[MOAB-dev] WriteHDF5::convert_handle_tag
Tim Tautges (ANL)
tautges at mcs.anl.gov
Wed Feb 5 12:45:00 CST 2014
Hi Anton,
Entities in the HDF5 file have what's called file ids, and these ids are separate from global ids. I don't think you
should want to use file ids. If you'd like faces to have global ids, I suggest using either WriteUtilIface::assign_ids
or ParallelComm::assign_global_ids, depending on whether you're running serial or parallel, resp.
- tim
On 02/05/2014 12:27 PM, kanaev at ibrae.ac.ru wrote:
> Hello, MOAB-dev!
> How can i get access to WriteHDF5 class and its function convert_handle_tag?
> Faces created after get_adjacency call have zero GLOBAL_ID tag in written .h5m file
> WriteHDF5.hpp is not in include dir within MOAB build
> Thanks
> Anton
steadfast, because he trusts in you." Isaiah 26:3
Tim Tautges Argonne National Laboratory
(tautges at mcs.anl.gov) (telecommuting from UW-Madison)
phone (gvoice): (608) 354-1459 1500 Engineering Dr.
fax: (608) 263-4499 Madison, WI 53706
