[MOAB-dev] Discussion on return type of MOAB routines
    Tim Tautges (ANL)
    tautges at mcs.anl.gov
    Fri Jan 24 10:15:49 CST 2014
No, because sometimes those MB ones you list below are errors and sometimes not, depending on the application.
- tim
On 01/24/2014 10:13 AM, Wu, Danqing wrote:
> When designing possible error codes, it seems that PETSc only defines "TRUE" errors (all with PETSC_ERR prefix)
> #define PETSC_ERR_MIN_VALUE        54   /* should always be one less then the smallest value */
> #define PETSC_ERR_MEM              55   /* unable to allocate requested memory */
> #define PETSC_ERR_NOT_CONVERGED    91  /* solver did not converge */
> #define PETSC_ERR_MAX_VALUE        92  /* this is always the one more than the largest error code */
> While for MOAB, we do have quite a few error codes that are not always "TRUE" errors, like:
> MB_ENTITY_NOT_FOUND
> MB_MULTIPLE_ENTITIES_FOUND
> MB_TAG_NOT_FOUND
> MB_ALREADY_ALLOCATED
> MB_VARIABLE_DATA_LENGTH
> MB_STRUCTURED_MESH
> Would it be better to separate these non-error conditions from current enum ErrorCode?
> Best
> Danqing
> From: Tautges, Timothy J.
> Sent: Friday, January 24, 2014 9:07 AM
> To: Paul Wilson; Wu, Danqing; Vijay S. Mahadevan
> Cc: Jed Brown; moab-dev at mcs.anl.gov
> Subject: Re: [MOAB-dev] Discussion on return type of MOAB routines
> On 01/23/2014 10:14 PM, Paul Wilson wrote:
>> Hi Tim,
>> On 01/23/2014 11:05 AM, Tim Tautges (ANL) wrote:
>>> The trouble is then where do you leave the extra information to be picked up if the caller needs it.  We want to avoid
>>> things like a last_error string on the instance, since that's not thread safe.
>> I'm imagining that you effectively repeat the same query that produced the information in the first place, but through a
>> different interface that was setup to collect the interesting information.
>> This may be too expensive in general, but I thought I'd throw the idea out there.
>> Do you have a good sense of how common this would be?  You offered one use case, but are there many places in MOAB that
>> offer more information to the calling function?
> Not that many, but it's one of those things where the application determines what's "normal".
> And for applications, if we pass back only an ErrorCode, plus maybe a stack trace gets printed under certain conditions,
> what about those cases where the application needs more information, e.g. which handle turned out to be invalid or
> didn't have a given tag?  Then we're stuck back with a member of the Core class, which we don't want because it's not
> thread safe.  Is it enough to just make that thread local?
> - tim
>> Paul
>>> - tim
>>> On 01/23/2014 07:54 AM, Paul Wilson wrote:
>>>> Hi all,
>>>> Just catching up on this thread...
>>>> On 01/22/2014 03:24 PM, Wu, Danqing wrote:
>>>>> Below is the summary of the discussions on return type so far. I notice that how we handle special "non-success"
>>>>> condition (like TAG_NOT_FOUND) will affect our decision. Any decision has its pros and cons. Maybe we need more
>>>>> opinions from other people.
>>>>> As for existing ErrorCode return type, Vijay and I prefer to use it. Iulian also voted to keep it simple (enum/int)
>>>>> 1) This does not break any existing user code nor does it need to change existing method signatures
>>>>> 2) According to Jed, PETSc returns error code because it is simple and portable between languages
>>>>> 3) Benchmarking tests show that it has least overhead for function return
>>>>> 4) No need to store any context explicitly, including error messages that are already printed out in the stack trace
>>>>> Tim has some other reasons to return a class object instead of a plain enum type
>>>>> 5) The overhead might be acceptable for MOAB
>>>>> 6) For non-success conditions, we might need extra information hat can only come from the lower-level functions.
>>>> Since the calling function knows what it asked, couldn't this be addressed by a combination of:
>>>> * return one of a rich set of int/enum return codes
>>>> * API for querying the necessary information that is missing in a simple error code
>>>> Cons:
>>>> * for cases in which there is necessary information, this would be slower than the other options proposed because of
>>>> another function call
>>>> Pros:
>>>> * the calling function gets to decide whether it cares about (and hence bothers to query) the additional information
>>>> * there can be a richer interface for that additional information other than parsing a string
>>>> * a sufficiently rich enough set of error codes, may reduce the number of times that a calling function cares about that
>>>> info.
>>>> Using Tim's tag_get_handle example (mismatched properties to tag_get_handle), if the return code was
>>>> MOAB_TAG_EXISTS_WITH_DIFFERENT_PROPERTIES (not a great choice, but illustrative), then there may be many cases where the
>>>> calling function just wants to handle this and move on, rather than query something like tag_get_props().
