[MOAB-dev] Discussion on return type of MOAB routines
Tim Tautges (ANL)
tautges at mcs.anl.gov
Thu Jan 23 11:05:23 CST 2014
The trouble is then where do you leave the extra information to be picked up if the caller needs it. We want to avoid
things like a last_error string on the instance, since that's not thread safe.
- tim
On 01/23/2014 07:54 AM, Paul Wilson wrote:
> Hi all,
> Just catching up on this thread...
> On 01/22/2014 03:24 PM, Wu, Danqing wrote:
>> Below is the summary of the discussions on return type so far. I notice that how we handle special "non-success"
>> condition (like TAG_NOT_FOUND) will affect our decision. Any decision has its pros and cons. Maybe we need more
>> opinions from other people.
>> As for existing ErrorCode return type, Vijay and I prefer to use it. Iulian also voted to keep it simple (enum/int)
>> 1) This does not break any existing user code nor does it need to change existing method signatures
>> 2) According to Jed, PETSc returns error code because it is simple and portable between languages
>> 3) Benchmarking tests show that it has least overhead for function return
>> 4) No need to store any context explicitly, including error messages that are already printed out in the stack trace
>> Tim has some other reasons to return a class object instead of a plain enum type
>> 5) The overhead might be acceptable for MOAB
>> 6) For non-success conditions, we might need extra information hat can only come from the lower-level functions.
> Since the calling function knows what it asked, couldn't this be addressed by a combination of:
> * return one of a rich set of int/enum return codes
> * API for querying the necessary information that is missing in a simple error code
> Cons:
> * for cases in which there is necessary information, this would be slower than the other options proposed because of
> another function call
> Pros:
> * the calling function gets to decide whether it cares about (and hence bothers to query) the additional information
> * there can be a richer interface for that additional information other than parsing a string
> * a sufficiently rich enough set of error codes, may reduce the number of times that a calling function cares about that
> info.
> Using Tim's tag_get_handle example (mismatched properties to tag_get_handle), if the return code was
> MOAB_TAG_EXISTS_WITH_DIFFERENT_PROPERTIES (not a great choice, but illustrative), then there may be many cases where the
> calling function just wants to handle this and move on, rather than query something like tag_get_props().
> Or am I missing something?
> Paul
>> Regarding 6), Vijay and I have similar opinion:
>> Is that extra information in the returned class object really necessary? An upper level caller, based on some context,
>> usually knows how to handle a non-error condition. It can choose to treat is as an expected error, and set it. It can
>> choose to handle it and then return success. It can also keep it unhanded, and return this condition code unchanged to
>> its callers. Of course, the lowest routines, like tag_get_handle(), will never set it as an error (because it does not
>> know, totally decided by higher level callers), and just returns this code as is. In this case, an ErrorCode still
>> would suffice. Using an object to store any context explicitly is probably not necessary here.
>> BTW, according to Jed, PETSc never uses error handlers/return codes for non-error conditions. It defines what should
>> happen in that case and have a flag return if the caller needs to know.
>> Regarding returning a class object, there are three different options:
>> 1) Use ostringstream as a member. This has more overhead according to benchmarking tests. The size of the object is
>> 360 bytes.
>> 2) Use std::string as a member. This is slightly better than a). The size of the object is 16 bytes.
>> 3) Make the class a POD type, like C style struct, without constructors. Then char* is used as a member. A global heap
>> space should be allocated to store the string. The issue is how to make this thread safe.
>> For now, it is more likely that we will use either 2) or 3)
>> Best
>> Danqing
>> ________________________________________
>> From: Tautges, Timothy J.
>> Sent: Wednesday, January 22, 2014 3:36 PM
>> To: Vijay S. Mahadevan
>> Cc: Jed Brown; Wu, Danqing; moab-dev at mcs.anl.gov
>> Subject: Re: [MOAB-dev] Discussion on return type of MOAB routines
>> On 01/22/2014 01:34 PM, Vijay S. Mahadevan wrote:
>>>> It's entirely dependent on the application, same API call, same return,
>>>> different handling, and in some cases the application is a tool inside the
>>>> library.
>>> If the calling function knows how to handle the error based on the
>>> context i.e., fail with an error message or return with an error code
>>> to be handled by upper level routines, an ErrorCode still would
>>> suffice. Using an object to store any context explicitly is not be
>>> necessary here IMO.
>> But it's information from lower-level functions that will go missing. Maybe that's not enough information to really
>> worry about, esp. if we have a stack trace, but that's the reason I'm saying we need this string.
>> - tim
>>> If you just want the control to augment the printed error message (in
>>> fatal failure cases), use macros like SETERR that take a stream. Since
>>> the program is going to exit due to the failure, each calling routine
>>> can print its message and return appropriately without worrying about
>>> the actual cost of storage of strings etc. For successful exits,
>>> string remains null. The const char* version in my timing results will
>>> be appropriate here.
>>> Vijay
>>> On Wed, Jan 22, 2014 at 1:26 PM, Tim Tautges (ANL) <tautges at mcs.anl.gov> wrote:
>>>> On 01/22/2014 01:21 PM, Jed Brown wrote:
>>>>> "Tim Tautges (ANL)" <tautges at mcs.anl.gov> writes:
>>>>>> This depends on how often it happens. In all cases, IMO, a success
>>>>>> condition should result in nothing more than a
>>>>>> POD-sized object (and I should add, no virtual table).
>>>>> vtables are just pointers like any other in terms of performance.
>>>> Sure but we still don't want that extra expense.
>>>>>> If it's a non-success condition that is "expected" (normal condition
>>>>>> that's handled by the calling code), IMO this shouldn't print anything
>>>>>> by default. If it's a non-success that's also unexpected, printing is
>>>>>> fine (including stack trace).
>>>>> I don't believe in expected failures. I find keeping expected and error
>>>>> conditions in-band leads to confusing control flow, but YMMV.
>>>> library.
>>>> - tim
>>>> "You will keep in perfect peace him whose mind is
>>>> steadfast, because he trusts in you." Isaiah 26:3
>>>> Tim Tautges Argonne National Laboratory
>>>> (tautges at mcs.anl.gov) (telecommuting from UW-Madison)
>>>> phone (gvoice): (608) 354-1459 1500 Engineering Dr.
>>>> fax: (608) 263-4499 Madison, WI 53706
