[MOAB-dev] commit/MOAB: danwu: A compile error is fixed for examples/point_in_elem_search.cpp. This regression is caused by change to src/moab/SpatialLocator.hpp (commit 4d437a5 on 2013-11-27)
commits-noreply at bitbucket.org
Thu Feb 6 11:07:30 CST 2014
1 new commit in MOAB:
https://bitbucket.org/fathomteam/moab/commits/e7583dca6d11/
Changeset: e7583dca6d11
Branch: master
User: danwu
Date: 2014-02-06 18:02:36
Summary: A compile error is fixed for examples/point_in_elem_search.cpp. This regression is caused by change to src/moab/SpatialLocator.hpp (commit 4d437a5 on 2013-11-27)
1) Signature of locate_point() has been updated. The corresponding function call should also be updated in point_in_elem_search.cpp.
2) locate_point() is now private. It should be set back to public so that it can be called by point_in_elem_search.cpp.
A small bug in point_in_elem_search.cpp is also fixed:
The file to be loaded should be argv[1], instead of argv[argc-1].
Affected #: 2 files
diff --git a/examples/point_in_elem_search.cpp b/examples/point_in_elem_search.cpp
index a917fa0..ce22928 100644
--- a/examples/point_in_elem_search.cpp
+++ b/examples/point_in_elem_search.cpp
@@ -27,7 +27,7 @@ int main(int argc, char **argv) {
int num_queries = 1000000;
- if (argc == 1) {
+ if (argc < 2 || argc > 3) {
std::cout << "Usage: " << argv[0] << "<filename> [num_queries]" << std::endl;
return 0;
@@ -37,7 +37,7 @@ int main(int argc, char **argv) {
moab::Core mb;
// load the file
- ErrorCode rval = mb.load_file(argv[argc-1]); ERR("Error loading file");
+ ErrorCode rval = mb.load_file(argv[1]); ERR("Error loading file");
// get all 3d elements in the file
Range elems;
@@ -66,7 +66,7 @@ int main(int argc, char **argv) {
for (int i = 0; i < num_queries; i++) {
pos = box.bMin +
CartVect(box_extents[0]*.01*(rand()%100), box_extents[1]*.01*(rand()%100), box_extents[2]*.01*(rand()%100));
- ErrorCode tmp_rval = sl.locate_point(pos.array(), elem, params.array(), 0.0, 0.0, &is_inside);
+ ErrorCode tmp_rval = sl.locate_point(pos.array(), elem, params.array(), &is_inside, 0.0, 0.0);
if (MB_SUCCESS != tmp_rval) rval = tmp_rval;
if (is_inside) num_inside++;
diff --git a/src/moab/SpatialLocator.hpp b/src/moab/SpatialLocator.hpp
index bb639d0..e8ab5cf 100644
--- a/src/moab/SpatialLocator.hpp
+++ b/src/moab/SpatialLocator.hpp
@@ -121,6 +121,12 @@ namespace moab {
const double inside_tol = 1.0e-6);
#endif
+ /* locate a point */
+ ErrorCode locate_point(const double *pos,
+ EntityHandle &ent, double *params, bool *is_inside = NULL,
+ const double rel_iter_tol = 1.0e-10, const double abs_iter_tol = 1.0e-10,
+ const double inside_tol = 1.0e-6);
/* return the tree */
Tree *get_tree() {return myTree;}
@@ -151,12 +157,6 @@ namespace moab {
private:
- /* locate a point */
- ErrorCode locate_point(const double *pos,
- EntityHandle &ent, double *params, bool *is_inside = NULL,
- const double rel_iter_tol = 1.0e-10, const double abs_iter_tol = 1.0e-10,
- const double inside_tol = 1.0e-6);
/* MOAB instance */
Interface* mbImpl;
Repository URL: https://bitbucket.org/fathomteam/moab/
This is a commit notification from bitbucket.org. You are receiving
this because you have the service enabled, addressing the recipient of
this email.
