[MOAB-dev] buildbot failure in moab-occ-par-sta2: failed test
Grindeanu, Iulian R. iulian at mcs.anl.gov
Tue Feb 11 07:55:44 CST 2014
The builds are all on gnep; I don't know how to attach the log with buildbot
FAIL: read_cgm_basic_test (exit: 1)
Running read_cube_test ...
ERROR: File formats other than OCC, STEP and IGES are not supported by OCC
ErrorCode Test Failed: MB_SUCCESS == rval
  at line 31 of 'read_cgm_basic_test.cpp'
  Expected value: Success (0)
  Actual value:   Failure (16)
  read_cube_test: FAILED
The problem is that all moab builds that depend on cgm built with OpenCascade failed
OCC cannot read sat files; it has to be converted to stp format (cubit 14 can do it)
 Patrick, see what we do in cgm load test
#ifdef MESHDIR
#ifdef HAVE_OCC_STEP
static const char input_file[] = STRINGIFY(MESHDIR) "/io/dum.stp";
#else
static const char input_file[] = STRINGIFY(MESHDIR) "/io/dum.sat";
#endif
#else
static const char input_file[] = "dum.stp";
#else
static const char input_file[] = "dum.sat";
Iulian
From: moab-dev-bounces at mcs.anl.gov [moab-dev-bounces at mcs.anl.gov] on behalf of Vijay S. Mahadevan [vijay.m at gmail.com]
Sent: Tuesday, February 11, 2014 2:23 AM
To: moab-dev at mcs.anl.gov
Subject: Re: [MOAB-dev] buildbot failure in moab-occ-par-sta2: failed test
Patrick, Check the tests (make check) and verify before merging. Please push the necessary fix.
Iulian, how do we access the test-suite.log ? Can we make buildbot attach detailed errors when it fails ?
Vijay
On Tue, Feb 11, 2014 at 2:17 AM, <moab-dev at mcs.anl.gov<mailto:moab-dev at mcs.anl.gov>> wrote:
Fathom<http://gnep.mcs.anl.gov:8010/>: moab-occ-par-sta2<http://gnep.mcs.anl.gov:8010/builders/moab-occ-par-sta2> build #370<http://gnep.mcs.anl.gov:8010/builders/moab-occ-par-sta2/builds/370>
Results:        failed test
Buildslave:     gnep
Revision:       None
Log Excerpt
/home/fathom/3rdparty/mpich2/mpich2-1.2.1/gcc/include/mpicxx.h:1886: warning: unused parameter ‘ex’
/home/fathom/3rdparty/mpich2/mpich2-1.2.1/gcc/include/mpicxx.h:1888: warning: unused parameter ‘oldwin’
/home/fathom/3rdparty/mpich2/mpich2-1.2.1/gcc/include/mpicxx.h:1888: warning: unused parameter ‘keyval’
/home/fathom/3rdparty/mpich2/mpich2-1.2.1/gcc/include/mpicxx.h:1888: warning: unused parameter ‘ex’
mv -f .deps/read_mpas_nc.Tpo .deps/read_mpas_nc.Po
/bin/sh ../../libtool  --tag=CXX   --mode=link /homes/fathom/3rdparty/mpich2/mpich2-1.2.1/gcc/bin/mpicxx  -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align  -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -R/homes/fathom/install/occparsta2/cgm/lib  -L/home/fathom/3rdparty/ParMETIS3_1/gcc -L/home/fathom/3rdparty/Zoltan_v3.3/lib  -L/homes/iulian/lib/pnetcdf/lib -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/parallel/gcc/lib     -L/homes/fathom/3rdparty/zlib/zlib-1.2.4/gcc/lib  -L/homes/fathom/3rdparty/hdf5/hdf5-1.8.3/parallel/gcc/lib -L/homes/fathom/install/occparsta2/cgm/lib  -L/homes/fathom/3rdparty/occ/OpenCASCADE6.5.3/gccGnep/lib -L/homes/fathom/3rdparty/zlib/zlib-1.2.4/gcc/lib  -L/homes/fathom/3rdparty/hdf5/hdf5-1.8.3/parallel/gcc/lib  -L/homes/fathom/3rdparty/zlib/zlib-1.2.4/gcc/lib  -L/homes/fathom/3rdparty/hdf5/hdf5-1.8.3/parallel/gcc/lib  -L/homes/fathom/3rdparty/zlib/zlib-1.2.4/gcc/lib  -L/homes/fathom/3rdparty/hdf5/hdf5-1.8.3
 /parallel/gcc/lib -o read_mpas_nc read_mpas_nc.o ../../src/libMOAB.la -lm
