[MOAB-dev] Using MOAB linked to Nek5000
Tim Tautges (ANL)
tautges at mcs.anl.gov
Mon Feb 3 14:02:08 CST 2014
If you use --with-zoltan=, you'll also likely need --with-metis=. Still, there's also a problem with HDF5, so we need
to see config.log. My guess is that your HDF5 isn't compiled with parallel support, you might want to check that first.
tautges at chronos:~/$ grep "Parallel HDF5" /usr/local/hdf5-1.8.9-par-gcc-openmpi/lib/libhdf5.settings
Parallel HDF5: yes
- tim
On 02/03/2014 12:32 PM, Mohsen Behzad wrote:
> Dear MOAB team,
> I am writing to let you know that I intend to use MOAB with "Nek5000" for my simulations which will be performed on the
> SciNet cluster (http://wiki.scinethpc.ca/wiki/) in collaboration with the University of Toronto, in which I am a
> post-doc fellow.
> Right now, I tried to build MOAB with previously built packages on this system including "hdf5" (v. 1.8.7 compiled with
> openmpi) and "netcdf" (parallel version: 1.2.0 compiled with openmpi). As it is stated both of these packages were
> compiled with "openmpi" (v. 1.4.4 compiled with intel v. 12.1) and therefore there should be no issue of compilers
> compatibility. However, when I attempted to build MOAB on this system with the following configuration options and flags:
> ./configure FC=mpif90 F77=mpif77 CC=mpicc CXX=mpicxx \
> --prefix=`pwd` \
> --with-mpi=${SCINET_MPI_BASE} \
> --with-netcdf=${SCINET_PNETCDF_BASE} \
> --with-hdf5=${SCINET_HDF5_BASE} \
> --with-zlib="/scinet/gpc/Libraries/HDF5-1.8.7/zlib-intel/" \
> --with-szip=${SCINET_SZIP_BASE} \
> --enable-mbzoltan \
> --with-zoltan="/home/a/ashgriz/mbehzad/nek5_svn/Zoltan_v3.8/BUILD_DIR/"
> I have encountered an error in the configuration as:
> "configure: error: HDF5 library not found or not usable."
> It should be noted that "zlib" and "szip" libraries were compiled with intel too.
> I am wondering if you can help me on this issue.
> Regards,
> /Mohsen Behzad, //Ph.D./
> /Department of Civil Eng./
> /University of Toronto/
> /Room 117, 170 College st. M5S 3E3/
> /Toronto, Ontario, Canada/
> /m.behzad.jazi at mail.utoronto.ca/// <mailto:m.behzad.jazi at utoronto.ca>
> /http://mussl.mie.utoronto.ca/ <http://mussl.mie.utoronto.ca/>///
steadfast, because he trusts in you." Isaiah 26:3
Tim Tautges Argonne National Laboratory
(tautges at mcs.anl.gov) (telecommuting from UW-Madison)
phone (gvoice): (608) 354-1459 1500 Engineering Dr.
fax: (608) 263-4499 Madison, WI 53706
