[MOAB-dev] commit/MOAB: danwu: Update TestErrorHandling example, as the error handler now uses ErrorOutput class to print error messages and stack traces.
commits-noreply at bitbucket.org commits-noreply at bitbucket.org
Wed Jan 29 17:08:45 CST 2014
1 new commit in MOAB:
https://bitbucket.org/fathomteam/moab/commits/264ee8346d42/
Changeset:   264ee8346d42
Branch:      error_handling_enhancement
User:        danwu
Date:        2014-01-30 00:08:30
Summary:     Update TestErrorHandling example, as the error handler now uses ErrorOutput class to print error messages and stack traces.
Affected #:  1 file
diff --git a/examples/TestErrorHandling.cpp b/examples/TestErrorHandling.cpp
index 3108b99..ba97767 100644
--- a/examples/TestErrorHandling.cpp
+++ b/examples/TestErrorHandling.cpp
@@ -20,12 +20,12 @@ ErrorInfo FunctionC(int n)
   else if (2 == n) {
     // Simulate MB_FILE_WRITE_ERROR
-    SET_ERR1(MB_FILE_WRITE_ERROR, "FunctionC created a contrived error MB_ENTITY_MB_FILE_WRITE_ERROR.");
+    SET_ERR1(MB_FILE_WRITE_ERROR, "FunctionC created a contrived error MB_ENTITY_MB_FILE_WRITE_ERROR");
   else if (3 == n) {
     // Simulate MB_NOT_IMPLEMENTED
     ErrorInfo err_info(MB_NOT_IMPLEMENTED);
-    err_info << "n = " << n << ", FunctionC created a contrived MB_NOT_IMPLEMENTED (this message is built with C++ streaming).";
+    err_info << "n = " << n << ", FunctionC created a contrived MB_NOT_IMPLEMENTED (this message is built with C++ streaming)";
     SET_ERR(err_info);
@@ -73,6 +73,8 @@ ErrorInfo Test_3()
 int main()
+  MBErrorHandler_Init();
   cout << "--------------------Running test case 1 start--------------------" << endl;
   Test_1();
   cout << "--------------------Running test case 1 end----------------------\n" << endl;
@@ -85,5 +87,7 @@ int main()
   Test_3();
   cout << "--------------------Running test case 3 end----------------------\n" << endl;
+  MBErrorHandler_Finalize();
   return 0;
Repository URL: https://bitbucket.org/fathomteam/moab/
This is a commit notification from bitbucket.org. You are receiving
this because you have the service enabled, addressing the recipient of
this email.