libtool: link: /homes/fathom/3rdparty/mpich2/mpich2-1.2.1/gcc/bin/mpicxx -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -o read_mpas_nc read_mpas_nc.o  -L/home/fathom/3rdparty/ParMETIS3_1/gcc -L/home/fathom/3rdparty/Zoltan_v3.3/lib -L/homes/iulian/lib/pnetcdf/lib -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/parallel/gcc/lib -L/homes/fathom/3rdparty/zlib/zlib-1.2.4/gcc/lib -L/homes/fathom/3rdparty/hdf5/hdf5-1.8.3/parallel/gcc/lib -L/homes/fathom/install/occparsta2/cgm/lib -L/homes/fathom/3rdparty/occ/OpenCASCADE6.5.3/gccGnep/lib ../../src/.libs/libMOAB.a /home/fathom/3rdparty/netcdf/netcdf-4.0.1/parallel/gcc/lib/libnetcdf.so -L/home/fathom/3rdparty/hdf5/hdf5-1.8.3/parallel/gcc/lib -L/home/fathom/3rdparty/zlib/zlib-1.2.4/gcc/lib -L/home/fathom/3rdparty/szip/szip-2.1/gcc/lib /home/fathom/3rdparty/hdf5/hdf5-1.8.3/parallel/gcc/lib/libhdf5_hl.so -lpnetcdf /home/fathom/3rdparty/hdf5/hdf5-1
 .8.3/parallel/gcc/lib/libhdf5.so -lz /homes/fathom/install/occparsta2/cgm/lib/libcgm.a /homes/fathom/3rdparty/occ/OpenCASCADE6.5.3/gccGnep/lib/libTKSTL.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.3/gccGnep/lib/libTKSTEP.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.3/gccGnep/lib/libTKSTEP209.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.3/gccGnep/lib/libTKSTEPAttr.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.3/gccGnep/lib/libTKSTEPBase.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.3/gccGnep/lib/libTKIGES.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.3/gccGnep/lib/libTKXSBase.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.3/gccGnep/lib/libTKBinL.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.3/gccGnep/lib/libTKCAF.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.3/gccGnep/lib/libTKLCAF.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.3/gccGnep/lib/libTKCDF.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.3/gccGnep/lib/libTKV3d.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.3/gccGnep/lib/libTKV2d.
 so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.3/gccGnep/lib/libTKService.so -lXmu -lGLU -lGL /homes/fathom/3rdparty/occ/OpenCASCADE6.5.3/gccGnep/lib/libTKHLR.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.3/gccGnep/lib/libTKOffset.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.3/gccGnep/lib/libTKFillet.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.3/gccGnep/lib/libTKFeat.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.3/gccGnep/lib/libTKBool.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.3/gccGnep/lib/libTKShHealing.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.3/gccGnep/lib/libTKBO.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.3/gccGnep/lib/libTKPrim.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.3/gccGnep/lib/libTKMesh.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.3/gccGnep/lib/libTKTopAlgo.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.3/gccGnep/lib/libTKGeomAlgo.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.3/gccGnep/lib/libTKBRep.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.3/gccGnep/lib/
 libTKGeomBase.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.3/gccGnep/lib/libTKG3d.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.3/gccGnep/lib/libTKG2d.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.3/gccGnep/lib/libTKMath.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.3/gccGnep/lib/libTKernel.so -lXt -lX11 -ldl -lzoltan -lparmetis -lmetis -lm -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/parallel/gcc/lib -Wl,-rpath -Wl,/home/fathom/3rdparty/hdf5/hdf5-1.8.3/parallel/gcc/lib -Wl,-rpath -Wl,/homes/fathom/3rdparty/occ/OpenCASCADE6.5.3/gccGnep/lib -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/parallel/gcc/lib -Wl,-rpath -Wl,/home/fathom/3rdparty/hdf5/hdf5-1.8.3/parallel/gcc/lib -Wl,-rpath -Wl,/homes/fathom/3rdparty/occ/OpenCASCADE6.5.3/gccGnep/lib -Wl,-rpath -Wl,/homes/fathom/install/occparsta2/cgm/lib
