[MOAB-dev] Discussion on return type of MOAB routines
Tim Tautges (ANL)
tautges at mcs.anl.gov
Wed Jan 22 15:36:48 CST 2014
On 01/22/2014 01:34 PM, Vijay S. Mahadevan wrote:
>> It's entirely dependent on the application, same API call, same return,
>> different handling, and in some cases the application is a tool inside the
>> library.
> If the calling function knows how to handle the error based on the
> context i.e., fail with an error message or return with an error code
> to be handled by upper level routines, an ErrorCode still would
> suffice. Using an object to store any context explicitly is not be
> necessary here IMO.
But it's information from lower-level functions that will go missing. Maybe that's not enough information to really
worry about, esp. if we have a stack trace, but that's the reason I'm saying we need this string.
- tim
> If you just want the control to augment the printed error message (in
> fatal failure cases), use macros like SETERR that take a stream. Since
> the program is going to exit due to the failure, each calling routine
> can print its message and return appropriately without worrying about
> the actual cost of storage of strings etc. For successful exits,
> string remains null. The const char* version in my timing results will
> be appropriate here.
> Vijay
> On Wed, Jan 22, 2014 at 1:26 PM, Tim Tautges (ANL) <tautges at mcs.anl.gov> wrote:
>> On 01/22/2014 01:21 PM, Jed Brown wrote:
>>> "Tim Tautges (ANL)" <tautges at mcs.anl.gov> writes:
>>>> This depends on how often it happens. In all cases, IMO, a success
>>>> condition should result in nothing more than a
>>>> POD-sized object (and I should add, no virtual table).
>>> vtables are just pointers like any other in terms of performance.
>> Sure but we still don't want that extra expense.
>>>> If it's a non-success condition that is "expected" (normal condition
>>>> that's handled by the calling code), IMO this shouldn't print anything
>>>> by default. If it's a non-success that's also unexpected, printing is
>>>> fine (including stack trace).
>>> I don't believe in expected failures. I find keeping expected and error
>>> conditions in-band leads to confusing control flow, but YMMV.
>> library.
>> - tim
>> "You will keep in perfect peace him whose mind is
>> steadfast, because he trusts in you." Isaiah 26:3
>> Tim Tautges Argonne National Laboratory
>> (tautges at mcs.anl.gov) (telecommuting from UW-Madison)
>> phone (gvoice): (608) 354-1459 1500 Engineering Dr.
>> fax: (608) 263-4499 Madison, WI 53706