>>>> Or am I missing something?
>>>> Paul
>>>>> Regarding 6), Vijay and I have similar opinion:
>>>>> Is that extra information in the returned class object really necessary? An upper level caller, based on some context,
>>>>> usually knows how to handle a non-error condition. It can choose to treat is as an expected error, and set it. It can
>>>>> choose to handle it and then return success. It can also keep it unhanded, and return this condition code unchanged to
>>>>> its callers. Of course, the lowest routines, like tag_get_handle(), will never set it as an error (because it does not
>>>>> know, totally decided by higher level callers), and just returns this code as is. In this case, an ErrorCode still
>>>>> would suffice. Using an object to store any context explicitly is probably not necessary here.
>>>>> BTW, according to Jed, PETSc never uses error handlers/return codes for non-error conditions. It defines what should
>>>>> happen in that case and have a flag return if the caller needs to know.
>>>>> Regarding returning a class object, there are three different options:
>>>>> 1) Use ostringstream as a member. This has more overhead according to benchmarking tests. The size of the object is
>>>>> 360 bytes.
>>>>> 2) Use std::string as a member. This is slightly better than a). The size of the object is 16 bytes.
>>>>> 3) Make the class a POD type, like C style struct, without constructors. Then char* is used as a member. A global heap
>>>>> space should be allocated to store the string. The issue is how to make this thread safe.
>>>>> For now, it is more likely that we will use either 2) or 3)
>>>>> Best
>>>>> Danqing
>>>>> Sent: Wednesday, January 22, 2014 3:36 PM
>>>>> To: Vijay S. Mahadevan
>>>>> Cc: Jed Brown; Wu, Danqing; moab-dev at mcs.anl.gov
>>>>> On 01/22/2014 01:34 PM, Vijay S. Mahadevan wrote:
>>>>>>> It's entirely dependent on the application, same API call, same return,
>>>>>>> different handling, and in some cases the application is a tool inside the
>>>>>>> library.
>>>>>> If the calling function knows how to handle the error based on the
>>>>>> context i.e., fail with an error message or return with an error code
>>>>>> to be handled by upper level routines, an ErrorCode still would
>>>>>> suffice. Using an object to store any context explicitly is not be
>>>>>> necessary here IMO.
>>>>> But it's information from lower-level functions that will go missing.  Maybe that's not enough information to really
>>>>> worry about, esp. if we have a stack trace, but that's the reason I'm saying we need this string.
>>>>> - tim
>>>>>> If you just want the control to augment the printed error message (in
>>>>>> fatal failure cases), use macros like SETERR that take a stream. Since
>>>>>> the program is going to exit due to the failure, each calling routine
>>>>>> can print its message and return appropriately without worrying about
>>>>>> the actual cost of storage of strings etc. For successful exits,
>>>>>> string remains null. The const char* version in my timing results will
>>>>>> be appropriate here.
>>>>>> Vijay
>>>>>> On Wed, Jan 22, 2014 at 1:26 PM, Tim Tautges (ANL) <tautges at mcs.anl.gov> wrote:
>>>>>>> On 01/22/2014 01:21 PM, Jed Brown wrote:
>>>>>>>> "Tim Tautges (ANL)" <tautges at mcs.anl.gov> writes:
>>>>>>>>> This depends on how often it happens.  In all cases, IMO, a success
>>>>>>>>> condition should result in nothing more than a
>>>>>>>>> POD-sized object (and I should add, no virtual table).
>>>>>>>> vtables are just pointers like any other in terms of performance.
>>>>>>> Sure but we still don't want that extra expense.
>>>>>>>>> If it's a non-success condition that is "expected" (normal condition
>>>>>>>>> that's handled by the calling code), IMO this shouldn't print anything
>>>>>>>>> by default.  If it's a non-success that's also unexpected, printing is
>>>>>>>>> fine (including stack trace).
>>>>>>>> I don't believe in expected failures.  I find keeping expected and error
>>>>>>>> conditions in-band leads to confusing control flow, but YMMV.
>>>>>>> library.
>>>>>>> - tim
>>>>>>> "You will keep in perfect peace him whose mind is
>>>>>>>      steadfast, because he trusts in you." Isaiah 26:3
>>>>>>>                 Tim Tautges            Argonne National Laboratory
>>>>>>>             (tautges at mcs.anl.gov)      (telecommuting from UW-Madison)
>>>>>>>     phone (gvoice): (608) 354-1459      1500 Engineering Dr.
>>>>>>>                fax: (608) 263-4499      Madison, WI 53706