/homes/fathom/3rdparty/mpich2/mpich2-1.2.1/gcc/bin/mpicxx -DHAVE_CONFIG_H -I. -I../.. -I../../src/moab -I../../src/parallel -I../../src  -I/homes/iulian/lib/pnetcdf/include -I/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/parallel/gcc/include    -I/homes/fathom/3rdparty/hdf5/hdf5-1.8.3/parallel/gcc/include -isystem /homes/fathom/3rdparty/hdf5/hdf5-1.8.3/parallel/gcc/include  -DTEMPLATE_SPECIALIZATION -DTEMPLATE_FUNC_SPECIALIZATION -DHAVE_VSNPRINTF -D_FILE_OFFSET_BITS=64   -DUSE_MPI -DHDF5_FILE -DHDF5_PARALLEL -DNETCDF_FILE -DPNETCDF_FILE -DHAVE_ZOLTAN -DCGM -DSRCDIR=. -DMESHDIR=../../MeshFiles/unittest -I. -I.. -I./.. -I../../src -I../../src -I../../src/io -I../../src/parallel -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map -DHAVE_UNORDERED_SET=tr1/unordered_set  -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align  -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -MT ideas_test.o -MD -MP -MF .deps/ideas_test.Tpo -c -o id
 eas_test.o ideas_test.cc
mv -f .deps/ideas_test.Tpo .deps/ideas_test.Po
 /parallel/gcc/lib -o ideas_test ideas_test.o ../../src/libMOAB.la -lm
libtool: link: /homes/fathom/3rdparty/mpich2/mpich2-1.2.1/gcc/bin/mpicxx -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -o ideas_test ideas_test.o  -L/home/fathom/3rdparty/ParMETIS3_1/gcc -L/home/fathom/3rdparty/Zoltan_v3.3/lib -L/homes/iulian/lib/pnetcdf/lib -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/parallel/gcc/lib -L/homes/fathom/3rdparty/zlib/zlib-1.2.4/gcc/lib -L/homes/fathom/3rdparty/hdf5/hdf5-1.8.3/parallel/gcc/lib -L/homes/fathom/install/occparsta2/cgm/lib -L/homes/fathom/3rdparty/occ/OpenCASCADE6.5.3/gccGnep/lib ../../src/.libs/libMOAB.a /home/fathom/3rdparty/netcdf/netcdf-4.0.1/parallel/gcc/lib/libnetcdf.so -L/home/fathom/3rdparty/hdf5/hdf5-1.8.3/parallel/gcc/lib -L/home/fathom/3rdparty/zlib/zlib-1.2.4/gcc/lib -L/home/fathom/3rdparty/szip/szip-2.1/gcc/lib /home/fathom/3rdparty/hdf5/hdf5-1.8.3/parallel/gcc/lib/libhdf5_hl.so -lpnetcdf /home/fathom/3rdparty/hdf5/hdf5-1.8.3
 /parallel/gcc/lib/libhdf5.so -lz /homes/fathom/install/occparsta2/cgm/lib/libcgm.a /homes/fathom/3rdparty/occ/OpenCASCADE6.5.3/gccGnep/lib/libTKSTL.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.3/gccGnep/lib/libTKSTEP.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.3/gccGnep/lib/libTKSTEP209.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.3/gccGnep/lib/libTKSTEPAttr.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.3/gccGnep/lib/libTKSTEPBase.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.3/gccGnep/lib/libTKIGES.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.3/gccGnep/lib/libTKXSBase.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.3/gccGnep/lib/libTKBinL.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.3/gccGnep/lib/libTKCAF.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.3/gccGnep/lib/libTKLCAF.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.3/gccGnep/lib/libTKCDF.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.3/gccGnep/lib/libTKV3d.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.3/gccGnep/lib/libTKV2d.so /
 homes/fathom/3rdparty/occ/OpenCASCADE6.5.3/gccGnep/lib/libTKService.so -lXmu -lGLU -lGL /homes/fathom/3rdparty/occ/OpenCASCADE6.5.3/gccGnep/lib/libTKHLR.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.3/gccGnep/lib/libTKOffset.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.3/gccGnep/lib/libTKFillet.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.3/gccGnep/lib/libTKFeat.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.3/gccGnep/lib/libTKBool.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.3/gccGnep/lib/libTKShHealing.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.3/gccGnep/lib/libTKBO.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.3/gccGnep/lib/libTKPrim.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.3/gccGnep/lib/libTKMesh.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.3/gccGnep/lib/libTKTopAlgo.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.3/gccGnep/lib/libTKGeomAlgo.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.3/gccGnep/lib/libTKBRep.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.3/gccGnep/lib/libT
