,-1.0));
+#193=DIRECTION('',(0.0,0.0,-1.0));
+#194=DIRECTION('',(0.0,0.0,-1.0));
+ENDSEC;
+END-ISO-10303-21;
diff --git a/test/io/read_cgm_basic_test.cpp b/test/io/read_cgm_basic_test.cpp
index 156e5bd..7a2d07d 100644
--- a/test/io/read_cgm_basic_test.cpp
+++ b/test/io/read_cgm_basic_test.cpp
@@ -18,11 +18,18 @@ using namespace moab;
 #ifdef MESHDIR
+#ifdef HAVE_OCC_STEP
+static const char input_cube[] = STRINGIFY(MESHDIR) "/io/cube.stp";
+#else
 static const char input_cube[] = STRINGIFY(MESHDIR) "/io/cube.sat";
+#endif
+#else
+static const char input_cube[] = "cube.stp";
 #else
-static const char input_cube[] = "/io/cube.sat";
+static const char input_cube[] = "cube.sat";
+#endif
 #endif
 void read_cube_test()
Repository URL: https://bitbucket.org/fathomteam/moab/
This is a commit notification from bitbucket.org. You are receiving
this because you have the service enabled, addressing the recipient of
this email.
