[MOAB-dev] get_adjacencies of same dim
    Grindeanu, Iulian R.
    iulian at mcs.anl.gov
    Mon Jan 27 16:24:25 CST 2014
hello,
are you using the last parameter / flag to the get_adjacency? By default it is intersect.
maybe you want "union" of the input ?
 virtual ErrorCode get_adjacencies(const Range &from_entities,
                                         const int to_dimension,
                                         const bool create_if_missing,
                                         Range &adj_entities,
                                         const int operation_type = Interface::INTERSECT);
What are you getting and you do not expect it?
Iulian
From: moab-dev-bounces at mcs.anl.gov [moab-dev-bounces at mcs.anl.gov] on behalf of Patrick Shriwise [shriwise at wisc.edu]
Sent: Monday, January 27, 2014 4:08 PM
To: moab-dev at mcs.anl.gov
Subject: [MOAB-dev] get_adjacencies of same dim
Hey all,
Quick question. Working on a couple tests for ReadCGM and calling for
the adjacencies of an entity which are the same dimension of the entity
itself but I'm not getting the result I'm expecting. Any this special to
know in this case?
Cheers,
Patrick C. Shriwise
Research Assistant
University of Wisconsin - Madison
Engineering Research Building - Rm. 428
1500 Engineering Drive
Madison, WI 53706
(608) 446-8173