/homes/fathom/3rdparty/mpich2/mpich2-1.2.1/gcc/bin/mpicxx -DHAVE_CONFIG_H -I. -I../.. -I../../src/moab -I../../src/parallel -I../../src  -I/homes/iulian/lib/pnetcdf/include -I/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/parallel/gcc/include    -I/homes/fathom/3rdparty/hdf5/hdf5-1.8.3/parallel/gcc/include -isystem /homes/fathom/3rdparty/hdf5/hdf5-1.8.3/parallel/gcc/include  -DTEMPLATE_SPECIALIZATION -DTEMPLATE_FUNC_SPECIALIZATION -DHAVE_VSNPRINTF -D_FILE_OFFSET_BITS=64   -DUSE_MPI -DHDF5_FILE -DHDF5_PARALLEL -DNETCDF_FILE -DPNETCDF_FILE -DHAVE_ZOLTAN -DCGM -DSRCDIR=. -DMESHDIR=../../MeshFiles/unittest -I. -I.. -I./.. -I../../src -I../../src -I../../src/io -I../../src/parallel -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map -DHAVE_UNORDERED_SET=tr1/unordered_set  -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align  -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -MT stl_test.o -MD -MP -MF .deps/stl_test.Tpo -c -o stl_te
 st.o stl_test.cc
mv -f .deps/stl_test.Tpo .deps/stl_test.Po
 /parallel/gcc/lib -o stl_test stl_test.o ../../src/libMOAB.la -lm
libtool: link: /homes/fathom/3rdparty/mpich2/mpich2-1.2.1/gcc/bin/mpicxx -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -o stl_test stl_test.o  -L/home/fathom/3rdparty/ParMETIS3_1/gcc -L/home/fathom/3rdparty/Zoltan_v3.3/lib -L/homes/iulian/lib/pnetcdf/lib -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/parallel/gcc/lib -L/homes/fathom/3rdparty/zlib/zlib-1.2.4/gcc/lib -L/homes/fathom/3rdparty/hdf5/hdf5-1.8.3/parallel/gcc/lib -L/homes/fathom/install/occparsta2/cgm/lib -L/homes/fathom/3rdparty/occ/OpenCASCADE6.5.3/gccGnep/lib ../../src/.libs/libMOAB.a /home/fathom/3rdparty/netcdf/netcdf-4.0.1/parallel/gcc/lib/libnetcdf.so -L/home/fathom/3rdparty/hdf5/hdf5-1.8.3/parallel/gcc/lib -L/home/fathom/3rdparty/zlib/zlib-1.2.4/gcc/lib -L/home/fathom/3rdparty/szip/szip-2.1/gcc/lib /home/fathom/3rdparty/hdf5/hdf5-1.8.3/parallel/gcc/lib/libhdf5_hl.so -lpnetcdf /home/fathom/3rdparty/hdf5/hdf5-1.8.3/par
 allel/gcc/lib/libhdf5.so -lz /homes/fathom/install/occparsta2/cgm/lib/libcgm.a /homes/fathom/3rdparty/occ/OpenCASCADE6.5.3/gccGnep/lib/libTKSTL.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.3/gccGnep/lib/libTKSTEP.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.3/gccGnep/lib/libTKSTEP209.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.3/gccGnep/lib/libTKSTEPAttr.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.3/gccGnep/lib/libTKSTEPBase.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.3/gccGnep/lib/libTKIGES.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.3/gccGnep/lib/libTKXSBase.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.3/gccGnep/lib/libTKBinL.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.3/gccGnep/lib/libTKCAF.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.3/gccGnep/lib/libTKLCAF.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.3/gccGnep/lib/libTKCDF.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.3/gccGnep/lib/libTKV3d.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.3/gccGnep/lib/libTKV2d.so /home
 s/fathom/3rdparty/occ/OpenCASCADE6.5.3/gccGnep/lib/libTKService.so -lXmu -lGLU -lGL /homes/fathom/3rdparty/occ/OpenCASCADE6.5.3/gccGnep/lib/libTKHLR.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.3/gccGnep/lib/libTKOffset.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.3/gccGnep/lib/libTKFillet.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.3/gccGnep/lib/libTKFeat.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.3/gccGnep/lib/libTKBool.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.3/gccGnep/lib/libTKShHealing.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.3/gccGnep/lib/libTKBO.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.3/gccGnep/lib/libTKPrim.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.3/gccGnep/lib/libTKMesh.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.3/gccGnep/lib/libTKTopAlgo.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.3/gccGnep/lib/libTKGeomAlgo.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.3/gccGnep/lib/libTKBRep.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.3/gccGnep/lib/libTKGeo
/homes/fathom/3rdparty/mpich2/mpich2-1.2.1/gcc/bin/mpicxx -DHAVE_CONFIG_H -I. -I../.. -I../../src/moab -I../../src/parallel -I../../src  -I/homes/iulian/lib/pnetcdf/include -I/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/parallel/gcc/include    -I/homes/fathom/3rdparty/hdf5/hdf5-1.8.3/parallel/gcc/include -isystem /homes/fathom/3rdparty/hdf5/hdf5-1.8.3/parallel/gcc/include  -DTEMPLATE_SPECIALIZATION -DTEMPLATE_FUNC_SPECIALIZATION -DHAVE_VSNPRINTF -D_FILE_OFFSET_BITS=64   -DUSE_MPI -DHDF5_FILE -DHDF5_PARALLEL -DNETCDF_FILE -DPNETCDF_FILE -DHAVE_ZOLTAN -DCGM -DSRCDIR=. -DMESHDIR=../../MeshFiles/unittest -I. -I.. -I./.. -I../../src -I../../src -I../../src/io -I../../src/parallel -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map -DHAVE_UNORDERED_SET=tr1/unordered_set  -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align  -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -MT smf_test.o -MD -MP -MF .deps/smf_test.Tpo -c -o smf_te
 st.o smf_test.cc
mv -f .deps/smf_test.Tpo .deps/smf_test.Po
 /parallel/gcc/lib -o smf_test smf_test.o ../../src/libMOAB.la -lm
libtool: link: /homes/fathom/3rdparty/mpich2/mpich2-1.2.1/gcc/bin/mpicxx -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -o smf_test smf_test.o  -L/home/fathom/3rdparty/ParMETIS3_1/gcc -L/home/fathom/3rdparty/Zoltan_v3.3/lib -L/homes/iulian/lib/pnetcdf/lib -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/parallel/gcc/lib -L/homes/fathom/3rdparty/zlib/zlib-1.2.4/gcc/lib -L/homes/fathom/3rdparty/hdf5/hdf5-1.8.3/parallel/gcc/lib -L/homes/fathom/install/occparsta2/cgm/lib -L/homes/fathom/3rdparty/occ/OpenCASCADE6.5.3/gccGnep/lib ../../src/.libs/libMOAB.a /home/fathom/3rdparty/netcdf/netcdf-4.0.1/parallel/gcc/lib/libnetcdf.so -L/home/fathom/3rdparty/hdf5/hdf5-1.8.3/parallel/gcc/lib -L/home/fathom/3rdparty/zlib/zlib-1.2.4/gcc/lib -L/home/fathom/3rdparty/szip/szip-2.1/gcc/lib /home/fathom/3rdparty/hdf5/hdf5-1.8.3/parallel/gcc/lib/libhdf5_hl.so -lpnetcdf /home/fathom/3rdparty/hdf5/hdf5-1.8.3/par
/homes/fathom/3rdparty/mpich2/mpich2-1.2.1/gcc/bin/mpicxx -DHAVE_CONFIG_H -I. -I../.. -I../../src/moab -I../../src/parallel -I../../src  -I/homes/iulian/lib/pnetcdf/include -I/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/parallel/gcc/include    -I/homes/fathom/3rdparty/hdf5/hdf5-1.8.3/parallel/gcc/include -isystem /homes/fathom/3rdparty/hdf5/hdf5-1.8.3/parallel/gcc/include  -DTEMPLATE_SPECIALIZATION -DTEMPLATE_FUNC_SPECIALIZATION -DHAVE_VSNPRINTF -D_FILE_OFFSET_BITS=64   -DUSE_MPI -DHDF5_FILE -DHDF5_PARALLEL -DNETCDF_FILE -DPNETCDF_FILE -DHAVE_ZOLTAN -DCGM -DSRCDIR=. -DMESHDIR=../../MeshFiles/unittest -I. -I.. -I./.. -I../../src -I../../src -I../../src/io -I../../src/parallel -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map -DHAVE_UNORDERED_SET=tr1/unordered_set -DTEMPLATE_DEFS_INCLUDED  -DHAVE_OCC -DHAVE_OCC_IGES -DHAVE_OCC_STEP -DHAVE_OCC_STL -I/homes/fathom/3rdparty/occ/OpenCASCADE6.5.3/gccGnep/inc -D_OCC64 -DHAVE_IOSTREAM -DHAVE_IOMANIP -DHAVE_FSTREAM -DHAV
 E_LIMITS_H -I/homes/fathom/install/occparsta2/cgm/include  -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align  -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align  -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -MT read_cgm_load_test-read_cgm_load_test.o -MD -MP -MF .deps/read_cgm_load_test-read_cgm_load_test.Tpo -c -o read_cgm_load_test-read_cgm_load_test.o `test -f 'read_cgm_load_test.cpp' || echo './'`read_cgm_load_test.cpp
mv -f .deps/read_cgm_load_test-read_cgm_load_test.Tpo .deps/read_cgm_load_test-read_cgm_load_test.Po
/bin/sh ../../libtool  --tag=CXX   --mode=link /homes/fathom/3rdparty/mpich2/mpich2-1.2.1/gcc/bin/mpicxx -DTEMPLATE_DEFS_INCLUDED  -DHAVE_OCC -DHAVE_OCC_IGES -DHAVE_OCC_STEP -DHAVE_OCC_STL -I/homes/fathom/3rdparty/occ/OpenCASCADE6.5.3/gccGnep/inc -D_OCC64 -DHAVE_IOSTREAM -DHAVE_IOMANIP -DHAVE_FSTREAM -DHAVE_LIMITS_H -I/homes/fathom/install/occparsta2/cgm/include  -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align  -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align  -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -R/homes/fathom/install/occparsta2/cgm/lib  -L/home/fathom/3rdparty/ParMETIS3_1/gcc -L/home/fathom/3rdparty/Zoltan_v3.3/lib  -L/homes/iulian/lib/pnetcdf/lib -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/parallel/gcc/lib     -L/homes/fathom/3rdparty/zlib/zlib-1.2.4/gcc/lib  -L/homes/fathom/3rdparty/hdf5/hdf5-1.8.3/parallel/gcc/lib -L/home
 s/fathom/install/occparsta2/cgm/lib  -L/homes/fathom/3rdparty/occ/OpenCASCADE6.5.3/gccGnep/lib -L/homes/fathom/3rdparty/zlib/zlib-1.2.4/gcc/lib  -L/homes/fathom/3rdparty/hdf5/hdf5-1.8.3/parallel/gcc/lib  -L/homes/fathom/3rdparty/zlib/zlib-1.2.4/gcc/lib  -L/homes/fathom/3rdparty/hdf5/hdf5-1.8.3/parallel/gcc/lib  -L/homes/fathom/3rdparty/zlib/zlib-1.2.4/gcc/lib  -L/homes/fathom/3rdparty/hdf5/hdf5-1.8.3/parallel/gcc/lib -o read_cgm_load_test read_cgm_load_test-read_cgm_load_test.o ../../src/libMOAB.la -lm
libtool: link: /homes/fathom/3rdparty/mpich2/mpich2-1.2.1/gcc/bin/mpicxx -DTEMPLATE_DEFS_INCLUDED -DHAVE_OCC -DHAVE_OCC_IGES -DHAVE_OCC_STEP -DHAVE_OCC_STL -I/homes/fathom/3rdparty/occ/OpenCASCADE6.5.3/gccGnep/inc -D_OCC64 -DHAVE_IOSTREAM -DHAVE_IOMANIP -DHAVE_FSTREAM -DHAVE_LIMITS_H -I/homes/fathom/install/occparsta2/cgm/include -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -o read_cgm_load_test read_cgm_load_test-read_cgm_load_test.o  -L/home/fathom/3rdparty/ParMETIS3_1/gcc -L/home/fathom/3rdparty/Zoltan_v3.3/lib -L/homes/iulian/lib/pnetcdf/lib -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/parallel/gcc/lib -L/homes/fathom/3rdparty/zlib/zlib-1.2.4/gcc/lib -L/homes/fathom/3rdparty/hdf5/hdf5-1.8.3/parallel/gcc/lib -L/homes/fathom/install/occpar
 sta2/cgm/lib -L/homes/fathom/3rdparty/occ/OpenCASCADE6.5.3/gccGnep/lib ../../src/.libs/libMOAB.a /home/fathom/3rdparty/netcdf/netcdf-4.0.1/parallel/gcc/lib/libnetcdf.so -L/home/fathom/3rdparty/hdf5/hdf5-1.8.3/parallel/gcc/lib -L/home/fathom/3rdparty/zlib/zlib-1.2.4/gcc/lib -L/home/fathom/3rdparty/szip/szip-2.1/gcc/lib /home/fathom/3rdparty/hdf5/hdf5-1.8.3/parallel/gcc/lib/libhdf5_hl.so -lpnetcdf /home/fathom/3rdparty/hdf5/hdf5-1.8.3/parallel/gcc/lib/libhdf5.so -lz /homes/fathom/install/occparsta2/cgm/lib/libcgm.a /homes/fathom/3rdparty/occ/OpenCASCADE6.5.3/gccGnep/lib/libTKSTL.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.3/gccGnep/lib/libTKSTEP.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.3/gccGnep/lib/libTKSTEP209.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.3/gccGnep/lib/libTKSTEPAttr.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.3/gccGnep/lib/libTKSTEPBase.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.3/gccGnep/lib/libTKIGES.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.3/gc
 cGnep/lib/libTKXSBase.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.3/gccGnep/lib/libTKBinL.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.3/gccGnep/lib/libTKCAF.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.3/gccGnep/lib/libTKLCAF.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.3/gccGnep/lib/libTKCDF.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.3/gccGnep/lib/libTKV3d.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.3/gccGnep/lib/libTKV2d.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.3/gccGnep/lib/libTKService.so -lXmu -lGLU -lGL /homes/fathom/3rdparty/occ/OpenCASCADE6.5.3/gccGnep/lib/libTKHLR.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.3/gccGnep/lib/libTKOffset.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.3/gccGnep/lib/libTKFillet.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.3/gccGnep/lib/libTKFeat.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.3/gccGnep/lib/libTKBool.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.3/gccGnep/lib/libTKShHealing.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.3
 /gccGnep/lib/libTKBO.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.3/gccGnep/lib/libTKPrim.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.3/gccGnep/lib/libTKMesh.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.3/gccGnep/lib/libTKTopAlgo.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.3/gccGnep/lib/libTKGeomAlgo.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.3/gccGnep/lib/libTKBRep.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.3/gccGnep/lib/libTKGeomBase.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.3/gccGnep/lib/libTKG3d.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.3/gccGnep/lib/libTKG2d.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.3/gccGnep/lib/libTKMath.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.3/gccGnep/lib/libTKernel.so -lXt -lX11 -ldl -lzoltan -lparmetis -lmetis -lm -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/parallel/gcc/lib -Wl,-rpath -Wl,/home/fathom/3rdparty/hdf5/hdf5-1.8.3/parallel/gcc/lib -Wl,-rpath -Wl,/homes/fathom/3rdparty/occ/OpenCASCADE6.5.3/gccGnep/lib -W
 E_LIMITS_H -I/homes/fathom/install/occparsta2/cgm/include  -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align  -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align  -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -MT read_cgm_basic_test-read_cgm_basic_test.o -MD -MP -MF .deps/read_cgm_basic_test-read_cgm_basic_test.Tpo -c -o read_cgm_basic_test-read_cgm_basic_test.o `test -f 'read_cgm_basic_test.cpp' || echo './'`read_cgm_basic_test.cpp
mv -f .deps/read_cgm_basic_test-read_cgm_basic_test.Tpo .deps/read_cgm_basic_test-read_cgm_basic_test.Po
 s/fathom/install/occparsta2/cgm/lib  -L/homes/fathom/3rdparty/occ/OpenCASCADE6.5.3/gccGnep/lib -L/homes/fathom/3rdparty/zlib/zlib-1.2.4/gcc/lib  -L/homes/fathom/3rdparty/hdf5/hdf5-1.8.3/parallel/gcc/lib  -L/homes/fathom/3rdparty/zlib/zlib-1.2.4/gcc/lib  -L/homes/fathom/3rdparty/hdf5/hdf5-1.8.3/parallel/gcc/lib  -L/homes/fathom/3rdparty/zlib/zlib-1.2.4/gcc/lib  -L/homes/fathom/3rdparty/hdf5/hdf5-1.8.3/parallel/gcc/lib -o read_cgm_basic_test read_cgm_basic_test-read_cgm_basic_test.o ../../src/libMOAB.la -lm
libtool: link: /homes/fathom/3rdparty/mpich2/mpich2-1.2.1/gcc/bin/mpicxx -DTEMPLATE_DEFS_INCLUDED -DHAVE_OCC -DHAVE_OCC_IGES -DHAVE_OCC_STEP -DHAVE_OCC_STL -I/homes/fathom/3rdparty/occ/OpenCASCADE6.5.3/gccGnep/inc -D_OCC64 -DHAVE_IOSTREAM -DHAVE_IOMANIP -DHAVE_FSTREAM -DHAVE_LIMITS_H -I/homes/fathom/install/occparsta2/cgm/include -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -o read_cgm_basic_test read_cgm_basic_test-read_cgm_basic_test.o  -L/home/fathom/3rdparty/ParMETIS3_1/gcc -L/home/fathom/3rdparty/Zoltan_v3.3/lib -L/homes/iulian/lib/pnetcdf/lib -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/parallel/gcc/lib -L/homes/fathom/3rdparty/zlib/zlib-1.2.4/gcc/lib -L/homes/fathom/3rdparty/hdf5/hdf5-1.8.3/parallel/gcc/lib -L/homes/fathom/install/occ
 parsta2/cgm/lib -L/homes/fathom/3rdparty/occ/OpenCASCADE6.5.3/gccGnep/lib ../../src/.libs/libMOAB.a /home/fathom/3rdparty/netcdf/netcdf-4.0.1/parallel/gcc/lib/libnetcdf.so -L/home/fathom/3rdparty/hdf5/hdf5-1.8.3/parallel/gcc/lib -L/home/fathom/3rdparty/zlib/zlib-1.2.4/gcc/lib -L/home/fathom/3rdparty/szip/szip-2.1/gcc/lib /home/fathom/3rdparty/hdf5/hdf5-1.8.3/parallel/gcc/lib/libhdf5_hl.so -lpnetcdf /home/fathom/3rdparty/hdf5/hdf5-1.8.3/parallel/gcc/lib/libhdf5.so -lz /homes/fathom/install/occparsta2/cgm/lib/libcgm.a /homes/fathom/3rdparty/occ/OpenCASCADE6.5.3/gccGnep/lib/libTKSTL.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.3/gccGnep/lib/libTKSTEP.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.3/gccGnep/lib/libTKSTEP209.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.3/gccGnep/lib/libTKSTEPAttr.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.3/gccGnep/lib/libTKSTEPBase.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.3/gccGnep/lib/libTKIGES.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.3
 /gccGnep/lib/libTKXSBase.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.3/gccGnep/lib/libTKBinL.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.3/gccGnep/lib/libTKCAF.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.3/gccGnep/lib/libTKLCAF.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.3/gccGnep/lib/libTKCDF.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.3/gccGnep/lib/libTKV3d.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.3/gccGnep/lib/libTKV2d.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.3/gccGnep/lib/libTKService.so -lXmu -lGLU -lGL /homes/fathom/3rdparty/occ/OpenCASCADE6.5.3/gccGnep/lib/libTKHLR.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.3/gccGnep/lib/libTKOffset.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.3/gccGnep/lib/libTKFillet.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.3/gccGnep/lib/libTKFeat.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.3/gccGnep/lib/libTKBool.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.3/gccGnep/lib/libTKShHealing.so /homes/fathom/3rdparty/occ/OpenCASCADE6.
 5.3/gccGnep/lib/libTKBO.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.3/gccGnep/lib/libTKPrim.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.3/gccGnep/lib/libTKMesh.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.3/gccGnep/lib/libTKTopAlgo.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.3/gccGnep/lib/libTKGeomAlgo.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.3/gccGnep/lib/libTKBRep.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.3/gccGnep/lib/libTKGeomBase.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.3/gccGnep/lib/libTKG3d.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.3/gccGnep/lib/libTKG2d.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.3/gccGnep/lib/libTKMath.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.3/gccGnep/lib/libTKernel.so -lXt -lX11 -ldl -lzoltan -lparmetis -lmetis -lm -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/parallel/gcc/lib -Wl,-rpath -Wl,/home/fathom/3rdparty/hdf5/hdf5-1.8.3/parallel/gcc/lib -Wl,-rpath -Wl,/homes/fathom/3rdparty/occ/OpenCASCADE6.5.3/gccGnep/lib
 ...make  check-TESTS
make[4]: Entering directory `/disks/itaps-buildslave/moab-occ-par-sta2/build/test/io'
make[5]: Entering directory `/disks/itaps-buildslave/moab-occ-par-sta2/build/test/io'
 [0;32mPASS [m: readutil_test
 [0;32mPASS [m: tqdcfr
 [0;32mPASS [m: vtk_test
 [0;32mPASS [m: cub_file_test
 [0;32mPASS [m: exodus_test
 [0;32mPASS [m: gmsh_test
 [0;32mPASS [m: nastran_test
 [0;32mPASS [m: read_nc
 [0;32mPASS [m: read_ucd_nc
 [0;32mPASS [m: read_mpas_nc
 [0;32mPASS [m: ideas_test
 [0;32mPASS [m: stl_test
 [0;32mPASS [m: smf_test
 [0;32mPASS [m: read_cgm_load_test
 [0;31mFAIL [m: read_cgm_basic_test
 [0;31m==========================
1 of 15 tests failed
See test/io/test-suite.log
 [mmake[5]: *** [test-suite.log] Error 1
URL: <http://lists.mcs.anl.gov/pipermail/moab-dev/attachments/20140211/d1ae1090/attachment-0001.html>
